cgma
volumes.cpp File Reference
#include <iostream>
#include <map>
#include <cfloat>
#include <cassert>
#include "MCNPInput.hpp"
#include "volumes.hpp"
#include "geometry.hpp"
#include "options.hpp"
Classes
class  PlaneSurface
class  CylinderSurface
class  ConeSurface
class  TorusSurface
class  SphereSurface
class  EllipsoidSurface
class  BoxVolume
class  RppVolume
class  RecVolume
class  RccVolume
class  HexVolume
class  VolumeCache
Enumerations
enum  axis_t { X = 0, Y = 1, Z = 2 }
Functions
iBase_EntityHandle makeWorldSphere (iGeom_Instance &igm, double world_size)
static iBase_EntityHandle embedWithinWorld (bool positive, iGeom_Instance &igm, double world_size, iBase_EntityHandle body, bool bound_with_world)
iBase_EntityHandle applyTransform (const Transform &t, iGeom_Instance &igm, iBase_EntityHandle &e)
iBase_EntityHandle applyReverseTransform (const Transform &tx, iGeom_Instance &igm, iBase_EntityHandle &e)
static Transform axesImage (const Vector3d &v1, const Vector3d &v2, const Vector3d &v3, const Vector3d &translation=Vector3d())
static Transform imageZAxisTo (const Vector3d &v, const Vector3d &translation=Vector3d())
bool sqIsEllipsoid (const std::vector< double > &args)
SurfaceVolumemakeSurface (const SurfaceCard *card, VolumeCache *v)
Variables
static Vector3d origin (0, 0, 0)
static VolumeCache default_volume_cache
Enumeration Type Documentation
enum axis_t
Enumerator:
X
Y
Z
Definition at line 164 of file volumes.cpp.
{ X=0, Y=1, Z=2 } axis_t;
Function Documentation
Definition at line 93 of file volumes.cpp.
  int igm_result;
  Transform rev_t = tx.reverse();
  const Vector3d& translation = rev_t.getTranslation();
  iGeom_moveEnt( igm, e, translation.v[0], translation.v[1], translation.v[2], &igm_result);
  CHECK_IGEOM( igm_result, "applying reverse translation" );
  if( rev_t.hasInversion() ){
    iGeom_rotateEnt( igm, e, 180, 0, 0, 0, &igm_result );
    CHECK_IGEOM( igm_result, "inverting for reverse transformation" );
  if( rev_t.hasRot() ){
    const Vector3d& axis = rev_t.getAxis();
    iGeom_rotateEnt( igm, e, rev_t.getTheta(), axis.v[0], axis.v[1], axis.v[2], &igm_result );
    CHECK_IGEOM( igm_result, "applying rotation" );
  return e;
Definition at line 59 of file volumes.cpp.
  int igm_result;
  if( t.hasRot()  ){
    const Vector3d& axis = t.getAxis();
    iGeom_rotateEnt( igm, e, t.getTheta(), axis.v[0], axis.v[1], axis.v[2], &igm_result );
  if( t.hasInversion() ){
      //TODO: ask about the right way to do this.  Rotate seems to work, but I don't really know why...
      //iGeom_rotateEnt( igm, e, 180, 0, 0, 0, &igm_result );
    //if( !t.hasRot() ){
      iGeom_reflectEnt( igm, e, 0, 0, 0, 0, 0, 1, &igm_result );
      iGeom_reflectEnt( igm, e, 0, 0, 0, 0, 1, 0, &igm_result );
      iGeom_reflectEnt( igm, e, 0, 0, 0, 1, 0, 0, &igm_result );
      //else{
      //   const Vector3d& axis = t.getAxis();
      //   iGeom_reflectEnt( igm, e, axis.v[0], axis.v[1], axis.v[2], &igm_result );
      CHECK_IGEOM( igm_result, "inverting for transformation" );
  const Vector3d& translation = t.getTranslation();
  CHECK_IGEOM( igm_result, "applying translation" );
  return e;
static Transform axesImage ( const Vector3d v1,
const Vector3d v2,
const Vector3d v3,
const Vector3d translation = Vector3d()
) [static]
Definition at line 463 of file volumes.cpp.
  Vector3d x(1, 0, 0), y(0, 1, 0), z(0, 0, 1);
  Vector3d a1 = v1.normalize(), a2 = v2.normalize(), a3 = v3.normalize();
  if( OPT_DEBUG ) std::cout << "Axes image: " << a1 << " : " << a2 << " : " << a3 << std::endl;
  double rot_matrix[9] =
    { a1.dot(x), a2.dot(x), a3.dot(x),
      a1.dot(y), a2.dot(y), a3.dot(y),
      a1.dot(z), a2.dot(z), a3.dot(z) };
  return Transform( rot_matrix, translation );
static iBase_EntityHandle embedWithinWorld ( bool  positive,
iGeom_Instance igm,
double  world_size,
) [static]
A convenience function for SurfaceVolumes to call at the end of getHandle functions. Return the negative or positive sense of the given body, as appropriate. If bound_within_world is true, a negative-sense body will be intersected with the world sphere (a step necessary for cylinders and other infinite bodies)
Definition at line 33 of file volumes.cpp.
  iBase_EntityHandle final_body;
  int igm_result;
  if( !positive && !bound_with_world ){
    final_body = body;
  else{
    iBase_EntityHandle world_sphere = makeWorldSphere( igm, world_size );
    if( positive ){
      iGeom_subtractEnts( igm, world_sphere, body, &final_body, &igm_result);
      CHECK_IGEOM( igm_result, "making positive body" );
    else{ // !positive && bound_with_world
      iGeom_intersectEnts( igm, world_sphere, body, &final_body, &igm_result);
      CHECK_IGEOM( igm_result, "making negative body" );
  return final_body;
static Transform imageZAxisTo ( const Vector3d v,
) [static]
Definition at line 479 of file volumes.cpp.
  // approach: find two vectors perpendicular to v, then use axesImage.
  Vector3d a = v.normalize();
  Vector3d x(1, 0, 0);
  Vector3d b = x.cross( v.normalize() );
  if( b.length() < DBL_EPSILON ){
    // v is indistinguishable from the x axis
    b = Vector3d(0, -1, 0);
    if( OPT_DEBUG ) std::cout << "imageZAxisTo: Changing v " << std::endl;
  Vector3d c = b.cross( v.normalize() );
  return axesImage( c, b, a, translation );
SurfaceVolume& makeSurface ( const SurfaceCard card,
VolumeCache v = NULL
Function to create an SurfaceVolume object from a SurfaceCard. Created volumes are kept in a cache. If the v parameter is null, a default cache (static within volumes.cpp) will be used. If multiple MCNPInput instances are used in the course of a single program, then there will need to be a way to get multiple VolumeCache objects; that's not an issue right now, so I haven't coded it.
Definition at line 802 of file volumes.cpp.
  VolumeCache& cache = default_volume_cache;
  if( v != NULL ){
    cache = *v;
  if( cache.contains( card ) ){
    return *cache.get( card );
  else{
    // SurfaceCard variables:  mnemonic, args, coord_xform
    SurfaceVolume* surface;
    const std::string& mnemonic = card->getMnemonic();
    const std::vector< double >& args = card->getArgs();
    if( mnemonic == "so"){
      surface = new SphereSurface( origin, args.at(0) );
    else if( mnemonic == "sx"){
      surface = new SphereSurface( Vector3d( args.at(0), 0, 0 ), args.at(1) );
    else if( mnemonic == "sy"){
      surface = new SphereSurface( Vector3d( 0, args.at(0), 0 ), args.at(1) );
    else if( mnemonic == "sz"){
      surface = new SphereSurface( Vector3d( 0, 0, args.at(0) ), args.at(1) );
    else if( mnemonic == "s" || mnemonic == "sph" ){
      surface = new SphereSurface( Vector3d( args ), args.at(3) );
    else if( mnemonic == "sq" && sqIsEllipsoid(args) ){
      surface = new EllipsoidSurface( Vector3d( args.at(7), args.at(8), args.at(9) ), Vector3d( args )* (-1/args.at(6)) );
    else if( mnemonic == "p"){
      if( args.size() == 4 ){
        // plane given as ABCD coefficients (Ax+By+Cz-D=0)
        Vector3d v(args);
        surface = new PlaneSurface( v, args.at(3)/v.length() );
      else if( args.size() == 9 ){
        // plane is given at three points in space
        Vector3d v1(args), v2(args,3), v3(args,6);
        // ordering of the points is arbitrary, but make sure v1 is furthest from origin.
        if( v1.length() < v2.length() ){
          std::swap( v1, v2 );
        if( v1.length() < v3.length() ){
          std::swap( v1, v3 );
        // the normal (up to reversal) of the plane
        // The normal may need to be reversed to ensure that the origin
        // has negative sense, as required by MCNP
        Vector3d normal = v1.add(-v2).cross( v1.add(-v3) ).normalize();
        // If a ray started from the origin and followed the normal vector,
        // p is the point where it intersects the plane
        Vector3d p = normal.scale( v1.dot(normal) );
        // cos of the angle between v1 and normal
        double angle = normal.dot( v1.normalize() );
        // invert the normal if the angle is > 90 degrees, which indicates
        // that reversal is required.
        if( angle < 0 ){
          normal   = -normal;
        //std::cout << normal << " " << p.length() << " : " << angle << std::endl;
        surface = new PlaneSurface( normal, p.length() );
      else{
        throw std::runtime_error( "P surface with unsupported number of params" );
    else if( mnemonic == "px"){
      surface = new PlaneSurface( Vector3d( 1, 0, 0), args.at(0) );
    else if( mnemonic == "py"){
      surface = new PlaneSurface( Vector3d( 0, 1, 0), args.at(0) );
    else if( mnemonic == "pz"){
      surface = new PlaneSurface( Vector3d( 0, 0, 1), args.at(0) );
    else if( mnemonic == "cx" ){
      surface = new CylinderSurface( X, args.at(0) );
    else if( mnemonic == "cy" ){
      surface = new CylinderSurface( Y, args.at(0) );
    else if( mnemonic == "cz" ){
      surface = new CylinderSurface( Z, args.at(0) );
    else if( mnemonic == "c/x"){
      surface = new CylinderSurface( X, args.at(2), args.at(0), args.at(1) );
    else if( mnemonic == "c/y"){
      surface = new CylinderSurface( Y, args.at(2), args.at(0), args.at(1) );
    else if( mnemonic == "c/z"){
      surface = new CylinderSurface( Z, args.at(2), args.at(0), args.at(1) );
#ifdef HAVE_IGEOM_CONE
    else if( mnemonic == "kx"){
      double arg3 = ( args.size() == 3 ? args.at(2) : 0.0 );
      surface = new ConeSurface( X, args.at(1), args.at(0), arg3 );
    else if( mnemonic == "ky"){
      surface = new ConeSurface( Y, args.at(1), args.at(0), arg3 );
    else if( mnemonic == "kz"){
      surface = new ConeSurface( Z, args.at(1), args.at(0), arg3 );
    else if( mnemonic == "k/x" ){
      double arg5 = ( args.size() == 5 ? args.at(4) : 0.0 );
      surface = new ConeSurface( X, args.at(3), Vector3d(args),  arg5 );
    else if( mnemonic == "k/y" ){
      surface = new ConeSurface( Y, args.at(3), Vector3d(args),  arg5 );
    else if( mnemonic == "k/z" ){
      surface = new ConeSurface( Z, args.at(3), Vector3d(args),  arg5 );
    else if( mnemonic == "trc" ){
      surface = new TrcVolume( Vector3d(args), Vector3d(args,3), args.at(6), args.at(7) );
#endif /*HAVE_IGEOM_CONE */
    else if( mnemonic == "tx" ){
      surface = new TorusSurface( X, Vector3d(args), args.at(3), args.at(4), args.at(5) );
    else if( mnemonic == "ty" ){
      surface = new TorusSurface( Y, Vector3d(args), args.at(3), args.at(4), args.at(5) );
    else if( mnemonic == "tz" ){
      surface = new TorusSurface( Z, Vector3d(args), args.at(3), args.at(4), args.at(5) );
    else if( mnemonic == "box" ){
      surface = new BoxVolume( Vector3d(args), Vector3d(args,3), Vector3d(args,6), Vector3d(args,9) );
    else if( mnemonic == "rpp" ){
      surface = new RppVolume( Vector3d(args.at(0), args.at(2), args.at(4)), Vector3d(args.at(1), args.at(3), args.at(5)) );
    else if( mnemonic == "rcc" ){
      surface = new RccVolume( Vector3d(args), Vector3d(args,3), args.at(6) );
    else if( mnemonic == "rec" ){
      if( args.size() == 10 ){
        surface = new RecVolume( Vector3d( args ), Vector3d(args,3), Vector3d(args,6),  args.at(9) );
      else{
        surface = new RecVolume( Vector3d( args ), Vector3d(args,3), Vector3d(args,6), Vector3d(args,9) );
    else if( mnemonic == "hex" || mnemonic == "rhp" ){
        surface = new HexVolume( Vector3d( args ), Vector3d(args,3), Vector3d(args,6) );
      else{
        surface = new HexVolume( Vector3d( args ), Vector3d(args,3), Vector3d(args,6), Vector3d(args,9), Vector3d(args,12) );
    else if( mnemonic == "x" ) {
      switch (args.size()) {
      case 2: // plane
        break;
      case 4: // either plane, cylinder or cone
        if ( args.at(0) == args.at(2) ) // plane
        else if (args.at(1) == args.at(3)) // cylinder
          surface = new CylinderSurface( X, args.at(1) );
        else // cone
            double m = (args.at(3) - args.at(1))/(args.at(2)-args.at(0));
            double apex_p = args.at(0) - args.at(1)/m;
            surface = new ConeSurface( X, m*m, apex_p, (m > 0 ? 1 : -1 ) );
        break;
      default:
        throw std::runtime_error( mnemonic + " is only a supported surface with 2 or 4 arguments" );
        break;
    else if( mnemonic == "y" ) {
      case 2: // plane
        break;
          surface = new CylinderSurface( Y, args.at(1) );
        else // cone
            surface = new ConeSurface( Y, m*m, apex_p, (m > 0 ? 1 : -1 ) );
        break;
      default:
        break;
    else if( mnemonic == "z" ) {
      case 2: // plane
        break;
          surface = new CylinderSurface( Z, args.at(1) );
        else // cone
            surface = new ConeSurface( Z, m*m, apex_p, (m > 0 ? 1 : -1 ) );
        break;
      default:
        break;
    else{
      throw std::runtime_error( mnemonic + " is not a supported surface" );
    if( card->getTransform().hasData() ){
      const Transform& transform = card->getTransform().getData();
      surface->setTransform( &transform );
    cache.insert( card, surface );
    return *surface;
iBase_EntityHandle makeWorldSphere ( iGeom_Instance igm,
double  world_size
Definition at line 16 of file volumes.cpp.
  iBase_EntityHandle world_sphere;
  int igm_result;
  // Note: I tried using createBrick instead of createSphere to bound the universe with a box
  // instead of a sphere.  This worked but led to a substantial increase in run times and
  // memory usage, so should be avoided.
  iGeom_createSphere( igm, world_size, &world_sphere, &igm_result);
  CHECK_IGEOM( igm_result, "making world sphere" );
  return world_sphere;
bool sqIsEllipsoid ( const std::vector< double > &  args)
Definition at line 785 of file volumes.cpp.
  bool isEllipsoid = true;
  if ( args.at(3)*args.at(3) + args.at(4)*args.at(4) + args.at(5)*args.at(5) != 0)
    isEllipsoid = false;
  if ( args.at(0)*args.at(1)*args.at(2)*args.at(6) >= 0 )
  return isEllipsoid;
Variable Documentation
Definition at line 800 of file volumes.cpp.
Vector3d origin(0, 0, 0) [static]
