cgma
ChollaMesh Member List
This is the complete list of members for ChollaMesh, including all inherited members.
ChollaMesh()ChollaMesh
convert_from_facet(FacetEntity *f)ChollaMesh
convert_from_point(CubitPoint *p)ChollaMesh
convert_to_facet(SMD::SMDElement elem)ChollaMesh
convert_to_point(SMD::SMDNode node)ChollaMesh
create_elements(SMD::ElementType type, unsigned int num_nodes, const SMD::SMDNode node_handle_array[], unsigned int num_elements, unsigned int num_nodes_per_element, const unsigned int connectivity[], SMD::SMeshOwner new_entities_owner, SMD::SMDElement *created_element_handles)ChollaMesh
create_nodes(unsigned int num_nodes, const SMD::Real coords[][3], SMD::SMeshOwner owner, SMD::SMDNode node_handles[])ChollaMesh
create_nodes(unsigned int num_nodes, const SMD::Real *coords, SMD::SMeshOwner owner, SMD::SMDNode node_handles[])ChollaMesh [inline]
delete_element(SMD::SMDElement element)ChollaMesh
delete_node(SMD::SMDNode node)ChollaMesh
find_element(SMD::ElementType type, unsigned int num_pts, const SMD::SMDNode nodes[], SMD::SMDElement &found_element)ChollaMesh
get_connectivity(int num_elems, const SMD::SMDElement elements[], int &node_array_size, SMD::SMDNode node_handles[])ChollaMesh
get_coords(int num_nodes, const SMD::SMDNode node_handle_array[], float coords[][3])ChollaMesh
get_coords(int num_nodes, const SMD::SMDNode node_handle_array[], double coords[][3])ChollaMesh
get_coords(int num_nodes, const SMD::SMDNode node_handle_array[], SMD::Real x_coords[], SMD::Real y_coords[], SMD::Real z_coords[])ChollaMesh
get_element_area(SMD::SMDElement elem_handle, double &area)ChollaMesh
get_element_centroid(SMD::SMDElement elem_handle, double centroid[3])ChollaMesh
get_element_dimensions(int num_elems, const SMD::SMDElement elem_handle_array[], int dimensions[])ChollaMesh
get_element_handle(SMD::ElementType type, int id, SMD::SMDElement &elem)ChollaMesh
get_element_length(SMD::SMDElement elem_handle, double &length)ChollaMesh
get_element_normal(SMD::SMDElement elem_handle, double normal_vector[3])ChollaMesh
get_element_types(int num_elems, const SMD::SMDElement elem_handle_array[], SMD::ElementType type_array[], bool *same_type)ChollaMesh
get_expanded_connectivity(int num_elems, const SMD::SMDElement elements[], unsigned int nodes_per_elem, int node_array_size, SMD::SMDNode node_handles[])ChollaMesh
get_expanded_connectivity(SMD::SMDElement elements, unsigned int &nodes_per_elem, int node_array_size, SMD::SMDNode node_handles[])ChollaMesh
get_ids(size_t num, const SMD::SMDNode nodes[], int ids[])ChollaMesh
get_ids(size_t num, const SMD::SMDElement elems[], int ids[])ChollaMesh
get_node_handle(int id, SMD::SMDNode &node)ChollaMesh
reverse_element_connectivity(SMD::SMDElement element)ChollaMesh
~ChollaMesh()ChollaMesh
