cgma
CubitOperationEvent Class Reference
#include <CubitOperationEvent.hpp>
Inheritance diagram for CubitOperationEvent:
CubitEvent
List of all members.
Public Types
enum  Type {
  DEVELOPER_COMMAND_FLAG_MODIFIED, HEALER_COMPLETED, COMPOSITE_CREATION_COMPLETED, SPLIT_SURFACE_COMPLETED,
  SEPARATE_OPERATION_COMPLETED, COLLAPSE_CURVE_COMPLETED, AUTO_CLEAN_COMPLETED, GEOMETRY_DEFEATURING_COMPLETED,
  REMOVE_SURFACE_COMPLETED, REMOVE_TOPOLOGY_COMPLETED, REGULARIZE_ENTITY_COMPLETED, WEBCUT_COMPLETED,
  ENTITIES_MODIFIED, BOOLEAN_OPERATION_COMPLETE, MODEL_RESET, GRAPHICS_MODE_MODIFIED,
  SUSPEND_GENESIS_PROCESSING, RESUME_GENESIS_PROCESSING, UPDATE_GENESIS_DISPLAY, UNDO_STATE_CHANGED,
  UNDO_COMPLETE, GRANITE_FILE_IMPORTED, GEOMETRY_ENGINE_CHANGED, WORKING_DIRECTORY_CHANGED,
  APREPRO_MODIFIED, FATAL_ERROR_ENCOUNTERED, IDS_COMPRESSED, COMMAND_STARTED,
  COMMAND_FINISHED
Public Member Functions
 CubitOperationEvent (Type type)
 ~CubitOperationEvent ()
CubitObservableget_entity () const
Type get_type () const
Protected Attributes
Type mType
Detailed Description
Definition at line 7 of file CubitOperationEvent.hpp.
Member Enumeration Documentation
Enumerator:
HEALER_COMPLETED
WEBCUT_COMPLETED
ENTITIES_MODIFIED
MODEL_RESET
UNDO_STATE_CHANGED
UNDO_COMPLETE
APREPRO_MODIFIED
IDS_COMPRESSED
COMMAND_STARTED
COMMAND_FINISHED
Definition at line 10 of file CubitOperationEvent.hpp.
Definition at line 4 of file CubitOperationEvent.cpp.
  : mType(type)
Member Function Documentation
Definition at line 46 of file CubitOperationEvent.hpp.
{ return NULL; }
Type CubitOperationEvent::get_type ( ) const [inline]
Definition at line 48 of file CubitOperationEvent.hpp.
{return mType;}
Member Data Documentation
Definition at line 51 of file CubitOperationEvent.hpp.
