cgma
FacetLump Member List
This is the complete list of members for FacetLump, including all inherited members.
add_body(BodySM *new_body)FacetLump [inline]
add_shell(FacetShell *shell)FacetLump
append_simple_attribute_virt(const CubitSimpleAttrib &)FacetLump [virtual]
attribSetFacetLump [private]
bodysm()TopologyBridge
bodysms(DLIList< BodySM * > &bodies, bool unique=true)TopologyBridge
bounding_box() const FacetLump [virtual]
bridge_manager() const TopologyBridge
bridge_manager(BridgeManager *manager)TopologyBridge
bridge_sense()TopologyBridge [inline]
ChildType typedefLump
coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true)TopologyBridge
curves(DLIList< Curve * > &curves, bool unique=true)TopologyBridge
curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true)TopologyBridge
disconnect_all_shells()FacetLump
FacetLump(DLIList< ShellSM * > &my_shells, BodySM *body_sm_ptr=NULL)FacetLump
geometry_type()Lump [inline, virtual]
GeometryEntity()GeometryEntity [inline]
get_bodies(DLIList< FacetBody * > &bodies)FacetLump
get_body() const FacetLump [inline]
get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER)TopologyBridge
get_children_virt(DLIList< TopologyBridge * > &children)FacetLump [virtual]
get_coedges(DLIList< FacetCoEdge * > &coedges)FacetLump
get_curves(DLIList< FacetCurve * > &curves)FacetLump
get_geometry_query_engine() const FacetLump [virtual]
get_parents(DLIList< TopologyBridge * > &parents)TopologyBridge
get_parents_virt(DLIList< TopologyBridge * > &parents)FacetLump [virtual]
get_saved_id() const GeometryEntity [inline]
get_saved_names(std::vector< CubitString > &names)GeometryEntity
get_shells(DLIList< FacetShell * > &shells)FacetLump
get_simple_attribute(DLIList< CubitSimpleAttrib > &)FacetLump [virtual]
get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &)FacetLump [virtual]
get_surfaces(DLIList< FacetSurface * > &surfaces)FacetLump
is_sheet()FacetLump
layer() const TopologyBridge [inline, virtual]
loopsm()TopologyBridge
loopsms(DLIList< LoopSM * > &loopsms, bool unique=true)TopologyBridge
Lump()Lump
lump()TopologyBridge
lumps(DLIList< Lump * > &lumps, bool unique=true)TopologyBridge
mass_properties(CubitVector &centroid, double &volume)FacetLump [virtual]
Lump::mass_properties(CubitVector[3], CubitVector &, CubitVector &, double &)Lump [inline, virtual]
MAX_TB_LAYER enum valueTopologyBridge
measure()FacetLump [virtual]
merge(GeometryEntity *)FacetLump [inline, virtual]
myBodyPtrFacetLump [private]
myShellsFacetLump [private]
owner() const TopologyBridge [inline]
owner(TBOwner *new_owner)TopologyBridge [inline]
point_containment(const CubitVector &point, double tolerance)FacetLump
points(DLIList< TBPoint * > &points, bool unique=true)TopologyBridge
remove_all_simple_attribute_virt()FacetLump [virtual]
remove_body()FacetLump [inline]
remove_shell(FacetShell *shell)FacetLump
remove_simple_attribute_virt(const CubitSimpleAttrib &)FacetLump [virtual]
restore_attribs(FILE *file_ptr, unsigned int endian)FacetLump
reverse_bridge_sense()TopologyBridge [inline]
save_attribs(FILE *file_ptr)FacetLump
set_saved_id(int value)GeometryEntity [inline]
set_saved_names(const std::vector< CubitString > &names)GeometryEntity
shellsms(DLIList< ShellSM * > &shellsms, bool unique=true)TopologyBridge
surfaces(DLIList< Surface * > &surfaces, bool unique=true)TopologyBridge
surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true)TopologyBridge
topology_entity() const TopologyBridge
TopologyBridge()TopologyBridge [inline]
unmerge(DLIList< RefVolume * >)FacetLump [inline, virtual]
validate(const CubitString &, DLIList< TopologyEntity * > &)TopologyBridge [inline, virtual]
~FacetLump()FacetLump [virtual]
~GeometryEntity()GeometryEntity [virtual]
~Lump()Lump [virtual]
~TopologyBridge()TopologyBridge [virtual]
