cgma
CompositeSurface Member List
This is the complete list of members for CompositeSurface, including all inherited members.
add(CompositeLoop *loop)CompositeSurface
add(CompositeCoSurf *cosurf)CompositeSurface
append_simple_attribute_virt(const CubitSimpleAttrib &simple_attrib_ptr)CompositeSurface [virtual]
are_positions_on(DLIList< CubitVector * > &test_position_list, DLIList< CubitBoolean * > &is_on_list)Surface [virtual]
bodysm()TopologyBridge
bodysms(DLIList< BodySM * > &bodies, bool unique=true)TopologyBridge
bounding_box() const CompositeSurface [virtual]
bridge_destroyed(TopologyBridge *bridge)TBOwner [inline, virtual]
bridge_manager() const TopologyBridge
bridge_manager(BridgeManager *manager)TopologyBridge
bridge_sense()TopologyBridge [inline]
ChildType typedefSurface
closest_point(CubitVector const &location, CubitVector *closest_location=NULL, CubitVector *unit_normal=NULL, CubitVector *curvature1=NULL, CubitVector *curvature2=NULL)CompositeSurface [virtual]
closest_point_along_vector(CubitVector &from_point, CubitVector &along_vector, CubitVector &point_on_surface)CompositeSurface [virtual]
closest_point_trimmed(CubitVector from_point, CubitVector &result)CompositeSurface [virtual]
closest_point_uv_guess(CubitVector const &location, double &u, double &v, CubitVector *closest_location=NULL, CubitVector *unit_normal=NULL)CompositeSurface [virtual]
closest_points(DLIList< CubitVector * > &location_list, DLIList< CubitVector * > *closest_location_list=NULL, DLIList< CubitVector * > *unit_normal_list=NULL, DLIList< CubitVector * > *curvature1_list=NULL, DLIList< CubitVector * > *curvature2_list=NULL)Surface [virtual]
closest_points_trimmed(std::vector< CubitVector > &from_points_list, std::vector< CubitVector > &points_on_surface_list)Surface [virtual]
closest_trimmed(int underlying_surface, const CubitVector &position, CubitVector &result)CompositeSurface [protected]
closest_underlying_surface(const CubitVector &position)CompositeSurface
coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true)TopologyBridge
combine(CompositeSurface *dead_surface)CompositeSurface
compGeomCompositeSurface [private]
CompositeEngine classCompositeSurface [friend]
CompositeSurface(Surface *surf_ptr)CompositeSurface
CompositeSurface(CompositeGeom *geom_ptr)CompositeSurface
CompositeSurface(const CompositeSurface &)CompositeSurface [private]
contains_bridge(TopologyBridge *bridge) const CompositeSurface [virtual]
curves(DLIList< Curve * > &curves, bool unique=true)TopologyBridge
curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true)TopologyBridge
evaluate(double u, double v, CubitVector *position, CubitVector *normal, CubitVector *curvature1, CubitVector *curvature2)CompositeSurface [virtual]
Surface::evaluate(double u, double v, CubitVector &pos, CubitVector deriv1[2], CubitVector deriv2[3])Surface [virtual]
facetToolCompositeSurface [private]
find_first(CompositeShell *shell) const CompositeSurface
find_first(CompositeLump *lump) const CompositeSurface
find_next(CompositeCoSurf *cosurf) const CompositeSurface
first_loop() const CompositeSurface [inline]
firstCoSurfCompositeSurface [private]
firstLoopCompositeSurface [private]
geometry_type()CompositeSurface [virtual]
GeometryEntity()GeometryEntity [inline]
get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER)TopologyBridge
get_children_virt(DLIList< TopologyBridge * > &children)CompositeSurface [virtual]
get_cone_params(CubitVector &center, CubitVector &normal, CubitVector &major_axis, double &radius_ratio, double &sine_angle, double &cos_angle) const CompositeSurface [virtual]
get_curves(DLIList< CompositeCurve * > &curves)CompositeSurface
get_geometry_query_engine() const CompositeSurface [virtual]
get_geometry_sense()CompositeSurface [virtual]
get_graphics(GMem &gmem)CompositeSurface
get_hidden_curves(DLIList< Curve * > &curves)CompositeSurface
get_ignored_surfs(DLIList< Surface * > &surfs)CompositeSurface
get_nurb_params(bool &rational, int &degree_u, int &degree_v, int &num_cntrl_pts_u, int &num_cntrl_pts_v, DLIList< CubitVector > &cntrl_pts, DLIList< double > &weights, DLIList< double > &u_knots, DLIList< double > &v_knots) const CompositeSurface [virtual]
get_param_range_U(double &lower, double &upper)CompositeSurface [virtual]
get_param_range_V(double &lower, double &upper)CompositeSurface [virtual]
get_parents(DLIList< TopologyBridge * > &parents)TopologyBridge
get_parents_virt(DLIList< TopologyBridge * > &parents)CompositeSurface [virtual]
get_point_normal(CubitVector &origin, CubitVector &normal)CompositeSurface [virtual]
get_projected_distance_on_surface(CubitVector *pos1, CubitVector *pos2, double &distance)CompositeSurface [virtual]
get_saved_id() const GeometryEntity [inline]
get_saved_names(std::vector< CubitString > &names)GeometryEntity
get_sense(int index) const CompositeSurface [inline]
get_shell_sense(ShellSM *shell_ptr) const CompositeSurface [virtual]
get_simple_attribute(DLIList< CubitSimpleAttrib > &attrib_list)CompositeSurface [virtual]
get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &attrib_list)CompositeSurface [virtual]
get_sphere_params(CubitVector &center, double &radius) const CompositeSurface [virtual]
get_stitch_partner() const CompositeSurface [inline]
get_surface(int index) const CompositeSurface [inline]
get_torus_params(CubitVector &center, CubitVector &normal, double &major_radius, double &minor_radius) const CompositeSurface [virtual]
get_uv_sense()Surface [inline, virtual]
HadBridgeRemovedCompositeSurface [private]
has_hidden_entities() const CompositeSurface
hidden_entities()CompositeSurface [inline]
hiddenSetCompositeSurface [private]
ignore_surface(int surface_id)CompositeSurface
ignore_surface(Surface *surf)CompositeSurface
index_of(Surface *surface) const CompositeSurface [inline]
is_closed_in_U()CompositeSurface [virtual]
is_closed_in_V()CompositeSurface [virtual]
is_cylindrical()Surface [inline, virtual]
is_dead_coedge(CompositeCoEdge *coedge)CompositeSurface [protected]
is_parametric()CompositeSurface [virtual]
is_periodic()CompositeSurface [virtual]
is_periodic_in_U(double &period)CompositeSurface [virtual]
is_periodic_in_V(double &period)CompositeSurface [virtual]
is_position_on(CubitVector &position)CompositeSurface [virtual]
is_singular_in_U(double u_value)CompositeSurface [virtual]
is_singular_in_V(double v_value)CompositeSurface [virtual]
layer() const CompositeSurface [inline, virtual]
loopsm()TopologyBridge
loopsms(DLIList< LoopSM * > &loopsms, bool unique=true)TopologyBridge
lump()TopologyBridge
lumps(DLIList< Lump * > &lumps, bool unique=true)TopologyBridge
MAX_TB_LAYER enum valueTopologyBridge
measure()CompositeSurface [virtual]
next_co_surface(CompositeCoSurf *prev=0) const CompositeSurface [inline]
next_loop(CompositeLoop *after_this=0) const CompositeSurface [inline]
notify_copied(TopologyBridge *, TopologyBridge *)TBOwner [inline, virtual]
notify_joined(TopologyBridge *, TopologyBridge *)TBOwner [inline, virtual]
notify_merged(TopologyBridge *dead_bridge, TopologyBridge *)TBOwner [inline, virtual]
notify_reversed(TopologyBridge *bridge)CompositeSurface [virtual]
notify_split(TopologyBridge *new_bridge, TopologyBridge *old_bridge)CompositeSurface [virtual]
notify_topology_modified(TopologyBridge *bridge)CompositeSurface [virtual]
notify_transformed()CompositeSurface
num_surfs() const CompositeSurface [inline]
operator=(const CompositeSurface &)CompositeSurface [private]
owner() const TopologyBridge [inline]
owner(TBOwner *new_owner)TopologyBridge [inline]
param_dir(CubitVector &, CubitVector &, double &, double &)Surface [inline, virtual]
point_containment(const CubitVector &point)CompositeSurface [virtual]
point_containment(double u, double v)CompositeSurface [virtual]
points(DLIList< TBPoint * > &points, bool unique=true)TopologyBridge
position_from_u_v(double u, double v)CompositeSurface [virtual]
principal_curvatures(CubitVector const &location, double &curvature_1, double &curvature_2, CubitVector *closest_location)CompositeSurface [virtual]
print_cpt_stats()CompositeSurface [static]
print_debug_info(const char *line_prefix=0, bool brief=false)CompositeSurface
read_attributes()CompositeSurface [inline]
remove(CompositeLoop *loop)CompositeSurface
remove(CompositeCoSurf *cosurf)CompositeSurface
remove_all_simple_attribute_virt()CompositeSurface [virtual]
remove_bridge(TopologyBridge *bridge)CompositeSurface [virtual]
remove_dead_coedge(CompositeCoEdge *coedge)CompositeSurface [protected]
remove_simple_attribute_virt(const CubitSimpleAttrib &simple_attrib_ptr)CompositeSurface [virtual]
remove_surface(int index)CompositeSurface
reset_cpt_stats()CompositeSurface [static]
reverse_bridge_sense()TopologyBridge [inline]
reverse_sense()CompositeSurface [virtual]
set_saved_id(int value)GeometryEntity [inline]
set_saved_names(const std::vector< CubitString > &names)GeometryEntity
shellsms(DLIList< ShellSM * > &shellsms, bool unique=true)TopologyBridge
split(VGArray< int > &indices_to_move)CompositeSurface
stitch(CompositeSurface *stitch_partner)CompositeSurface
stitchPartnerCompositeSurface [private]
Surface()Surface
surfaces(DLIList< Surface * > &surfaces, bool unique=true)TopologyBridge
surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true)TopologyBridge
surfacesToIgnoreCompositeSurface [private]
swap_bridge(TopologyBridge *old_tb, TopologyBridge *new_tb, bool reversed)CompositeSurface [virtual]
topology_entity() const TopologyBridge
TopologyBridge()TopologyBridge [inline]
u_v_from_position(CubitVector const &position, double &u, double &v, CubitVector *closest_point)CompositeSurface [virtual]
unignore_surface(int surface_id)CompositeSurface
unstitch()CompositeSurface
update()CompositeSurface [inline]
update_facet_tool()CompositeSurface [protected]
update_facets_to_ignore()CompositeSurface [protected]
update_modified(Surface *modified_surface, DLIList< CompositeCurve * > &new_curves)CompositeSurface [protected]
update_modified()CompositeSurface [protected]
uv_derivitives(double u, double v, CubitVector &du, CubitVector &dv)CompositeSurface [virtual]
validate(const CubitString &, DLIList< TopologyEntity * > &)TopologyBridge [inline, virtual]
write_attributes()CompositeSurface [inline]
~CompositeSurface()CompositeSurface [virtual]
~GeometryEntity()GeometryEntity [virtual]
~Surface()Surface [virtual]
~TBOwner()TBOwner [virtual]
~TopologyBridge()TopologyBridge [virtual]
