cgma
CubitDynamicLoader Namespace Reference
Typedefs
typedef void * LibraryHandle
Functions
CUBIT_UTIL_EXPORT void add_search_path (const char *path)
CUBIT_UTIL_EXPORT CubitBoolean library_exists (const char *library)
CUBIT_UTIL_EXPORT LibraryHandle load_library (const char *library)
CUBIT_UTIL_EXPORT CubitString get_error ()
CUBIT_UTIL_EXPORT CubitStatus unload_library (LibraryHandle)
CUBIT_UTIL_EXPORT void * get_symbol_address (LibraryHandle, const char *)
CUBIT_UTIL_EXPORT const char * library_prefix ()
CUBIT_UTIL_EXPORT const char * library_extension ()
Variables
CUBIT_UTIL_EXPORT LibraryHandle InvalidLibraryHandle = NULL
Typedef Documentation
Definition at line 26 of file CubitDynamicLoader.hpp.
Function Documentation
void CubitDynamicLoader::add_search_path ( const char *  path)
Definition at line 15 of file CubitDynamicLoader.cpp.
  gSearchPaths.push_back(CubitString(path));
Definition at line 224 of file CubitDynamicLoader.cpp.
  return dlerror();
Definition at line 234 of file CubitDynamicLoader.cpp.
  return dlsym(lib, symbol);
Definition at line 31 of file CubitDynamicLoader.cpp.
  struct stat buf;
  // if absolute path, test it directly
  if(absolute_path(library))
    return stat(library, &buf) == 0 ? CUBIT_TRUE : CUBIT_FALSE;
  else
    // try finding with our search paths
    for(int i=0; i<(int)gSearchPaths.size(); i++)
      CubitString path = gSearchPaths[i] + CubitString("/") + library;
      if(stat(path.c_str(), &buf) == 0)
        return CUBIT_TRUE;
  // one more final attempt
  if (stat(library, &buf) == 0)
    return CUBIT_TRUE;
  return CUBIT_FALSE;
Definition at line 244 of file CubitDynamicLoader.cpp.
  return ".so";
Definition at line 239 of file CubitDynamicLoader.cpp.
  return "lib";
Definition at line 201 of file CubitDynamicLoader.cpp.
  if(absolute_path(lib))
    return dlopen(lib, RTLD_LAZY);
  else
      CubitString path = gSearchPaths[i]+CubitString("/")+lib;
      LibraryHandle handle = dlopen(path.c_str(), RTLD_LAZY);
      if(handle != InvalidLibraryHandle)
        return handle;
  return dlopen(lib, RTLD_LAZY );
Variable Documentation
