cgma
CubitCoordinateSystem Class Reference
#include <CubitCoordinateSystem.hpp>
Inheritance diagram for CubitCoordinateSystem:
CubitEntity CubitObservable
List of all members.
Public Types
enum  Type { Rectangular, Cylindrical, Spherical }
 coordinate systems are of the types: More...
Public Member Functions
 CubitCoordinateSystem (int id)
 default constructor, initializes to rectangular type with an identity transform
 ~CubitCoordinateSystem ()
virtual CubitBox bounding_box ()
 get the id
virtual const std::type_info & entity_type_info () const
virtual const char * class_name () const
virtual CubitString entity_name () const
Type get_type () const
 get and set the type of this coordinate system
void set_type (Type)
const CubitTransformMatrixget_transform () const
 return the transform of this coordinate system
void set_transform (const CubitTransformMatrix &mat)
 set the transform of this coordinate system
CubitTransformMatrix get_concatenated_transform () const
Protected Attributes
Type mType
CubitTransformMatrix mMatrix
CubitCoordinateSystemmReference
DLIList< CubitCoordinateSystem * > mUses
Detailed Description
Definition at line 12 of file CubitCoordinateSystem.hpp.
Member Enumeration Documentation
Enumerator:
Rectangular
Cylindrical
Spherical
Definition at line 18 of file CubitCoordinateSystem.hpp.
Definition at line 14 of file CubitCoordinateSystem.cpp.
destructor, if this system is concatenated to others, their matrices will by multiplied by this transform
Definition at line 20 of file CubitCoordinateSystem.cpp.
  if(mReference)
    mReference->mUses.remove(this);
  // if we have uses, make them reference this reference
  while(mUses.size())
    CubitCoordinateSystem* sys = mUses.get();
    sys->set_transform(sys->mMatrix * this->mMatrix);
    sys->mReference = this->mReference;
    if(mReference)
      mReference->mUses.append(sys);
    mUses.remove();
  this->remove_from_observers();
  AppUtil::instance()->send_event(CubitCoordEvent(CubitCoordEvent::COORDINATE_SYSTEM_DELETED, this));
Member Function Documentation
get the id
Implements CubitEntity.
Definition at line 41 of file CubitCoordinateSystem.cpp.
    assert(0); // this function is only here b/c CubitEntity requires it
    CubitBox temp;
    return temp;
const char * CubitCoordinateSystem::class_name ( ) const [virtual]
Definition at line 54 of file CubitCoordinateSystem.cpp.
    return "Coordinate System";
Definition at line 59 of file CubitCoordinateSystem.cpp.
  CubitString name = class_name();
  name += " ";
  name += CubitString::number( this->id() );
  return name;
const std::type_info & CubitCoordinateSystem::entity_type_info ( ) const [virtual]
Definition at line 49 of file CubitCoordinateSystem.cpp.
    return typeid(CubitCoordinateSystem);
return the transform of this coordinate system with reference to the global coordinate system
return the transform of this coordinate system with respect to the global coordinate system
Definition at line 94 of file CubitCoordinateSystem.cpp.
  CubitTransformMatrix mat;
  mat = mMatrix;
  CubitCoordinateSystem* ref;
  for(ref = mReference; ref != 0; ref = ref->mReference)
    mat = mat * ref->mMatrix;
  return mat;
Definition at line 80 of file CubitCoordinateSystem.cpp.
  return mMatrix;
Definition at line 67 of file CubitCoordinateSystem.cpp.
  return mType;
Definition at line 85 of file CubitCoordinateSystem.cpp.
Member Data Documentation
Definition at line 57 of file CubitCoordinateSystem.hpp.
