cgma
GraphicsData.cpp File Reference
GraphicsData, another simple C++ driver for CGM. More...
#include <cassert>
#include "stdio.h"
#include "GMem.hpp"
#include "GeometryQueryTool.hpp"
#include "GeometryModifyTool.hpp"
#include "RefEdge.hpp"
#include "RefFace.hpp"
#include "CubitDefines.h"
#include "CubitBox.hpp"
#include "InitCGMA.hpp"
#include "TestUtilities.hpp"
Defines
#define SRCDIR   .
#define STRINGIFY_(X)   #X
#define STRINGIFY(X)   STRINGIFY_(X)
#define SRCPATH   STRINGIFY(SRCDIR) "/"
#define PRINT_SEPARATOR   PRINT_INFO("=======================================\n");
Functions
int GraphicsData ()
int main (int argc, char **argv)
Detailed Description
This program acts as a simple driver for CGM. It reads in a geometry, and performs varies checks for bodies, surfaces, curves and vertices.
Definition in file GraphicsData.cpp.
Define Documentation
Definition at line 43 of file GraphicsData.cpp.
#define SRCDIR   .
Definition at line 26 of file GraphicsData.cpp.
Definition at line 37 of file GraphicsData.cpp.
#define STRINGIFY (   X)    STRINGIFY_(X)
Definition at line 36 of file GraphicsData.cpp.
#define STRINGIFY_ (   X)    #X
Definition at line 35 of file GraphicsData.cpp.
Function Documentation
int GraphicsData ( )
Definition at line 69 of file GraphicsData.cpp.
  GeometryModifyTool::instance()->brick(10,10,10);
  GeometryQueryEngine* engine = GeometryQueryTool::instance()->get_gqe();
  if(!engine)
    printf("no engine\n");
    return 1;
  CubitBox uninit_box;
  CubitBox model_bbox(
      CubitVector(-5, -5, -5),
      CubitVector(5, 5, 5)
  DLIList<RefEdge*> edges;
  GeometryQueryTool::instance()->ref_edges(edges);
  // expect 24 edges
  if(edges.size() != 12)
    printf("wrong edge count\n");
    return 1;
  // get graphics data for the curves
  CubitBox g_curves = uninit_box;
  GMem gmem;
  for(int i=0; i<edges.size(); i++)
    RefEdge* edge = edges.get_and_step();
    if(engine->get_graphics(edge->get_curve_ptr(), &gmem) != CUBIT_SUCCESS ||
        gmem.pointListCount == 0)
      printf("got no edge facet data for edge %i\n", edge->id());
    else
      for(int j=0; j<gmem.pointListCount; j++)
        const GPoint& pt = gmem.point_list()[j];
        g_curves |= CubitVector(pt.x, pt.y, pt.z);
  printf("curve bbox range = %f %f %f\n",
      g_curves.x_range(), g_curves.y_range(), g_curves.z_range());
  if(!cubit_box_identical(g_curves, model_bbox, GEOMETRY_RESABS))
    printf("didn't get accurate facet data for curves\n");
    return 1;
  CubitBox g_surfaces = uninit_box;
  DLIList<RefFace*> faces;
  GeometryQueryTool::instance()->ref_faces(faces);
  // expect 6 edges
  if(faces.size() != 6)
    printf("wrong face count\n");
    return 1;
  // get graphics data for the surfaces
  for(int i=0; i<faces.size(); i++)
    RefFace* face = faces.get_and_step();
    if(engine->get_graphics(face->get_surface_ptr(), &gmem) != CUBIT_SUCCESS ||
        gmem.pointListCount == 0 || gmem.fListCount == 0)
      printf("got no face facet data for face %i\n", face->id());
    else
      const GPoint* pts = gmem.point_list();
      const int* facets = gmem.facet_list();
      int facet_size = gmem.fListCount;
      for(int j=0; j<facet_size;)
        int num = facets[j++];
        for(int k=0; k<num; k++)
          const GPoint& pt = pts[facets[j++]];
          g_surfaces |= CubitVector(pt.x, pt.y, pt.z);
  printf("surface bbox range = %f %f %f\n",
      g_surfaces.x_range(), g_surfaces.y_range(), g_surfaces.z_range());
  if(!cubit_box_identical(g_surfaces, model_bbox, GEOMETRY_RESABS))
    printf("didn't get accurate facet data for surfaces\n");
    return 1;
  return 0;
int main ( int  argc,
char **  argv
Definition at line 47 of file GraphicsData.cpp.
  CubitStatus s = InitCGMA::initialize_cgma( ENGINE );
  if (CUBIT_SUCCESS != s) return 1;
  //Do tests.
  int rsl = GraphicsData();
  if (rsl == 1)
     PRINT_INFO("Operation Failed");
  int ret_val = ( CubitMessage::instance()->error_count() );
  if ( ret_val != 0 )
    PRINT_ERROR("Errors found during Mergechk session.\n");
  else
    ret_val = 0;
  return ret_val;
