cgma
CompositeEngine Member List
This is the complete list of members for CompositeEngine, including all inherited members.
about_spatially_equal(Curve *curve_1, Curve *curve_2, CubitSense &relative_sense, double tolerance_factor, int layer=TopologyBridge::MAX_TB_LAYER)CompositeEngine
append_attrib(TopologyBridge *bridge, const CubitSimpleAttrib &attrib)CompositeEngine [protected, static]
attribute_after_imprinting(DLIList< TopologyBridge * > &tb_list, DLIList< Body * > &old_bodies)CompositeEngine [virtual]
clean_out_deactivated_geometry()CompositeEngine [virtual]
combine(CompositeCurve *curve1, CompositeCurve *curve2, CompositePoint *keep_point=0, bool remove_partitions=false)CompositeEngine [protected]
combine_bodies(BodySM *body1, BodySM *body2)CompositeEngine
composite(Curve *survivor, Curve *dead, TBPoint *keep_point=0, bool remove_partitions=false)CompositeEngine
CompositeEngine()CompositeEngine [private]
create_composites(DLIList< BodySM * > &)CompositeEngine [protected]
create_composites(DLIList< Surface * > &)CompositeEngine [protected]
create_composites(DLIList< Curve * > &)CompositeEngine [protected]
create_composites(DLIList< TBPoint * > &)CompositeEngine [protected]
deactivatedListCompositeEngine [private]
delete_instance()CompositeEngine [static]
destroy_point_curve(CompositeCurve *curve)CompositeEngine [protected]
export_geometry(DLIList< TopologyBridge * > &geometry_to_save)CompositeEngine [virtual]
find_attribute_by_name(TopologyBridge *bridge, const CubitString name)CompositeEngine [static]
find_coedges(CompositeSurface *surface, CompositeCurve *curve, CompositePoint *point, CompositeCoEdge *&previous, CompositeCoEdge *&next)CompositeEngine [protected, static]
find_next_point_coedge(CompositeSurface *const surface, CoEdgeSM *const coedge, CompositePoint *point, DLIList< CompositeCoEdge * > &point_coedges)CompositeEngine [protected, static]
get_all_curves_and_points(DLIList< TopologyBridge * > &tb_list, DLIList< Curve * > &curves, DLIList< TBPoint * > &points)CompositeEngine
get_tbs_with_bridge_manager_as_owner(TopologyBridge *source_bridge, DLIList< TopologyBridge * > &tbs)CompositeEngine [virtual]
import_geometry(DLIList< TopologyBridge * > &imported_geometry)CompositeEngine [virtual]
insert_curve(DLIList< Surface * > &surfaces, DLIList< CubitVector * > &polyline, DLIList< Surface * > &new_surfaces, DLIList< Curve * > &new_curves)CompositeEngine
insert_nonmanifold_surfaces(DLIList< CompositeSurface * > &surfs, CompositeShell *shell1, CompositeShell *shell2)CompositeEngine [protected]
insert_point(CompositeCurve *curve, double u)CompositeEngine
insert_point_curve(CompositeSurface *surface, const CubitVector &position)CompositeEngine
inside_shell(CompositeShell *const shell, CompositeSurface *const surf, bool &result)CompositeEngine [protected]
instance_CompositeEngine [protected, static]
is_composite(TBOwner *bridge_owner)CompositeEngine [virtual]
is_composite(TopologyBridge *bridge)CompositeEngine [virtual]
is_hidden(TopologyBridge *tb)CompositeEngine
is_partition(TBOwner *bridge_owner)CompositeEngine [virtual]
level() const CompositeEngine [inline, virtual]
notify_deactivated(CompositeBody *body)CompositeEngine
notify_deactivated(CompositeLump *volume)CompositeEngine
notify_deactivated(CompositeSurface *surface)CompositeEngine
notify_deactivated(CompositeCurve *curve)CompositeEngine
notify_deactivated(CompositePoint *point)CompositeEngine
notify_transform(TopologyBridge *bridge, const CubitTransformMatrix &xform)CompositeEngine [virtual]
process_curves_after_imprint(Curve *att_bridge, Curve *other_bridge, DLIList< BodySM * > &new_sms)CompositeEngine [private]
process_points_after_imprint(TBPoint *att_bridge, TBPoint *other_bridge, DLIList< BodySM * > &new_sms)CompositeEngine [private]
push_imprint_attributes_before_modify(DLIList< BodySM * > &body_sms)CompositeEngine [virtual]
push_named_attributes_to_curves_and_points(DLIList< TopologyBridge * > &tb_list, const char *name_in)CompositeEngine [virtual]
reflect(CompositeBody *body, const CubitVector &axis)CompositeEngine
reflect(CompositeSurface *surface, const CubitVector &axis)CompositeEngine
reflect(CompositeCurve *curve, const CubitVector &axis)CompositeEngine
remove_attributes(DLIList< TopologyBridge * > &bridge_list)CompositeEngine [virtual]
remove_attributes_from_unmodifed_virtual(DLIList< TopologyBridge * > &bridges)CompositeEngine [virtual]
remove_composite(CompositePoint *point)CompositeEngine [protected]
remove_composite(CompositeCurve *composite)CompositeEngine [protected]
remove_composite(CompositeSurface *composite)CompositeEngine [protected]
remove_composite(CompositeLump *composite)CompositeEngine [protected]
remove_composite(CompositeBody *composite)CompositeEngine [protected]
remove_curve(Curve *dead_curve, bool remove_partitions=false, Surface *survivor=0)CompositeEngine
remove_imprint_attributes_after_modify(DLIList< BodySM * > &old_sms, DLIList< BodySM * > &new_sms)CompositeEngine [virtual]
remove_modified(DLIList< Surface * > &all_surfs, DLIList< Curve * > &all_curves, DLIList< TBPoint * > &all_pts)CompositeEngine [virtual]
remove_partition_curves(CompositeCurve *curve_owner)CompositeEngine [protected]
remove_partition_point(CompositePoint *point_owner)CompositeEngine [protected]
remove_point(TBPoint *dead_point, bool remove_partitions=false, Curve *survivor=0)CompositeEngine
remove_surface(Surface *dead_surf, Surface *stitch_partner=0, bool remove_partitions=false)CompositeEngine
replace_body(BodySM *body)CompositeEngine
replace_curve(Curve *dead_curve)CompositeEngine
replace_lump(Lump *lump)CompositeEngine
replace_point(TBPoint *dead_point)CompositeEngine
replace_surface(Surface *surface)CompositeEngine
restore_curve(Curve *curve)CompositeEngine
restore_point(TBPoint *point)CompositeEngine
restore_point_in_curve(TBPoint *point)CompositeEngine
restore_point_in_surface(TBPoint *point)CompositeEngine
restore_surface(Surface *surface, Surface *&stitch_parnter)CompositeEngine
restore_transform(CompositeBody *body)CompositeEngine
rotate(CompositeBody *body, const CubitVector &axis, double degrees)CompositeEngine
rotate(CompositeSurface *surface, const CubitVector &axis, double degrees)CompositeEngine
rotate(CompositeCurve *curve, const CubitVector &axis, double degrees)CompositeEngine
save(CompositePoint *)CompositeEngine [protected]
save(CompositeCurve *)CompositeEngine [protected]
save(CompositeSurface *)CompositeEngine [protected]
save(CompositeLump *)CompositeEngine [protected]
save(CompositeBody *)CompositeEngine [protected]
scale(CompositeBody *body, const CubitVector &factors)CompositeEngine
scale(CompositeSurface *surface, const CubitVector &factors)CompositeEngine
scale(CompositeCurve *curve, const CubitVector &factors)CompositeEngine
split(CompositeCurve *curve, int after_index, Curve *&result1, Curve *&resutl2)CompositeEngine [protected]
split_body(CompositeBody *body_to_split, DLIList< BodySM * > &resulting_bodies)CompositeEngine
split_lump(CompositeShell *shell_to_split)CompositeEngine [private]
split_shell(CompositeShell *shell)CompositeEngine [protected]
split_surface(CompositeSurface *surf_to_split, CompositeLoop *loop_on_surf, CompositeLoop *new_loop)CompositeEngine [private]
stitch_curves(Curve *curve1, Curve *curve2)CompositeEngine
stitch_points(TBPoint *point1, TBPoint *point2)CompositeEngine
stitch_surfaces(Surface *surf, Surface *surf2)CompositeEngine
strip_attributes(TopologyBridge *bridge)CompositeEngine [static]
translate(CompositeBody *body, const CubitVector &delta)CompositeEngine
translate(CompositeSurface *surface, const CubitVector &delta)CompositeEngine
translate(CompositeCurve *curve, const CubitVector &delta)CompositeEngine
~CompositeEngine()CompositeEngine [virtual]
