cgma
MemoryManager.hpp
00001 //-       Class: MemoryManager
00002 //-       Owner: Jim Hipp
00003 //- Description: MemoryManager provides object information and stack
00004 //-              storage pointer management used in association with
00005 //-              MemoryBlock and MemoryAllocation classes.
00006 //- Checked By:
00007 //-    Version:
00008
00009 #ifndef MEMORY_MANAGER_HPP
00010 #define MEMORY_MANAGER_HPP
00011
00012 #define USE_DYNAMIC_MEMORY_ALLOCATION
00013 //- comment out this #define to use global system level dynamic memory
00014 //- allocation ... Otherwise overloaded operators new and delete will
00015 //- be set to call operator_new and operator_delete defined in this module
00016
00017 const  int DEFAULT_MEMORY_ALLOC_SIZE = 1024;
00018 //- Default MemoryBlock allocation size
00019
00020 const  int STATIC_MEMORY_MANAGER = 1;
00021 //- Static Memory Manager definition argument
00022
00023 #include <cstdlib>
00024 #include <cassert>
00025 #include "CGMUtilConfigure.h"
00026
00027 class MemoryBlock;
00028
00029 class CUBIT_UTIL_EXPORT MemoryManager
00030 {
00031 private:
00032
00033   const bool     useNew;
00034     //- Disable memory management (pass all calls to new/delete)
00035     //- Unused if compiled with -DNDEBUG
00036
00037   char*          objectName;
00038     //- name of the class for which this memory manager is declared
00039
00040   MemoryBlock*   memBlockStack;
00041     //- memBlockStack is the head of a stack of MemoryBlock objects
00042     //- that contain allocated memory chunks
00043
00044   char*          headOfFreeList;
00045     //- headOfFreeList is the head of a stack that contains free
00046     //- elements that have not yet been constructed by the allocating
00047     //- object
00048
00049   std::size_t         objectSize;
00050     //- objectSize is the size of the allocating object
00051
00052   int            memAllocatnSize;
00053     //- memAllocatnSize is the size of the MemoryBlocks that will be
00054     //- allocated by the allocating object
00055
00056   MemoryManager* next;
00057     //- next object pointer is used to save memory managers on a
00058     //- static stack.
00059
00060   int            staticManager;
00061     //- static flag to indicate that this memory manager is a static
00062     //- object.  This parameter is used by the destructor when the
00063     //- program terminates and static object destructors are called.
00064     //- The destructor calls destroy_memory() which asserts if
00065     //- the used objects attached to this memory manager have not been
00066     //- deleted (generally true for static memory managers at program
00067     //- termination).  Forcing an assert is desirable during normal
00068     //- program operation but not during a normal program termination
00069     //- sequence (Typing QUIT at the CUBIT command line prompt and
00070     //- observing an assert in MemoryManager is not comforting).
00071
00072   static MemoryManager* memoryManagerListHead;
00073     //- stack head containing all allocated memory managers.
00074
00075   MemoryManager();
00076   MemoryManager(const MemoryManager&);
00077     //- do not allow default constructor (must assign objectSize)
00078
00079   static void process_mem_usage(unsigned long &vm_usage, unsigned long &resident_set);
00080   static void process_file_io(unsigned long &read, unsigned long &write );
00081
00082 public:
00083
00084   MemoryManager(const char* name, std::size_t size, int mem_size = 0,
00085                 int static_flag = 0);
00086   ~MemoryManager();
00087     //- constructor / destructor
00088
00089   void   set_memory_allocation_increment(int mem_size = 0);
00090   int    get_memory_allocation_increment() const;
00091     //- set / get memory block allocation increment
00092
00093   std::size_t get_object_size() const;
00094     //- get object size
00095
00096   void   destroy_memory(int static_flag = 0);
00097     //- destroy allocated memory
00098
00099   int    compress_memory();
00100     //- compresses memory for the object by removing unused MemoryBlocks
00101
00102   int    get_allocated_objects();
00103     //- returns number of object storage locations that have been
00104     //- allocated
00105
00106   int    get_free_objects();
00107     //- returns number of objects that are not in use but have been
00108     //- allocated
00109
00110   int    get_used_objects();
00111     //- returns number of objects that are currently in use from those
00112     //- that have been allocated
00113
00114   void*  operator_new(std::size_t size);
00115     //- generic operator new
00116
00117   void   operator_delete(void *deadObject, std::size_t size);
00118     //- generic operator delete
00119
00120   static void show_object_memory(const char* s);
00121   static void show_all_object_memory();
00122     //- prints allocation information to the command line.  The
00123     //- functions are declared static to enable their use throughout
00124     //- the code.  The character string argument is interpreted as the
00125     //- class name provided as input when the memory manager was
00126     //- constructed.
00127
00128   static int compress_object_memory(const char* s);
00129   static int compress_all_object_memory();
00130     //- recaptures unused memory blocks and returns them to free store
00131     //- and returns the amount of reclaimed memory.  The functions are
00132     //- declared static to enable their use throughout the code.  The
00133     //- character string argument is interpreted as the class name
00134     //- provided as input when the memory manager was constructed.
00135 };
00136
00137 #ifdef USE_DYNAMIC_MEMORY_ALLOCATION
00138
00139 #define SetDynamicMemoryAllocation(memManager)                               \
00140        \
00141   void*  operator new(std::size_t size)                                           \
00142          {return memManager.operator_new(size);}                             \
00143   void   operator delete(void *deadObject, std::size_t size)                      \
00144          {memManager.operator_delete(deadObject, size);}                     \
00145   /*  overloaded new and delete operators */                                    \
00146        \
00147
00148 #else
00149
00150 #define SetDynamicMemoryAllocation(memManager)                               \
00151        \
00152   /* DO NOT overload new and delete operators ... use global allocation */   \
00153        \
00154
00155 #endif
00156
00157 #endif // MEMORY_MANAGER_HPP
00158
