cgma
ChollaCurve Member List
This is the complete list of members for ChollaCurve, including all inherited members.
add_facet(FacetEntity *exterior_edge)ChollaCurve [inline]
add_facet_unique(FacetEntity *exterior_edge)ChollaCurve [inline]
add_point(ChollaPoint *fpm_ptr)ChollaCurve [inline]
add_surface(ChollaSurface *fsm_ptr)ChollaCurve [inline]
adj_facet_edges(CubitPoint *cubit_pnt, CubitFacetEdge *&adj_edge1, CubitFacetEdge *&adj_edge2)ChollaCurve
assign_eval_tool(CurveFacetEvalTool *curv_eval_tool)ChollaCurve [inline]
assign_geometric_curve(void *curv)ChollaCurve [inline]
blockIDChollaCurve [private]
build_curve_facet_eval_tool(void)ChollaCurve
build_curve_from_edges(CubitPoint *start_point, int periodic, int max_edges, CubitFacetEdge *start_edge_ptr, ChollaCurve *parent_curve)ChollaCurve
ChollaCurve(int block_id)ChollaCurve
ChollaEntity()ChollaEntity
clean_out_edges()ChollaCurve [inline]
curveEdgeListChollaCurve [private]
debug_draw()ChollaCurve
determine_ends()ChollaCurve [private]
disassociate_from_points(void)ChollaCurve
disassociate_from_surfaces(void)ChollaCurve
endPointChollaCurve [private]
feature_angle(double min_dot)ChollaCurve
flagChollaCurve [private]
get_block_id()ChollaCurve [inline]
get_ends(CubitVector &start, CubitVector &end)ChollaCurve
get_ends(CubitPoint *&start_ptr, CubitPoint *&end_ptr)ChollaCurve
get_eval_tool()ChollaCurve [inline]
get_facet_list()ChollaCurve [inline]
get_facet_list_ptr()ChollaCurve [inline]
get_facet_points(DLIList< CubitPoint * > &point_list, CubitBoolean inclusive)ChollaCurve
get_flag()ChollaCurve [inline]
get_geometric_curve()ChollaCurve [inline]
get_id()ChollaCurve [inline]
get_points()ChollaCurve [inline]
get_surface_list_ptr()ChollaCurve [inline]
get_surfaces()ChollaCurve [inline]
get_surfaces(DLIList< ChollaSurface * > &surf_list)ChollaCurve [inline]
has_point(ChollaPoint *pt)ChollaCurve
idChollaCurve [private]
insert_facet(FacetEntity *old_edge, FacetEntity *new_edge)ChollaCurve
is_contain(FacetEntity *edge)ChollaCurve
is_in_surface(ChollaSurface *chsurf_ptr)ChollaCurve
is_in_volume(ChollaVolume *chvol_ptr)ChollaCurve
length()ChollaCurve
merge_partner()ChollaCurve [inline]
myCurveChollaCurve [private]
myEvalToolChollaCurve [private]
myLengthChollaCurve [private]
myMergePartnerChollaCurve [private]
next_edge(CubitPoint *node_ptr, CubitFacetEdge *edge_ptr)ChollaCurve [private]
num_edges()ChollaCurve [inline]
num_volumes()ChollaCurve
order_edges()ChollaCurve
pointListChollaCurve [private]
print()ChollaCurve
remove_facet(FacetEntity *facet_edge)ChollaCurve [inline]
remove_point(ChollaPoint *fpm_ptr)ChollaCurve [inline]
remove_surface(ChollaSurface *fsm_ptr)ChollaCurve [inline]
remove_td_associativity(ChollaSurface *fsm_ptr)ChollaCurve
replace_facet(FacetEntity *remove_edge, FacetEntity *replace_edge)ChollaCurve
set_end(CubitPoint *end_pt)ChollaCurve [inline]
set_flag(int flg)ChollaCurve [inline]
set_merge_partner(ChollaCurve *merge_partner)ChollaCurve [inline]
set_start(CubitPoint *start_pt)ChollaCurve [inline]
split_curve(DLIList< ChollaCurve * > &facet_curve_list)ChollaCurve
startPointChollaCurve [private]
surfaceListChollaCurve [private]
verify_points()ChollaCurve
~ChollaCurve()ChollaCurve
~ChollaEntity()ChollaEntity [virtual]
