cgma
CubitOctree Member List
This is the complete list of members for CubitOctree, including all inherited members.
apd_vector_item(CubitOctreeNode *ptr_grid_node)CubitOctree [inline, private]
bboxCenterCubitOctree [private]
bboxDimensionCubitOctree [private]
bboxMaxXCubitOctree [private]
bboxMaxYCubitOctree [private]
bboxMaxZCubitOctree [private]
bboxMinXCubitOctree [private]
bboxMinYCubitOctree [private]
bboxMinZCubitOctree [private]
blackCellListCubitOctree [private]
boundaryWhiteGridNodeListCubitOctree [private]
build_octree_till_min_depth(CubitOctreeCell *ptr_cell)CubitOctree
calculate_depth_based_on_size(double size)CubitOctree [private]
capsule_distance_to_facet(const CubitVector &point, CubitFacet *lp_facet, CubitVector &int_point, CubitBoolean use_projection_only=CUBIT_FALSE)CubitOctree [static]
circumcenter(CubitVector &a, CubitVector &b, CubitVector &c, CubitVector &center, double &radius)CubitOctree [private, static]
color_octreecell(void)CubitOctree
CubitOctree(CubitOctreeGenerator *lattice_gen)CubitOctree
cubitOctreeGeneratorCubitOctree [private]
display(const int mode, int opt=0)CubitOctree
epsilonBBoxCubitOctree [private]
establish_smooth_transition_of_cells(int max_depth)CubitOctree
find_cell_list_intersecting_line_segment(const CubitVector &p0, const CubitVector &p1, DLIList< CubitOctreeCell * > &cell_list)CubitOctree
find_cells_based_on_surface_angle(DLIList< CubitOctreeCell * > &refine_cell_list, DLIList< CubitFacetEdge * > &crease_edges, DLIList< CubitFacet * > &crease_facets, RefFace *one, RefFace *two, const CubitBoolean draw_facets=CUBIT_FALSE, double dihedral_angle_thresh=CUBIT_PI/2.0)CubitOctree
find_intersection_between_grid_edges_and_facet(CubitOctreeType type, RefFace *ptr_face, CubitFacet *ptr_facet, DLIList< CubitOctreeNode * > &CubitOctree_grid_node_list)CubitOctree
find_max_min_size_grid_node_for_scaling(void)CubitOctree [private]
find_octree_cells_contained_inside_bbox(CubitFacet *ptr_facet, DLIList< CubitOctreeCell * > &CubitOctree_cell_list)CubitOctree
find_octreecell(const CubitVector &pnt)CubitOctree
find_radius_at_boundary_node(void)CubitOctree [private]
gather_initial_grid_nodes_for_smooth_transition(DLIList< CubitOctreeNode * > &queue)CubitOctree [private]
get_bbox_dimension(void)CubitOctree [inline, private]
get_blackcelllist()CubitOctree [inline]
get_greycelllist(void)CubitOctree [inline]
get_gridnodevector(void)CubitOctree [inline]
get_max_depth(void)CubitOctree [inline]
get_max_size_grid_node(void)CubitOctree [inline]
get_min_depth(void)CubitOctree [inline]
get_min_size_grid_node(void) const CubitOctree [inline]
get_root(void)CubitOctree [inline]
get_scaled_from_wrld_size_grid_node(double wrld_size)CubitOctree
get_whitenodelist(void)CubitOctree [inline]
greyCellListCubitOctree [private]
greyGridNodeVectorCubitOctree [private]
gridNodeVectorCubitOctree [private]
initialize_octree_generation(void)CubitOctree
mark_cells_that_intersect_facet_plane(DLIList< CubitOctreeCell * > &CubitOctree_cell_list)CubitOctree [private]
mark_positive_and_negative_octree_grid_nodes(CubitFacet *ptr_facet, DLIList< CubitOctreeCell * > &CubitOctree_cell_list, DLIList< CubitOctreeNode * > &CubitOctree_grid_node_list)CubitOctree
maxDepthCubitOctree [private]
maxSizeGridNodeCubitOctree [private]
minDepthCubitOctree [private]
minSizeGridNodeCubitOctree [private]
point_containment(CubitVector tmp_vec, double tolerance)CubitOctree
prepare_for_background_mesh()CubitOctree [private]
refine_cells_to_target_depth(DLIList< CubitOctreeCell * > &refine_cell_list, const int target_depth)CubitOctree [private]
release_memory(void)CubitOctree
reset_internal_node_size(float value, int type)CubitOctree [private]
rootCubitOctree [private]
set_max_depth(int max_depth)CubitOctree [inline]
set_min_depth(int min_depth)CubitOctree [inline]
set_status_octree_coloring(CubitBoolean type)CubitOctree [inline]
size_at_a_point(const CubitVector &point, int size_type)CubitOctree
statusCubitOctreeColoringCubitOctree [private]
subdivide_octree_based_on_facet_point(OctreeFacetPointData *ptr_facet_point_data, int max_depth)CubitOctree
subdivide_octree_cell(CubitOctreeCell *ptr_cell, DLIList< CubitOctreeNode * > *ptr_queue, int max_depth)CubitOctree
subdivide_octree_from_leaf_cell(CubitOctreeCell *ptr_cell, OctreeFacetPointData *ptr_facet_point_data, int max_depth)CubitOctree [private]
unmark_octree_cells_not_intersecting_with_facet(CubitFacet *ptr_facet, DLIList< CubitOctreeCell * > &CubitOctree_cell_list)CubitOctree [private]
write_matlab_sizing_info_file(const char *file_name)CubitOctree [private]
write_octree_sizing_info_file(const char *file_name)CubitOctree [private]
write_sizing_info_file(const char *file_name)CubitOctree [private]
~CubitOctree()CubitOctree [virtual]
