cgma
CASourceFeature Class Reference
Attribute for managing RefEntity source feature types. More...
#include <CASourceFeature.hpp>
Inheritance diagram for CASourceFeature:
CubitAttrib
List of all members.
Public Member Functions
 CASourceFeature (RefEntity *, const CubitSimpleAttrib &)
 Constructor.
virtual ~CASourceFeature ()
 destructor
CubitStatus actuate ()
 Actuate.
CubitStatus update ()
 Update.
CubitStatus reset ()
 Reset function, cleans out name lists.
CubitSimpleAttrib cubit_simple_attrib ()
 Returns the simple cubit attribute for this attribute.
GeometryFeatureEngine::FeatureType string_to_feature_type (CubitString value_in)
 Given a cubit attribute string return the FeatureType.
CubitString feature_type_to_string (GeometryFeatureEngine::FeatureType type_in)
 Returning a cubit simple attribute string for the input feature type.
int int_attrib_type ()
 Return the #define attribute type.
void print ()
 Print this attribute to the output.
Private Attributes
GeometryFeatureEngine::FeatureType sourceFeature
 Temp source feature enum.
Detailed Description
Definition at line 13 of file CASourceFeature.hpp.
CASourceFeature::CASourceFeature ( RefEntity new_attrib_owner,
const CubitSimpleAttrib csa_ptr
Constructor.
Definition at line 14 of file CASourceFeature.cpp.
                                 : CubitAttrib(new_attrib_owner)
    sourceFeature = GeometryFeatureEngine::FEATURE_UNDEFINED;
    if(!csa_ptr.isEmpty())
      const std::vector<CubitString>& cs_list = csa_ptr.string_data_list();
      // step over the attribute type
      // now read name / option pairs
      if(cs_list.size()==2)
        CubitString cs = cs_list[1];
          if (cs.length() == 0)
              PRINT_WARNING("Empty feature attribute for %s %d.\n",
              attribOwnerEntity->class_name(),
              attribOwnerEntity->id());
          else
              sourceFeature = string_to_feature_type(cs);
      else
          deleteAttrib = CUBIT_TRUE;
destructor
Definition at line 42 of file CASourceFeature.cpp.
Member Function Documentation
Actuate.
Implements CubitAttrib.
Definition at line 46 of file CASourceFeature.cpp.
    if (hasActuated == CUBIT_TRUE)
        return CUBIT_SUCCESS;
    // create a TDSourceFeature for the entity, if it doesn't already
    // exist
    TDSourceFeature *source_feature_data =
        (TDSourceFeature *) attrib_owner()->get_TD(&TDSourceFeature::is_source_feature);
    if (!source_feature_data)
        // else make a new one
        TDSourceFeature* new_tool_data = new TDSourceFeature(sourceFeature);
        attrib_owner()->add_TD(new_tool_data);
    delete_attrib(CUBIT_TRUE);
    hasActuated = CUBIT_TRUE;
Definition at line 102 of file CASourceFeature.cpp.
    std::vector<CubitString> cs_list;
    // pack the string list:
    // character type of this CA
    cs_list.push_back(att_internal_name());
    // name, option pairs
    cs_list.push_back(feature_type_to_string(sourceFeature));
    return CubitSimpleAttrib(&cs_list, NULL, NULL);
Definition at line 157 of file CASourceFeature.cpp.
    switch(type_in)
    case GeometryFeatureEngine::FEATURE_IMPRINT:
        return "IMPRINT";
    case GeometryFeatureEngine::FEATURE_HOLE:
        return "HOLE";
    case GeometryFeatureEngine::FEATURE_ROUND:
        return "ROUND";
    case GeometryFeatureEngine::FEATURE_CHAMFER:
        return "CHAMFER";
    case GeometryFeatureEngine::FEATURE_SLOT:
        return "SLOT";
    case GeometryFeatureEngine::FEATURE_CUT:
        return "CUT";
    default:
        return "";
int CASourceFeature::int_attrib_type ( ) [inline, virtual]
Definition at line 47 of file CASourceFeature.hpp.
void CASourceFeature::print ( ) [virtual]
Reimplemented from CubitAttrib.
Definition at line 117 of file CASourceFeature.cpp.
    // print info on this attribute
    PRINT_INFO("CASourceFeature: owner = %s %d; feature: ",
        attribOwnerEntity->class_name(), attribOwnerEntity->id());
    PRINT_INFO("%s ", feature_type_to_string(sourceFeature).c_str());
    PRINT_INFO("\n");
Definition at line 94 of file CASourceFeature.cpp.
Definition at line 128 of file CASourceFeature.cpp.
    FEATURE_UNDEFINED,
    FEATURE_HOLE,
    FEATURE_ROUND,
    FEATURE_CHAMFER,
    FEATURE_SLOT ,
    FEATURE_CUT,
    FEATURE_IMPRINT
    if(value_in == "IMPRINT")
        return GeometryFeatureEngine::FEATURE_IMPRINT;
    else if(value_in == "HOLE")
        return GeometryFeatureEngine::FEATURE_HOLE;
    else if(value_in == "ROUND")
        return GeometryFeatureEngine::FEATURE_ROUND;
    else if(value_in == "CHAMFER")
        return GeometryFeatureEngine::FEATURE_CHAMFER;
    else if(value_in == "SLOT")
        return GeometryFeatureEngine::FEATURE_SLOT;
    else if(value_in == "CUT")
        return GeometryFeatureEngine::FEATURE_CUT;
    else
        return GeometryFeatureEngine::FEATURE_UNDEFINED;
Update.
Definition at line 69 of file CASourceFeature.cpp.
    if(hasUpdated)
    // set the updated flag
    hasUpdated = CUBIT_TRUE;
    // if the owner has a unique id, save it, otherwise delete this one
    else
        if (delete_attrib() == CUBIT_TRUE)
            delete_attrib(CUBIT_FALSE);
        sourceFeature = source_feature_data->source_feature();
Member Data Documentation
Definition at line 17 of file CASourceFeature.hpp.
