cgma
FacetQueryEngine Member List
This is the complete list of members for FacetQueryEngine, including all inherited members.
add_hash_point(CubitPoint *point_ptr)FacetQueryEngine [private, static]
bodies_overlap(BodySM *body_ptr_1, BodySM *body_ptr_2) const FacetQueryEngine [virtual]
can_delete_bodies(DLIList< Body * >body_list)FacetQueryEngine
copy_body(Body *body_ptr)FacetQueryEngine
create_facet_bounding_box(BodySM *bodySM, CubitBox &bbox)FacetQueryEngine
create_super_facet_bounding_box(DLIList< BodySM * > &body_list, CubitBox &super_box)FacetQueryEngine
curve_is_on_ignored_surface(Curve *, Surface *)GeometryQueryEngine [inline, virtual]
delete_hash_points()FacetQueryEngine [private, static]
delete_instance()FacetQueryEngine [static]
delete_solid_model_entities(DLIList< BodySM * > &body_list) const FacetQueryEngine [virtual]
delete_solid_model_entities(BodySM *body_ptr) const FacetQueryEngine [virtual]
delete_solid_model_entities(Surface *surf_ptr) const FacetQueryEngine [virtual]
delete_solid_model_entities(Curve *curve_ptr) const FacetQueryEngine [virtual]
delete_solid_model_entities(TBPoint *point_ptr) const FacetQueryEngine [virtual]
GeometryQueryEngine::delete_solid_model_entities(GeometryEntity *ref_entity_ptr) const GeometryQueryEngine [virtual]
delete_topology_bridge(TopologyBridge *bridge) const GeometryQueryEngine [virtual]
dump_facets(FILE *fp, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list)FacetQueryEngine
ensure_is_ascii_stl_file(FILE *fp, CubitBoolean &is_ascii)FacetQueryEngine
entity_entity_distance(GeometryEntity *ref_entity_ptr1, GeometryEntity *ref_entity_ptr2, CubitVector &pos1, CubitVector &pos2, double &distance)FacetQueryEngine [virtual]
entity_extrema(DLIList< GeometryEntity * > &entity_list, const CubitVector *dir1, const CubitVector *dir2, const CubitVector *dir3, CubitVector &extrema, GeometryEntity *&extrema_entity_ptr)FacetQueryEngine [virtual]
entity_type_info() const FacetQueryEngine [virtual]
export_facets(DLIList< CubitFacet * > &facet_list, char *filename)FacetQueryEngine [static]
export_solid_model(DLIList< TopologyBridge * > &bridge_list, const char *file_name, Model_File_Type file_type, const CubitString &cubit_version, ModelExportOptions &export_options)FacetQueryEngine [virtual]
export_solid_model(DLIList< TopologyBridge * > &bridge_list, char *&p_buffer, int &n_buffer_size, bool b_export_buffer)FacetQueryEngine [inline, virtual]
FacetQueryEngine()FacetQueryEngine [protected]
FacetSurface classFacetQueryEngine [friend]
fire_ray(CubitVector &origin, CubitVector &direction, DLIList< TopologyBridge * > &at_entity_list, DLIList< double > &ray_params, int max_hits, double ray_radius, DLIList< TopologyBridge * > *hit_entity_list=0) const FacetQueryEngine [virtual]
FQE_MAJOR_VERSIONFacetQueryEngine [private, static]
FQE_MINOR_VERSIONFacetQueryEngine [private, static]
FQE_SUBMINOR_VERSIONFacetQueryEngine [private, static]
gather_all_facet_entities(DLIList< FacetBody * > &facet_bodies, DLIList< FacetLump * > &facet_lumps, DLIList< FacetShell * > &facet_shells, DLIList< FacetSurface * > &facet_surfaces, DLIList< FacetLoop * > &facet_loops, DLIList< FacetCoEdge * > &facet_coedges, DLIList< FacetCurve * > &facet_curves, DLIList< FacetPoint * > &facet_points)FacetQueryEngine
gather_facets(DLIList< FacetSurface * > facet_surfaces, DLIList< FacetCurve * > facet_curves, DLIList< FacetPoint * > facet_points, DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitPoint * > &point_list)FacetQueryEngine
get_all_hash_points(DLIList< CubitPoint * > &point_list)FacetQueryEngine [private, static]
get_allint_version()GeometryQueryEngine [virtual]
get_connected_patch(DLIList< FacetSurface * > &remaining_surfs, DLIList< FacetSurface * > &output_patch)FacetQueryEngine
get_engine_version_string()FacetQueryEngine [virtual]
get_graphics(BodySM *bodysm, GMem *g_mem, std::vector< Surface * > &surface_to_facets_vector, std::vector< TopologyBridge * > &vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > &facet_edges_on_curves, unsigned short normal_tolerance, double distance_tolerance, double max_edge_length) const FacetQueryEngine [virtual]
get_graphics(Surface *surface_ptr, GMem *gMem, unsigned short normal_tolerance, double distance_tolerance, double max_edge_length) const FacetQueryEngine [virtual]
get_graphics(Curve *curve_ptr, GMem *gMem, double angle_tolerance=0, double distance_tolerance=0, double max_edge_length=0) const FacetQueryEngine [virtual]
GeometryQueryEngine::get_graphics(Surface *surface_ptr, GMem *gmem, std::vector< TopologyBridge * > &vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > &facet_edges_on_curves, unsigned short normal_tolerance=15, double distance_tolerance=0.0, double max_edge_length=0.0) const GeometryQueryEngine [virtual]
get_hash_key(int id)FacetQueryEngine [private, static]
get_hash_point(int id)FacetQueryEngine [private, static]
get_intersections(Curve *, CubitVector &point1, CubitVector &, DLIList< CubitVector > &, CubitBoolean, CubitBoolean)FacetQueryEngine [virtual]
get_intersections(Curve *, Curve *, DLIList< CubitVector > &, CubitBoolean, CubitBoolean)FacetQueryEngine [virtual]
get_intersections(Curve *ref_edge1, Curve *ref_edge2, DLIList< CubitVector > &intersection_list, double offset, CubitBoolean ext_first=CUBIT_TRUE)FacetQueryEngine [virtual]
get_intersections(Curve *ref_edge, Surface *ref_face, DLIList< CubitVector > &intersection_list, CubitBoolean bounded=CUBIT_FALSE)FacetQueryEngine [virtual]
GeometryQueryEngine::get_intersections(Curve *ref_edge1, CubitVector &point1, CubitVector &point2, DLIList< CubitVector > &intersection_list, bool bounded=false, bool closest=false)=0GeometryQueryEngine [pure virtual]
GeometryQueryEngine::get_intersections(Curve *ref_edge1, Curve *ref_edge2, DLIList< CubitVector > &intersection_list, bool bounded=false, bool closest=false)=0GeometryQueryEngine [pure virtual]
GeometryQueryEngine::get_intersections(Curve *curve, Surface *surface, DLIList< CubitVector > &intersection_list, bool bounded=false)=0GeometryQueryEngine [pure virtual]
get_isoparametric_points(Surface *, int &, int &, GMem *&) const FacetQueryEngine [virtual]
get_major_version()FacetQueryEngine [virtual]
get_minor_version()FacetQueryEngine [virtual]
get_ordered_loops(RefFace *, DLIList< Loop * > &) const GeometryQueryEngine [inline, virtual]
get_point_containment(DLIList< BodySM * > &bodysm_list, DLIList< CubitVector > &point_list, double tolerance, bool allow_pts_in_multiple_bodies, std::vector< std::pair< BodySM *, std::vector< int > > > &bodysm_to_pt_indices)FacetQueryEngine [virtual]
get_sme_resabs_tolerance() const FacetQueryEngine [virtual]
get_subminor_version()FacetQueryEngine [virtual]
get_u_isoparametric_points(Surface *ref_face_ptr, double v, int &n, GMem *&gMem) const FacetQueryEngine [virtual]
get_underlying_bridges(TopologyBridge *bridge_ptr, DLIList< TopologyBridge * > &bridge_list)GeometryQueryEngine [virtual]
get_underlying_curves(Curve *curve_ptr, DLIList< TopologyBridge * > &curve_list)GeometryQueryEngine [virtual]
get_underlying_surfaces(Surface *surf_ptr, DLIList< TopologyBridge * > &surf_list)GeometryQueryEngine [virtual]
get_v_isoparametric_points(Surface *ref_face_ptr, double u, int &n, GMem *&gMem) const FacetQueryEngine [virtual]
get_visible_entities(TopologyBridge *hidden_tb, DLIList< TopologyBridge * > &real_tbs)GeometryQueryEngine [virtual]
get_visible_entity_at_point(TopologyBridge *, CubitVector *)GeometryQueryEngine [inline, virtual]
hashPointArrayFacetQueryEngine [private, static]
hashPointSizeFacetQueryEngine [private, static]
import_facets(const char *file_name, CubitBoolean use_feature_angle, double feature_angle, double tolerance, int interp_order, CubitBoolean smooth_non_manifold, CubitBoolean split_surfaces, CubitBoolean stitch, CubitBoolean improve, DLIList< CubitQuadFacet * > &quad_facet_list, DLIList< CubitFacet * > &tri_facet_list, DLIList< Surface * > &surface_list, FacetFileFormat file_format=CUBIT_FACET_FILE)FacetQueryEngine
import_solid_model(const char *file_name, Model_File_Type file_type, DLIList< TopologyBridge * > &imported_entities, ModelImportOptions &import_options)FacetQueryEngine [virtual]
import_solid_model(DLIList< TopologyBridge * > &imported_entities, const char *pBuffer, const int n_buffer_size)FacetQueryEngine [inline, virtual]
import_solid_model(FILE *file_ptr, DLIList< TopologyBridge * > &imported_entities)FacetQueryEngine [private]
init_hash_points(int num_points)FacetQueryEngine [private, static]
instance_FacetQueryEngine [private, static]
is_close(CubitVector &this_point, DLIList< CubitFacet * > &facet_list, CubitFacet *&lastFacet, double tol)FacetQueryEngine
is_intermediate_engine()GeometryQueryEngine [inline, virtual]
is_solid_modeler_type() const FacetQueryEngine [inline, virtual]
list_engine_versions(CubitString &versions)GeometryQueryEngine [virtual]
make_BodySM(Surface *) const FacetQueryEngine [virtual]
make_BodySM(DLIList< Lump * > &) const FacetQueryEngine [virtual]
make_Curve(Curve *) const FacetQueryEngine [virtual]
make_Curve(TBPoint const *, TBPoint const *, RefFace *, CubitVector *) const FacetQueryEngine [virtual]
make_Curve(GeometryType, TBPoint const *, TBPoint const *, DLIList< CubitVector * > &, RefFace *) const FacetQueryEngine [virtual]
make_Curve(GeometryType, TBPoint const *, TBPoint const *, CubitVector const *, CubitSense) const FacetQueryEngine [virtual]
make_facets(int *conn, int nfacets, DLIList< CubitQuadFacet * > &facet_list)FacetQueryEngine [static]
make_facets(int *conn, int nfacets, DLIList< CubitFacet * > &facet_list)FacetQueryEngine [static]
make_Lump(GeometryType, DLIList< Surface * > &) const FacetQueryEngine [virtual]
make_Point(GeometryType point_type, CubitVector const &point) const FacetQueryEngine [virtual]
make_Surface(Surface *, DLIList< Loop * > &, CubitBoolean) const FacetQueryEngine [virtual]
make_Surface(GeometryType, DLIList< Curve * > &, DLIList< Loop * > &, Surface *) const FacetQueryEngine [virtual]
modeler_type()FacetQueryEngine [inline, virtual]
read_cholla_file(const char *file_name, double &feature_angle, DLIList< CubitPoint * > &point_list, DLIList< CubitFacet * > &facet_list)FacetQueryEngine [static]
read_facets(const char *file_name, int *&conn, int &npoints, int &nquad, int &ntri, FacetFileFormat file_format=CUBIT_FACET_FILE)FacetQueryEngine [static]
read_facets(FILE *fp, unsigned int endian, int &num_facets, int &num_edges, int &num_points, CubitFacet **&facets, CubitFacetEdge **&edges, CubitPoint **&points)FacetQueryEngine [private]
read_facets_stl(DLIList< CubitFacet * > &tfacet_list, DLIList< CubitPoint * > &point_list, const char *file_name, int &npoints, int &ntri, long &seek_address)FacetQueryEngine
read_facets_stl_tolerance(DLIList< CubitFacet * > &tfacet_list, DLIList< CubitPoint * > &point_list, const char *file_name, int &npoints, int &ntri, long &seek_address, double tolerance)FacetQueryEngine
reflect(BodySM *body, const CubitVector &axis)FacetQueryEngine [virtual]
reflect(GeometryEntity *ent, const CubitVector &axis)FacetQueryEngine [virtual]
restore_eval_tools(FILE *fp, unsigned int endian, int num_facets, int num_edges, int num_points, CubitFacet **facets, CubitFacetEdge **edges, CubitPoint **points, int &num_cfet, int &num_fet, CurveFacetEvalTool **&cfeval_tools, FacetEvalTool **&feval_tools)FacetQueryEngine
restore_facets(FILE *file_ptr, unsigned int endian, int &num_facets, int &num_edges, int &num_points, CubitPoint **&points_array, int &num_cfet, int &num_fet, CurveFacetEvalTool **&cfet_array, FacetEvalTool **&fet_array)FacetQueryEngine [private]
restore_topology(FILE *file_ptr, unsigned int endian, int num_points, CubitPoint **points_array, int num_cfet, CurveFacetEvalTool **cfev_array, int num_fet, FacetEvalTool **fev_array, DLIList< TopologyBridge * > &imported_entities)FacetQueryEngine [private]
restore_transform(BodySM *body)FacetQueryEngine [virtual]
rotate(BodySM *body, const CubitVector &axis, double angle)FacetQueryEngine [virtual]
rotate(GeometryEntity *ent, const CubitVector &axis, double degrees)FacetQueryEngine [virtual]
save_eval_tools(FILE *fp, DLIList< FacetSurface * > facet_surfaces, DLIList< FacetCurve * > facet_curves)FacetQueryEngine
save_facets(FILE *fp, DLIList< FacetSurface * > facet_surfaces, DLIList< FacetCurve * > facet_curves, DLIList< FacetPoint * > facet_points)FacetQueryEngine
save_temp_geom_file(DLIList< TopologyBridge * > &ref_entity_list, const char *file_name, const CubitString &cubit_version, CubitString &created_file, CubitString &created_file_type)FacetQueryEngine [virtual]
scale(BodySM *body, double factor)FacetQueryEngine [virtual]
scale(BodySM *body, const CubitVector &factors)FacetQueryEngine [virtual]
scale(GeometryEntity *ent, double factor)FacetQueryEngine [virtual]
scale(GeometryEntity *ent, const CubitVector &factors)FacetQueryEngine [virtual]
set_dbl_option(const char *opt_name, double val)FacetQueryEngine [virtual]
set_export_allint_version(const int version)GeometryQueryEngine [virtual]
set_export_version(const int major, const int minor)GeometryQueryEngine [virtual]
set_int_option(const char *opt_name, int val)FacetQueryEngine [virtual]
set_sme_resabs_tolerance(double new_resabs)FacetQueryEngine [virtual]
set_str_option(const char *opt_name, const char *val)FacetQueryEngine [virtual]
transform_vec_position(CubitVector const &, BodySM *, CubitVector &) const FacetQueryEngine [virtual]
translate(BodySM *body, const CubitVector &offset)FacetQueryEngine [virtual]
translate(GeometryEntity *ent, const CubitVector &offset)FacetQueryEngine [virtual]
validate_geometry_database() const GeometryQueryEngine [inline, virtual]
volumes_overlap(Lump *lump_ptr_1, Lump *lump_ptr_2) const FacetQueryEngine [virtual]
write_topology(FILE *file_ptr, DLIList< FacetBody * > &facet_bodies, DLIList< FacetLump * > &facet_lumps, DLIList< FacetShell * > &facet_shells, DLIList< FacetSurface * > &facet_surfaces, DLIList< FacetLoop * > &facet_loops, DLIList< FacetCoEdge * > &facet_coedges, DLIList< FacetCurve * > &facet_curves, DLIList< FacetPoint * > &facet_points)FacetQueryEngine [private]
~FacetQueryEngine()FacetQueryEngine [virtual]
~GeometryQueryEngine()GeometryQueryEngine [inline, virtual]
