cgma
FBRetriangulate.hpp
00001 /*
00002  *
00003  *
00004  * Copyright (C) 2004 Sandia Corporation.  Under the terms of Contract DE-AC04-94AL85000
00005  * with Sandia Corporation, the U.S. Government retains certain rights in this software.
00006  *
00007  * This file is part of facetbool--contact via [email protected]
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  * This library is distributed in the hope that it will be useful,
00015  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00016  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017  * Lesser General Public License for more details.
00018  *
00019  * You should have received a copy of the GNU Lesser General Public
00020  * License along with this library; if not, write to the Free Software
00021  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022  *
00023  *
00024  *
00025  */
00026
00027 #ifndef _FACETEDBOOLEANRETRIANGULATE
00028 #define _FACETEDBOOLEANRETRIANGULATE
00029 #include <math.h>
00030 #include <vector>
00031 #include "FBDefines.hpp"
00032 #include "FBStructs.hpp"
00033 #include "CubitDefines.h"
00034
00035 class FBRetriangulate {
00036
00037 public:
00038   FBRetriangulate(std::vector<FB_Coord *>& my_verts,
00039                   std::vector<FB_Triangle *>& my_tris,
00040                   std::vector<int>& my_newfacets,
00041                   std::vector<int>& my_newfacetsindex);
00042
00043   FBRetriangulate(std::vector<FB_Coord *>& my_verts,
00044                   std::vector<FB_Triangle *>& my_tris,
00045                   std::vector<int>& my_newfacets);
00046
00047   ~FBRetriangulate();
00048   CubitStatus retriangulate_this_tri(int sequence, std::vector<FB_Edge*> &orphaned_edges);
00049
00050 private:
00051   std::vector<FB_Coord *> verts;
00052   std::vector<FB_Triangle *> *tris;
00053   std::vector<int> *newfacets;
00054   std::vector<int> *newfacetsindex;
00055   int p_dir, s_dir;
00056   enum WindingType { CCW = 0, CW = 1 };
00057   WindingType winding;
00058   FB_Triangle *my_tri;
00059   std::vector<VertexStuff* > vertstufflist;
00060   void make_vert_list();
00061   CubitStatus add_bdry_edges(std::vector<FB_Edge*> &orphaned_edges);
00062   inline double get_dist(double x0, double y0, double z0,
00063                                  double x1, double y1, double z1) {
00064     return sqrt( (x1-x0)*(x1-x0) + (y1-y0)*(y1-y0) + (z1-z0)*(z1-z0) );
00065   };
00066   CubitStatus remove_min_max();
00067   void add_edge_up(int v0, int seq);
00068   void add_edge_down(int v0, int seq);
00069   bool test_for_crossing(int v0, int v1, int v2, int v3);
00070   void add_tri_edge(int v0, int v1, int v0_type, int v1_type);
00071   bool get_a_chain(std::vector<int> *chainlist);
00072   void sort_vertstufflist_edges();
00073   void get_next_vert_in_chain(int& vthis, int& vprev, int direction);
00074   void add_this_bdry_edge(int v0, int v1, int v0_type, int v1_type);
00075   void classify_edges();
00076   void get_edge_indices(int v0, int v1, int v2, int parent,
00077                         int &e0index, int &e1index, int &e2index);
00078
00079 };
00080
00081 #endif
