cgma
CADefines.hpp
00001
00002 #ifndef __CADEFINES_H__
00003 #define __CADEFINES_H__
00004
00005 enum CubitAttributeType {
00006     CA_UNDEFINED = -1,
00007     CA_MERGE_PARTNER = 0, // must be 0!!!
00008     CA_ENTITY_NAME,
00009     CA_GROUP,
00010     CA_ENTITY_ID,
00011     CA_PARTITION_VG,
00012     CA_COMPOSITE_VG,
00013     CA_VIRTUAL_VG,
00014     CA_UNIQUE_ID,
00015     CA_DEFERRED_ATTRIB,
00016     CA_MESH_INTERVAL,
00017     CA_MESH_RELATIVE_LENGTH,
00018     CA_GENESIS_ENTITY,
00019     CA_MESH_SCHEME,
00020     CA_SMOOTH_SCHEME,
00021     CA_VERTEX_TYPE,
00022     CA_MESH_CONTAINER,
00023     CA_BODIES,
00024     CA_ENTITY_COLOR,
00025     CA_ENTITY_TOL,
00026     CA_VERTEX_FORCE,
00027     CA_SURFACE_FORCE,
00028     CA_CURVE_FORCE,
00029     CA_VERTEX_DISPLACEMENT,
00030     CA_SURFACE_DISPLACEMENT,
00031     CA_CURVE_DISPLACEMENT,
00032     CA_VOLUME_DISPLACEMENT,
00033     CA_SURFACE_PRESSURE,
00034     CA_CURVE_PRESSURE,
00035     CA_SURFACE_TEMPERATURE,
00036     CA_CURVE_TEMPERATURE,
00037     CA_VERTEX_TEMPERATURE,
00038     CA_SURFACE_HEATFLUX,
00039     CA_CURVE_HEATFLUX,
00040     CA_SURFACE_CONVECTION,
00041     CA_CURVE_CONVECTION,
00042     CA_SURFACE_CONTACT,
00043     CA_CURVE_CONTACT,
00044     CA_COORD_SYS,
00045     CA_MATERIAL_BLOCK,
00046     CA_PROPERTY_BLOCK,
00047     CA_MERGE_STATUS,
00048     CA_GRAPHICS_OPTS,
00049     CA_ALL_ATTRIBUTES,// CA_ALL_ATTRIBUTES is used to refer to
00050                       // all attribute types.  It can NOT be assumed to be
00051                       // higher than any given
00052                       // attribute type (eg. for the last index in a loop)
00053     CA_ASSEMBLY_DATA,
00054     CA_SIZING_FUNCTION_SKELETON,
00055     CA_SOURCE_FEATURE,
00056     CA_MESH_OUTPUT_GROUP,
00057     CA_ENTITY_SENSE
00058 #ifdef CAT
00059     ,CA_PRO_WELD
00060 #endif
00061 };
00062
00063 #endif // __CADEFINES_H__
