cgma
BasicTopologyEntity Member List
This is the complete list of members for BasicTopologyEntity, including all inherited members.
actuate_cubit_attrib(int attrib_type)CubitAttribUser
actuate_cubit_attrib(DLIList< RefEntity * >, int)CubitAttribUser [static]
add_compare_data(RefEntity *partner)RefEntity
add_cubit_attrib(CubitAttrib *cubit_attrib_ptr)CubitAttribUser
add_grouping_entity(GroupingEntity *)BasicTopologyEntity
add_observer(CubitObserver *observer)CubitObservable [protected, virtual]
add_sense_entity(SenseEntity *)BasicTopologyEntity
add_TD(ToolData *new_td)ToolDataUser [virtual]
append_attrib_internal(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr)CubitAttribUser
append_simple_attribute(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr)CubitAttribUser
assign_default_name(CubitBoolean user_setting=CUBIT_FALSE)RefEntity
auto_actuate_cubit_attrib(CubitBoolean from_constructor=CUBIT_TRUE, CubitBoolean after_geom_changes=CUBIT_FALSE)CubitAttribUser
auto_read_cubit_attrib()CubitAttribUser
auto_update_cubit_attrib()CubitAttribUser
auto_update_cubit_attrib(DLIList< RefEntity * > &entity_list, CubitBoolean write_too=CUBIT_TRUE)CubitAttribUser [static]
autoMergeStatusRefEntity [protected]
BasicTopologyEntity()BasicTopologyEntity [inline]
BasicTopologyEntity(const BasicTopologyEntity &)BasicTopologyEntity [private]
bodies(DLIList< Body * > &body_list)TopologyEntity
body()TopologyEntity
bounding_box()BasicTopologyEntity [virtual]
bridge_manager() const TopologyEntity [inline]
bridge_manager()TopologyEntity [inline]
can_modify()RefEntity [virtual]
center_point()RefEntity [virtual]
chains(DLIList< Chain * > &chain_list)TopologyEntity
change_to_parent_ref_entities(DLIList< RefEntity * > &ancestors)RefEntity [static]
children_mergeable()RefEntity [virtual]
class_name() const BasicTopologyEntity [inline, virtual]
clear_all_simple_attrib(DLIList< RefEntity * > &entity_list)CubitAttribUser [static]
clear_all_simple_attrib_set_to_actuate(DLIList< RefEntity * > &entity_list)CubitAttribUser [static]
clear_simple_attribs()CubitAttribUser
clear_simple_attribs_set_to_actuate()CubitAttribUser
co_edge()TopologyEntity
co_edges(DLIList< CoEdge * > &co_edge_list)TopologyEntity
co_faces(DLIList< CoFace * > &co_face_list)TopologyEntity
co_vertices(DLIList< CoVertex * > &co_vertex_list)TopologyEntity
co_volumes(DLIList< CoVolume * > &co_volume_list)TopologyEntity
color(int value)RefEntity [virtual]
color() const RefEntity [virtual]
comparison_found(RefEntity *partner)RefEntity
CubitAttribUser(CubitAttrib *=NULL)CubitAttribUser
CubitEntity()CubitEntity [inline]
CubitEventDispatcher classCubitObservable [friend]
CubitObservable()CubitObservable
CubitObservable(const CubitObservable &)CubitObservable [protected]
CubitObserver classCubitObservable [friend]
dag_type() const =0BasicTopologyEntity [pure virtual]
RefEntity::dag_type(const std::type_info &)RefEntity [static]
RefEntity::dag_type(const char *cli_type_name)RefEntity [static]
deactivated(CubitBoolean flag)TopologyEntity
deactivated() const TopologyEntity
deactivatedStatus_TopologyEntity [protected]
delete_TD(IdentityFn specified_type)ToolDataUser [virtual]
delete_TD(ToolData *td)ToolDataUser [virtual]
dimension() const RefEntity [virtual]
disconnect_all_children(DLIList< TopologyEntity * > *children=0)BasicTopologyEntity [protected, virtual]
disconnect_all_parents(DLIList< TopologyEntity * > *parents=0)BasicTopologyEntity [protected, virtual]
disconnect_from_DAG()TopologyEntity
encountered_TopologyEntity [protected]
entity_name() const RefEntity [virtual]
entity_name(CubitString name)RefEntity
entity_names(DLIList< CubitString > &names) const RefEntity
entity_type_info() const =0RefEntity [pure virtual]
entityIdCubitEntity [protected]
find_cubit_attrib_type(int, DLIList< CubitAttrib * > &) const CubitAttribUser
find_sense_entity(GroupingEntity *gpe) const BasicTopologyEntity
find_sense_entity(BasicTopologyEntity *bte) const BasicTopologyEntity
firstGroupingEntityBasicTopologyEntity [private]
firstSenseEntityBasicTopologyEntity [private]
gather_bdy_entities(DLIList< RefEntity * > &entity_list, DLIList< RefEntity * > &bdy_list)RefEntity [static]
generate_default_name(CubitString &name)RefEntity
geometry_type() const BasicTopologyEntity
get_all_child_ref_entities(DLIList< RefEntity * > &entity_list)RefEntity
get_all_child_ref_entities(DLIList< RefEntity * > &input_list, DLIList< RefEntity * > &output_list)RefEntity [static]
get_all_parent_ref_entities(DLIList< RefEntity * > &entity_list, const int get_bodies=CUBIT_FALSE)RefEntity
get_all_TDs(IdentityFn specified_type, DLIList< ToolData * > *all_tds) const ToolDataUser [virtual]
get_all_TDs(DLIList< ToolData * > *all_tds) const ToolDataUser [virtual]
get_by_name(const CubitString &name)RefEntity [static]
get_child_ref_entities(DLIList< RefEntity * > &entity_list)RefEntity [virtual]
get_child_ref_entity_type() const RefEntity
get_child_ref_entity_type(DagType parent_type)RefEntity [static]
get_children(DLIList< TopologyEntity * > *list=0) const BasicTopologyEntity [virtual]
get_class_name()BasicTopologyEntity [inline, static]
get_compare_partner()RefEntity
get_cubit_attrib(int attrib_type, CubitBoolean create_if_missing=CUBIT_TRUE)CubitAttribUser
get_cubit_attrib_list(DLIList< CubitAttrib * > &)CubitAttribUser
get_entity_type_info(const char *entity_type)RefEntity [static]
get_first_grouping_entity_ptr() const BasicTopologyEntity [inline]
get_first_sense_entity_ptr() const BasicTopologyEntity [inline]
get_geometry_entity_ptr() const BasicTopologyEntity
get_geometry_query_engine() const TopologyEntity
get_grouping_entity_list(DLIList< GroupingEntity * > &groupingEntityList) const BasicTopologyEntity
get_observer_list(DLIList< CubitObserver * > &observers)CubitObservable
get_parent_ref_entities(DLIList< RefEntity * > &entity_list)=0RefEntity [pure virtual]
get_parent_ref_entity_type() const RefEntity
get_parent_ref_entity_type(DagType child_type)RefEntity [static]
get_parents(DLIList< TopologyEntity * > *list=0) const BasicTopologyEntity [virtual]
get_ref_class_name(const std::type_info &ref_type)RefEntity [static]
get_related_entity_list(const std::type_info &related_entity_type, DLIList< RefEntity * > &entity_list)RefEntity
get_sense_entities(DLIList< SenseEntity * > &result, GroupingEntity *in_this)BasicTopologyEntity
get_sense_entities(DLIList< SenseEntity * > &result, BasicTopologyEntity *in_this)BasicTopologyEntity
get_sense_entity_list(DLIList< SenseEntity * > &senseEntityList) const BasicTopologyEntity
get_TD(IdentityFn specified_type)ToolDataUser [virtual]
get_TD(IdentityFn specified_type) const ToolDataUser [virtual]
headAttribCubitAttribUser [protected]
id() const CubitEntity [virtual]
is_child(RefEntity *entity)RefEntity [virtual]
is_directly_related(TopologyEntity *entity)TopologyEntity
is_mergeable(AutoMergeStatus val)RefEntity [virtual]
is_mergeable()RefEntity
is_merged()RefEntity
is_nonmanifold(GroupingEntity *in_this_parent)BasicTopologyEntity
is_parent(RefEntity *entity)RefEntity [virtual]
is_transparent(int flag)CubitEntity [virtual]
is_transparent() const CubitEntity [virtual]
is_visible(int flag)CubitEntity [virtual]
is_visible() const CubitEntity [virtual]
join(RefEntity *ref_entity_2, DLIList< RefEntity * > &join_set)RefEntity
join(DLIList< RefEntity * > &ref_entities, DLIList< RefEntity * > &join_set)RefEntity [static]
lastGroupingEntityBasicTopologyEntity [private]
lastSenseEntityBasicTopologyEntity [private]
listFlagRefEntity [protected]
local_tolerance(double value)RefEntity [inline]
local_tolerance(void)RefEntity [inline]
loops(DLIList< Loop * > &loop_list)TopologyEntity
marked(int value)RefEntity [inline, virtual]
marked()RefEntity [inline, virtual]
markedFlagRefEntity [protected]
mColorRefEntity [protected]
measure()BasicTopologyEntity [virtual]
measure_label()RefEntity [virtual]
meet(RefEntity *ref_entity_2, DLIList< RefEntity * > &join_set)RefEntity
meet(DLIList< RefEntity * > &ref_entities, DLIList< RefEntity * > &join_set)RefEntity [static]
merge_entity_names(RefEntity *dead_entity)RefEntity
merge_owner(RefEntity *deletable_entity)CubitAttribUser
merge_status() const RefEntity
ModelQueryEngine classTopologyEntity [friend]
notify_observers(const CubitEvent *event)CubitObservable
notify_sub_all_observers(const GeometryEvent::Type &event)RefEntity
num_cubit_attrib()CubitAttribUser
num_loops()TopologyEntity
num_names() const RefEntity
num_parent_ref_entities()RefEntity
num_ref_edges()TopologyEntity
num_ref_faces()TopologyEntity
num_ref_vertices()TopologyEntity
num_ref_volumes()TopologyEntity
observerListCubitObservable [protected]
operator=(const BasicTopologyEntity &)BasicTopologyEntity [private]
CubitObservable::operator=(const CubitObservable &)CubitObservable [protected]
query_append_children(DLIList< TopologyEntity * > &list)BasicTopologyEntity [protected, virtual]
query_append_parents(DLIList< TopologyEntity * > &list)BasicTopologyEntity [protected, virtual]
read_cubit_attrib(int attrib_type)CubitAttribUser
ref_edge()TopologyEntity
ref_edges(DLIList< RefEdge * > &ref_edge_list)TopologyEntity
ref_face()TopologyEntity
ref_faces(DLIList< RefFace * > &ref_face_list)TopologyEntity
ref_vertex()TopologyEntity
ref_vertices(DLIList< RefVertex * > &ref_vertex_list)TopologyEntity
ref_volume()TopologyEntity
ref_volumes(DLIList< RefVolume * > &ref_volume_list)TopologyEntity
RefEntity()RefEntity
remove_all_simple_attribute(TopologyBridge *bridge)CubitAttribUser
remove_attrib_geometry_entity(CubitAttrib *)CubitAttribUser
remove_child_link(TopologyEntity *entity_ptr)BasicTopologyEntity [protected, virtual]
remove_compare_data()RefEntity
remove_cubit_attrib(int attrib_type)CubitAttribUser
remove_cubit_attrib(CubitAttrib *)CubitAttribUser
remove_entity_name(CubitString const &name)RefEntity
remove_entity_names()RefEntity
remove_from_DAG(CubitBoolean recursive_flag=CUBIT_FALSE)TopologyEntity
remove_from_observers()CubitObservable [protected]
remove_grouping_entity(GroupingEntity *)BasicTopologyEntity
remove_observer(CubitObserver *observer)CubitObservable [protected, virtual]
remove_sense_entity(SenseEntity *)BasicTopologyEntity
remove_simple_attribute(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr)CubitAttribUser
remove_TD(IdentityFn specified_type)ToolDataUser [virtual]
remove_TD(ToolData *td)ToolDataUser [virtual]
reverse_topology()TopologyEntity [inline, virtual]
set_geometry_entity_ptr(GeometryEntity *geometryEntityPtr)BasicTopologyEntity
set_grouping_entity_list(DLIList< GroupingEntity * > &new_list, DLIList< GroupingEntity * > &removed_list)BasicTopologyEntity
set_id(int i)RefEntity [virtual]
set_id(int i, CubitBoolean emit_event)RefEntity
set_topology_bridge(TopologyBridge *TB_ptr)TopologyEntity [protected]
set_updated_flag(CubitBoolean flag)CubitAttribUser
set_written_flag(CubitBoolean flag)CubitAttribUser
shells(DLIList< Shell * > &shell_list)TopologyEntity
split_owner(DLIList< CubitSimpleAttrib > &csa_list)CubitAttribUser
switch_entity_names(RefEntity *other_entity)RefEntity
ToolDataUser()ToolDataUser [inline]
TopologyEntity()TopologyEntity
transf_owner(const CubitVector &matrow1, const CubitVector &matrow2, const CubitVector &matrow3, const CubitVector &translate_vec, const double scale_factor)CubitAttribUser
unmerged_bounding_box()BasicTopologyEntity [virtual]
update_auto_merge_state()RefEntity
update_cubit_attrib(int)CubitAttribUser
valence(RefEntity *parent=NULL)RefEntity
validate()RefEntity [virtual]
write_cubit_attrib_by_type(int attrib_type)CubitAttribUser
write_cubit_attrib_list(DLIList< CubitAttrib * > attrib_list)CubitAttribUser
write_cubit_attribs()CubitAttribUser
write_specific_cubit_attrib(CubitAttrib *cubit_attrib_ptr)CubitAttribUser
~BasicTopologyEntity()BasicTopologyEntity [virtual]
~CubitAttribUser()CubitAttribUser [virtual]
~CubitEntity()CubitEntity [virtual]
~CubitObservable()CubitObservable [virtual]
~RefEntity()RefEntity [virtual]
~ToolDataUser()ToolDataUser [virtual]
~TopologyEntity()TopologyEntity [virtual]
