cgma
CurveSM Member List
This is the complete list of members for CurveSM, including all inherited members.
append_simple_attribute_virt(const CubitSimpleAttrib &)=0TopologyBridge [pure virtual]
bodysm()TopologyBridge
bodysms(DLIList< BodySM * > &bodies, bool unique=true)TopologyBridge
bounding_box() const =0GeometryEntity [pure virtual]
bridge_manager() const TopologyBridge
bridge_manager(BridgeManager *manager)TopologyBridge
bridge_sense()TopologyBridge [inline]
center_point()Curve [inline, virtual]
ChildType typedefCurve
closest_point(CubitVector const &location, CubitVector &closest_location, CubitVector *tangent_ptr=NULL, CubitVector *curvature_ptr=NULL, double *param=NULL)=0Curve [pure virtual]
closest_point_trimmed(CubitVector const &from_pt, CubitVector &result_pt)Curve [virtual]
coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true)TopologyBridge
Curve()Curve
curves(DLIList< Curve * > &curves, bool unique=true)TopologyBridge
curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true)TopologyBridge
CurveSM()CurveSM
end_param()=0Curve [pure virtual]
G1_discontinuous(double u, CubitVector *minus_tangent=NULL, CubitVector *plus_tangent=NULL)Curve [virtual]
geometry_type()Curve [inline, virtual]
GeometryEntity()GeometryEntity [inline]
get_arc_length()Curve [inline, virtual]
get_arc_length(const CubitVector &point1, const CubitVector &point2)Curve [inline, virtual]
get_arc_length(const CubitVector &point1, const int which_end)Curve [inline, virtual]
get_center_radius(CubitVector &center, double &radius)=0Curve [pure virtual]
get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER)TopologyBridge
get_children_virt(DLIList< TopologyBridge * > &children)=0TopologyBridge [pure virtual]
get_ellipse_params(CubitVector &center, CubitVector &normal, CubitVector &major_axis, double &radius_ratio) const =0Curve [pure virtual]
get_geometry_query_engine() const =0TopologyBridge [pure virtual]
get_interior_extrema(DLIList< CubitVector * > &interior_points, CubitSense &return_sense)=0Curve [pure virtual]
get_param_range(double &lower_bound, double &upper_bound)=0Curve [pure virtual]
get_parents(DLIList< TopologyBridge * > &parents)TopologyBridge
get_parents_virt(DLIList< TopologyBridge * > &parents)=0TopologyBridge [pure virtual]
get_point_direction(CubitVector &origin, CubitVector &direction)Curve [virtual]
get_saved_id() const GeometryEntity [inline]
get_saved_names(std::vector< CubitString > &names)GeometryEntity
get_simple_attribute(DLIList< CubitSimpleAttrib > &)=0TopologyBridge [pure virtual]
get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &)=0TopologyBridge [pure virtual]
get_spline_params(bool &rational, int &degree, DLIList< CubitVector > &cntrl_pts, DLIList< double > &cntrl_pt_weights, DLIList< double > &knots, bool &spline_is_reversed) const =0Curve [pure virtual]
is_periodic(double &period)=0Curve [pure virtual]
is_position_on(const CubitVector &test_position)=0Curve [pure virtual]
is_tolerant()Curve [inline, virtual]
layer() const TopologyBridge [inline, virtual]
length_from_u(double parameter1, double parameter2)=0Curve [pure virtual]
loopsm()TopologyBridge
loopsms(DLIList< LoopSM * > &loopsms, bool unique=true)TopologyBridge
lump()TopologyBridge
lumps(DLIList< Lump * > &lumps, bool unique=true)TopologyBridge
MAX_TB_LAYER enum valueTopologyBridge
measure()=0GeometryEntity [pure virtual]
mid_point(const CubitVector &point1, const CubitVector &point2, CubitVector &mid_point)Curve [inline, virtual]
mid_point(CubitVector &mid_point)Curve [inline, virtual]
owner() const TopologyBridge [inline]
owner(TBOwner *new_owner)TopologyBridge [inline]
point_containment(const CubitVector &point)=0Curve [pure virtual]
point_from_arc_length(double root_param, const double arc_length, CubitVector &new_point)Curve [virtual]
point_from_arc_length(const CubitVector &root_point, double const arc_length, CubitVector &new_point)Curve [virtual]
points(DLIList< TBPoint * > &points, bool unique=true)TopologyBridge
position_from_fraction(const double fraction_along_curve, CubitVector &output_position)Curve [inline, virtual]
position_from_u(double u_value, CubitVector &output_position)=0Curve [pure virtual]
relative_sense(Curve *other_curve)Curve [virtual]
remove_all_simple_attribute_virt()=0TopologyBridge [pure virtual]
remove_simple_attribute_virt(const CubitSimpleAttrib &)=0TopologyBridge [pure virtual]
reverse_bridge_sense()TopologyBridge [inline]
set_saved_id(int value)GeometryEntity [inline]
set_saved_names(const std::vector< CubitString > &names)GeometryEntity
shellsms(DLIList< ShellSM * > &shellsms, bool unique=true)TopologyBridge
start_param()=0Curve [pure virtual]
surfaces(DLIList< Surface * > &surfaces, bool unique=true)TopologyBridge
surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true)TopologyBridge
topology_entity() const TopologyBridge
TopologyBridge()TopologyBridge [inline]
u_from_arc_length(double root_param, double arc_length)=0Curve [pure virtual]
u_from_position(const CubitVector &input_position)=0Curve [pure virtual]
validate(const CubitString &, DLIList< TopologyEntity * > &)TopologyBridge [inline, virtual]
~Curve()Curve [virtual]
~CurveSM()CurveSM [virtual]
~GeometryEntity()GeometryEntity [virtual]
~TopologyBridge()TopologyBridge [virtual]
