cgma
FaceterFacetData Member List
This is the complete list of members for FaceterFacetData, including all inherited members.
add_edge(CubitFacetEdge *edge)CubitFacet
add_TD(ToolData *new_td)ToolDataUser [virtual]
adjacent(int &index, int *tool_data)CubitFacet [inline]
angle(CubitPoint *pt)CubitFacet
area()CubitFacet
aspect_ratio()CubitFacet
bBoxCubitFacet [protected]
bounding_box()CubitFacet [inline]
bounding_box(CubitBox &box)CubitFacet [inline]
cachedPlaneCubitFacet [protected]
center()CubitFacet
closest_pointFaceterFacetData
CubitFacet::closest_point(const CubitVector &point, CubitVector &closest_point)CubitFacet [virtual]
closest_point_trimmed(const CubitVector &point, CubitVector &closest_point, CubitPoint *&next_edge_p1, CubitPoint *&next_edge_p2)CubitFacet
contains(CubitPoint *p1)CubitFacet
control_points()CubitFacet [inline]
CubitFacet()CubitFacet
debug_draw(int color=-1, int flush_it=1, int draw_uv=0)CubitFacet [virtual]
delete_TD(IdentityFn specified_type)ToolDataUser [virtual]
delete_TD(ToolData *td)ToolDataUser [virtual]
edge(int index)FaceterFacetData [inline, virtual]
edge(CubitFacetEdge *the_edge, int index)FaceterFacetData [inline, virtual]
edge_from_pts(CubitPoint *p1, CubitPoint *p2, int &index)CubitFacet
edge_index(CubitPoint *p1, CubitPoint *p2, int &sense)CubitFacet
edge_index(CubitFacetEdge *edge)CubitFacet
edge_use(int direction, int index)FaceterFacetData [inline, virtual]
edge_use(int index)FaceterFacetData [inline, virtual]
edgeArrayFaceterFacetData [private]
edges(DLIList< CubitFacetEdge * > &edge_list)CubitFacet [inline, virtual]
edgeUseFaceterFacetData [private]
entityIdFaceterFacetData [private]
eval_order()CubitFacet [inline]
evaluate(CubitVector &areacoord, CubitVector *eval_point, CubitVector *eval_normal=NULL)CubitFacet
evaluate_position(const CubitVector &start_position, CubitVector *eval_point, CubitVector *eval_normal=NULL)CubitFacet
FacetEntity()FacetEntity
FaceterFacetData(CubitPoint *p1, CubitPoint *p2, CubitPoint *p3)FaceterFacetData
facets(DLIList< CubitFacet * > &facet_list)CubitFacet [inline, virtual]
facetWeightCubitFacet [protected]
flip()FaceterFacetData [virtual]
get_all_TDs(IdentityFn specified_type, DLIList< ToolData * > *all_tds) const ToolDataUser [virtual]
get_all_TDs(DLIList< ToolData * > *all_tds) const ToolDataUser [virtual]
get_control_points(CubitVector points[6])CubitFacet
get_edge_1(CubitPoint *&p1, CubitPoint *&p2)CubitFacet [inline]
get_edge_2(CubitPoint *&p1, CubitPoint *&p2)CubitFacet [inline]
get_edge_3(CubitPoint *&p1, CubitPoint *&p2)CubitFacet [inline]
get_edge_control_points(CubitVector P[3][5])CubitFacet
get_edge_pts(int index, CubitPoint *&p1, CubitPoint *&p2)CubitFacet
get_parents(DLIList< FacetEntity * > &)CubitFacet [inline, virtual]
get_TD(IdentityFn specified_type)ToolDataUser [virtual]
get_TD(IdentityFn specified_type) const ToolDataUser [virtual]
id()FaceterFacetData [inline, virtual]
init_patch()CubitFacet
insert_point(const CubitVector &position, CubitFacet *&new_tri1, CubitFacet *&new_tri2)FaceterFacetData [virtual]
is_backwards()CubitFacet [inline]
is_backwards(int flipped)CubitFacet [inline]
is_flat()CubitFacet
is_flat(int flat)CubitFacet [inline]
isBackwardsCubitFacet [protected]
isFlatCubitFacet [protected]
marked(int mark)CubitFacet [inline]
marked()CubitFacet [inline]
markedFlagCubitFacet [protected]
memoryManagerFaceterFacetData [private, static]
min_diagonal()CubitFacet
my_pointsCubitFacet [static]
myOwnerFaceterFacetData [private]
next_edge(CubitFacetEdge *edge)CubitFacet
next_edge_at_point(CubitFacetEdge *edge_ptr, CubitPoint *point_ptr)CubitFacet
next_node(CubitPoint *current_point)CubitFacet [inline]
normal()CubitFacet
opposite_edge(CubitPoint *point, CubitPoint *&p1, CubitPoint *&p2)CubitFacet
opposite_point(CubitFacetEdge *edge)CubitFacet
other_index(CubitPoint *pt1, CubitPoint *pt2)CubitFacet
owner(RefEntity *owner)FaceterFacetData [inline]
owner()FaceterFacetData [inline]
patchCtrlPtsCubitFacet [protected]
plane()CubitFacet
plane(CubitPlane &this_plane)CubitFacet [inline]
point(int index)FaceterFacetData [inline, virtual]
point_edge_connCubitFacet [static]
point_facet_connCubitFacet [static]
point_index(CubitPoint *pt)CubitFacet
pointArrayFaceterFacetData [private]
points(CubitPoint *&p0, CubitPoint *&p1, CubitPoint *&p2)CubitFacet [inline]
points(CubitPoint *pts[3])CubitFacet [inline]
points(DLIList< CubitPoint * > &point_list)CubitFacet [inline, virtual]
prev_edge(CubitFacetEdge *edge)CubitFacet
remove_TD(IdentityFn specified_type)ToolDataUser [virtual]
remove_TD(ToolData *td)ToolDataUser [virtual]
reset_bounding_box()CubitFacet
sense(int)CubitFacet [inline, virtual]
set_control_points(CubitVector points[6])CubitFacet
set_control_points(const double *pt_array)CubitFacet
set_id(int ii)FaceterFacetData [inline, virtual]
set_point(CubitPoint *the_point, int index)FaceterFacetData [inline]
set_tool_id(int tool_id)CubitFacet [inline]
SetDynamicMemoryAllocation(memoryManager) CubitStatus closest_point(const CubitVector &pointFaceterFacetData
shared_edge(CubitFacet *cubit_facet)CubitFacet
shared_facet(CubitPoint *p1, CubitPoint *p2)CubitFacet
shared_facet_on_surf(CubitPoint *p1, CubitPoint *p2, int tool_id)CubitFacet
shared_facets(CubitPoint *p1, CubitPoint *p2, DLIList< CubitFacet * > &adj_facet_list)CubitFacet
split_edge(CubitPoint *edge_pt1, CubitPoint *edge_pt2, const CubitVector &position)FaceterFacetData [virtual]
tool_id()CubitFacet [inline]
ToolDataUser()ToolDataUser [inline]
toolIDCubitFacet [protected]
tri_nodes(CubitPoint *&p0, CubitPoint *&p1, CubitPoint *&p2)CubitFacet [inline]
unlink_from_children(void)CubitFacet
update_bezier_bounding_box()CubitFacet
update_normal(void)CubitFacet
update_plane()CubitFacet
weight(double facweight)CubitFacet [inline]
weight()CubitFacet [inline]
~CubitFacet()CubitFacet [virtual]
~FacetEntity()FacetEntity [virtual]
~FaceterFacetData()FaceterFacetData
~ToolDataUser()ToolDataUser [virtual]
