cgma
scale.cpp File Reference
scale, scaling and bounding box More...
#include "GeometryModifyTool.hpp"
#include "GeometryQueryTool.hpp"
#include "OCCQueryEngine.hpp"
#include "Body.hpp"
#include "InitCGMA.hpp"
#include "OCCModifyEngine.hpp"
#include "CubitCompat.hpp"
#include "TestUtilities.hpp"
Functions
int main (int argc, char **argv)
Variables
bool debug = false
Detailed Description
This program creates solid geometries - compute bounding box1 then scales again computes bounding box2. For a sphere, cylinder and circle-surface with OCE 0.17 and OCC 7.0, the bounding box is not acceptable.
Definition in file scale.cpp.
Function Documentation
int main ( int  argc,
char **  argv
Definition at line 22 of file scale.cpp.
  CubitStatus status = InitCGMA::initialize_cgma("OCC");
  if (CUBIT_SUCCESS != status) return 1;
  GeometryQueryTool *gti = GeometryQueryTool::instance();
  GeometryModifyTool *gmti = GeometryModifyTool::instance();
  int prob_type =1; // problem type 1 only works, the bounding box computation for sphere, circle surface and cylinder is off - more investigation is needed. The bug is in OCC or OCE not CGM. Tested direct OCE calls and the error persist.
  Body* body2 = NULL;
  CubitVector plane(1, 0, 0);
  if (prob_type == 1)
    body2 = gmti->brick(10, 10, 10);
  else if (prob_type == 2)
    body2 = gmti->sphere(5.0, 0 , 0, 0, 0, false);
  else if (prob_type == 3)
    body2 = gmti->cylinder(5.0, 5.0, 5.0, 5.0);
  else if (prob_type == 4)
    body2 = gmti->create_circle_surface(5.0, plane);
  // compute bounding box
  CubitBox curr_box_before = gti->bounding_box_of_bodies();
  CubitVector scale(2, 2, 2);
  CubitVector p1(0, 0, 0);
  gmti->scale(body2, p1, scale);
  CubitBox curr_box_after = gti->bounding_box_of_bodies();
  // check if bounding boxes are identical
  double tol = 1.0/100;
  int return_val = cubit_box_identical(curr_box_after, 2*curr_box_before, tol, true);
  // save file if debug true
  if (debug){
      DLIList<RefEntity*> ref_entity_list;
      ref_entity_list.push( (RefEntity*) body2);
      const CubitString cubit_version="12.2";
      int num_ents_exported=0;
      const char *filename = "scale.brep";
      const char *filetype = "OCC";
      CubitCompat_export_solid_model(ref_entity_list, filename, filetype,
                                     num_ents_exported, cubit_version);
  return (return_val-1);
Variable Documentation
bool debug = false
Definition at line 20 of file scale.cpp.
