cgma
ChollaSurface Member List
This is the complete list of members for ChollaSurface, including all inherited members.
add_curve(ChollaCurve *bcm_ptr)ChollaSurface [inline]
add_curve_unique(ChollaCurve *bcm_ptr)ChollaSurface [inline]
add_facet(FacetEntity *exterior_face)ChollaSurface [inline]
add_mesh_unique(FacetEntity *exterior_face)ChollaSurface [inline]
add_preexisting_feature_edges(DLIList< CubitFacetEdge * > &feature_edge_list)ChollaSurface
add_volume(ChollaVolume *cholla_vol_ptr)ChollaSurface [inline]
add_volume_unique(ChollaVolume *cholla_vol_ptr)ChollaSurface [inline]
assign_eval_tool(FacetEvalTool *eval_tool_ptr)ChollaSurface [inline]
assign_geometric_surface(void *surf)ChollaSurface [inline]
blockIdChollaSurface [private]
check_faceting()ChollaSurface [private]
ChollaEntity()ChollaEntity
ChollaSurface(int block_id)ChollaSurface
clean_features()ChollaSurface
curveListChollaSurface [private]
debug_draw()ChollaSurface
feature_angle(double min_dot, DLIList< CubitFacetEdge * > &feature_edge_list)ChollaSurface
flip_facets()ChollaSurface
get_adj_facets(FacetEntity *start_face_ptr, DLIList< FacetEntity * > &face_list, int mydebug=0, bool bound_check=false, bool feature_edge_check=true)ChollaSurface
get_block_id()ChollaSurface [inline]
get_curves(DLIList< ChollaCurve * > &bcm_list)ChollaSurface [inline]
get_eval_tool()ChollaSurface [inline]
get_facet_list()ChollaSurface [inline]
get_facet_list_ptr()ChollaSurface [inline]
get_facets(DLIList< FacetEntity * > &surface_facets)ChollaSurface [inline]
get_flag()ChollaSurface [inline]
get_geometric_surface()ChollaSurface [inline]
get_id()ChollaSurface [inline]
get_loop_edges()ChollaSurface
get_points(DLIList< CubitPoint * > &point_list)ChollaSurface
get_vertices(DLIList< ChollaPoint * > &chpt_list)ChollaSurface
get_volumes(DLIList< ChollaVolume * > &cholla_vol_list)ChollaSurface [inline]
idChollaSurface [private]
init_hit_flags()ChollaSurface
is_adjacent(ChollaSurface *other_surf)ChollaSurface
is_contain(FacetEntity *facet)ChollaSurface
is_in_volume(ChollaVolume *chvol_ptr)ChollaSurface
merge_partner()ChollaSurface [inline]
myEvalToolChollaSurface [private]
myFlagChollaSurface [private]
myMergePartnerChollaSurface [private]
mySurfaceChollaSurface [private]
non_manifold_edges(DLIList< CubitFacetEdge * > &feature_edge_list)ChollaSurface
num_volumes()ChollaSurface [inline]
remove_curve(ChollaCurve *bcm_ptr)ChollaSurface [inline]
remove_facet(FacetEntity *facet)ChollaSurface [inline]
remove_volume(ChollaVolume *cholla_vol_ptr)ChollaSurface [inline]
reset_facet_flags()ChollaSurface
set_block_id(int flag)ChollaSurface [inline]
set_flag(CubitBoolean stat)ChollaSurface [inline]
set_merge_partner(ChollaSurface *merge_partner)ChollaSurface [inline]
split_surface(DLIList< ChollaSurface * > &block_surface_list)ChollaSurface
surfaceElemListChollaSurface [private]
update_boundary_tool_data()ChollaSurface
volListChollaSurface [private]
~ChollaEntity()ChollaEntity [virtual]
~ChollaSurface()ChollaSurface
