cgma
CGMParallelComm Class Reference
Parallel communications in CGM. More...
#include <CGMParallelComm.hpp>
List of all members.
Public Member Functions
 CGMParallelComm (MPI_Comm comm=MPI_COMM_WORLD)
 constructor
 CGMParallelComm (std::vector< unsigned char > &tmp_buff, MPI_Comm comm=MPI_COMM_WORLD)
 constructor taking buffer, for testing
 ~CGMParallelComm ()
 destructor
DLIList< RefEntity * > & partition_surf_list ()
 return partition ref entity list
const DLIList< RefEntity * > & partition_surf_list () const
DLIList< RefEntity * > & partition_body_list ()
const DLIList< RefEntity * > & partition_body_list () const
const CGMProcConfigproc_config () const
 Get proc config for this communication object.
CubitStatus broadcast_entities (const unsigned int from_proc, DLIList< RefEntity * > &ref_entity_list)
CubitStatus scatter_entities (const unsigned int from_proc, DLIList< RefEntity * > &ref_entity_list)
CubitStatus write_buffer (DLIList< RefEntity * > &ref_entity_list, char *pBuffer, int &n_buffer_size, bool b_export_buffer)
CubitStatus read_buffer (DLIList< RefEntity * > &ref_entity_list, const char *pBuffer, const int n_buffer_size)
CubitStatus bcast_buffer (const unsigned int from_proc)
CubitStatus append_to_buffer (DLIList< RefEntity * > &ref_entity_list, int add_size)
Private Member Functions
CubitStatus check_size (int &target_size, const CubitBoolean keep=CUBIT_FALSE)
Private Attributes
GeometryQueryToolgqt
 CGM query tool interface associated with this writer.
CGMProcConfig procConfig
 Proc config object, keeps info on parallel stuff.
std::vector< unsigned char > myBuffer
 data buffer used to communicate
char * m_pBuffer
int m_nBufferSize
int m_currentPosition
DLIList< RefEntity * > partitioningSurfList
DLIList< RefEntity * > partitioningBodyList
Detailed Description
Author:
Hong-Jun Kim, copied from MBParallelComm.hpp
This class implements methods to communicate geometry between processors
Definition at line 21 of file CGMParallelComm.hpp.
constructor
Definition at line 19 of file CGMParallelComm.cpp.
  : gqt(NULL), procConfig(comm), m_pBuffer(NULL), m_nBufferSize(0), m_currentPosition(0)
  myBuffer.resize(INITIAL_BUFF_SIZE);
  int flag = 1;
  int retval = MPI_Initialized(&flag);
  if (MPI_SUCCESS != retval || !flag) {
    int argc = 0;
    char **argv = NULL;
    // mpi not initialized yet - initialize here
    retval = MPI_Init(&argc, &argv);
CGMParallelComm::CGMParallelComm ( std::vector< unsigned char > &  tmp_buff,
MPI_Comm  comm = MPI_COMM_WORLD
Definition at line 35 of file CGMParallelComm.cpp.
  myBuffer.swap(tmp_buff);
  int flag = 1;
    int argc = 0;
    char **argv = NULL;
destructor
Definition at line 51 of file CGMParallelComm.cpp.
  delete m_pBuffer;
Member Function Documentation
CubitStatus CGMParallelComm::append_to_buffer ( DLIList< RefEntity * > &  ref_entity_list,
int  add_size
Definition at line 269 of file CGMParallelComm.cpp.
  if (m_currentPosition + add_size > m_nBufferSize) return CUBIT_FAILURE;
  CubitStatus result = write_buffer(ref_entity_list, m_pBuffer + m_currentPosition, add_size, true);
  RRA("Failed to append ref entity list to buffer.");
  return CUBIT_SUCCESS;
CubitStatus CGMParallelComm::bcast_buffer ( const unsigned int  from_proc)
Definition at line 56 of file CGMParallelComm.cpp.
  //- broadcasts the buffer contained in this object
  if (procConfig.proc_rank() == from_proc) {
    printf("Broadcasting buffer size from %d.\n", from_proc);
    MPI_Bcast(&m_nBufferSize, 1, MPI_INT, from_proc, MPI_COMM_WORLD);
    printf("Broadcasting buffer from %d, %d bytes.\n", from_proc,
       m_nBufferSize);
    MPI_Bcast(m_pBuffer, m_nBufferSize, MPI_BYTE, from_proc,
              MPI_COMM_WORLD);
  else {
    int this_size;
    printf("Broadcasting buffer size from proc %d.\n",
       procConfig.proc_rank());
    MPI_Bcast(&this_size, 1, MPI_INT, from_proc,
              MPI_COMM_WORLD);
    printf("Processor %d: received size of %d.\n", procConfig.proc_rank(), this_size);
    check_size(this_size);
    printf("Broadcasting buffer from proc %d, %d bytes.\n",
    MPI_Bcast(m_pBuffer, this_size, MPI_BYTE, from_proc,
              MPI_COMM_WORLD);
CubitStatus CGMParallelComm::broadcast_entities ( const unsigned int  from_proc,
Definition at line 84 of file CGMParallelComm.cpp.
#ifndef USE_MPI
#else
  CubitStatus result = CUBIT_SUCCESS;
    int nBufferSize = 0;
    result = write_buffer(ref_entity_list, m_pBuffer, nBufferSize, false);
    RRA("Failed to write ref entity list to buffer.");
    result = check_size(nBufferSize);
    result = write_buffer(ref_entity_list, m_pBuffer, nBufferSize, true);
  result = bcast_buffer(from_proc);
  RRA("Failed to broadcast buffer to processors.");
  if (procConfig.proc_rank() != from_proc) {
    result = read_buffer(ref_entity_list, m_pBuffer, m_nBufferSize);
    RRA("Failed to read ref entity list from buffer.");
#endif
CubitStatus CGMParallelComm::check_size ( int &  target_size,
const CubitBoolean  keep = CUBIT_FALSE
) [private]
Definition at line 252 of file CGMParallelComm.cpp.
  printf("Checking buffer size on proc %d, target size %d.\n",
                  procConfig.proc_rank(), target_size);
  if (m_nBufferSize < target_size) {
    printf("Increasing buffer size on proc %d.\n", procConfig.proc_rank());
    void *temp_buffer = malloc(target_size);
    if (keep && 0 != m_currentPosition) memcpy(temp_buffer, m_pBuffer, m_currentPosition);
    delete m_pBuffer;
    m_pBuffer = (char *) temp_buffer;
    m_nBufferSize = target_size;
Definition at line 41 of file CGMParallelComm.hpp.
Definition at line 38 of file CGMParallelComm.hpp.
Definition at line 39 of file CGMParallelComm.hpp.
const CGMProcConfig& CGMParallelComm::proc_config ( ) const [inline]
Definition at line 44 of file CGMParallelComm.hpp.
{return procConfig;}
Definition at line 47 of file CGMParallelComm.hpp.
CubitStatus CGMParallelComm::read_buffer ( DLIList< RefEntity * > &  ref_entity_list,
const char *  pBuffer,
Definition at line 233 of file CGMParallelComm.cpp.
#ifndef USE_MPI
#else
  if (n_buffer_size == 0) return CUBIT_SUCCESS;
#ifdef HAVE_OCC
  CubitStatus result = GeometryQueryTool::instance()->import_solid_model(&ref_entity_list, pBuffer,
                                     n_buffer_size);
  RRA("Failed to read ref entities from buffer.");
#endif
#endif
CubitStatus CGMParallelComm::scatter_entities ( const unsigned int  from_proc,
Definition at line 117 of file CGMParallelComm.cpp.
#ifndef USE_MPI
#else
  int i, mySendCount, nEntity;
  int nProcs = procConfig.proc_size();
  int *sendCounts = new int[nProcs];
  int *displacements = new int[nProcs];
  displacements[0] = 0;
    // make a balanced entity lists
    int sum = 0;
    DLIList<RefEntity*> **balancedLists = new DLIList<RefEntity*>*[nProcs];
    for (i = 0; i < nProcs; i++) {
      balancedLists[i] = new DLIList<RefEntity*>;
    nEntity = ref_entity_list.size();
    ref_entity_list.reset();
    for (i = 0; i < nEntity; i++) {
      RefEntity* entity = ref_entity_list.get_and_step();
      TDParallel *td_par = (TDParallel *) entity->get_TD(&TDParallel::is_parallel);
      if (td_par == NULL) {
    PRINT_ERROR("Partitioned entities should have TDParallel data.");
      unsigned int charge_p = td_par->get_charge_proc();
      if (charge_p != from_proc) { // only to compute processors
        balancedLists[charge_p]->append(entity); // add charge processor
      DLIList<int>* ghost_procs = td_par->get_ghost_proc_list();
      int n_ghost = ghost_procs->size();
      ghost_procs->reset();
      for (int j = 0; j < n_ghost; j++) { // add ghost processors
        unsigned int ghost_p = ghost_procs->get_and_step();
        if (ghost_p != from_proc) balancedLists[ghost_p]->append(entity);
    // add buffer size for each processors
      result = write_buffer(*(balancedLists[i]), m_pBuffer, sendCounts[i], false);
      sum += sendCounts[i];
    // check the size of the buffer and resize if necessary
    check_size(sum);
    // now append the real information
      append_to_buffer(*(balancedLists[i]), sendCounts[i]);
    delete [] balancedLists;
  // broadcast buffer size array
  printf("Broadcasting buffer size array from master.\n");
  MPI_Bcast(sendCounts, nProcs, MPI_INT, from_proc, MPI_COMM_WORLD);
  for ( i = 1; i < nProcs; i++) {
    displacements[i] = displacements[i-1] + sendCounts[i-1];
  mySendCount = sendCounts[procConfig.proc_rank()];
  if (procConfig.proc_rank() != from_proc) check_size(mySendCount);
  printf("Scattering buffer from master.\n");
  // scatter geometry
  MPI_Scatterv(m_pBuffer, sendCounts, displacements, MPI_BYTE, m_pBuffer,
           mySendCount, MPI_BYTE, from_proc, MPI_COMM_WORLD);
    result = read_buffer(ref_entity_list, m_pBuffer, mySendCount);
#endif
CubitStatus CGMParallelComm::write_buffer ( DLIList< RefEntity * > &  ref_entity_list,
char *  pBuffer,
int &  n_buffer_size,
Definition at line 209 of file CGMParallelComm.cpp.
#ifndef USE_MPI
#else
  if (ref_entity_list.size() == 0) {
    n_buffer_size = 0;
#ifdef HAVE_OCC
  CubitStatus result = GeometryQueryTool::instance()->export_solid_model(ref_entity_list, pBuffer,
                                     n_buffer_size, b_write_buffer);
  RRA("Failed to write ref entities to buffer.");
#endif
  if (b_write_buffer) m_currentPosition += n_buffer_size;
#endif
Member Data Documentation
Definition at line 75 of file CGMParallelComm.hpp.
Definition at line 87 of file CGMParallelComm.hpp.
Definition at line 85 of file CGMParallelComm.hpp.
char* CGMParallelComm::m_pBuffer [private]
Definition at line 83 of file CGMParallelComm.hpp.
std::vector<unsigned char> CGMParallelComm::myBuffer [private]
Definition at line 81 of file CGMParallelComm.hpp.
Definition at line 78 of file CGMParallelComm.hpp.
