cgma
CurveFacetEvalTool Member List
This is the complete list of members for CurveFacetEvalTool, including all inherited members.
bounding_box()CurveFacetEvalTool
closest_point(CubitVector &this_point, CubitVector &closest_point_ptr, CubitVector *normal_ptr=NULL, CubitVector *curvature_ptr=NULL, double *param=NULL)CurveFacetEvalTool
CurveFacetEvalTool()CurveFacetEvalTool
curvSenseCurveFacetEvalTool [private]
debug_draw_facet_edges(int color=-1)CurveFacetEvalTool
destroy_facets()CurveFacetEvalTool [private]
draw_edge(CubitFacetEdge *edge, int color)CurveFacetEvalTool [private]
draw_edges(int color=-1)CurveFacetEvalTool [private]
draw_line(CubitVector &begin, CubitVector &end, int color=-1)CurveFacetEvalTool [private]
draw_location(CubitVector &loc, int color=-1)CurveFacetEvalTool [private]
evaluate_bezier_edge(CubitFacetEdge *edge, int index0, int index1, double fraction, CubitVector &location_on_curve, double *tangent)CurveFacetEvalTool [private]
facetLengthCurveFacetEvalTool [private]
find_curv_sense(CubitPoint *start_ptr)CurveFacetEvalTool [private]
find_curv_sense(CubitVector &start)CurveFacetEvalTool [private]
fix_point_edge_order()CurveFacetEvalTool [private]
get_facets(DLIList< CubitFacetEdge * > &facet_list)CurveFacetEvalTool [inline]
get_output_id()CurveFacetEvalTool [inline]
get_points(DLIList< CubitPoint * > &point_list)CurveFacetEvalTool [inline]
get_segments_from_loops(DLIList< DLIList< CubitFacetEdge * > * > *facet_loop_list, CubitVector &start, CubitVector &end, DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list, CubitSense owrts)CurveFacetEvalTool [private]
get_segments_from_loops(DLIList< DLIList< CubitFacetEdge * > * > *facet_loop_list, CubitPoint *start_pt, CubitPoint *end_pt, DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list, CubitSense owrts)CurveFacetEvalTool [private]
get_segments_from_positions(std::vector< CubitVector > &positions, CubitVector &start_pt, DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list)CurveFacetEvalTool [private]
get_surf_eval_tool()CurveFacetEvalTool [inline]
goodCurveDataCurveFacetEvalTool [private]
has_good_curve_data()CurveFacetEvalTool [inline]
initialize(DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list, FacetEvalTool *surf_eval=NULL)CurveFacetEvalTool
initialize(FacetEvalTool *surf_eval_tool, CubitPoint *start_point, CubitPoint *end_point, CubitSense orientation)CurveFacetEvalTool
initialize(FacetEvalTool *surf_eval_tool, CubitVector &start, CubitVector &end, CubitSense orientation)CurveFacetEvalTool
initialize(FacetEvalTool *surf_eval_tool, CubitVector &start, std::vector< CubitVector > &positions)CurveFacetEvalTool
interpOrderCurveFacetEvalTool [private]
length()CurveFacetEvalTool [inline]
length_from_u(double root_param, double end_param)CurveFacetEvalTool
myBBoxCurveFacetEvalTool [private]
myEdgeListCurveFacetEvalTool [private]
myPointListCurveFacetEvalTool [private]
output_idCurveFacetEvalTool [private]
position_from_fraction(double fraction, CubitVector &location_on_curve)CurveFacetEvalTool
project_to_bezier_edge(CubitFacetEdge *edge, CubitVector &point, CubitVector &projected_point, double *tangent, double *tval)CurveFacetEvalTool [private]
remove_facets(DLIList< CubitFacetEdge * > &facet_edges)CurveFacetEvalTool
replace_facets(DLIList< CubitFacetEdge * > &curv_edges)CurveFacetEvalTool
replace_point(CubitPoint *del_pnt, CubitPoint *keep_pnt)CurveFacetEvalTool
restore(FILE *fp, unsigned int endian, int num_edges, int num_points, CubitFacetEdge **edges, CubitPoint **points, int num_fets, FacetEvalTool **fet_list)CurveFacetEvalTool
save(FILE *fp)CurveFacetEvalTool
sense()CurveFacetEvalTool [inline]
set_facet_eval_tool(FacetEvalTool *surf_eval_tool_ptr)CurveFacetEvalTool [inline]
set_length()CurveFacetEvalTool
set_output_id(int id)CurveFacetEvalTool [inline]
surfFacetEvalToolCurveFacetEvalTool [private]
toolIDCurveFacetEvalTool [private]
u_from_arc_length(double root_param, double arc_length)CurveFacetEvalTool
u_on_facet_edge(CubitFacetEdge *edge_at_pt, CubitVector pt)CurveFacetEvalTool [private]
~CurveFacetEvalTool()CurveFacetEvalTool
