cgma
CubitFacetEdgeData.hpp
00001 //-----------------------------------------------------------------------------
00002 //
00003 //  File: CubitFacetEdgeData.hpp
00004 //
00005 //  Purpose:  Child class of CubitFacetEdge.  It is the Cubit-specific version of
00006 //            of the CubitFacetEdge.
00007 //
00008 //  Notes:    Note that this class contains data which is accessed
00009 //            virtually from CubitFacetEdge.  In most cases, you can create
00010 //            a CubitFacetEdgeData and treat it as if it is a CubitFacetEdge.
00011 //            For example:
00012 //               CubitFacetEdge *cfe = (CubitFacetEdge *) new CubitFacetEdgeData(...);
00013 //            There should be no reason to reference the CubitFacetEdgeData
00014 //            directly.  This is done to allow different data representations
00015 //            of a facet edge in addition to that used by Cubit.
00016 //
00017 //-----------------------------------------------------------------------------
00018
00019 #ifndef CUBITFACETEDGEDATA_HPP
00020 #define CUBITFACETEDGEDATA_HPP
00021
00022 // Include for CubitBoolean
00023 #include "CubitDefines.h"
00024 #include "CubitPoint.hpp"
00025 #include "DLIList.hpp"
00026 #include "CubitFacetEdge.hpp"
00027
00028 class CubitVector;
00029 class CubitFacet;
00030 class CubitPoint;
00031
00032 class CubitFacetEdgeData : public CubitFacetEdge
00033 {
00034 private:
00035   CubitPoint *pointArray[2];
00036   DLIList<CubitFacet *> adjFacetList;
00037   int entityId;
00038     //- for debug tracking...
00039 public:
00040   CubitFacetEdgeData(CubitPoint *p1, CubitPoint *p2);
00041   CubitFacetEdgeData(CubitPoint *p1, CubitPoint *p2,
00042                  CubitFacet *facet1, CubitFacet *facet2,
00043                  int edge_index1, int edge_index2);
00044     //- constructors
00045   ~CubitFacetEdgeData();
00046     //- destructor
00047   int id(){return entityId;}
00048   void set_id( int ent_id ) {entityId=ent_id;};
00049
00050   CubitPoint *point( int index) { return pointArray[index]; };
00051   CubitPoint *start_node() { return point(0); }
00052   CubitPoint *end_node() { return point(1); }
00053     //- get one of its points
00054   void set_point( CubitPoint *pt, int index ) { pointArray[index] = pt; }
00055     //- set one of the points
00056   CubitFacet *adj_facet( int index );
00057     //- get the list of adjacent facets
00058   void facets(DLIList<CubitFacet*> &facet_list );
00059
00060   void edges(DLIList<CubitFacetEdge*> &edge_list );
00061   void points(DLIList<CubitPoint*> &point_list );
00062   int num_adj_facets()
00063     { return adjFacetList.size(); }
00064   int number_tris() { return num_adj_facets(); }
00065   void marked (int my_flag ) { set_flag(my_flag); }
00066   int marked() { return get_flag(); }
00067
00068   void add_facet(CubitFacet *facet_ptr){ adjFacetList.append(facet_ptr); }
00069   CubitStatus remove_facet( CubitFacet *facet_ptr );
00070
00071   CubitStatus merge_edges( CubitFacetEdgeData* other_edge );
00072
00073   void flip();
00074
00075 };
00076
00077
00078 #endif
00079
00080
