cgma
CollapseAngleTool Class Reference
#include <CollapseAngleTool.hpp>
List of all members.
Public Member Functions
CubitStatus auto_collapse (double length, double angle, CubitBoolean preview, CubitBoolean if_comp_vertex, double max_angle)
void collapse_one_angle (RefVertex *vex_ptr, RefEdge *edge_to_remove, RefEdge *the_other_edge, double length1, double length2, CubitBoolean get_position, CubitVector &position, CubitBoolean preview, CubitBoolean if_comp_vertex, double angle)
Static Public Member Functions
static CollapseAngleToolinstance ()
Private Member Functions
 CollapseAngleTool ()
 ~CollapseAngleTool ()
CubitStatus partition_curve (RefEdge *&edge, RefVertex *root_vertex, CubitVector &position, RefVertex *&new_vertex)
CubitBoolean if_partition_surf (RefVertex *vex_ptr, RefEdge *edge_to_remove, RefFace *common_face)
CubitStatus partition_curve (RefEdge *&edge, RefVertex *root_vertex, double arc_length, RefVertex *&new_vertex)
CubitStatus partition_surface (RefFace *common_face, RefEdge *&edge, RefVertex *root, RefVertex *vertex1, RefVertex *veretx2, RefFace *&result_face)
CubitStatus collapse_angle (RefVertex *vex_ptr, RefEdge *edge_to_remove, RefEdge *the_other_edge, double length1, double length2, CubitBoolean get_position, CubitVector &position)
CubitStatus draw_preview (RefVertex *vex_ptr, RefEdge *edge_to_remove, RefEdge *the_other_edge, double length1, double length2, CubitBoolean get_position, CubitVector &position)
void exchange_edges (RefEdge *&edge, RefEdge *&the_other_edge)
double the_surface_angle (RefEdge *edge, RefVertex *root_vertex, double length)
CubitStatus position_from_length (RefEdge *edge, RefVertex *root_vertex, double arc_length, CubitVector &v_new)
Private Attributes
DLIList< RefEdge * > partly_drawn_curve
Static Private Attributes
static CollapseAngleToolinstance_ = NULL
Detailed Description
Definition at line 19 of file CollapseAngleTool.hpp.
Definition at line 353 of file CollapseAngleTool.cpp.
Definition at line 357 of file CollapseAngleTool.cpp.
Member Function Documentation
CubitStatus CollapseAngleTool::auto_collapse ( double  length,
double  angle,
double  max_angle
Definition at line 133 of file CollapseAngleTool.cpp.
    //clear out the partly_drawn_curve list
    partly_drawn_curve.clean_out();
    //finding all angles less than 'angle'
    DLIList<RefEntity*> entity_list;
    DLIList<RefVolume*> volume_list;
    RefVolume * ref_volume;
    DLIList <RefEdge *> large_edge_angles_list;
    DLIList <RefEdge *> small_edge_angles_list;
    DLIList <double> large_angles_list;
    DLIList <double> small_angles_list;
    int total_interior;
    int total_fuzzy;
    CubitStatus  result = CUBIT_SUCCESS;
    // get an instance of GeometryQueryTool
    GeometryQueryTool *gqt = GeometryQueryTool::instance();
    volume_list.clean_out();
    result = gqt->ref_entity_list("volume", entity_list);
    if (result == CUBIT_FAILURE || entity_list.size() < 1)
      PRINT_ERROR("This command is prepared for volume mesh only.\n"
                  "The angles must reside on volumes.\n");
      return result;
    CAST_LIST(entity_list, volume_list, RefVolume);
    int i;
    small_edge_angles_list.clean_out();
    for (i=0; i < volume_list.size(); i++)
       ref_volume = volume_list.get_and_step();
       assert (ref_volume != NULL);
       GeomMeasureTool::find_interior_curve_angles(ref_volume,
                                                   360,
                                                   angle,
                                                   large_edge_angles_list,
                                                   small_edge_angles_list,
                                                   large_angles_list,
                                                   small_angles_list,
                                                   total_interior,
                                                   total_fuzzy);
    //collapse small angles, use perpendicular to the second curve.
    int size = small_edge_angles_list.size();
    int init_size = size+1;
    int index = 0;
    RefVertex *vex_ptr = NULL;
    RefEdge   *edge_to_remove = NULL;
    RefEdge   *the_other_edge = NULL;
    double    length1 = -1.0, length2 = -1.0;
    CubitVector  position;
    CubitBoolean if_step_over = CUBIT_FALSE;
    while (size != 0)
       if (init_size <= size)
          break;
       init_size = size;
       small_edge_angles_list.reset();
       assert (size%2 == 0);
       double angle1, angle2;
       if (CUBIT_TRUE == preview || CUBIT_TRUE == if_step_over)
          for (i=0; i<index; i++)
            small_edge_angles_list.step();
       //find the vertex for each edge pair.
       edge_to_remove = small_edge_angles_list.get_and_step();
       the_other_edge = small_edge_angles_list.get_and_step();
       index += 2;
       assert (edge_to_remove != NULL && the_other_edge != NULL);
       vex_ptr = edge_to_remove->common_ref_vertex(the_other_edge);
       if (vex_ptr == NULL)
          size -= 2;
          if_step_over = CUBIT_TRUE;
          continue;
       //check to make sure there's one common refface between the edges.
       if(edge_to_remove->num_of_common_ref_face(the_other_edge) != 1)
          PRINT_INFO("Curves %d and %d are not candidates for collapsing because\n",
                     edge_to_remove->id(), the_other_edge->id());
          PRINT_INFO("the two curves need to have exactly one common face.\n");
          size -= 2;
          continue;
       //find the true to_be_removed edge
       angle1 = the_surface_angle(edge_to_remove, vex_ptr, length);
       angle2 = the_surface_angle(the_other_edge, vex_ptr, length);
       if (angle1 != -1.0 && angle2 != -1.0 &&
          (fabs(angle1 - CUBIT_PI) > fabs(angle2 - CUBIT_PI)))
          exchange_edges(edge_to_remove, the_other_edge);
       else if (angle1 == -1.0 || angle2 == -1.0 ||
               (fabs(angle1 - CUBIT_PI) == fabs(angle2 - CUBIT_PI)))
          //curved curve has higher priority than straight curve.
          if ((edge_to_remove->geometry_type() == STRAIGHT_CURVE_TYPE)
              &&(the_other_edge->geometry_type() != STRAIGHT_CURVE_TYPE))
          //shorter curve has higher priority than longer curve.
          else if (((edge_to_remove->geometry_type() != STRAIGHT_CURVE_TYPE)
             &&(the_other_edge->geometry_type() != STRAIGHT_CURVE_TYPE)) ||
              &&(the_other_edge->geometry_type() == STRAIGHT_CURVE_TYPE)))
             if (edge_to_remove->get_arc_length() >
                the_other_edge->get_arc_length())
       }//else if
       // determine the length1
       if (length >= (edge_to_remove->get_arc_length() - GEOMETRY_RESABS))
          length1 = -1.0;
       else
          length1 = length;
       //determine the position on curve2
       RefVertex * tmp_vertex = edge_to_remove->other_vertex(vex_ptr);
       CubitVector tmp_vec = tmp_vertex->coordinates();
       if (length1 != -1.0)
         result = position_from_length(edge_to_remove, vex_ptr, length1, tmp_vec);
       the_other_edge->closest_point(tmp_vec, position);
       //check if position is within the_other_edge
       CubitBox position_box(position);
       CubitBox edge_box = the_other_edge->bounding_box();
       // check if it's a preview command.
       if (CUBIT_TRUE == preview)
          if (!position_box.overlap(0, edge_box))
             draw_preview(vex_ptr, edge_to_remove, the_other_edge,
                          length1, -1.0, CUBIT_FALSE, position);
          else
                          length1, -1.0, CUBIT_TRUE, position);
          size -= 2;
          continue;
       //collapse angle
       else if (!position_box.overlap(0, edge_box))
          result = collapse_angle( vex_ptr, edge_to_remove, the_other_edge,
       else
                                   length1, length2, CUBIT_TRUE, position);
       if (result != CUBIT_SUCCESS)
          continue ;
       if (if_comp_vertex)
          DLIList<RefEdge*> edge_list;
          vex_ptr->ref_edges(edge_list);
          int id = vex_ptr->id();
          if (edge_list.size() == 2)
             DLIList<RefEdge*> composite_edges;
             max_angle *= (CUBIT_PI / 180);
             CompositeTool::instance()->composite(edge_list, composite_edges,
                                                  NULL, max_angle);
             if (composite_edges.size() > 0)
                DLIList<int> id_list;
                id_list.append(id);
                CubitUtil::list_entity_ids("Composite out of vertex ", id_list);
                                                      360,
                                                      angle,
                                                      large_angles_list,
                                                      small_angles_list,
                                                      total_interior,
                                                      total_fuzzy);
   }//while
   return result;
CubitStatus CollapseAngleTool::collapse_angle ( RefVertex vex_ptr,
RefEdge edge_to_remove,
RefEdge the_other_edge,
double  length1,
double  length2,
) [private]
Definition at line 681 of file CollapseAngleTool.cpp.
  RefVertex *new_vertex1 = edge_to_remove->other_vertex(vex_ptr);
  RefVertex *new_vertex2 = the_other_edge->other_vertex(vex_ptr);
  DLIList<RefFace*> ref_faces;
  edge_to_remove-> ref_faces(ref_faces);
  RefFace *common_face = NULL;
  DLIList<RefFace*> common_face_list;
  int nfaces = edge_to_remove->num_of_common_ref_face(the_other_edge);
  if (nfaces == 1)
    common_face = edge_to_remove->common_ref_face(the_other_edge);
  else
    assert (nfaces == 2);
    edge_to_remove->common_ref_faces(the_other_edge, common_face_list);
    result = partition_curve(edge_to_remove, vex_ptr, length1, new_vertex1);
       PRINT_ERROR("Operation failed at vertex %d, curve %d and curve %d.\n",
                vex_ptr->id(), edge_to_remove->id(), the_other_edge->id());
       return result;
  if (get_position)
    result = partition_curve(the_other_edge, NULL, position, new_vertex2);
       return result;
  else if (!get_position && length2 != -1.0)
    result = partition_curve(the_other_edge, vex_ptr, length2, new_vertex2);
       return result;
  if (nfaces > 1) //determine the common face.
     CubitBox edge_box(new_vertex1->coordinates());
     edge_box |= new_vertex2->bounding_box();
     CubitBox face_box1, face_box2;
     RefFace *face1, *face2;
     face1 = common_face_list.get_and_step();
     face2 = common_face_list.get();
     face_box1 = face1->bounding_box();
     face_box2 = face2->bounding_box();
     if(edge_box.overlap(0, face_box1))
       // Face 1 overlaps with the partition points.
       if(edge_box.overlap(0, face_box2))
         // Both face 1 and face 2 overlap with the parition points.
         // We must do a further check to try to choose the best one.
         // Take the mid point between the two vertices and calculate
         // the distance from both faces.  Choose the one with the
         // smaller distance.  This approach was chosen because there
         // was a case where one of the potential common faces was
         // actually a composite that had a 90 degree turn in it
         // so that the end points of the edge that would be used
         // to partition it fell on the composite surface but the
         // rest of the interior of the edge didn't lie on the surface.
         // However, the edge completely lied on the other potential
         // surface and so it was the better candidate.
         CubitVector mid_pos = (new_vertex1->coordinates() +
                new_vertex2->coordinates())/2;
         Surface *surf1 = face1->get_surface_ptr();
         Surface *surf2 = face2->get_surface_ptr();
         if(surf1 && surf2)
           CubitVector pos1, pos2;
           surf1->closest_point(mid_pos, &pos1);
           surf2->closest_point(mid_pos, &pos2);
           if((mid_pos - pos1).length_squared() <
             (mid_pos - pos2).length_squared())
             common_face = face1;
           else
             common_face = face2;
         else
            PRINT_ERROR("Operation failed because one of the potential common faces doesn't have a surface.\n");
            return CUBIT_FAILURE;
       else
         // Only face 1 overlaps so use it as the common face.
     else if(edge_box.overlap(0, face_box2))
       // Only face 2 overlaps so use it as the common face.
     else
       // Neither face overlaps so throw an error.
       PRINT_ERROR("Operation failed to find a valid common face for partitioning.\n");
  CubitBoolean partition_surface_ = CUBIT_FALSE;
  // check if edge_to_remove is the only one that shares the two surfaces.
  if (length1 == -1.0)
     partition_surface_ = if_partition_surf(vex_ptr, edge_to_remove,
                                            common_face);
  RefFace * face_to_remove = common_face;
  if (length1 != -1.0 || get_position || length2 != -1.0 || partition_surface_)
     RefFace *result_face;
     result = partition_surface(common_face, edge_to_remove, vex_ptr,
                                new_vertex1, new_vertex2, result_face);
       PRINT_ERROR("Split of surface %d failed.\n", common_face->id());
       return result;
     DLIList<RefEdge*> ref_edges;
     result_face->ref_edges(ref_edges);
     int i;
     for (i = 0; i <ref_edges.size(); i++)
        if (ref_edges.get_and_step() == edge_to_remove)
           face_to_remove = result_face;
           break;
  if (face_to_remove != common_face)
    ref_faces.remove(common_face);
    ref_faces.append(face_to_remove);
  DLIList<RefFace*> result_faces;
  CompositeTool::instance()->composite(ref_faces, result_faces);
  if( result_faces.size() > 0 )
     int e;
     for(  e = 0; e < result_faces.size(); e++)
        id_list.append( result_faces.get_and_step()->id() );
        CubitUtil::list_entity_ids("Created composite surfaces ", id_list );
  else
     result = CUBIT_FAILURE;
  //composite out new_vertex1
  RefEdge* composite_edge = NULL;
  int id = new_vertex1->id();
  new_vertex1->ref_edges(edge_list);
    composite_edge = CompositeTool::instance()->composite(edge_list);
  if (composite_edge)
     id_list.append(id);
  return result;
void CollapseAngleTool::collapse_one_angle ( RefVertex vex_ptr,
double  length1,
double  length2,
CubitVector position,
double  angle
Definition at line 47 of file CollapseAngleTool.cpp.
       draw_preview(vex_ptr, edge_to_remove, the_other_edge, length1,
                    length2, get_position, position);
    else
      edge_to_remove->ref_faces(ref_faces);
      if( nfaces == 0 )
        return;
      if (nfaces == 1)
      else
      if(common_face)
        common_face_list.append_unique( common_face );
      bool undo_on = false;
      DLIList<Body*> bodies_to_note;
      if( CubitUndo::get_undo_enabled() )
        for( int k=0; k<common_face_list.size(); k++ )
          bodies_to_note.append_unique( common_face_list[k]->body() );
        CubitUndo::save_state_with_cubit_file( bodies_to_note );
        undo_on = true;
        CubitUndo::set_undo_enabled( false );
       CubitStatus status = collapse_angle( vex_ptr, edge_to_remove, the_other_edge,
                       length1, length2, get_position, position);
       if( CUBIT_FAILURE == status && undo_on )
         CubitUndo::set_undo_enabled( true );
         CubitUndo::remove_last_undo();
         return;
       if (if_comp_vertex)
                                                  NULL, angle);
                id_list.append(id);
       if( undo_on )
       if( CubitUndo::get_undo_enabled() && CUBIT_SUCCESS == result )
         CubitUndo::note_result_bodies( bodies_to_note );
       else if( CubitUndo::get_undo_enabled() && CUBIT_FAILURE == result )
CubitStatus CollapseAngleTool::draw_preview ( RefVertex vex_ptr,
double  length1,
double  length2,
) [private]
Definition at line 519 of file CollapseAngleTool.cpp.
   //flush out previous drawing
   GfxDebug::display_all();
   //wireframe display of future composite surface per design review.
   RefFace *common_face = edge_to_remove->common_ref_face(the_other_edge);
   assert(ref_faces.size() == 2);
   RefFace *highlight_surf = ref_faces.get_and_step();
   if (highlight_surf == common_face)
       highlight_surf = ref_faces.get();
   highlight_surf->ref_edges(ref_edges);
   ref_edges.remove(edge_to_remove);
   int i;
   for (i = 0; i < partly_drawn_curve.size(); i++)
      ref_edges.remove(partly_drawn_curve.get_and_step());
   for(i = 0; i < ref_edges.size(); i++)
      GfxDebug::draw_ref_entity(ref_edges.get_and_step(), CUBIT_BLUE_INDEX);
   //check if there will be a cutting edge
   CubitBoolean if_partition = if_partition_surf(vex_ptr, edge_to_remove,
                                               common_face);
   if (length1 == -1.0 && !get_position && length2 == -1.0 && !if_partition)
      ref_edges.clean_out();
      common_face->ref_edges(ref_edges);
      return result;
   CubitVector location, location2, location3;
       location = edge_to_remove->other_vertex(vex_ptr)->coordinates();
                                       length1, location);
   if ( !get_position && length2 == -1.0 &&
        (length1 != -1.0 ||
         (length1 == -1.0 && if_partition)))
      location2=the_other_edge->other_vertex(vex_ptr)->coordinates();
   else if(get_position)
      location2 = position;
   else if (length2 != -1.0)
      result = position_from_length(the_other_edge, vex_ptr, length2, location2);
   GfxDebug::draw_line(location, location2, CUBIT_BLUE_INDEX);
   //Draw part of curves
   double length;
   CubitVector temp_vex;
   GPoint pts[5];
   location3 = vex_ptr->coordinates();
   partly_drawn_curve.append(the_other_edge);
   partly_drawn_curve.append(edge_to_remove);
   if (the_other_edge->geometry_type() == STRAIGHT_CURVE_TYPE)
      GfxDebug::draw_line(location3, location2, CUBIT_BLUE_INDEX);
   else
      length = the_other_edge->get_arc_length(location2, location3);
      pts[0].x = location3.x();
      pts[0].y = location3.y();
      pts[0].z = location3.z();
      pts[4].x = location2.x();
      pts[4].y = location2.y();
      pts[4].z = location2.z();
      position_from_length(the_other_edge, vex_ptr, length/4, temp_vex);
      pts[1].x = temp_vex.x();
      pts[1].y = temp_vex.y();
      pts[1].z = temp_vex.z();
      position_from_length(the_other_edge, vex_ptr, length/2, temp_vex);
      pts[2].x = temp_vex.x();
      pts[2].y = temp_vex.y();
      pts[2].z = temp_vex.z();
      position_from_length(the_other_edge, vex_ptr, length*0.75, temp_vex);
      pts[3].x = temp_vex.x();
      pts[3].y = temp_vex.y();
      pts[3].z = temp_vex.z();
      GfxDebug::draw_polyline(pts, 5, CUBIT_BLUE_INDEX);
   RefVertex *vertex = edge_to_remove->other_vertex(vex_ptr);
   location3 = vertex->coordinates();
   if (edge_to_remove->geometry_type() == STRAIGHT_CURVE_TYPE)
      GfxDebug::draw_line(location3, location, CUBIT_BLUE_INDEX);
   else
      length = edge_to_remove->get_arc_length(location, location3);
      pts[4].x = location.x();
      pts[4].y = location.y();
      pts[4].z = location.z();
      position_from_length(edge_to_remove, vertex, length/4, temp_vex);
      position_from_length(edge_to_remove, vertex, length/2, temp_vex);
      position_from_length(edge_to_remove, vertex, length*0.75, temp_vex);
   GfxDebug::flush();
   return result;
void CollapseAngleTool::exchange_edges ( RefEdge *&  edge,
RefEdge *&  the_other_edge
) [private]
Definition at line 361 of file CollapseAngleTool.cpp.
   RefEdge* temp_edge;
   temp_edge = edge;
   edge = the_other_edge;
   the_other_edge = temp_edge;
CubitBoolean CollapseAngleTool::if_partition_surf ( RefVertex vex_ptr,
RefFace common_face
) [private]
Definition at line 661 of file CollapseAngleTool.cpp.
   CubitBoolean partition_surface_ =CUBIT_FALSE;
   RefVertex *temp_vtx = NULL;
   RefEdge * temp_edge = NULL;
   if (edge_to_remove->start_vertex() == vex_ptr)
       temp_vtx = edge_to_remove->end_vertex();
   else
       temp_vtx = edge_to_remove->start_vertex();
   temp_edge = edge_to_remove->get_other_curve(temp_vtx, common_face);
   if (temp_edge->num_of_common_ref_face(edge_to_remove) > 1)
       partition_surface_ = CUBIT_TRUE;
   return partition_surface_;
Definition at line 40 of file CollapseAngleTool.cpp.
  if (instance_ == NULL) instance_ = new CollapseAngleTool();
  return instance_;
CubitStatus CollapseAngleTool::partition_curve ( RefEdge *&  edge,
RefVertex root_vertex,
RefVertex *&  new_vertex
) [private]
Definition at line 423 of file CollapseAngleTool.cpp.
   DLIList<CubitVector*> vect_list;
   vect_list.append(  new CubitVector( position ) );
   DLIList<RefVertex*> vertex_list;
   RefVertex* the_vertex = NULL;
   edge->ref_vertices(vertex_list);
   if (vertex_list.size() == 1)
     the_vertex = vertex_list.get();
   DLIList<RefEdge*> tmp_list;
   result = PartitionTool::instance()->
          partition( edge, vect_list, tmp_list );
   delete vect_list.pop();
   if (!result)
      PRINT_ERROR("Split of curve %d failed.\n", edge->id());
      return result;
//Only change new_vertex when the partition succeeds.
   RefEdge *temp_edge = tmp_list.get_and_step();
   if (NULL != the_vertex)
     new_vertex = temp_edge->other_vertex(the_vertex);
     double len1 = temp_edge->get_arc_length();
     double len2 = tmp_list.get()->get_arc_length();
     if (len1 > len2)
       edge =  tmp_list.get();
     else
       edge = temp_edge;
   else if (temp_edge != edge)
     new_vertex = edge->common_ref_vertex(temp_edge);
     if (root_vertex && edge->start_vertex() != root_vertex &&
         edge->end_vertex() != root_vertex)
       edge = temp_edge;
   else
     new_vertex = edge->common_ref_vertex(tmp_list.get());
   return result;
double  arc_length,
) [private]
Definition at line 408 of file CollapseAngleTool.cpp.
   CubitVector v_new;
   result = position_from_length(edge, root_vertex, arc_length, v_new);
   if (result == CUBIT_SUCCESS)
      result = partition_curve(edge, root_vertex, v_new, new_vertex);
   return result;
CubitStatus CollapseAngleTool::partition_surface ( RefFace common_face,
RefEdge *&  edge,
RefVertex root,
RefVertex vertex1,
RefVertex veretx2,
RefFace *&  result_face
) [private]
Definition at line 476 of file CollapseAngleTool.cpp.
   DLIList<CubitVector*> positions;
   positions.append(new CubitVector(vertex1->get_point_ptr()->coordinates()));
   positions.append(new CubitVector(vertex2->get_point_ptr()->coordinates()));
   DLIList<RefEdge*> new_edges;
   result_face = PartitionTool::instance()->
      insert_edge( common_face, positions, CUBIT_FALSE, new_edges );
   // make sure that we actually get something out of insert_edge
   if (new_edges.size() == 0)
     if (positions[0])
       delete positions[0];
     if (positions[1])
       delete positions[1];
   RefEdge *new_edge = new_edges.get();
   if(new_edge)
     RefVertex * start = new_edge->start_vertex();
     RefVertex * end = new_edge->end_vertex();
     if (start != vertex1 && end != vertex1)
       edge_to_remove = root->common_ref_edge(start == vertex2 ? end : start);
   delete positions.get_and_step();
   delete positions.get();
   if( result_face == NULL )
   return result;
CubitStatus CollapseAngleTool::position_from_length ( RefEdge edge,
double  arc_length,
CubitVector v_new
) [private]
Definition at line 393 of file CollapseAngleTool.cpp.
   CubitStatus result;
   double sense = 1.0;
   if (root_vertex != edge->start_vertex())
      sense = -1.0;
   CubitVector v_root = root_vertex->get_point_ptr()->coordinates();
   result = edge->point_from_arc_length(v_root, arc_length*sense, v_new);
   return result;
double CollapseAngleTool::the_surface_angle ( RefEdge edge,
double  length
) [private]
Definition at line 370 of file CollapseAngleTool.cpp.
   DLIList <RefFace *> ref_faces;
   double arc_length = length/2;
   double fraction;
   if (length > edge->get_arc_length())
     arc_length = edge->get_arc_length()/2;
   fraction = edge->fraction_from_arc_length(root_vertex, arc_length);
   edge->ref_faces(ref_faces);
   if (ref_faces.size() != 2)
      return -1.0;
   double angle =  GeometryQueryTool::instance()->
                 surface_angle(ref_faces.get_and_step(),ref_faces.get(),
                 edge, NULL, fraction);
   return angle;
Member Data Documentation
CollapseAngleTool * CollapseAngleTool::instance_ = NULL [static, private]
Definition at line 49 of file CollapseAngleTool.hpp.
