cgma
CADefines.hpp File Reference
Enumerations
enum  CubitAttributeType {
  CA_UNDEFINED = -1, CA_MERGE_PARTNER = 0, CA_ENTITY_NAME, CA_GROUP,
  CA_ENTITY_ID, CA_PARTITION_VG, CA_COMPOSITE_VG, CA_VIRTUAL_VG,
  CA_UNIQUE_ID, CA_DEFERRED_ATTRIB, CA_MESH_INTERVAL, CA_MESH_RELATIVE_LENGTH,
  CA_GENESIS_ENTITY, CA_MESH_SCHEME, CA_SMOOTH_SCHEME, CA_VERTEX_TYPE,
  CA_MESH_CONTAINER, CA_BODIES, CA_ENTITY_COLOR, CA_ENTITY_TOL,
  CA_VERTEX_FORCE, CA_SURFACE_FORCE, CA_CURVE_FORCE, CA_VERTEX_DISPLACEMENT,
  CA_SURFACE_DISPLACEMENT, CA_CURVE_DISPLACEMENT, CA_VOLUME_DISPLACEMENT, CA_SURFACE_PRESSURE,
  CA_CURVE_PRESSURE, CA_SURFACE_TEMPERATURE, CA_CURVE_TEMPERATURE, CA_VERTEX_TEMPERATURE,
  CA_SURFACE_HEATFLUX, CA_CURVE_HEATFLUX, CA_SURFACE_CONVECTION, CA_CURVE_CONVECTION,
  CA_SURFACE_CONTACT, CA_CURVE_CONTACT, CA_COORD_SYS, CA_MATERIAL_BLOCK,
  CA_PROPERTY_BLOCK, CA_MERGE_STATUS, CA_GRAPHICS_OPTS, CA_ALL_ATTRIBUTES,
  CA_ASSEMBLY_DATA, CA_SIZING_FUNCTION_SKELETON, CA_SOURCE_FEATURE, CA_MESH_OUTPUT_GROUP,
  CA_ENTITY_SENSE
Enumeration Type Documentation
Enumerator:
CA_UNDEFINED
CA_MERGE_PARTNER
CA_ENTITY_NAME
CA_GROUP
CA_ENTITY_ID
CA_PARTITION_VG
CA_COMPOSITE_VG
CA_VIRTUAL_VG
CA_UNIQUE_ID
CA_DEFERRED_ATTRIB
CA_MESH_INTERVAL
CA_GENESIS_ENTITY
CA_MESH_SCHEME
CA_SMOOTH_SCHEME
CA_VERTEX_TYPE
CA_MESH_CONTAINER
CA_BODIES
CA_ENTITY_COLOR
CA_ENTITY_TOL
CA_VERTEX_FORCE
CA_SURFACE_FORCE
CA_CURVE_FORCE
CA_SURFACE_PRESSURE
CA_CURVE_PRESSURE
CA_SURFACE_HEATFLUX
CA_CURVE_HEATFLUX
CA_CURVE_CONVECTION
CA_SURFACE_CONTACT
CA_CURVE_CONTACT
CA_COORD_SYS
CA_MATERIAL_BLOCK
CA_PROPERTY_BLOCK
CA_MERGE_STATUS
CA_GRAPHICS_OPTS
CA_ALL_ATTRIBUTES
CA_ASSEMBLY_DATA
CA_SOURCE_FEATURE
CA_ENTITY_SENSE
Definition at line 5 of file CADefines.hpp.
