cgma
GeomMeasureTool Class Reference
Calculates measurements and statistics for a given entity. More...
#include <GeomMeasureTool.hpp>
List of all members.
Public Member Functions
 GeomMeasureTool ()
 ~GeomMeasureTool ()
Static Public Member Functions
static bool is_surface_narrow (RefFace *face, double small_curve_size)
 Determines if a surface is narrow.
static void find_split_points_for_narrow_regions (RefFace *face, double size, DLIList< CubitVector > &split_pos1_list, DLIList< CubitVector > &split_pos2_list)
 Determines points along which to make a curve for splitting a narrow surface.
static void measure_curve_length (DLIList< RefEntity * > &entity_list, double &smallest, RefEdge *&smallest_edge, double &largest, RefEdge *&largest_edge, double &average, double &sum)
static void measure_curve_length (DLIList< RefEdge * > &ref_edges, double &smallest, RefEdge *&smallest_edge, double &largest, RefEdge *&largest_edge, double &average, double &sum)
static void measure_face_curves (RefFace *ref_face, double &min_curve_length, double &max_curve_ratio, RefEdge *&min_ref_edge)
static int narrow_region_exists (RefFace *face, RefEdge *edge, const double &tol)
static int narrow_region_exists (RefEdge *e1, RefEdge *e2, RefFace *face, const double &tol, DLIList< CubitVector * > &e1_pos_list, DLIList< CubitVector * > &e2_pos_list, DLIList< RefVertex * > &e1_vert_list, DLIList< RefVertex * > &e2_vert_list)
static int narrow_region_exists (RefFace *face, const double &tol)
static int is_narrow_region_at_point (RefEdge *e1, RefFace *face, const CubitVector &pt_on_e1, RefEdge *e2, const double &tol_sq, CubitVector &closest)
static CubitStatus measure_face_loops (RefFace *face, double &min_distance_between_loops, double &min_distance_in_one_loop, double &min_angle, double &max_angle, double tolerance)
static void measure_face_area (DLIList< RefEntity * > &entity_list, double &smallest, RefFace *&smallest_face, double &largest, RefFace *&largest_face, double &average, double &sum)
static void measure_face_area (DLIList< RefFace * > &ref_faces, double &smallest, RefFace *&smallest_face, double &largest, RefFace *&largest_face, double &average, double &sum)
static void measure_volume_volume (DLIList< RefEntity * > &entity_list, double &smallest, RefVolume *&smallest_volume, double &largest, RefVolume *&largest_volume, double &average, double &sum)
static void measure_volume_volume (DLIList< RefVolume * > &ref_volumes, double &smallest, RefVolume *&smallest_volume, double &largest, RefVolume *&largest_volume, double &average, double &sum)
static void measure_face_area_and_hydraulic_radius (RefFace *curr_face, double &face_area, double &face_hydraulic_radius)
static void measure_volume_volume_and_hydraulic_radius (RefVolume *curr_volume, double &volume_volume, double &volume_hydraulic_radius)
static void angles_between_volume_surfaces (RefVolume *curr_volume, double &min_angle, double &max_angle, RefFace *&face_min_1, RefFace *&face_min_2, RefFace *&face_max_1, RefFace *&face_max_2)
static void merged_unmerged_surface_ratio (DLIList< RefVolume * > &ref_volumes, int &merged, int &unmerged, double &ratio)
static void report_intersected_volumes (DLIList< RefVolume * > &volume_list, DLIList< RefVolume * > &intersection_list)
 From a list of volumes, find ones that intersect.
static void report_intersected_bodies (DLIList< Body * > &ref_bodies, DLIList< Body * > &intersection_list)
 From a list of bodies, find ones that intersect.
static void find_shells (DLIList< RefVolume * > &input_vols, RefGroup *&owner_groups, int &number_of_shells)
 Finds lists of surfaces sharing common curves. Lists are found in the returned RefGroup.
static CubitStatus get_boundary_points (RefFace *ref_face, PointLoopList &boundary_point_loops, double seg_length_tol)
static CubitStatus get_curve_facets (RefEdge *curve, PointList &segments, double seg_length_tol)
 Get the points that approximate the curve, use the graphics facets.
static CubitStatus convert_to_lines (PointLoopList &boundary_point_loops, SegLoopList &boundary_line_loops, RefFace *ref_face)
static void print_surface_measure_summary (DLIList< RefFace * > &ref_faces)
static void print_volume_measure_summary (DLIList< RefVolume * > &ref_volumes)
static void find_adjacent_face_ratios (RefVolume *curr_volume, double &max_face_ratio, RefFace *&big_face, RefFace *&small_face)
static void find_narrow_faces (DLIList< RefVolume * > &ref_vols, double small_curve_size, DLIList< RefFace * > &narrow_faces, DLIList< RefFace * > &surfs_to_ignore)
 Finds narrow surfaces in the specified volumes.
static void find_closed_narrow_faces (DLIList< RefVolume * > &ref_vols, double tol, DLIList< RefFace * > &face_list)
 Finds the closed, narrow surfaces in the specified volumes.
static void get_narrow_regions (DLIList< RefVolume * > &ref_vols, double tol, DLIList< RefFace * > &surfs_with_narrow_regions)
static RefEdgefind_first_small_curve (RefVolume *vol, double tol)
 Finds the curves with lengths less than the given tol in specified volume.
static void find_small_curves (DLIList< RefVolume * > &ref_vols, double tol, DLIList< RefEdge * > &small_curves, DLIList< double > &small_lengths)
 Finds the curves with lengths less than the given tol.
static void find_surfs_with_narrow_regions (DLIList< RefVolume * > &ref_vols, double tol, DLIList< RefFace * > &surfs_with_narrow_regions)
static void find_small_faces (DLIList< RefVolume * > &ref_vols, double tol, DLIList< RefFace * > &small_faces)
 Finds the faces with areas less than the given ammount.
static void find_small_faces_hydraulic_radius (DLIList< RefVolume * > &ref_vols, double tol, DLIList< RefFace * > &small_faces, DLIList< double > &small_hyd_rad, double &percent_planar, double &percent_pl_co)
static void find_small_volumes (DLIList< RefVolume * > &ref_vols, double tol, DLIList< RefVolume * > &small_volumes)
 Finds the volumes with volumes less than tol.
static void find_small_volumes_hydraulic_radius (DLIList< RefVolume * > &ref_vols, double tol, DLIList< RefVolume * > &small_volumes, DLIList< double > &small_hyd_rad)
static void find_interior_curve_angles (RefVolume *ref_volume, double upper_bound, double lower_bound, DLIList< RefEdge * > &large_edge_angles, DLIList< RefEdge * > &small_edge_angles, DLIList< double > &large_angles, DLIList< double > &small_angles, int &total_interior, int &total_fuzzy)
static void find_sharp_tangential_meets (RefVolume *ref_volume, DLIList< RefEdge * > &small_angle_edge_pairs, DLIList< RefFace * > &tangential_surface_pairs)
static void find_dihedral_angles (DLIList< RefVolume * > &ref_vols, double upper_bound, double lower_bound, DLIList< RefFace * > &large_face_angles, DLIList< RefFace * > &small_face_angles, DLIList< double > &large_angles, DLIList< double > &small_angles, int &total_interior, int &total_fuzzy, int &total_not_flat)
static void find_dihedral_angles (RefVolume *curr_volume, double lower_bound, double upper_bound, DLIList< RefFace * > &large_face_angles, DLIList< RefFace * > &small_face_angles, DLIList< double > &large_angles, DLIList< double > &small_angles, int &total_interior, int &total_fuzzy, int &total_not_flat)
static void find_close_loops (DLIList< RefVolume * > &ref_vols, DLIList< RefEdge * > &close_edges, DLIList< RefFace * > &close_loop_faces, DLIList< double > &small_lengths, double tol)
static void find_close_loops (RefFace *face, DLIList< RefEdge * > &close_edges, DLIList< double > &small_lengths, double tol)
static double measure_area (RefFace *curr_face)
static void find_bad_geometry (RefVolume *volume, DLIList< RefEntity * > &bad_ents)
static void find_blends (RefVolume *ref_volume, DLIList< RefFace * > &blend_faces, DLIList< DLIList< RefFace * > * > &blend_groups)
static CubitBoolean is_face_blend (RefFace *ref_face, RefVolume *ref_volume, RefEdge *&ref_edge, RefEdge *&other_edge)
static CubitBoolean is_vertex_blend (RefFace *ref_face, RefVolume *ref_volume)
static CubitStatus find_blend_chains (RefFace *start_face, std::vector< std::vector< RefFace * > > &blend_chains)
static void find_blends_from_edge (RefVolume *ref_volume, RefFace *start_face, RefEdge *start_edge, std::vector< RefFace * > &blend_faces)
static CubitStatus get_centroid (RefFace *ref_face, CubitVector &centroid, double &tot_area)
static CubitStatus center (DLIList< RefFace * > ref_faces)
 Finds averge center of specified surfaces.
static CubitStatus find_closest_vertex_vertex_pairs (DLIList< RefVolume * > &vol_list, int &num_to_return, DLIList< RefVertex * > &vert_list1, DLIList< RefVertex * > &vert_list2, DLIList< double > &distances)
 Finds the 'n' closest vertex-vertex pairs and their distances apart.
static CubitStatus find_closest_vertex_curve_pairs (DLIList< RefVolume * > &vol_list, int &num_to_return, DLIList< RefVertex * > &vert_list, DLIList< RefEdge * > &curve_list, DLIList< double > &distances)
 Finds the 'n' closest vertex-curve pairs and their distances apart.
static CubitStatus find_near_coincident_vertices_unique (DLIList< RefVolume * > &ref_volumes, double high_tol, std::map< RefVertex *, DLIList< dist_vert_struct * > * > &vert_dist_map)
static CubitStatus find_near_coincident_vertices (DLIList< RefVolume * > &ref_volumes, DLIList< RefVertex * > &ref_vertices_out, DLIList< double > &distances, double low_tol, double high_tol, bool filter_same_volume_cases=false)
static CubitStatus find_near_coincident_vertex_curve_pairs (DLIList< RefVolume * > &ref_vols, DLIList< RefEdge * > &ref_edges, DLIList< RefVertex * > &ref_verts, DLIList< double > &distances, double low_tol, double high_tol, bool filter_same_volume_cases=false)
static CubitStatus find_near_coincident_vertex_surface_pairs (DLIList< RefVolume * > &ref_vols, DLIList< RefFace * > &ref_faces, DLIList< RefVertex * > &ref_verts, DLIList< double > &distances, double low_tol, double high_tol, bool filter_same_volume_cases=false)
static void find_irregular_valence (DLIList< RefVolume * > &ref_volumes, DLIList< RefVertex * > &irregular_vertices)
static void find_irregular_valence (RefVolume *ref_volume, DLIList< RefVertex * > &irregular_vertices)
Static Private Member Functions
static void get_edges_from_list (DLIList< RefEntity * > &entity_list, DLIList< RefEdge * > &ref_edges)
static void get_faces_from_list (DLIList< RefEntity * > &entity_list, DLIList< RefFace * > &ref_faces)
static void get_volumes_from_list (DLIList< RefEntity * > &entity_list, DLIList< RefVolume * > &ref_volumes)
static void get_bodies_from_list (DLIList< RefVolume * > &entity_list, DLIList< Body * > &ref_bodies)
static double dist_sq_point_data (CubitVector &curr_point, GeomSeg *&curr_seg)
static CubitStatus interior_angle (GeomSeg *first_seg, GeomSeg *next_seg, RefFace *face, double &angle)
static void find_index (DLIList< AreaHashTuple * > *hash_table, int table_size, RefFace *ref_face, AreaHashTuple *&curr_tuple)
static void get_adjacent_faces (RefFace *curr_face, DLIList< RefFace * > &adjacent_faces)
static CubitBoolean find_opposite_edge (RefEdge *ref_edge, RefFace *ref_face, RefEdge *&other_edge, CubitVector &closest_point)
static CubitBoolean is_equal (double v1, double v2)
static RefFacevalid_start (DLIList< RefFace * > &all_faces)
static void face_list_from_volume_list (DLIList< RefVolume * > &input_vols, DLIList< RefFace * > &all_faces)
Detailed Description
Definition at line 59 of file GeomMeasureTool.hpp.
Definition at line 132 of file GeomMeasureTool.hpp.
Definition at line 135 of file GeomMeasureTool.hpp.
Member Function Documentation
void GeomMeasureTool::angles_between_volume_surfaces ( RefVolume curr_volume,
double &  min_angle,
double &  max_angle,
RefFace *&  face_min_1,
RefFace *&  face_min_2,
RefFace *&  face_max_1,
RefFace *&  face_max_2
) [static]
Definition at line 1035 of file GeomMeasureTool.cpp.
  int ii, jj, shared_angles = 0;
  double common_angle, sum_of_angles = 0.0;
  double smallest = CUBIT_DBL_MAX, largest = 0.0;
  DLIList <RefFace*> face_list_1, face_list_2;
  RefFace *curr_face_1, *curr_face_2;
  RefEdge *common_edge;
  curr_volume->ref_faces(face_list_1);
  face_list_2 = face_list_1;
  for (ii = face_list_1.size(); ii > 0; ii--)
    curr_face_1 = face_list_1.get_and_step();
    for(jj = face_list_2.size(); jj > 0; jj--)
      curr_face_2 = face_list_2.get_and_step();
      if(curr_face_1 == curr_face_2)
        continue;
      else
        common_edge = curr_face_1->common_ref_edge(curr_face_2);
        if( common_edge == NULL )
          continue;
        else
          shared_angles++;
          if ( common_edge->get_curve_ptr()->geometry_type() != STRAIGHT_CURVE_TYPE )
            int kk;
            double frac_pos = 0.00;
            for ( kk = 0; kk < 4; kk++ )
              common_angle =  GeometryQueryTool::instance()->surface_angle(curr_face_1, curr_face_2,
        common_edge, curr_volume,
        frac_pos);
              frac_pos += .25;
              if( common_angle < smallest )
                min_angle = common_angle * (180 / CUBIT_PI);
                smallest = common_angle;
                face_min_1 = curr_face_1;
                face_min_2 = curr_face_2;
              if( common_angle > largest )
                max_angle = common_angle * (180 / CUBIT_PI);
                largest = common_angle;
                face_max_1 = curr_face_1;
                face_max_2 = curr_face_2;
          else
        common_edge, curr_volume );
          sum_of_angles += common_angle;
CubitStatus GeomMeasureTool::center ( DLIList< RefFace * >  ref_faces) [static]
Definition at line 4855 of file GeomMeasureTool.cpp.
  int ii,id;
  double surf_area;
  double tot_area = 0.0;
  CubitVector surf_centroid;
  CubitVector centroid;
  centroid.set( 0.0, 0.0, 0.0 );
  for ( ii = ref_faces.size(); ii > 0; ii-- )
    RefFace *ref_face = ref_faces.get_and_step();
    if( GeomMeasureTool::get_centroid( ref_face, surf_centroid, surf_area) != CUBIT_SUCCESS )
      return CUBIT_FAILURE;
    centroid += (surf_area * surf_centroid);
    tot_area += surf_area;
    id = ref_face->id();
  centroid /= tot_area;
  if( ref_faces.size() > 1 )
    PRINT_INFO("Centroid of Composite surface located at: ( %f , %f , %f )\n\n",
                 centroid.x(), centroid.y(), centroid.z());
  else
    PRINT_INFO("Centroid of Surface %i located at: ( %f , %f , %f )\n\n",
                  id, centroid.x(), centroid.y(), centroid.z());
  return CUBIT_SUCCESS;
CubitStatus GeomMeasureTool::convert_to_lines ( PointLoopList boundary_point_loops,
SegLoopList boundary_line_loops,
RefFace ref_face
) [static]
Converts the loops of points to line segments. Can fail if it can't determine the owner of the line segment. The refface may be needed to help determine ownership.
Definition at line 558 of file GeomMeasureTool.cpp.
    //This does more than just converts the boundary points to line segments.  It also
    //Sets up a doubily linked list through the ImprintLineSegment data structure.
    //Calling codes need to make sure all this data is deleted.
    //This function also sets the PointType for each of the boundary points.  This
    //will depend also on the boundary_1 flag.  If we are doing boundary_1 then,
    //the flag will be true, otherwise it will be false.
  int ii, jj;
  PointList *point_list;
  SegList *segment_list;
  GeomSeg *new_line, *prev = NULL;
  SegList allocated_segs;
  RefEntity *entity_start, *entity_end, *seg_owner;
  boundary_point_loops.reset();
  for ( ii = boundary_point_loops.size(); ii > 0; ii-- )
    point_list = boundary_point_loops.get_and_step();
    segment_list = new SegList;
    prev = NULL;
    new_line = NULL;
    seg_owner = NULL;
    for ( jj = point_list->size(); jj > 0; jj-- )
      entity_start = point_list->get()->owner();
      entity_end = point_list->next()->owner();
      seg_owner =  CAST_TO(entity_start, RefEdge);
      if ( seg_owner == NULL )
        seg_owner = CAST_TO(entity_end, RefEdge);
          RefVertex *ref_vert_end = CAST_TO(entity_end, RefVertex);
          RefVertex *ref_vert_start = CAST_TO(entity_start, RefVertex);
          DLIList <RefEdge*> common_edges;
          ref_vert_start->common_ref_edges(ref_vert_end,
                                           common_edges,
                                           ref_face);
          if ( common_edges.size() == 0  )
            PRINT_ERROR("GeomMeasureTool::convert_to_lines having problem finding owner \n"
                        "       of boundary.  Could be indicative of corrupt geometry.\n");
            int ll;
            for ( ll = boundary_line_loops.size(); ll > 0; ll-- )
              delete boundary_line_loops.pop();
            for ( ll = allocated_segs.size(); ll > 0; ll-- )
              delete allocated_segs.pop();
            delete segment_list;
          if ( common_edges.size() == 1 )
            seg_owner = common_edges.get();
          else
              //Now we have to decide which of these edges is the one.
              //Lets take a mid point on this segment and check the distances.
              //First find the mid_point of the line segment.
            CubitVector start = point_list->get()->coordinates();
            CubitVector end = point_list->next()->coordinates();
            CubitVector mid = (start+end)/2.0;
            CubitVector closest_point;
              //Now test the edges to see which is closest.
            RefEdge *closest_edge = NULL, *curr_ref_edge;
            double min_dist = CUBIT_DBL_MAX, dist;
            int kk;
            for ( kk = common_edges.size(); kk > 0; kk-- )
              curr_ref_edge = common_edges.get_and_step();
              curr_ref_edge->closest_point(mid, closest_point);
              dist = (mid - closest_point).length_squared();
              if ( dist < min_dist )
                min_dist = dist;
                closest_edge = curr_ref_edge;
            if ( closest_edge == NULL )
              PRINT_ERROR("Problems determining segment ownwership.\n"
                          "Internal problem with virtual imprinting.\n");
              int ll;
            seg_owner = closest_edge;
      new_line = new GeomSeg( point_list->get(), point_list->next(), seg_owner);
      allocated_segs.append(new_line);
      point_list->step();
      segment_list->append(new_line);
      if ( prev != NULL )
        prev->set_next(new_line);
        new_line->set_prev(prev);
      prev = new_line;
    if ( prev != NULL )
      segment_list->reset();
      assert(prev == segment_list->prev());
      segment_list->prev()->set_next(segment_list->get());
      segment_list->get()->set_prev(segment_list->prev());
      assert(segment_list->get()->get_next() != NULL );
    if ( segment_list->size() )
      boundary_line_loops.append(segment_list);
    else
double GeomMeasureTool::dist_sq_point_data ( CubitVector curr_point,
GeomSeg *&  curr_seg
) [static, private]
converts the entity list, and expands the list to get the edges, faces or volumes of the entities.
Definition at line 515 of file GeomMeasureTool.cpp.
  double node[3];
  double point_0[3], point_1[3];
  node[0] = curr_point.x();
  node[1] = curr_point.y();
  node[2] = curr_point.z();
  CubitVector start_v = curr_seg->get_start()->coordinates();
  CubitVector end_v = curr_seg->get_end()->coordinates();
  point_0[0] = start_v.x();
  point_0[1] = start_v.y();
  point_0[2] = start_v.z();
  point_1[0] = end_v.x();
  point_1[1] = end_v.y();
  point_1[2] = end_v.z();
  IntersectionTool new_tool(GEOMETRY_RESABS);
  double t;
  double dist = new_tool.distance_point_line(node, point_0,
                                             point_1, t);
  if ( dist < 0.0 )
      //This happens if the point is beyond the line segment, in which
      //case we just want the closer end point.
    if ( t < 0.0 )
      dist = (curr_point -start_v).length_squared();
    else
      dist = (curr_point - end_v).length_squared();
  else
      //I hate to do this but everything else is in
      //terms of distance squared.
    dist = dist*dist;
  return dist;
void GeomMeasureTool::face_list_from_volume_list ( DLIList< RefVolume * > &  input_vols,
DLIList< RefFace * > &  all_faces
) [static, private]
Definition at line 1306 of file GeomMeasureTool.cpp.
  DLIList <RefFace*> curr_faces;
  RefVolume *curr_vol;
  RefFace *curr_face;
  int ii, jj;
    //get the all RefFaces from input_vols.
    //put them into all_faces list.
  for ( ii = 0; ii < input_vols.size(); ii++ )
    curr_vol = input_vols.get_and_step();
    curr_faces.clean_out();
    curr_vol->ref_faces(curr_faces);
    for( jj = 0; jj < curr_faces.size(); jj++ )
      curr_face = curr_faces.get_and_step();
      if( curr_face->marked() )
        continue;
      else
        curr_face->marked(1);
        all_faces.append(curr_face);
  for ( ii = all_faces.size();ii >0; ii-- )
    all_faces.get_and_step()->marked(0);
void GeomMeasureTool::find_adjacent_face_ratios ( RefVolume curr_volume,
double &  max_face_ratio,
RefFace *&  big_face,
RefFace *&  small_face
) [static]
Finds the max ratio of adjacent face areas (big face area divided by small face area);
Definition at line 1574 of file GeomMeasureTool.cpp.
    //Loop over all the faces in the model.  Find the maximum face area ratio.
    //(larger face area / smaller face area)
  DLIList <Shell*> shells;
  curr_volume->shells(shells);
  DLIList <RefFace*> ref_face_stack, adj_faces;
  Shell* curr_shell;
  RefFace *curr_ref_face, *adj_face;
    //AreaHashTuple is defined in the .hpp file.
  DLIList <AreaHashTuple*> *hash_table;
  max_face_ratio = -CUBIT_DBL_MAX;
  int ii, jj, table_size;
  int hash_val;
  double tmp_area;
  double tmp_ratio;
  AreaHashTuple* curr_tuple, *adj_tuple;
  for ( ii = shells.size(); ii > 0; ii-- )
    curr_shell = shells.get_and_step();
    ref_face_stack.clean_out();
    curr_shell->ref_faces(ref_face_stack);
    table_size = ref_face_stack.size();
      //build a hash table with the most simple form
      //of hashing based on the ref face id.
      //To get this more reliable, make table size a prime
      //number...
      //Do this so that we don't have to calculate the
      //areas more than once...
    hash_table = new DLIList<AreaHashTuple*> [table_size];
    for ( jj = 0; jj < ref_face_stack.size(); jj++ )
      curr_ref_face = ref_face_stack.get_and_step();
      tmp_area = curr_ref_face->measure();
      curr_tuple = new AreaHashTuple();
      curr_tuple->myFace = curr_ref_face;
      curr_tuple->myArea = tmp_area;
      hash_val = curr_ref_face->id() % table_size;
      hash_table[hash_val].append(curr_tuple);
    while ( ref_face_stack.size() )
      curr_ref_face = ref_face_stack.pop();
        //Now get the adjacent faces.
      get_adjacent_faces(curr_ref_face, adj_faces);
      find_index(hash_table, table_size, curr_ref_face, curr_tuple);
      assert(curr_tuple != NULL);
      if ( curr_tuple == NULL )
        return;
      CubitBoolean curr_is_big = CUBIT_TRUE;
      for ( jj = 0; jj < adj_faces.size(); jj++ )
        adj_face = adj_faces.get_and_step();
        find_index(hash_table, table_size, adj_face, adj_tuple);
        if ( adj_tuple == NULL )
          continue;
        if ( curr_tuple->myArea < adj_tuple->myArea )
          tmp_ratio = adj_tuple->myArea / curr_tuple->myArea;
          curr_is_big = CUBIT_FALSE;
        else
          tmp_ratio = curr_tuple->myArea / adj_tuple->myArea;
        if ( tmp_ratio > max_face_ratio )
          max_face_ratio = tmp_ratio;
          if ( curr_is_big )
            big_face = curr_ref_face;
            small_face = adj_face;
          else
            big_face = adj_face;
            small_face = curr_ref_face;
    for ( jj = 0; jj < table_size; jj++ )
        //delete the area tuples.
      while ( hash_table[jj].size() > 0 )
        delete hash_table[jj].pop();
      //delete the hash_table.
    delete [] hash_table;
void GeomMeasureTool::find_bad_geometry ( RefVolume volume,
DLIList< RefEntity * > &  bad_ents
) [static]
This function simply gets the bad entities of the volume. This assumes the volume is from some solid modelar where this function is defined. If not, it will just be empty...
Definition at line 3960 of file GeomMeasureTool.cpp.
  Lump *lump_ptr = volume->get_lump_ptr();
  DLIList <TopologyEntity*> bad_top_ents;
  lump_ptr->validate(volume->entity_name(), bad_top_ents);
    //Now go through and get a RefEnttiy for each entity.
  RefEntity *ref_ent;
  TopologyEntity *topo_ent;
  GroupingEntity *gr_ent;
  SenseEntity *se_ent;
  int ii;
  for (ii = bad_top_ents.size(); ii > 0; ii-- )
    topo_ent = bad_top_ents.pop();
    ref_ent = CAST_TO(topo_ent, RefEntity);
    if ( ref_ent != NULL )
      bad_ents.append(ref_ent);
      continue;
    gr_ent = CAST_TO(topo_ent, GroupingEntity);
    if ( gr_ent != NULL )
      Chain *ch = CAST_TO(gr_ent, Chain);
      if ( ch != NULL )
        RefVertex *start_v = ch->start_vertex();
        RefVertex *end_v = ch->end_vertex();
        RefEdge *ref_edge = start_v->common_ref_edge(end_v);
        bad_ents.append(ref_edge);
        continue;
      Loop *lo = CAST_TO(gr_ent, Loop);
      if ( lo != NULL )
        RefFace *rf = lo->get_ref_face_ptr();
        bad_ents.append(rf);
        continue;
      Shell *sh = CAST_TO(gr_ent, Shell);
      if (sh != NULL )
        RefVolume *rv = sh->get_ref_volume_ptr();
        bad_ents.append(rv);
        continue;
      else
          //this is incase there is some other entity we don't
          //know about, just get the body...
        Body *body = topo_ent->body();
        bad_ents.append(body);
        continue;
    se_ent = CAST_TO(topo_ent, SenseEntity);
    if ( se_ent != NULL )
      BasicTopologyEntity *be = se_ent->get_basic_topology_entity_ptr();
      bad_ents.append(be);
      continue;
      //If we are here we didn't get the right entity.  Just get
      //the body associated with this topology entity.
    Body *b = topo_ent->body();
    bad_ents.append(b);
  return;
CubitStatus GeomMeasureTool::find_blend_chains ( RefFace start_face,
std::vector< std::vector< RefFace * > > &  blend_chains
) [static]
Given a starting blend surface find a chain of blends from that surface.
Note that this function intentionally does _not_ clear the blend_face list so that additional chains can be added.
Definition at line 4312 of file GeomMeasureTool.cpp.
  if (start_face == NULL)
  std::vector <RefFace*> blend_faces;
  // get the owning volume of this blend
  DLIList<RefEntity*> entity_list;
  RefVolume* ref_volume;
  int ii;
  start_face->get_parent_ref_entities(entity_list);
  // this indicates merged enitites and potential problems
  if (entity_list.size() > 1)
  // make sure we're at the beginning of the list and get the first
  // and only item on the list and cast it to a RefVolume
  entity_list.reset();
  ref_volume = CAST_TO(entity_list.get(), RefVolume);
  if (!ref_volume)
  // initialize the mark on all surfaces in the volume
  DLIList <RefFace*> ref_faces;
  ref_volume->ref_faces(ref_faces);
  RefEdge *spring_curve1, *spring_curve2;
  if ( is_face_blend(start_face, ref_volume, spring_curve1, spring_curve2 ) )
    // the is_face_blend function assumes (poorly) rectangular surfaces
    // without any holes.  It returns the spring curves and we want
    // the cross curves. So get all four edges and remove the two
    // spring curves returned by is_face_blend
    DLIList <RefEdge*> ref_edges;
    start_face->ref_edges(ref_edges);
    ref_edges.remove(spring_curve1);
    ref_edges.remove(spring_curve2);
    // there is a special case where the blend is a periodic surface
    // meaning that there _are_ no cross curves
    if ( ref_edges.size() == 0 )
      blend_faces.push_back(start_face);
    else
      // now find additional blends extending from either side of the blend
      blend_faces.clear();
      find_blends_from_edge( ref_volume, start_face, ref_edges.get(), blend_faces);
      find_blends_from_edge( ref_volume, start_face, ref_edges.next(1), blend_faces);
      // make sure that we have a unique list (the start surface is probably here twice)
      std::vector<RefFace*>::iterator new_end;
      std::sort( blend_faces.begin(), blend_faces.end() );
      new_end = std::unique( blend_faces.begin(), blend_faces.end() );
      blend_faces.erase(new_end, blend_faces.end());
    blend_chains.push_back(blend_faces);
  else if ( is_vertex_blend(start_face, ref_volume) )
    DLIList<RefEdge*> ref_edges;
    for (ii = 0; ii < ref_edges.size(); ii++)
      RefEdge* start_edge = ref_edges.get_and_step();
      find_blends_from_edge( ref_volume, start_face, start_edge, blend_faces);
  else
    // the given face is not a blend
void GeomMeasureTool::find_blends ( RefVolume ref_volume,
DLIList< RefFace * > &  blend_faces,
DLIList< DLIList< RefFace * > * > &  blend_groups
) [static]
Find fillets and rounds.
====IMPORTANT==== Calling functions BEWARE, YOU MUST DELETE THE LISTS OF BLEND SURFACES IN THE BLEND GROUPS AFTER CALLING THIS FUNCTION!!!! ====IMPORTANT====
Definition at line 4075 of file GeomMeasureTool.cpp.
    //Assume for now that blends have cartesian angles between
    //all the attached faces and itself.
    //Also a blend cannot be planar.  And directly accross from
    //one blend edge, there is usually another blended edge but
    //the angle between the two normals must be orthogonal. In other
    //words their must be some sort of transition.
    //mark all the faces as 0.  The mark is used here to find the
    // blend groups.  The function is_vertex_blend() marks faces
    // as being a vertex blend.  The group of faces is then traversed
    // until the adjacent surface (across the cross curve) is either
    // a vertex blend or not a blend.
  DLIList <RefFace*> vertex_blends, face_blends;
  int ii, jj;
  for ( ii =0; ii < ref_faces.size(); ii++ )
    ref_faces.get_and_step()->marked(0);
    //First go through each face and each edge on each face.
  RefFace *ref_face;
  RefEdge *ref_edge, *other_edge;
  int num_vertex_blends = 0;
  int num_face_blends = 0;
      //Test the face to see if it is a face or vertex blend.
    other_edge = NULL;
    ref_edge = NULL;
    if ( is_face_blend(ref_face, ref_volume,
                       ref_edge, other_edge ) )
      face_blends.append(ref_face);
      ref_face->marked(1);
      num_face_blends++;
    else if ( is_vertex_blend(ref_face, ref_volume) )
      vertex_blends.append(ref_face);
      ref_face->marked(2);
      num_vertex_blends++;  // keep track of the number of vertex blends
  if ( face_blends.size() + vertex_blends.size() == 0 )
    return;
    //Find out how many different groups of surfaces there
    //are that share curves.
  DLIList <RefFace*> *blend_group = NULL;
  DLIList <RefFace*> stack;
  RefFace *start_face = NULL, *other_face;
  // continue while there are blends to process
  while ( vertex_blends.size() + face_blends.size() > 0 ||
          start_face != NULL)
    // if we don't have a start_face, get a new one.
    if (!start_face)
      // this is the start of a new group
      blend_group = new DLIList <RefFace*>;
      blend_groups.append(blend_group);
      // always prefer to start at a vertex blend if one exists
      if (vertex_blends.size() > 0 )
        start_face = vertex_blends.pop();
      else
        start_face = face_blends.pop();
    blend_group->append(start_face);  // add ref_face to group
    blend_faces.append(start_face);   // add the ref_face to the returned list
    start_face->marked(BLEND_PROCESSED);
    ref_edges.clean_out();
    for ( jj = 0; jj < ref_edges.size(); jj++ )
      ref_edge = ref_edges.get_and_step();
      other_face = ref_edge->other_face(start_face, ref_volume);
      if (other_face == NULL)
        start_face = NULL;
        break;
      // if this blend has been processed and isn't in the current group
      if (other_face->marked() == BLEND_PROCESSED &&
          !blend_group->is_in_list(other_face) )
        start_face = NULL;
        break;  // reached an end of this loop
      else if (other_face->marked() == VERTEX_BLEND)
        blend_group->append(other_face);  // add the ref_face to the group
        blend_faces.append(other_face);   // add the ref_face to the returned list
        vertex_blends.remove(other_face);
        other_face->marked(BLEND_PROCESSED);
        start_face = NULL;
        break;  // a vertex blend is also end of the line
      else if (other_face->marked() == FACE_BLEND)
        start_face = other_face;
        face_blends.remove(other_face);
        break;  // continue using this face as the new start face
    // if we traversed through all the edges of this blend without
    // finding another blend attached, this is the end of the chain
    // and we need to find another starting place.
    if ( jj >= ref_edges.size() )
      start_face = NULL;
    //cleanup marks.
  for ( ii =0; ii < blend_faces.size(); ii++ )
    blend_faces.get_and_step()->marked(0);
    //Okay we should have it now.
    //REMEMBER TO DELETE the dllists in blend_faces.
  return;
void GeomMeasureTool::find_blends_from_edge ( RefVolume ref_volume,
RefFace start_face,
RefEdge start_edge,
std::vector< RefFace * > &  blend_faces
) [static]
should this one be private? Given a blend surface and one of the cross curves, find the blends connected along the edge in the one direction.
Definition at line 4224 of file GeomMeasureTool.cpp.
  RefEdge *next_edge, *other_edge;
  int ii;
  std::stack<NextBlend> blend_stack;
  NextBlend blend;
  blend.ref_edge = start_edge;
  blend.ref_face = start_face;
  blend_stack.push(blend);
  while (blend_stack.size() > 0)
    // this is an oddity with std::stack.  Get the top of the stack
    // and then you have to remove it from the stack with pop
    NextBlend next_blend = blend_stack.top();
    blend_stack.pop();
    RefEdge* ref_edge = next_blend.ref_edge;
    RefFace* ref_face = next_blend.ref_face;
    RefFace* next_face;
    next_face = ref_edge->other_face(ref_face, ref_volume);
    // the the next face exists and it's a face blend, save the current blend,
    // create a new blend object and add it to the stack
    if ( next_face && is_face_blend(next_face, ref_volume, next_edge, other_edge ) )
      // if the next face is already processed, the chain loops back on itself.
      if (next_face->marked() == BLEND_PROCESSED)
        return;
      blend_faces.push_back(next_face);
      next_face->marked(BLEND_PROCESSED);
      next_face->ref_edges(ref_edges);
      ref_edges.remove(next_edge);
      ref_edges.remove(other_edge);
      if (ref_edges.get() != ref_edge)
        next_blend.ref_edge = ref_edges.get();
      else
        next_blend.ref_edge = ref_edges.next(1);
      next_blend.ref_face = next_face;
      blend_stack.push(next_blend);
    else if ( next_face && is_vertex_blend(next_face, ref_volume) )
      // we will stop the chain at a vertex blend
  // clean up the marks
  std::vector<RefFace*>::iterator iter;
  for ( iter = blend_faces.begin(); iter != blend_faces.end(); iter++)
    (*iter)->marked(0);
void GeomMeasureTool::find_close_loops ( DLIList< RefVolume * > &  ref_vols,
DLIList< RefEdge * > &  close_edges,
DLIList< RefFace * > &  close_loop_faces,
DLIList< double > &  small_lengths,
double  tol
) [static]
Finds the surfaces with multiple loops that have small, relative to tol, distances between the loops. Note that all the lists are syncronized to be connected. The pairs of close edges with the small_lengths and the surfaces that they are on. The close_loop_faces list may not contain distinct instances of faces, as they may be repeated. Note that this will only find the closest edge pair, within tol, for each loop.
Definition at line 3713 of file GeomMeasureTool.cpp.
  int ii, jj;
  DLIList <RefFace*> ref_faces, temp_faces;
  RefVolume *ref_vol;
  RefFace *curr_face;
  for ( ii = 0; ii < ref_vols.size(); ii++ )
    ref_vol = ref_vols.get_and_step();
    ref_vol->ref_faces(temp_faces);
      //uniquely add the faces.
    for ( jj = temp_faces.size(); jj > 0; jj-- )
      curr_face = temp_faces.pop();
      ref_faces.append(curr_face);
  DLIList <RefEdge*> tmp_close_edges;
  DLIList <double> tmp_small_lengths;
    curr_face = ref_faces.get_and_step();
    curr_face->marked(0);
    if ( curr_face->num_loops() < 2 )
      continue;
    tmp_close_edges.clean_out();
    tmp_small_lengths.clean_out();
    find_close_loops( curr_face, tmp_close_edges,
                      tmp_small_lengths, tol);
    if ( tmp_close_edges.size() > 0 )
      assert(tmp_close_edges.size()%2 == 0 );
      tmp_close_edges.reset();
      tmp_small_lengths.reset();
      for ( jj = tmp_close_edges.size()/2; jj > 0; jj-- )
        close_edges.append(tmp_close_edges.get_and_step());
        small_lengths.append(tmp_small_lengths.get_and_step());
        close_loop_faces.append(curr_face);
  return;
void GeomMeasureTool::find_close_loops ( RefFace face,
double  tol
) [static]
Finds the edges of the loops that are within some tol. The edges are stored in successive pairs in close_edges while the actual distances are stored in the small_lengths list. These lists are syncronized (and are assumed to be empty upon entrance to the function).
Definition at line 3765 of file GeomMeasureTool.cpp.
    //only do faces with multiple loops since we are measuring the
    //distances between these loops.
  if ( face->num_loops() < 2 )
    return;
    //This is the most tricky of these functions.
    //To do this I'm going to facet the edges, then use an AbstractTree to
    //find the minimum distance between the loops and between a single
    //loop.
  PointLoopList boundary_point_loops;
  CubitStatus stat;
  stat = get_boundary_points(face, boundary_point_loops, GEOMETRY_RESABS*100);
  if ( stat != CUBIT_SUCCESS )
    return;
  SegLoopList boundary_seg_loops;
  stat = convert_to_lines( boundary_point_loops,
                           boundary_seg_loops,
                           face);
    return;
    //Now add the points to the AbstractTree.
  DLIList<AbstractTree<GeomSeg*>*> atree_list;
  AbstractTree<GeomSeg*> *curr_tree;
  SegList *seg_list;
  GeomSeg  *curr_seg;
  int ii,jj, kk;
  //const double angle_convert = 180.0/CUBIT_PI;
  boundary_seg_loops.reset();
  int num_segs = 0;
  for (ii = 0; ii < boundary_seg_loops.size(); ii++ )
    seg_list = boundary_seg_loops.get_and_step();
    curr_tree = new RTree<GeomSeg*>(GEOMETRY_RESABS);
    for ( jj = seg_list->size(); jj > 0; jj-- )
        //build the r-tree.
      num_segs++;
      curr_seg = seg_list->get_and_step();
      curr_tree->add(curr_seg);
        //calculate the interior angles.
    atree_list.append(curr_tree);
    //determine the minimum distance between the loops.
  PointList *curr_points;
  GeomPoint *curr_point;
  DLIList <GeomSeg*> nearest_neighbors;
  RefEdge *closest_edge_1, *closest_edge_2;
  CubitVector curr_loc;
  double closest_dist;
  double min_for_loop_squared;
  atree_list.reset();
  // This searching was orignally coded to not be an n-squared
  // search but I changed it to be n-squared because the
  // way the loops are compared comparing loop 1 against loop 2 may
  // give a different result than comparing loop 2 against loop 1.
  for ( ii = 0; ii < atree_list.size(); ii++ )
    curr_points = boundary_point_loops.get_and_step();
    for ( jj = 1; jj < atree_list.size(); jj++ )
      min_for_loop_squared = CUBIT_DBL_MAX;
      closest_edge_1 = NULL;
      closest_edge_2 = NULL;
      curr_tree = atree_list.next(ii+jj);
        //now for every point in curr_points, find it's closest_point
        //in the curr_tree.
      for ( kk = 0; kk < curr_points->size(); kk++ )
        curr_point = curr_points->get_and_step();
        curr_loc.set(curr_point->coordinates());
        nearest_neighbors.clean_out();
        curr_tree->k_nearest_neighbor(curr_loc,
                                      1, closest_dist, nearest_neighbors,
                                      dist_sq_point_data);
        if ( nearest_neighbors.size() == 0)
            //hmm, not sure what is wrong here.
          PRINT_ERROR("Can't find closest point between loops.\n");
        if (closest_dist <= tol*tol && closest_dist < min_for_loop_squared )
            //just store the smaller ones.  Don't store
          RefEntity *ref_ent = curr_point->owner();
          GeomSeg *near_seg = nearest_neighbors.get();
          RefEdge *ref_edge_1 = CAST_TO(ref_ent, RefEdge);
          if ( ref_edge_1 == NULL )
              //assume this is a vertex.
            RefVertex *ref_vert = CAST_TO(ref_ent, RefVertex);
            if ( ref_vert == NULL )
              PRINT_ERROR("problem with point ownership in closest loops.\n");
              continue;
            ref_vert->ref_edges(ref_edges);
            int ll;
            RefEdge *the_edge = NULL;
            for ( ll = ref_edges.size(); ll > 0; ll-- )
              if ( ref_edges.get()->is_directly_related(face) )
                the_edge = ref_edges.get();
                break;
              ref_edges.step();
            if ( the_edge == NULL )
              continue;
            ref_edge_1 = the_edge;
          ref_ent = near_seg->owner();
          RefEdge *ref_edge_2 = CAST_TO(ref_ent, RefEdge);
          if ( ref_edge_2 == NULL )
            continue;
          min_for_loop_squared = closest_dist;
          closest_edge_1 = ref_edge_1;
          closest_edge_2 = ref_edge_2;
      if ( closest_edge_1 != NULL )
        close_edges.append(closest_edge_1);
        close_edges.append(closest_edge_2);
        small_lengths.append(sqrt(min_for_loop_squared));
    //clean up the memory.
  int ll,mm;
  atree_list.reset();
  for ( ll = boundary_seg_loops.size(); ll > 0; ll-- )
    delete atree_list.pop();
    seg_list = boundary_seg_loops.pop();
    for ( mm = seg_list->size(); mm > 0; mm-- )
      delete seg_list->pop();
    delete seg_list;
  for ( ll = boundary_point_loops.size(); ll > 0; ll-- )
    point_list = boundary_point_loops.pop();
    for ( mm = point_list->size(); mm > 0; mm-- )
      GeomPoint *tmp_point = point_list->pop();
        //delete the CubitPointData
      delete tmp_point;
    delete point_list;
  return;
void GeomMeasureTool::find_closed_narrow_faces ( DLIList< RefVolume * > &  ref_vols,
double  tol,
DLIList< RefFace * > &  face_list
) [static]
Definition at line 3016 of file GeomMeasureTool.cpp.
  int ii, jj;
  RefVolume *ref_vol;
  RefFace *curr_face;
    DLIList<RefFace*> faces;
    ref_vol->ref_faces(faces);
    for ( jj = faces.size(); jj > 0; jj-- )
      curr_face = faces.get_and_step();
      temp_faces.append(curr_face);
    curr_face = temp_faces.get_and_step();
    if ( curr_face->marked()== 0 )
  int num_faces = ref_faces.size();
  ProgressTool *progress_ptr = NULL;
  if (num_faces > 20)
    progress_ptr = AppUtil::instance()->progress_tool();
    assert(progress_ptr != NULL);
    progress_ptr->start(0, 100, "Finding Small Surfaces",
      NULL, CUBIT_TRUE, CUBIT_TRUE);
  int total_faces = 0;
  double curr_percent = 0.0;
    total_faces++;
    if ( progress_ptr != NULL )
      curr_percent = ((double)(total_faces))/((double)(num_faces));
      progress_ptr->percent(curr_percent);
    if ( AppUtil::instance()->interrupt() )
        //interrpt.  We need to exit.
        progress_ptr->end();
        //just leave what has been calculated...
      return;
    if(curr_face->get_surface_ptr()->is_closed_in_U() || curr_face->get_surface_ptr()->is_closed_in_V())
      if(curr_face->num_loops() == 2)
        DLIList<RefEdge*> ref_edge_list;
        curr_face->ref_edges(ref_edge_list);
        if(ref_edge_list.size() == 2)
          int num_pts = 5;
          double start, end;
          RefEdge *e1 = ref_edge_list.get_and_step();
          RefEdge *e2 = ref_edge_list.get();
          e1->get_param_range(start, end);
          double dt = (end-start)/(double)(num_pts-1);
          double t = start;
          bool one_bad = false;
          double dist_sq = tol*tol;
          for(jj=0; jj<num_pts && one_bad == false; jj++)
            CubitVector pos1, pos2;
            e1->position_from_u(t, pos1);
            e2->closest_point_trimmed(pos1, pos2);
            if((pos1-pos2).length_squared() > dist_sq)
              one_bad = true;
            t += dt;
          if(one_bad == false)
            face_list.append(curr_face);
  return;
CubitStatus GeomMeasureTool::find_closest_vertex_curve_pairs ( DLIList< RefVolume * > &  vol_list,
int &  num_to_return,
DLIList< RefVertex * > &  vert_list,
DLIList< RefEdge * > &  curve_list,
DLIList< double > &  distances
) [static]
Definition at line 5099 of file GeomMeasureTool.cpp.
  DLIList<RefFace*> surfs;
  int i, total_num_entries = 0;
  for( i=vol_list.size(); i--; )
    RefVolume *tmp_vol = vol_list.get_and_step();
    tmp_vol->ref_faces( surfs );
  std::set<dist_vert_curve_struct*,vert_curve_dist_sort_ptr> distance_vertex_curve_set;
  for(i=surfs.size(); i>0; i--)
    RefFace *surf = surfs.get_and_step();
    DLIList<RefVertex*> surf_verts;
    surf->ref_vertices(surf_verts);
    DLIList<RefEdge*> surf_curves;
    surf->ref_edges(surf_curves);
    int j;
    for(j=surf_verts.size(); j>0; j--)
      RefVertex *tmp_vert = surf_verts.get_and_step();
      CubitVector vert_xyz = tmp_vert->coordinates();
      CubitVector closest_pt;
      int k;
      for(k=surf_curves.size(); k>0; k--)
        RefEdge *cur_edge = surf_curves.get_and_step();
        if(cur_edge->start_vertex() != tmp_vert &&
          cur_edge->end_vertex() != tmp_vert)
          cur_edge->closest_point_trimmed(vert_xyz, closest_pt);
          if(!closest_pt.about_equal(cur_edge->start_coordinates()) &&
             !closest_pt.about_equal(cur_edge->end_coordinates()))
            double dist_sq = vert_xyz.distance_between_squared(closest_pt);
            dist_vert_curve_struct *tmp_struct = new dist_vert_curve_struct;
            tmp_struct->dist = dist_sq;
            tmp_struct->vert = tmp_vert;
            tmp_struct->edge = cur_edge;
            distance_vertex_curve_set.insert( tmp_struct );
            total_num_entries++;
  std::set<dist_vert_curve_struct*, vert_curve_dist_sort_ptr>::iterator iter, upper_iter;
  int local_num_to_return = num_to_return;
  if(num_to_return == -1)
    local_num_to_return = total_num_entries;
  int cntr = 0;
  iter = distance_vertex_curve_set.begin();
  for(; iter!=distance_vertex_curve_set.end() && cntr < local_num_to_return; iter++ )
    distances.append( sqrt((*iter)->dist) );
    vert_list.append( (*iter)->vert );
    curve_list.append( (*iter)->edge );
    cntr++;
  for(; iter!=distance_vertex_curve_set.end(); iter++ )
    delete *iter;
CubitStatus GeomMeasureTool::find_closest_vertex_vertex_pairs ( DLIList< RefVolume * > &  vol_list,
DLIList< RefVertex * > &  vert_list1,
DLIList< RefVertex * > &  vert_list2,
) [static]
Definition at line 5181 of file GeomMeasureTool.cpp.
  std::set<dist_vert_vert_struct*,vert_vert_dist_sort_ptr> distance_vertex_vertex_set;
    DLIList<RefVertex*> vol_verts;
    tmp_vol->ref_vertices(vol_verts);
    while(vol_verts.size() > 1)
      RefVertex *vert1 = vol_verts.pop();
      CubitVector vert1_xyz = vert1->coordinates();
      int j;
      for(j=vol_verts.size(); j>0; j--)
        RefVertex *vert2 = vol_verts.get_and_step();
        double dist_sq = vert2->coordinates().distance_between_squared(vert1_xyz);
        dist_vert_vert_struct *tmp_struct = new dist_vert_vert_struct;
        tmp_struct->vert1 = vert1;
        tmp_struct->vert2 = vert2;
        distance_vertex_vertex_set.insert( tmp_struct );
  std::set<dist_vert_vert_struct*, vert_vert_dist_sort_ptr>::iterator iter, upper_iter;
  int cntr = 0;
  iter = distance_vertex_vertex_set.begin();
  for(; iter!=distance_vertex_vertex_set.end() && cntr < local_num_to_return; iter++ )
    vert_list1.append( (*iter)->vert1 );
    vert_list2.append( (*iter)->vert2 );
    cntr++;
  for(; iter!=distance_vertex_vertex_set.end(); iter++ )
    delete *iter;
void GeomMeasureTool::find_dihedral_angles ( DLIList< RefVolume * > &  ref_vols,
double  upper_bound,
double  lower_bound,
DLIList< RefFace * > &  large_face_angles,
DLIList< RefFace * > &  small_face_angles,
DLIList< double > &  large_angles,
DLIList< double > &  small_angles,
int &  total_interior,
int &  total_fuzzy,
int &  total_not_flat
) [static]
Finds the large and small angles or rather the surfaces on the volumes that make them.
Definition at line 3580 of file GeomMeasureTool.cpp.
  int ii;
  RefVolume *ref_vol;
  total_interior = 0;
  total_fuzzy = 0;
  total_not_flat = 0;
    find_dihedral_angles(ref_vol, upper_bound,
                         lower_bound,
                         large_face_angles,
                         small_face_angles,
                         large_angles, small_angles,
                         total_interior, total_fuzzy, total_not_flat);
  return;
void GeomMeasureTool::find_dihedral_angles ( RefVolume curr_volume,
double  lower_bound,
double  upper_bound,
int &  total_fuzzy,
) [static]
Finds the surfaces that have big and small angles compared to the upper and lower bounds (these should be in degrees...). The faces that make these angles are paired (one after the other) in the lists large and small angles.
Definition at line 3608 of file GeomMeasureTool.cpp.
  double common_angle;
  DLIList <RefFace*> face_list;
  RefFace *tmp_face;
  DLIList <RefVolume*> ref_vols;
  DLIList<RefEdge*> vol_edges;
  curr_volume->ref_edges(vol_edges);
  //maybe the body is a sheet-body...don't print errors if so
  bool is_sheet_body = false;
  if( curr_volume->measure() == 0 )
    is_sheet_body = true;
  for ( ii = vol_edges.size(); ii > 0; ii-- )
    common_edge = vol_edges.get_and_step();
    //skip point curves
    if( common_edge->geometry_type() == POINT_CURVE_TYPE )
      continue;
    curr_face_1 = NULL;
    curr_face_2 = NULL;
    face_list.clean_out();
    common_edge->ref_faces(face_list);
      //find the two faces that are part of this volume.
    for ( jj = face_list.size(); jj > 0; jj-- )
      tmp_face = face_list.get_and_step();
      ref_vols.clean_out();
      tmp_face->ref_volumes(ref_vols);
      if ( ref_vols.move_to(curr_volume) )
        if ( curr_face_1 == NULL )
          curr_face_1 = tmp_face;
        else if ( curr_face_2 == NULL )
          curr_face_2 = tmp_face;
          break;
    if ( curr_face_1 == NULL ||
      if( is_sheet_body == false )
        PRINT_ERROR("Problems finding connected surfaces to a curve\n"
                   "\tfor measuring dihedral angles.\n");
      continue;
    shared_angles++;
        curr_face_2,
        common_edge,
        curr_volume);
    common_angle *= 180.0/CUBIT_PI;
    total_interior++;
      //use hard coded angles because we want these a little looser.
    if ( common_angle >= 200.0 ||
         common_angle <= 160.0 )
      total_not_flat++;
    if ( curr_face_1->geometry_type() != PLANE_SURFACE_TYPE ||
         curr_face_2->geometry_type() != PLANE_SURFACE_TYPE )
      total_fuzzy++;
    else if ( common_angle <= GEOM_END_LOWER )
      total_fuzzy++;
    else if ( common_angle >= GEOM_END_UPPER &&
              common_angle <= GEOM_SIDE_LOWER )
      total_fuzzy++;
    else if ( common_angle >= GEOM_SIDE_UPPER &&
              common_angle <= GEOM_CORNER_LOWER )
      total_fuzzy++;
    else if ( common_angle >= GEOM_CORNER_UPPER )
      total_fuzzy++;
    if( common_angle <= lower_bound )
      small_face_angles.append(curr_face_1);
      small_face_angles.append(curr_face_2);
      small_angles.append(common_angle);
    if( common_angle >= upper_bound )
      large_face_angles.append(curr_face_1);
      large_face_angles.append(curr_face_2);
      large_angles.append(common_angle);
    //clean up the edge marks.
    vol_edges.get_and_step()->marked(0);
RefEdge * GeomMeasureTool::find_first_small_curve ( RefVolume vol,
double  tol
) [static]
Definition at line 2838 of file GeomMeasureTool.cpp.
  RefEdge *ret = NULL;
  int j;
  vol->ref_edges(ref_edges);
  for(j=ref_edges.size(); j > 0 && !ret; j--)
    RefEdge *curr_edge = ref_edges.get_and_step();
    if(curr_edge->measure() <= tol)
      ret = curr_edge;
  return ret;
void GeomMeasureTool::find_index ( DLIList< AreaHashTuple * > *  hash_table,
int  table_size,
RefFace ref_face,
AreaHashTuple *&  curr_tuple
) [static, private]
measures the interior angle between the two connected segments. Returns an error if the segments are not connected or if the surface normal length is zero.
Definition at line 1672 of file GeomMeasureTool.cpp.
  int ii;
  int hash_val = ref_face->id() % table_size;
  if ( hash_table[hash_val].size() == 0 )
      //this ref face isn't store here.
    curr_tuple = NULL;
    return;
  int curr_size = hash_table[hash_val].size();
    //resolve collisions by separate chaining method...
  for ( ii = 0;ii < curr_size; ii++ )
    if ( hash_table[hash_val].next(ii)->myFace == ref_face )
      curr_tuple = hash_table[hash_val].next(ii);
      return;
  curr_tuple = NULL;
  return;
void GeomMeasureTool::find_interior_curve_angles ( RefVolume ref_volume,
double  upper_bound,
double  lower_bound,
DLIList< RefEdge * > &  large_edge_angles,
DLIList< RefEdge * > &  small_edge_angles,
int &  total_fuzzy
) [static]
For each surface in the volume, find the interior angles defined by the curves in the surfaces that are either below or greater than the the upper and lower bounds. The angles and therefor bounds, are tracked in degrees. Curves that fit into these categories are stored pairwise in the large or small edge_angles lists. The corresponding angle measurements are stored in the respective small and large angles lists.
Definition at line 3449 of file GeomMeasureTool.cpp.
  int ii, jj, kk;
  RefFace *curr_face;
  total_interior = 0;
  total_fuzzy = 0;
    //Okay now loop over the edge loops of the reffaces
    //and find the interior angles.
  DLIList<Loop*> loops;
  Loop *curr_loop;
  DLIList <CoEdge*> co_edges;
  CoEdge *curr_edge, *next_edge;
  double angle = 0.0;
  const double RAD_TO_DEG = 180.0/CUBIT_PI;
    curr_face->loops(loops);
      //Now loop over these loops.
    for ( jj = loops.size(); jj > 0; jj-- )
      curr_loop = loops.pop();
        //now loop over the edges in this
      co_edges.clean_out();
      curr_loop->ordered_co_edges(co_edges);
      for ( kk = co_edges.size(); kk > 0; kk-- )
        curr_edge = co_edges.get_and_step();
        next_edge = co_edges.get();
        if ( curr_edge == next_edge )
            //This is a hardpoint
          if ( curr_edge->get_ref_edge_ptr()->geometry_type() == POINT_CURVE_TYPE )
            angle = 360.0;
              //for now ignore this..
            continue;
          else
            RefEdge *the_edge = curr_edge->get_ref_edge_ptr();
              //Get points 1% from the ends in both directions.
            CubitVector point_start, point_end;
            CubitStatus stat = the_edge->position_from_fraction(0.01,
        point_start);
              angle = 180.0;
            else
              stat = the_edge->position_from_fraction(0.99,
                                                      point_end);
                angle = 180.0;
              else
                CubitVector normal = curr_face->normal_at(point_start, NULL);
                CubitVector tangent_1, tangent_2;
                stat = the_edge->tangent( point_start, tangent_1, curr_face);
                CubitStatus stat2 = the_edge->tangent( point_end, tangent_2, curr_face);
                if ( stat != CUBIT_SUCCESS || stat2 != CUBIT_SUCCESS )
                  angle = 180.0;
                else
                    //one of the tangents will be pointing the wrong
                    //direction, so reverse it based on the sense.
                  if ( curr_edge->get_sense() == CUBIT_REVERSED )
                    tangent_1 = -tangent_1;
                  else
                    tangent_2 = -tangent_2;
                  angle = normal.vector_angle(tangent_2, tangent_1);
                  angle *= RAD_TO_DEG;
        else if ( curr_edge->get_ref_edge_ptr() == next_edge->get_ref_edge_ptr() )
            //This is the end of a hard line. Set this angle because
            //it is tricky to measure it.
          angle = 360.0;
        else if ( curr_edge != next_edge )
          angle =
            GeometryQueryTool::instance()->geometric_angle(curr_edge,
                                                           next_edge);
        total_interior++;
          //count the number of angles that are fuzzy.
        if ( angle <= GEOM_END_LOWER )
          total_fuzzy++;
        else if ( angle >= GEOM_END_UPPER &&
          total_fuzzy++;
        else if ( angle >= GEOM_SIDE_UPPER &&
          total_fuzzy++;
        else if ( angle >= GEOM_CORNER_UPPER )
          total_fuzzy++;
        if ( angle <= lower_bound )
          small_edge_angles.append(curr_edge->get_ref_edge_ptr());
          small_edge_angles.append(next_edge->get_ref_edge_ptr());
          small_angles.append(angle);
        if ( angle >= upper_bound )
          large_edge_angles.append(curr_edge->get_ref_edge_ptr());
          large_edge_angles.append(next_edge->get_ref_edge_ptr());
          large_angles.append(angle);
  return;
void GeomMeasureTool::find_irregular_valence ( DLIList< RefVolume * > &  ref_volumes,
DLIList< RefVertex * > &  irregular_vertices
) [static]
Find the irregular vertex valences. Find things like vertices with valences greater than 4. Assume for now that the volumes are not merged..
Definition at line 4037 of file GeomMeasureTool.cpp.
  RefVolume *ref_vol;
  int ii;
  for ( ii = 0; ii < ref_volumes.size(); ii++ )
    ref_vol = ref_volumes.get_and_step();
    find_irregular_valence(ref_vol, irregular_vertices);
void GeomMeasureTool::find_irregular_valence ( RefVolume ref_volume,
) [static]
Definition at line 4053 of file GeomMeasureTool.cpp.
  RefVertex *ref_vert;
  DLIList <RefVertex*> ref_vertices;
  ref_volume->ref_vertices(ref_vertices);
  int ii;
  for ( ii = ref_vertices.size(); ii > 0; ii-- )
    ref_vert = ref_vertices.get_and_step();
    if ( ref_vert->num_ref_edges() > 4 )
      irregular_vertices.append(ref_vert);
void GeomMeasureTool::find_narrow_faces ( DLIList< RefVolume * > &  ref_vols,
DLIList< RefFace * > &  narrow_faces,
DLIList< RefFace * > &  surfs_to_ignore
) [static]
Definition at line 2854 of file GeomMeasureTool.cpp.
  int ii, jj;
  RefVolume *ref_vol;
  RefFace *curr_face;
  if (num_faces > 20)
    progress_ptr->start(0, 100, "Finding Narrow Surfaces",
    total_faces++;
      return;
    if(!surfs_to_ignore.is_in_list(curr_face))
      if(narrow_region_exists(curr_face, small_curve_size))
        DLIList<CubitVector> split_pos1_list;
        DLIList<CubitVector> split_pos2_list;
        find_split_points_for_narrow_regions(curr_face,
          small_curve_size, split_pos1_list, split_pos2_list);
        if(split_pos1_list.size() == 0)
          narrow_faces.append_unique(curr_face);
  return;
CubitStatus GeomMeasureTool::find_near_coincident_vertex_curve_pairs ( DLIList< RefVolume * > &  ref_vols,
DLIList< RefEdge * > &  ref_edges,
DLIList< RefVertex * > &  ref_verts,
DLIList< double > &  distances,
double  low_tol,
double  high_tol,
bool  filter_same_volume_cases = false
) [static]
Finds coincident vertex-curve pairs where with distance between the vertex and curve is greater than low_tol but less than high_tol.
Definition at line 5239 of file GeomMeasureTool.cpp.
  //get all the curves and vertices of volumes in list
  DLIList<RefVertex*> verts;
  DLIList<RefEdge*> curves;
  RTree<RefEdge*> a_tree(high_tol);
  int i,j;
  for( i=ref_vols.size(); i--; )
    RefVolume *tmp_vol = ref_vols.get_and_step();
    tmp_vol->ref_vertices( verts );
    curves.clean_out();
    tmp_vol->ref_edges( curves );
    for( j=curves.size(); j--; )
      RefEdge *tmp_edge = curves.get_and_step();
      a_tree.add( tmp_edge );
  int total_verts = verts.size();
  if (total_verts > 5)
    progress_ptr->start(0, 100, "Finding Near Coincident Vertex-Curve Pairs",
  int processed_verts = 0;
  std::multimap<double, dist_vert_curve_struct> distance_vertex_curve_map;
  //for each vertex
  for( i=verts.size(); i--; )
    processed_verts++;
      curr_percent = ((double)(processed_verts))/((double)(total_verts));
    RefVertex *tmp_vert = verts.get_and_step();
    RefVolume *v1 = tmp_vert->ref_volume();
    CubitBox vertex_box ( tmp_vert->coordinates(), tmp_vert->coordinates() );
    DLIList<RefEdge*> close_curves;
    a_tree.find( vertex_box, close_curves );
    CubitVector vertex_xyz = tmp_vert->coordinates();
    for( j=close_curves.size(); j--; )
      RefEdge *tmp_edge = close_curves.get_and_step();
      RefVolume *v2 = tmp_edge->ref_volume();
      bool check_distance = true;
      if(filter_same_volume_cases && v1 && v2 && v1 == v2)
        check_distance = false;
      if(check_distance)
        CubitVector closest_location;
        tmp_edge->closest_point_trimmed( vertex_xyz, closest_location );
        double distance = closest_location.distance_between( vertex_xyz );
        if( distance >= low_tol && distance <= high_tol )
          dist_vert_curve_struct tmp_struct;
          tmp_struct.dist = distance;
          tmp_struct.vert = tmp_vert;
          tmp_struct.edge = tmp_edge;
          distance_vertex_curve_map.insert( std::multimap<double, dist_vert_curve_struct>::
                                            value_type( distance, tmp_struct ));
  //std::set<dist_vert_curve_struct, vert_curve_dist_sort>::iterator iter, upper_iter;
  std::multimap<double, dist_vert_curve_struct>::reverse_iterator iter;
  iter = distance_vertex_curve_map.rbegin();
  for(; iter!=distance_vertex_curve_map.rend(); iter++ )
    distances.append( (*iter).second.dist );
    ref_verts.append( (*iter).second.vert );
    ref_edges.append( (*iter).second.edge );
CubitStatus GeomMeasureTool::find_near_coincident_vertex_surface_pairs ( DLIList< RefVolume * > &  ref_vols,
DLIList< RefFace * > &  ref_faces,
double  low_tol,
double  high_tol,
) [static]
Finds coincident vertex-surface pairs where with distance between the vertex and surface is greater than low_tol but less than high_tol.
Definition at line 5378 of file GeomMeasureTool.cpp.
  AbstractTree<RefFace*> *a_tree = new RTree<RefFace*>( high_tol );
  int i,j;
    faces.clean_out();
    tmp_vol->ref_faces( faces );
    // Populate the Surface AbstractTree
    for( j=faces.size(); j--; )
      RefFace *tmp_face = faces.get_and_step();
      a_tree->add( tmp_face );
  if (total_verts > 50)
    progress_ptr->start(0, 100, "Finding Near Coincident Vertex-Surface Pairs",
  std::multimap<double, dist_vert_surf_struct> distance_vertex_surface_map;
  //for each vertex
    processed_verts++;
    DLIList<RefFace*> close_faces;
    a_tree->find( vertex_box, close_faces);
    for( j=close_faces.size(); j--; )
      RefFace *tmp_face = close_faces.get_and_step();
      RefVolume *v2 = tmp_face->ref_volume();
      bool check = true;
        check = false;
      if(check)
        DLIList<RefVertex*> tmp_verts;
        tmp_face->ref_vertices( tmp_verts );
        if( tmp_verts.is_in_list( tmp_vert ) )
          continue;
        tmp_face->find_closest_point_trimmed( vertex_xyz, closest_location );
        if( distance > low_tol && distance < high_tol )
          dist_vert_surf_struct tmp_struct;
          tmp_struct.face = tmp_face;
          distance_vertex_surface_map.insert( std::multimap<double, dist_vert_surf_struct>::
  std::multimap<double, dist_vert_surf_struct>::reverse_iterator iter;
  iter = distance_vertex_surface_map.rbegin();
  for(; iter!=distance_vertex_surface_map.rend(); iter++ )
    ref_faces.append( (*iter).second.face);
  delete a_tree;
CubitStatus GeomMeasureTool::find_near_coincident_vertices ( DLIList< RefVolume * > &  ref_volumes,
DLIList< RefVertex * > &  ref_vertices_out,
double  low_tol,
double  high_tol,
) [static]
Finds coincident vertex-vertex pairs where the vertices in the pair are between low_tol and high_tol of one another.
Definition at line 4885 of file GeomMeasureTool.cpp.
  DLIList<RefVertex*> tmp_vert_list;
  DLIList<RefVertex*> ref_verts;
  int i,j;
  for( i=ref_volumes.size(); i--; )
    RefVolume *tmp_vol = ref_volumes.get_and_step();
    tmp_vert_list.clean_out();
    tmp_vol->ref_vertices( tmp_vert_list );
    ref_verts += tmp_vert_list;
  //put all the vertices in a tree
  AbstractTree <RefVertex*> *a_tree = new RTree<RefVertex*>( high_tol );
  for (i=ref_verts.size(); i--;)
    a_tree->add(ref_verts.get_and_step());
  std::multimap<double, dist_vert_struct> distance_vertex_map;
  //for each vertex
    RefVertex *tmp_vert = ref_verts.get_and_step();
    //get all close vertices
    DLIList<RefVertex*> close_verts;
    a_tree->find(tmp_vert->bounding_box(), close_verts);
    //if any vertex is between low_tol and high_tol
    //add it to the list
    DLIList<RefVertex*> near_coincident_verts;
    for( j=close_verts.size(); j--; )
      RefVertex *close_vert = close_verts.get_and_step();
      if( close_vert == tmp_vert )
        continue;
      RefVolume *v2 = close_vert->ref_volume();
      if(check_distance)
        double distance = vert_xyz.distance_between( close_vert->coordinates() );
          dist_vert_struct tmp_struct;
          tmp_struct.v1 = tmp_vert;
          tmp_struct.v2 = close_vert;
          distance_vertex_map.insert( std::multimap<double, dist_vert_struct>::
    a_tree->remove( tmp_vert );
  std::multimap<double, dist_vert_struct>::reverse_iterator iter;
  iter = distance_vertex_map.rbegin();
  for(; iter!=distance_vertex_map.rend(); iter++ )
    ref_vertices_out.append( (*iter).second.v1 );
    ref_vertices_out.append( (*iter).second.v2 );
  delete a_tree;
CubitStatus GeomMeasureTool::find_near_coincident_vertices_unique ( DLIList< RefVolume * > &  ref_volumes,
double  high_tol,
std::map< RefVertex *, DLIList< dist_vert_struct * > * > &  vert_dist_map
) [static]
Finds coincident vertex-vertex pairs where each vertex is in a separate volume. The two vertices in a vertex-vertex pairs are within high_tol of each other.
Definition at line 4973 of file GeomMeasureTool.cpp.
  int i,j;
  //for each vertex
    RefVolume *vol1 = tmp_vert->ref_volume();
    DLIList<dist_vert_struct*> *near_coincident_verts = NULL;
        continue;
      RefVolume *vol2 = close_vert->ref_volume();
      if(vol1 && vol2 && vol1 != vol2)
        if(!near_coincident_verts)
          near_coincident_verts = new DLIList<dist_vert_struct*>;
          vert_dist_map[tmp_vert] = near_coincident_verts;
        int h;
        bool found_entry_with_same_vol = false;
        for(h=near_coincident_verts->size(); h>0 && !found_entry_with_same_vol; h--)
          dist_vert_struct* vds = near_coincident_verts->get_and_step();
          if(vds->vol2 == vol2)
            found_entry_with_same_vol = true;
            if(distance < vds->dist)
              vds->dist = distance;
              vds->vol2 = vol2;
              vds->v2 = close_vert;
        if(!found_entry_with_same_vol)
          dist_vert_struct *new_vds = new dist_vert_struct;
          new_vds->dist = distance;
          new_vds->v2 = close_vert;
          new_vds->vol2 = vol2;
          near_coincident_verts->append(new_vds);
  delete a_tree;
CubitBoolean GeomMeasureTool::find_opposite_edge ( RefEdge ref_edge,
RefFace ref_face,
RefEdge *&  other_edge,
) [static, private]
Finds the adjacent faces to this face by traversing the DAG.
Definition at line 4622 of file GeomMeasureTool.cpp.
    //Here we want to find the edge that is "opposite" to ref_edge.
    //Opposite is defined by assuming the surface is a square or cylinder and
    //finding the edge on the other side, so that there is a point closest
    //to the mid point on the ref_edge.
  //double need_to_turn = CUBIT_PI;
  int ii;
  DLIList <Loop*> loops;
  Loop *curr_loop;
  CoEdge *co_edge, *this_co_edge;
  ref_edge->get_co_edges(co_edges, ref_face);
  if ( co_edges.size() != 1 )
    return CUBIT_FALSE;
  this_co_edge = co_edges.get();
  ref_face->loops(loops);
  if ( loops.size() > 2 )
    return CUBIT_FALSE;
  CubitBoolean found_loop = CUBIT_FALSE;
    //find the loop where this_co_edge is on.
  for(ii = loops.size(); ii > 0; ii-- )
    curr_loop = loops.get_and_step();
    if ( co_edges.move_to(this_co_edge) )
      found_loop = CUBIT_TRUE;
      break;
  if ( !found_loop )
    return CUBIT_FALSE;
  CoEdge *opp_co_edge = NULL;
  if ( loops.size() == 1 )
      //This is the normal case, I hope.
      //this co_edge, go around the interior until
      //we turn twice.  If there are angles greater than CUBIT_PI, this isn't
      //a traditional blend.  Everything should be convex.
    if ( co_edges.size() == 4 )
        //Just get the one opposite...
      opp_co_edge = co_edges.next(2);
    else
      //double total_angle = 0.0;
      int turn_counter = 0;
      CoEdge *next_co_edge = NULL;
      for ( ii = co_edges.size(); ii > 0; ii-- )
        co_edge = co_edges.get_and_step();
        next_co_edge = co_edges.get();
        double angle = GeometryQueryTool::instance()->geometric_angle(co_edge, next_co_edge);
          //we don't deal with small or concave angles.
        if ( angle < 10.0 )
          return CUBIT_FALSE;
        else if ( angle > 185.0 )
          return CUBIT_FALSE;
        else if ( angle < 140.0 )
          turn_counter++;
        if ( turn_counter == 2 )
          opp_co_edge = next_co_edge;
          break;
  else
      //Just get the other loop and get one coedge in it.
    curr_loop = loops.get();
    opp_co_edge = co_edges.get();
  if ( opp_co_edge == NULL )
    return CUBIT_FALSE;
    //This is just here to test correctness to this point, it can be taken out
    //if need be.
  if ( !co_edges.move_to(opp_co_edge) )
    PRINT_ERROR("logic messed-up in find_opposite edge\n");
    assert(0);
    return CUBIT_FALSE;
    //okay, we now have the co_edges in the correct position and
    //we have a canidate co_edge.
    //Search from the co_edge with the point that has closest point
    //to the mid point of this_co_edge.
  other_edge = NULL;
  CubitVector mid_point;
  ref_edge->mid_point(mid_point);
  CubitVector tmp_closest_point;
  double min_dist_sq = CUBIT_DBL_MAX;
  double dist_sq;
  RefEdge *test_ref_edge;
  CoEdge *prev_co_edge;
  CubitBoolean first = CUBIT_TRUE;
    prev_co_edge = co_edges.prev(2);
    test_ref_edge = co_edge->get_ref_edge_ptr();
      //We don't want edges that are connected to ref edge.
      //If we have them, we have gone to far around the surface.
    if ( test_ref_edge->common_ref_vertex(ref_edge) )
      break;
    if ( !first )
        //break out of the for loop if we turn again. We just want the closest
        //point opposite.
        geometric_angle(prev_co_edge, co_edge);
      if ( angle > 195.0 || angle < 145.0 )
        break;
    else
      first = CUBIT_FALSE;
      //now find the closest point to the mid point of ref_edge.
    test_ref_edge->closest_point_trimmed( mid_point,
                                          tmp_closest_point);
    dist_sq = (mid_point - closest_point).length_squared();
      //find and keep the closest one.
    if ( dist_sq < min_dist_sq )
      other_edge = test_ref_edge;
      min_dist_sq = dist_sq;
      closest_point = tmp_closest_point;
  if ( other_edge == NULL )
    return CUBIT_FALSE;
  return CUBIT_TRUE;
void GeomMeasureTool::find_sharp_tangential_meets ( RefVolume ref_volume,
DLIList< RefEdge * > &  small_angle_edge_pairs,
DLIList< RefFace * > &  tangential_surface_pairs
) [static]
Find the tangential meetings in the volume. This specifically looks for surfaces that meet tangentially that would be a problem. Usually these are surfaces that come into a side 180 degrees and on top there is a sharpe angle. Usually if there isn't a sharpe curve angle these meetings are not bad. Note that this function assumes that you are passing in sets of curve edges that have small interior angles between them. It also assumes that the edge pairs are ordered as they would be found in the surfaces (first edge then next edge). Basically, call the funciton, find_interior_curve_angles before calling this function, and pass this function those results.
Definition at line 3298 of file GeomMeasureTool.cpp.
    //Okay, given the small angle edge pairs.  See if there are surfaces that meet tangentially.
    //I'm really looking for something spefic.
  RefEdge *ref_edge_1, *ref_edge_2;
  int ii, jj;
  DLIList <Loop*> loops_1, loops_2;
  Loop *common_loop;
  const double rad_to_deg = 180.0/CUBIT_PI;
  RefFace *ref_face;
    //loop over for each edge pair.
  for ( ii = 0; ii < small_angle_edge_pairs.size(); ii += 2 )
    ref_edge_1 = small_angle_edge_pairs.get_and_step();
    ref_edge_2 = small_angle_edge_pairs.get_and_step();
      //find the loop that these edges are both on.
    loops_1.clean_out();
    loops_2.clean_out();
    ref_edge_1->loops(loops_1);
    ref_edge_2->loops(loops_2);
    common_loop = NULL;
    for ( jj = loops_1.size(); jj > 0; jj-- )
      if ( !loops_2.move_to(loops_1.get()) )
        loops_1.remove();
      else
        loops_1.step();
    if ( loops_1.size() == 1 )
      common_loop = loops_1.get();
    else
        //find the loop that has a co_edge from ref_edge_1
        //then a co_edge from ref_edge_2.
      Loop *tmp_loop;
      int kk;
      CoEdge *co_edge;
        tmp_loop = loops_1.get_and_step();
        tmp_loop->ordered_co_edges(co_edges);
          if ( co_edge->get_ref_edge_ptr() == ref_edge_1 )
            if ( co_edges.get()->get_ref_edge_ptr() == ref_edge_2 )
              common_loop = tmp_loop;
              break;
            else
                //not this loop..
              break;
        if ( common_loop != NULL )
          break;
    assert ( common_loop != NULL );
      //now find surface.
      //Then see if there are surfaces that meet at 180 degrees that
      //are 90* rotated from here.
    ref_face = common_loop->get_ref_face_ptr();
      //Okay, refface is the surface on which we have the bad angle.
      //One of these curves will have a concave angle and the other a
      //convex angle.  The surface on the other side of the convex angle
      //we need to check to see if it comes tangentially into another
      //surface (dihedral angle of 180.)
    RefFace *ref_face_1 = ref_edge_1->other_face(ref_face, ref_volume);
    if( ref_face_1 == NULL )
      continue;
    double surf_angle_1, surf_angle_2;
    RefFace *tangential_face = NULL;
    RefEdge *edge_next_to = NULL;
    surf_angle_1 =  GeometryQueryTool::instance()->surface_angle(ref_face,
        ref_face_1,
        ref_edge_1,
        ref_volume);
    surf_angle_1 *= rad_to_deg;
    RefFace *ref_face_2;
    ref_face_2 = ref_edge_2->other_face(ref_face, ref_volume);
    if( ref_face_2 == NULL )
      continue;
    surf_angle_2 = GeometryQueryTool::instance()->surface_angle(ref_face,
        ref_face_2,
        ref_edge_2,
        ref_volume);
    surf_angle_2 *= rad_to_deg;
    if ( surf_angle_1 < 180.0 && surf_angle_2 > 180.0 )
      tangential_face = ref_face_1;
      edge_next_to = ref_edge_1;
    else if ( surf_angle_2 < 180.0 && surf_angle_1 > 180.0 )
      tangential_face = ref_face_2;
      edge_next_to = ref_edge_2;
    if ( tangential_face == NULL ) // This isn't the config we seek.
      continue;
      //Now, on this face, there is an edge, next to edge_next_to,
      //that will have an interior angle of 180.0.  If that is the
      //case then this is what we seek.
    RefVertex* ref_vert = ref_edge_1->common_ref_vertex(ref_edge_2,
                                                        ref_face);
    DLIList <RefEdge*> tmp_ref_edges;
    ref_vert->ref_edges(tmp_ref_edges);
      //Find the edge that is on tangential face and is not edge_next_to.
    RefEdge *tangential_edge=NULL, *tmp_edge;
    for ( jj = tmp_ref_edges.size(); jj > 0; jj-- )
      tmp_edge = tmp_ref_edges.get_and_step();
      if ( tmp_edge != edge_next_to &&
           tmp_edge->is_directly_related(tangential_face) )
        tangential_edge = tmp_edge;
        break;
    if ( tangential_edge == NULL )
        //not what we are looking for.
      continue;
      //Now get the other face and measure the dihedral angle.
    RefFace *other_face = tangential_edge->other_face(tangential_face,
                                                      ref_volume);
    double tan_angle;
    tan_angle = GeometryQueryTool::instance()->surface_angle(tangential_face,
                                                             other_face,
                                                             tangential_edge,
                                                             ref_volume);
    tan_angle *= rad_to_deg;
      //If they are within tolerance, then we have it...
    if ( tan_angle > 165.0 && tan_angle < 195.0 )
      tangential_surface_pairs.append(tangential_face);
      tangential_surface_pairs.append(other_face);
void GeomMeasureTool::find_shells ( DLIList< RefVolume * > &  input_vols,
RefGroup *&  owner_groups,
int &  number_of_shells
) [static]
Finds lists of surfaces sharing common curves. Lists are found in the returned RefGroup.
Definition at line 1356 of file GeomMeasureTool.cpp.
  DLIList <DLIList<RefEntity*>*> list_of_lists;
  DLIList <RefEntity*> *new_list;
  DLIList <RefFace*> all_faces, stack, related_faces;
  DLIList <RefEdge*> curr_edges;
  RefFace *start_face, *curr_face, *related_face;
  RefEdge *curr_edge;
  int ii, jj;
  RefEntity *tmp_ent;
  number_of_shells = 0;
  DLIList <RefFace*> marked_faces;
  face_list_from_volume_list( input_vols, all_faces );
    // all_faces all marked - need unmarked
  for (ii = 0; ii < all_faces.size(); ii++ )
    curr_face = all_faces.get_and_step();
  while ( (start_face = valid_start(all_faces) ) != NULL )
      //create a list.
    stack.clean_out();
    new_list = new DLIList<RefEntity*>;
    stack.append(start_face);
    start_face->marked(1);
    marked_faces.append(start_face);
    while (stack.size() > 0 )
      curr_edges.clean_out();
      curr_face = stack.pop(); // get last face added
      tmp_ent = CAST_TO(curr_face, RefEntity);
      new_list->append(tmp_ent); // append that face to the newest list
      curr_face->ref_edges(curr_edges); // gets list of face's edges
      for( ii = 0; ii < curr_edges.size(); ii++ )  // loops edges
        related_faces.clean_out();
        curr_edge = curr_edges.get_and_step(); // chooses next edge
        curr_edge->ref_faces(related_faces); // finds edge's related faces
        for( jj = 0; jj < related_faces.size(); jj++ ) // loops faces
          related_face = related_faces.get_and_step(); // gets face
          if(!related_face->marked() && related_face->num_ref_volumes() == 1)
            stack.append(related_face);
            related_face->marked(1);
            marked_faces.append(related_face);
    list_of_lists.append(new_list);
    number_of_shells++;
  for (ii = 0; ii < marked_faces.size(); ii++ )
    curr_face = marked_faces.get_and_step();
  RefGroup *curr_group;
  owner_groups = RefEntityFactory::instance()->construct_RefGroup("volume_shells");
  for( ii = list_of_lists.size(); ii > 0; ii-- )
    new_list = list_of_lists.pop();
    curr_group = RefEntityFactory::instance()->construct_RefGroup(*new_list);
    tmp_ent = CAST_TO(curr_group, RefEntity);
    owner_groups->add_ref_entity(tmp_ent);
    delete new_list;
void GeomMeasureTool::find_small_curves ( DLIList< RefVolume * > &  ref_vols,
double  tol,
DLIList< RefEdge * > &  small_curves,
) [static]
Finds the curves with lengths less than the given tol.
Definition at line 2761 of file GeomMeasureTool.cpp.
  int ii, jj;
  DLIList <RefEdge*> ref_edges, temp_edges;
  RefVolume *ref_vol;
  RefEdge *curr_edge;
    ref_vol->ref_edges(temp_edges);
      //uniquely add the edges.
    for ( jj = temp_edges.size(); jj > 0; jj-- )
      curr_edge = temp_edges.pop();
      if ( curr_edge->marked()== 0 )
        curr_edge->marked(1);
        ref_edges.append(curr_edge);
  int num_curves = ref_edges.size();
  if (num_curves> 20)
    progress_ptr->start(0, 100, "Finding Small Curves",
  int total_curves = 0;
  double length;
    //find the small curves and reset the marked flag.
  for ( ii = ref_edges.size(); ii > 0; ii-- )
    total_curves++;
      curr_percent = ((double)(total_curves))/((double)(num_curves));
      return;
    curr_edge->marked(0);
    //skip point curves
    if( curr_edge->geometry_type() == POINT_CURVE_TYPE )
      continue;
    length = curr_edge->measure();
    if ( length <= tol )
      small_curves.append(curr_edge);
      small_lengths.append(length);
  return;
void GeomMeasureTool::find_small_faces ( DLIList< RefVolume * > &  ref_vols,
double  tol,
DLIList< RefFace * > &  small_faces
) [static]
Finds the faces with areas less than the given ammount.
Definition at line 2940 of file GeomMeasureTool.cpp.
  int ii, jj;
  RefVolume *ref_vol;
  RefFace *curr_face;
  if (num_faces > 20)
  double area;
    total_faces++;
      return;
    area = measure_area(curr_face);
    if ( area <= tol )
      small_faces.append(curr_face);
  return;
void GeomMeasureTool::find_small_faces_hydraulic_radius ( DLIList< RefVolume * > &  ref_vols,
double  tol,
DLIList< RefFace * > &  small_faces,
DLIList< double > &  small_hyd_rad,
double &  percent_planar,
double &  percent_pl_co
) [static]
Finds the faces with hydraulic radii less than tol. The hydraulic radus is defined by 4*(A/P) where A is the area of the surface and P is the total perimiter length around the surface. Also finds the % surfaces that are planar. And finds the % surfaces that are planar and conical. This is based on the geometry type, not some actual measurement.
Definition at line 3120 of file GeomMeasureTool.cpp.
  int ii, jj;
  RefVolume *ref_vol;
  RefFace *curr_face;
  double area;
  double length;
  int total_plane = 0;
  int total_cone = 0;
  double area_plane = 0.0;
  double total_area = 0.0;
  if (num_faces > 20)
    progress_ptr->start(0, 100, "Small Surface Progress",
    total_area += area;
    total_faces++;
      //update the progress..
      return;
    if ( curr_face->geometry_type() == PLANE_SURFACE_TYPE )
      total_plane++;
      area_plane += area;
    else if ( curr_face->geometry_type() == CONE_SURFACE_TYPE )
      total_cone++;
    curr_face->co_edges(co_edges);
    length = 0.0;
    for ( jj = co_edges.size(); jj > 0; jj-- )
      length += co_edges.get_and_step()->get_ref_edge_ptr()->measure();
      //reset the mark.
      //compute the hydraulic radius 4*(A/P).
    if ( length <= CUBIT_RESABS )
      PRINT_INFO("Total Perimeter Length of Surface %d is less than tolerance.\n",
                 curr_face->id());
      continue;
    area = 4.0*(area/length);
    if ( area <= tol )
      small_hyd_rad.append(area);
  if ( total_faces > 0 )
    percent_planar = 100.0*area_plane/total_area;
    percent_pl_co = 100.0*((double)total_plane+(double)total_cone)/(double)total_faces;
  else
    percent_planar = 0.;
    percent_pl_co = 0.;
  return;
void GeomMeasureTool::find_small_volumes ( DLIList< RefVolume * > &  ref_vols,
double  tol,
DLIList< RefVolume * > &  small_volumes
) [static]
Finds the volumes with volumes less than tol.
Definition at line 3234 of file GeomMeasureTool.cpp.
  int ii;
  RefVolume *ref_vol;
  double volume;
    volume = ref_vol->measure();
    if ( volume <= tol )
      small_volumes.append(ref_vol);
  return;
void GeomMeasureTool::find_small_volumes_hydraulic_radius ( DLIList< RefVolume * > &  ref_vols,
double  tol,
DLIList< RefVolume * > &  small_volumes,
) [static]
Measures the hydraulic radii for the volumes by 6*(V/A) where V is the volume of the volume and A is the total area of all the volume's surfaces. Volumes with small hydraulic radii (compared to tol) are stored in the small_volumes list.
Definition at line 3251 of file GeomMeasureTool.cpp.
  int ii, jj;
  RefVolume *ref_vol;
  RefFace *curr_face;
  double area;
  double hyd_volume;
    area = 0.0;
      area += measure_area(curr_face);
    if ( area <= CUBIT_RESABS )
      continue;
    hyd_volume = 6.0*(ref_vol->measure() / area);
    if ( hyd_volume <= tol )
      small_hyd_rad.append(hyd_volume);
  return;
void GeomMeasureTool::find_split_points_for_narrow_regions ( RefFace face,
double  size,
DLIList< CubitVector > &  split_pos1_list,
DLIList< CubitVector > &  split_pos2_list
) [static]
Determines points along which to make a curve for splitting a narrow surface.
Definition at line 2101 of file GeomMeasureTool.cpp.
  int k, i, j;
  double size_sq = size*size;
  DLIList<RefEdge*> edges;
  face->ref_edges(edges);
  while(edges.size() > 1)
    RefEdge *cur_edge = edges.extract();
    for(k=edges.size(); k--;)
      RefEdge *other_edge = edges.get_and_step();
      DLIList<CubitVector*> e1_pos_list, e2_pos_list;
      DLIList<RefVertex*> e1_vert_list, e2_vert_list;
      if(narrow_region_exists(cur_edge, other_edge, face, size,
        e1_pos_list, e2_pos_list, e1_vert_list, e2_vert_list))
        e1_pos_list.reset();
        e2_pos_list.reset();
        e1_vert_list.reset();
        e2_vert_list.reset();
        // Loop through each pair of positions defining a split.
        for(i=e1_pos_list.size(); i--;)
          RefVertex *e1_vert = e1_vert_list.get_and_step();
          RefVertex *e2_vert = e2_vert_list.get_and_step();
          CubitVector *e1_pos = e1_pos_list.get_and_step();
          CubitVector *e2_pos = e2_pos_list.get_and_step();
          // Snap to existing vertices if we are not already at at vertex.
          if(!e1_vert)
            if((cur_edge->start_vertex()->coordinates() - *e1_pos).length_squared() < size_sq)
              e1_vert = cur_edge->start_vertex();
            else if((cur_edge->end_vertex()->coordinates() - *e1_pos).length_squared() < size_sq)
              e1_vert = cur_edge->end_vertex();
          if(!e2_vert)
            if((other_edge->start_vertex()->coordinates() - *e2_pos).length_squared() < size_sq)
              e2_vert = other_edge->start_vertex();
            else if((other_edge->end_vertex()->coordinates() - *e2_pos).length_squared() < size_sq)
              e2_vert = other_edge->end_vertex();
          // We may have multiple edges separating these two vertices but the accumulated
          // length of them may still be within our narrow size so check this.  If this
          // is the case we will not want to consider this as a place to split and
          // will as a result discard these positions.
          if(e1_vert && e2_vert)
            double dist = size*sqrt(2.0);
            RefVertex *cur_vert = e1_vert;
            RefEdge *edge = cur_edge;
            double length = 0.0;
            while(edge && cur_vert != e2_vert && length <= dist)
              edge = edge->get_other_curve(cur_vert, face);
              if(edge)
                length += edge->get_arc_length();
                cur_vert = edge->other_vertex(cur_vert);
            if(length > dist)
              // We want to keep this split.
              split_pos1_list.append(e1_vert->coordinates());
              split_pos2_list.append(e2_vert->coordinates());
          else
            split_pos1_list.append(*e1_pos);
            split_pos2_list.append(*e2_pos);
      while(e1_pos_list.size())
        delete e1_pos_list.pop();
      while(e2_pos_list.size())
        delete e2_pos_list.pop();
  // Make splits unique
  DLIList<CubitVector> unique_list1, unique_list2;
  split_pos1_list.reset();
  split_pos2_list.reset();
  for(i=split_pos1_list.size(); i--;)
    CubitVector p1 = split_pos1_list.get_and_step();
    CubitVector p2 = split_pos2_list.get_and_step();
    int unique = 1;
    for(j=unique_list1.size(); j>0 && unique; j--)
      CubitVector u1 = unique_list1.get_and_step();
      CubitVector u2 = unique_list2.get_and_step();
      if((p1.about_equal(u1) && p2.about_equal(u2)) ||
        (p1.about_equal(u2) && p2.about_equal(u1)))
          unique = 0;
    if(unique)
      unique_list1.append(p1);
      unique_list2.append(p2);
  split_pos1_list = unique_list1;
  split_pos2_list = unique_list2;
void GeomMeasureTool::find_surfs_with_narrow_regions ( DLIList< RefVolume * > &  ref_vols,
double  tol,
DLIList< RefFace * > &  surfs_with_narrow_regions
) [static]
Definition at line 1884 of file GeomMeasureTool.cpp.
  int j;
  int ii, jj;
  RefVolume *ref_vol;
  RefFace *curr_face;
  if (num_faces > 20)
    progress_ptr->start(0, 100, "Finding Surfaces with Narrow Regions",
  for(j=0; j<num_faces; j++)
    RefFace *cur_face = ref_faces.get_and_step();
    total_faces++;
      return;
    find_split_points_for_narrow_regions(cur_face,
      tol, split_pos1_list, split_pos2_list);
    if(split_pos1_list.size() > 0)
      surfs_with_narrow_regions.append_unique(cur_face);
void GeomMeasureTool::get_adjacent_faces ( RefFace curr_face,
DLIList< RefFace * > &  adjacent_faces
) [static, private]
Finds the tuple for the given ref_face in the hash_table. This function is used in find_adjacent_face_ratios.
Definition at line 1699 of file GeomMeasureTool.cpp.
  DLIList <RefFace*> tmp_ref_faces;
  curr_face->ref_edges(ref_edges);
  RefEdge *ref_edge;
  RefFace *tmp_ref_face;
  int ii, jj;
  for ( ii = 0; ii < ref_edges.size(); ii++ )
    tmp_ref_faces.clean_out();
    ref_edge->ref_faces(tmp_ref_faces);
    for ( jj = 0; jj < tmp_ref_faces.size(); jj++ )
      tmp_ref_face = tmp_ref_faces.get_and_step();
      if ( !tmp_ref_face->marked() && tmp_ref_face != curr_face )
        tmp_ref_face->marked(1);
        adjacent_faces.append(tmp_ref_face);
      else
        continue;
  for ( ii = adjacent_faces.size(); ii > 0; ii-- )
    adjacent_faces.get_and_step()->marked(0);
void GeomMeasureTool::get_bodies_from_list ( DLIList< RefVolume * > &  entity_list,
DLIList< Body * > &  ref_bodies
) [static, private]
Definition at line 80 of file GeomMeasureTool.cpp.
    //assume the mark is zero.
  int ii, jj;
  RefVolume *entity_ptr;
  Body *ref_body;
  DLIList <Body*> tmp_bodies;
  for ( ii = entity_list.size(); ii > 0; ii-- )
    tmp_bodies.clean_out();
    entity_ptr = entity_list.get_and_step();
    topo_ent = CAST_TO(entity_ptr, TopologyEntity);
    if ( topo_ent == NULL )
      continue;
    topo_ent->bodies(tmp_bodies);
    for ( jj = tmp_bodies.size(); jj > 0; jj-- )
      ref_body = tmp_bodies.pop();
      if ( !ref_body->marked() )
        ref_body->marked(1);
        ref_bodies.append(ref_body);
  for ( ii = ref_bodies.size(); ii > 0; ii-- )
    ref_bodies.get_and_step()->marked(0);
CubitStatus GeomMeasureTool::get_boundary_points ( RefFace ref_face,
PointLoopList boundary_point_loops,
double  seg_length_tol
) [static]
Gets the points in ordered loops that are used to facet the boundary of the surface.
Definition at line 682 of file GeomMeasureTool.cpp.
  DLIList<DLIList<CoEdge*> > co_edge_loops;
  ref_face->co_edge_loops(co_edge_loops);
  int ii, jj;
  PointList *new_point_loop_ptr, tmp_point_list;
  RefEdge *ref_edge_ptr;
  CoEdge *co_edge_ptr;
  CubitStatus stat;
  CubitSense sense;
  for ( ii = co_edge_loops.size(); ii > 0; ii-- )
    DLIList <CoEdge*> &co_edge_list_ptr = co_edge_loops.get_and_step();
    new_point_loop_ptr = new PointList;
    for ( jj = co_edge_list_ptr.size(); jj > 0; jj-- )
      co_edge_ptr = co_edge_list_ptr.get_and_step();
      ref_edge_ptr = co_edge_ptr->get_ref_edge_ptr();
      tmp_point_list.clean_out();
      stat = get_curve_facets( ref_edge_ptr, tmp_point_list,
                               seg_length_tol );
        return CUBIT_FAILURE;
      if ( tmp_point_list.size() == 0 )
        continue;
      tmp_point_list.reset();
        //the points are in order from start vertex to end vertex.
        //append them now according to the loop.
      sense = co_edge_ptr->get_sense();
      if ( CUBIT_FORWARD != sense )
        tmp_point_list.reverse();
        //Now take off the last point as it is a duplicate with the
        //other list...
      delete tmp_point_list.pop();
      (*new_point_loop_ptr) += tmp_point_list;
    boundary_point_loops.append(new_point_loop_ptr);
  return CUBIT_SUCCESS;
CubitStatus GeomMeasureTool::get_centroid ( RefFace ref_face,
CubitVector centroid,
double &  tot_area
) [static]
Takes the area-weighted average of all display facet centroids and updates the passed in CubitVector to be that location. Also updates the tot_area variable to give the total facet area for the passed in ref_face.
Definition at line 4785 of file GeomMeasureTool.cpp.
  GMem g_mem;
  unsigned short norm_tol = 5;
  double dist_tol = -1.0;
  ref_face->get_geometry_query_engine()->
      get_graphics(ref_face->get_surface_ptr(), &g_mem, norm_tol, dist_tol );
  if(g_mem.fListCount < 1)
      // Decrease tolerance and try again (we can get this for small features)
      norm_tol /= 2;
      // Lets give up
      PRINT_ERROR( "Unable to find the center of a surface\n" );
  // Initialize
  tot_area = 0.0;
  centroid.set( 0.0, 0.0, 0.0 );
  // Loop through the triangles
  double tri_area;
  GPoint p[3];
  GPoint* plist = g_mem.point_list();
  int* facet_list = g_mem.facet_list();
  int c = 0;
  for( ; c < g_mem.fListCount; )
      p[0] = plist[facet_list[++c]];
      p[2] = plist[facet_list[++c]];
      p[1] = plist[facet_list[++c]];
      c++;
      // Get centroid
      CubitVector p1( p[0].x, p[0].y, p[0].z );
      CubitVector p2( p[2].x, p[2].y, p[2].z );
      CubitVector p3( p[1].x, p[1].y, p[1].z );
      CubitVector center = (p1 + p2 + p3)/3.0;
      //Calculate area
      CubitVector vec1 = (p2 - p1);
      CubitVector vec2 = (p3 - p1);
      CubitVector cross = vec1 * vec2;
      tri_area = 0.5* sqrt(cross.x() * cross.x() + cross.y() * cross.y() + cross.z() * cross.z());
      centroid += (tri_area * center);
      tot_area += tri_area;
  if( tot_area == 0 )
  centroid /= tot_area;
CubitStatus GeomMeasureTool::get_curve_facets ( RefEdge curve,
PointList segments,
) [static]
Get the points that approximate the curve, use the graphics facets.
Definition at line 728 of file GeomMeasureTool.cpp.
//  const double COS_ANGLE_TOL =  0.965925826289068312213715; // cos(15)
//  const double COS_ANGLE_TOL =  0.984807753012208020315654; // cos(10)
  //const double COS_ANGLE_TOL =  0.996194698091745545198705; // cos(5)
  GMem curve_graphics;
    //make this tol bigger than seg_length_tol, to
    //make sure the segments are larger than the tolerance.
  const double dist_tol = seg_length_tol;// + .05*seg_length_tol;
  //const double dist_tol_sqr = dist_tol*dist_tol;
  if ( curve->get_curve_ptr() == NULL )
    PRINT_ERROR("Curve %d had no geometry, this is a bug!\n", curve->id());
  else if ( curve->get_curve_ptr()->get_geometry_query_engine() == NULL )
    PRINT_ERROR("Curve %d had no geometry engine, this is a bug!\n",
                curve->id());
  curve->get_graphics( curve_graphics );
  GPoint* gp = curve_graphics.point_list();
  if ( gp == NULL )
    if ( curve->measure() < GEOMETRY_RESABS )
      if( curve->geometry_type() != POINT_CURVE_TYPE )
        PRINT_INFO("Curve %d has a zero length, and won't be used for loop measurements.\n",
                    curve->id());
    else
      PRINT_ERROR("Curve %d had not faceting.  Ignoring this curve.\n",
                  curve->id());
  GeomPoint *last = new GeomPoint( gp[0].x, gp[0].y, gp[0].z, curve );
  CubitVector lastv = last->coordinates();
  int num_points = curve_graphics.pointListCount;
  segments.append( last );
  int ii;
  CubitBoolean remove_second_to_end = CUBIT_FALSE;
  for ( ii = 1; ii < num_points; ii++ )
    CubitVector pos(  gp[ii].x, gp[ii].y, gp[ii].z );
    CubitVector step1 = (pos - lastv);
    double len1 = step1.length();
    if( len1 < dist_tol && ii != num_points - 1)
      continue;
    else if ( len1 < dist_tol && ii == num_points-1 )
      remove_second_to_end = CUBIT_TRUE;
    last = new GeomPoint(pos,curve);
    // Now check if the segment list is reversed wrt the curve direction.
  segments.reset();
  if ( remove_second_to_end )
    if ( segments.size() == 2 )
        //just leave it in, let it be small...
    else
        //Remove the second to last one.  To do
        //this efficiently (don't do remove), pop
        //the last one, then save that and
        //re-add it after poping the second one.
      GeomPoint *temp = segments.pop();
      segments.pop();
      segments.append(temp);
  segments.reset();
  if( curve->start_vertex() != curve->end_vertex() )
    CubitVector start_vec, end_vec;
    start_vec = curve->start_vertex()->coordinates();
    end_vec = curve->end_vertex()->coordinates();
    CubitVector start_seg = segments.get()->coordinates();
    double dist_1 = (start_seg - start_vec).length_squared();
    double dist_2 = (start_seg - end_vec).length_squared();
    if ( dist_1 > dist_2 )
      segments.reverse();
  else
    double u1, u2;
    u1 = curve->u_from_position( (segments.next(1)->coordinates()) );
    u2 = curve->u_from_position( (segments.next(2)->coordinates()) );
    if( (u2 < u1) && (curve->start_param() <= curve->end_param()) )
      segments.reverse();
    //clean up the periodic curve case (last seg may be too small.)
  if ( curve->start_vertex() == curve->end_vertex() )
    segments.reset();
    CubitVector start_v = segments.get()->coordinates();
    CubitVector last_v = segments.prev()->coordinates();
    double dist = (start_v - last_v).length();
    if ( dist < dist_tol )
        //remove the last one.
      segments.pop();
  if ( segments.size() < 2 )
    PRINT_ERROR("Problem faceting boundary.\n");
  segments.get()->owner(curve->start_vertex());
  segments.prev()->owner(curve->end_vertex());
void GeomMeasureTool::get_edges_from_list ( DLIList< RefEntity * > &  entity_list,
) [static, private]
Definition at line 48 of file GeomMeasureTool.cpp.
  int ii,jj;
  RefEntity *entity_ptr;
  RefEdge *ref_edge;
  TopologyEntity *topo_ent;
  DLIList <RefEdge*> tmp_edges;
    tmp_edges.clean_out();
      continue;
    topo_ent->ref_edges(tmp_edges);
    for ( jj = tmp_edges.size(); jj > 0; jj-- )
      ref_edge = tmp_edges.pop();
      if ( !ref_edge->marked() )
        ref_edge->marked(1);
        ref_edges.append(ref_edge);
    ref_edges.get_and_step()->marked(0);
void GeomMeasureTool::get_faces_from_list ( DLIList< RefEntity * > &  entity_list,
) [static, private]
Definition at line 112 of file GeomMeasureTool.cpp.
  int ii,jj;
  RefFace *ref_face;
  DLIList <RefFace*> tmp_faces;
    tmp_faces.clean_out();
    topo_ent->ref_faces(tmp_faces);
    for ( jj = tmp_faces.size(); jj > 0; jj-- )
      ref_face = tmp_faces.pop();
      if ( !ref_face->marked() )
        ref_faces.append(ref_face);
  for ( ii = ref_faces.size(); ii > 0; ii-- )
    ref_faces.get_and_step()->marked(0);
void GeomMeasureTool::get_narrow_regions ( DLIList< RefVolume * > &  ref_vols,
double  tol,
) [static]
Definition at line 1962 of file GeomMeasureTool.cpp.
  int ii, jj;
  RefVolume *ref_vol;
  RefFace *curr_face;
      curr_face->marked(1);
  if (num_faces > 20)
  for(jj=0; jj<num_faces; jj++)
    total_faces++;
      return;
    if(cur_face->num_loops() == 1)
        surfs_with_narrow_regions.append(cur_face);
    else if(cur_face->num_loops() > 1)
      find_close_loops( cur_face, tmp_close_edges,
void GeomMeasureTool::get_volumes_from_list ( DLIList< RefEntity * > &  entity_list,
) [static, private]
Definition at line 141 of file GeomMeasureTool.cpp.
  int ii,jj;
  RefVolume *ref_volume;
  DLIList <RefVolume*> tmp_volumes;
    tmp_volumes.clean_out();
    topo_ent->ref_volumes(tmp_volumes);
    for ( jj = tmp_volumes.size(); jj > 0; jj-- )
      ref_volume = tmp_volumes.pop();
      if ( !ref_volume->marked() )
        ref_volume->marked(1);
        ref_volumes.append(ref_volume);
  for ( ii = ref_volumes.size(); ii > 0; ii-- )
    ref_volumes.get_and_step()->marked(0);
CubitStatus GeomMeasureTool::interior_angle ( GeomSeg first_seg,
GeomSeg next_seg,
RefFace face,
double &  angle
) [static, private]
finds the distance between the point and the segment. Function used in the AbstractTree Nearest Neighbor calculation.
Definition at line 851 of file GeomMeasureTool.cpp.
  if ( first_seg->get_end() != next_seg->get_start() )
    PRINT_ERROR("GeomMeasureTool::interior_angle expects segments\n"
                "to be connected (Users: this is a bug, please submit.\n");
  CubitVector point = first_seg->get_end()->coordinates();
  CubitVector to_prev = first_seg->get_start()->coordinates();
  to_prev -= point;
  CubitVector to_next = next_seg->get_end()->coordinates();
  to_next -= point;
  CubitVector surf_norm = face->normal_at(point);
  if ( surf_norm.length_squared() < CUBIT_RESABS )
      //Try getting it at one of the other nodes...
    surf_norm = face->normal_at(first_seg->get_start()->coordinates() );
    if (surf_norm.length_squared() < CUBIT_RESABS )
      surf_norm = face->normal_at(next_seg->get_end()->coordinates() );
        PRINT_ERROR("Trying to get normal at surf %d.\n"
                    "       Normal length being returned equals zero.\n",
                    face->id() );
        angle = CUBIT_DBL_MAX;
  angle = surf_norm.vector_angle ( to_next, to_prev );
CubitBoolean GeomMeasureTool::is_equal ( double  v1,
double  v2
) [static, private]
finds the other edge which is about opposite to ref_edge. If there are more than two loops, we return CUBIT_FALSE. If there are two loops it finds the loop and curve on that loops, that has the closest point to the mid point of ref_edge. If there is just one loop, it turns on that loop to find the opposite. There can be no convex vertex angles on the loop.
Definition at line 4767 of file GeomMeasureTool.cpp.
  double smallv = v1-v2;
  if ( smallv < 0.0 )
    if ( smallv >= -CUBIT_RESABS )
      return CUBIT_TRUE;
    else
      return CUBIT_FALSE;
  else
    if ( smallv <= CUBIT_RESABS )
      return CUBIT_TRUE;
    else
      return CUBIT_FALSE;
CubitBoolean GeomMeasureTool::is_face_blend ( RefFace ref_face,
RefEdge *&  ref_edge,
) [static]
Determines if a face is a blend surface, returns the ref_edge on one side of the blend and other_edge on the opposite side. For this type of blend, only ref_edge must be tangentially meeting with another surface. Other_edge must be oriented orthogonally to it and may or may not blend with another surface. This assumes a rectangular blend surface, without holes.
Definition at line 4416 of file GeomMeasureTool.cpp.
    //first we know that blend surfaces are not planar.
    //so remove these first.
    //Also, don't look at faces with more than 2 loops.
  if ( ref_face->geometry_type() == PLANE_SURFACE_TYPE ||
       ref_face->num_loops() > 2 )
    return CUBIT_FALSE;
  CubitBoolean is_cartesian;
  DLIList<RefEdge*> ref_edges;
  ref_edge = NULL;
  other_edge = NULL;
  RefFace *other_face;
  int jj;
  double angle;
  ref_face->ref_edges(ref_edges);
  for ( jj = ref_edges.size(); jj > 0; jj-- )
    ref_edge = ref_edges.get_and_step();
    //Weed-out case where one edge is shared between more
    //than 2 surfaces of the same volume
    DLIList<RefFace*> tmp_faces;
    ref_edge->ref_faces( tmp_faces );
    if( tmp_faces.size() > 2 )
      int kk;
      for(kk=tmp_faces.size(); kk--;)
        if( !tmp_faces.get()->is_child( ref_volume ) )
          tmp_faces.change_to(NULL);
        tmp_faces.step();
      tmp_faces.remove_all_with_value( NULL );
        //this isn't the type of surface we are looking for...
        continue;
    other_face = ref_edge->other_face(ref_face, ref_volume);
    if ( other_face == NULL )
      break;
    angle = GeometryQueryTool::instance()->surface_angle(ref_face,
                                                         other_face,
                                                         ref_edge,
                                                         ref_volume);
    is_cartesian = CUBIT_TRUE;
    if ( angle <= GEOM_SIDE_LOWER ||
         angle >= GEOM_SIDE_UPPER )
      is_cartesian = CUBIT_FALSE;
      //Okay, we have one major criteria achieved, this edge is a cartesian meet.
    if ( !is_cartesian )
      continue;
      //Now we need to check the radius of curvatures between these
      //two surfaces. I'm not totally sure about this but I think we
      //don't want the same radius of curvature.
    double k1_s1, k2_s1, k1_s2, k2_s2;
    ref_face->get_principal_curvatures( mid_point, k1_s1, k2_s1, ref_volume);
    other_face->get_principal_curvatures( mid_point, k1_s2, k2_s2, ref_volume);
    if (( is_equal(k1_s1, k1_s2) || is_equal(k1_s1, k2_s2) ) &&
        ( is_equal(k2_s1, k1_s2) || is_equal(k2_s1, k2_s2) ) )
        //try a different edge.
      continue;
      //Okay, this looks pretty good.
      //Now try and find an edge that is on the "opposite" side of
      // this surface. Sort of assume this is like a mapable surface.
      //check the oposite side.
    other_edge = NULL;
    CubitVector opp_point;
    if ( !find_opposite_edge( ref_edge, ref_face, other_edge, opp_point) ||
        //if we can't find an opposite edge, we need to not
        //continue checking this surface.
      return CUBIT_FALSE;
      //Okay, we have the point opposite.  If this is a blend surface
      //the normal of this point should be pointing 90 degrees from
      //us.
    CubitVector normal_1 = ref_face->normal_at(mid_point, ref_volume);
    CubitVector normal_2 = ref_face->normal_at(opp_point, ref_volume);
    normal_1.normalize();
    normal_2.normalize();
    double dot_product = normal_1 % normal_2;
    if ( dot_product >= .5 || dot_product <= -.5  )
      continue;
    ref_edge->tangent(mid_point, tangent_1, ref_face);
    other_edge->tangent(opp_point, tangent_2, ref_face);
    tangent_1.normalize();
    tangent_2.normalize();
    dot_product = tangent_1 % tangent_2;
      //basically these edges should be somewhat parallel at
      //this point.
    if ( dot_product < .5 && dot_product > -.5 )
      continue;
//This was called but never checked, not sure why.
//      //check the curvature opposite.
//    double k1_s3, k2_s3;
//    ref_face->get_principal_curvatures( opp_point, k1_s3, k2_s3, ref_volume);
      //we are done with this face. It is a blend face.
    return CUBIT_TRUE;
  return CUBIT_FALSE;
int GeomMeasureTool::is_narrow_region_at_point ( RefEdge e1,
RefFace face,
const CubitVector pt_on_e1,
RefEdge e2,
const double &  tol_sq,
CubitVector closest
) [static]
Checks to see if at the given position the two edges are close together and have the same tangent. 'e1' is one of the edges. 'face' is the face that the edges are on. 'pt_on_e1' is a position on 'e1'. 'pt_on_e1' will be projected onto the other edge, 'e2', to look for closeness. 'tol_sq' is the squared distance defining what is 'close'. The closest pt on 'e2' to 'pt_on_e1' is returned. Returns a non-zero int if the two edges form a narrow region at the given point.
Definition at line 2222 of file GeomMeasureTool.cpp.
  int ret = 0;
  CubitVector tan_1, tan_2;
  e2->closest_point_trimmed(pt_on_e1, closest);
  double dist_sq = CUBIT_DBL_MAX;
  // If the surface is not a plane lets project
  // the midpoint to the surface and fit a circular
  // arc through the 3 points and get the arc length
  // to approximate the acutal distance on the surface
  // between the 2 original points.
  if(PLANE_SURFACE_TYPE != face->geometry_type())
    CubitVector closest_mid;
    CubitVector vec1 = closest-pt_on_e1;
    double straight_length_sq = vec1.length_squared();
    CubitVector mid = pt_on_e1 + 0.5 * vec1;
    face->get_surface_ptr()->closest_point(mid, &closest_mid);
    CubitVector mid_vec = mid-closest_mid;
    double mid_length_sq = mid_vec.length_squared();
    // If we are dealing with very small distances or
    // it doesn't look like there is much curvature just use
    // the straight line distance.
    if(straight_length_sq < 1e-10 || mid_length_sq < 0.01*straight_length_sq)
      dist_sq = straight_length_sq;
    else
      double mid_length = sqrt(mid_length_sq);
      double half_length = sqrt(straight_length_sq)/2.0;
      // theta is the angle between the vector from the orig point to its projection
      // on the other edge and the vector from the orig point to the projected mid point.
      double theta = atan(mid_length/half_length);
      // beta is the angle between the vector going from the circle center to
      // the orig point and the vector going from the circle center to the
      // projected mid point.
      double beta = 2.0*theta;
      // Some trig to get the radius of the circle that goes through all 3 points
      double radius = half_length/sin(beta);
      dist_sq = 2.0*radius*beta;
      dist_sq *= dist_sq;
  else
    dist_sq = (pt_on_e1-closest).length_squared();
  if(dist_sq < tol_sq)
    DLIList<CoEdge*> coes;
    e1->tangent(pt_on_e1, tan_1);
    e2->tangent(closest, tan_2);
    e1->get_co_edges(coes, face);
    if(coes.size() == 1)
      if(coes.get()->get_sense() == CUBIT_REVERSED)
        tan_1 *= -1.0;
      coes.clean_out();
      e2->get_co_edges(coes, face);
          tan_2 *= -1.0;
        tan_1.normalize();
        tan_2.normalize();
        if(tan_1 % tan_2 < -0.9)
          ret = 1;
  return ret;
bool GeomMeasureTool::is_surface_narrow ( RefFace face,
double  small_curve_size
) [static]
Determines if a surface is narrow.
Definition at line 2052 of file GeomMeasureTool.cpp.
  bool ret = true;
  RefVolume *vol = face->ref_volume();
  int i, j;
  double dist_sq = small_curve_size*small_curve_size;
  double proj_dist = 1.2 * small_curve_size;
  for(i=edges.size(); i>0 && ret == true; i--)
    RefEdge *cur_edge = edges.get_and_step();
    double edge_length = cur_edge->measure();
    if(edge_length > small_curve_size)
      int num_incs = (int)(edge_length/small_curve_size) + 1;
      double start, end;
      cur_edge->get_param_range(start, end);
      double t = start;
      for(j=0; j<num_incs && ret == true; j++)
        CubitVector pos1, tangent;
        cur_edge->position_from_u(t, pos1);
        cur_edge->tangent(pos1, tangent, face);
        CubitVector norm = face->normal_at(pos1, vol);
        CubitVector indir = norm * tangent;
        indir.normalize();
        CubitVector new_pos = pos1 + proj_dist * indir;
        CubitVector pt_on_surf;
        face->get_surface_ptr()->closest_point_trimmed(new_pos, pt_on_surf);
        if((pt_on_surf-pos1).length_squared() < dist_sq)
          one_bad = false;
        else // we found one out of small_curve range
          if(one_bad)  // if we had already found one out of range this makes two in a row
            ret = false;
          else  // this is the first one out of range
            one_bad = true;
  return ret;
CubitBoolean GeomMeasureTool::is_vertex_blend ( RefFace ref_face,
) [static]
Determines if a face is a vertex blend surface. It assumes that a vertex blend will be tangent to all adjoining surfaces and that the curvatures will be shared at the edges.
Definition at line 4541 of file GeomMeasureTool.cpp.
    return CUBIT_FALSE;
  RefEdge *ref_edge = NULL;
  int jj;
  double angle;
      int kk;
        tmp_faces.step();
        continue;
      break;
                                                         other_face,
                                                         ref_edge,
                                                         ref_volume);
      return CUBIT_FALSE;
      // want the same radius of curvature.
        continue;
    else
      return CUBIT_FALSE;
  // if all edges are tangent and share curvatures then it must be a
  // vertex blend.
  return CUBIT_TRUE;
double GeomMeasureTool::measure_area ( RefFace curr_face) [static]
Measures the area of the curr_face. Uses the GeomDataObserver class to cache the area on the face. After calling this function, curr_face will have a GeomDataObserver observing it. It will get removed if the surface is altered or changed.
Definition at line 3934 of file GeomMeasureTool.cpp.
  double area;
  GeomDataObserver *g_d_o = GeomDataObserver::get(curr_face);
  if ( g_d_o == NULL )
    g_d_o = GeomDataObserver::create(curr_face);
    assert(g_d_o != NULL );
    return curr_face->measure();
  if ( !g_d_o->is_measure_set() )
    area  = (curr_face->get_surface_ptr())->measure();
    g_d_o->set_measure(area);
  area = g_d_o->get_measure();
  return area;
void GeomMeasureTool::measure_curve_length ( DLIList< RefEntity * > &  entity_list,
double &  smallest,
RefEdge *&  smallest_edge,
double &  largest,
RefEdge *&  largest_edge,
double &  average,
double &  sum
) [static]
Find the smallest, longest and average size of the curves. Also compute the sum of all the curve. Do that for a list of RefEntity pointers.
Definition at line 170 of file GeomMeasureTool.cpp.
  get_edges_from_list(entity_list, ref_edges);
  measure_curve_length(ref_edges, smallest, smallest_edge,
                       largest, largest_edge, average, sum);
void GeomMeasureTool::measure_curve_length ( DLIList< RefEdge * > &  ref_edges,
double &  smallest,
double &  largest,
double &  average,
double &  sum
) [static]
Find the smallest, longest and average size of the curves. Also compute the sum of all the curve. Do that for a list of RefEdge pointers.
Definition at line 185 of file GeomMeasureTool.cpp.
  int ii;
  double curr_length, total_length = 0.0;
  smallest = CUBIT_DBL_MAX;
  largest = 0.0;
  RefEdge *curr_edge;
      continue;
    curr_length = curr_edge->measure();
    if ( curr_length < smallest )
      smallest = curr_length;
      smallest_edge = curr_edge;
    if ( curr_length > largest )
      largest = curr_length;
      largest_edge = curr_edge;
    total_length += curr_length;
  if ( ref_edges.size() != 0 )
    average = total_length/ref_edges.size();
  sum = total_length;
void GeomMeasureTool::measure_face_area ( DLIList< RefEntity * > &  entity_list,
double &  smallest,
RefFace *&  smallest_face,
double &  largest,
RefFace *&  largest_face,
double &  average,
double &  sum
) [static]
Find the smallest, largest and average area of the faces contained in the entity list.. Also compute the sum of all the face area.
Definition at line 890 of file GeomMeasureTool.cpp.
  DLIList<RefFace*> ref_faces;
  get_faces_from_list(entity_list, ref_faces);
  measure_face_area(ref_faces, smallest, smallest_face,
                    largest, largest_face, average, sum);
void GeomMeasureTool::measure_face_area ( DLIList< RefFace * > &  ref_faces,
double &  smallest,
double &  largest,
double &  average,
double &  sum
) [static]
Find the smallest, largest and average area of the faces in the face list.. Also compute the sum of all the face area.
Definition at line 905 of file GeomMeasureTool.cpp.
  int ii;
  double curr_area, total_area = 0.0;
  largest = 0.0;
  RefFace *curr_face;
  for( ii = ref_faces.size(); ii > 0; ii-- )
    curr_face = ref_faces.get_and_step();
    curr_area = measure_area(curr_face);
    if ( curr_area < smallest )
      smallest = curr_area;
      smallest_face = curr_face;
    if( curr_area > largest )
      largest = curr_area;
      largest_face = curr_face;
    total_area += curr_area;
  if (ref_faces.size() != 0 )
    average = total_area/ref_faces.size();
  sum = total_area;
void GeomMeasureTool::measure_face_area_and_hydraulic_radius ( RefFace curr_face,
double &  face_area,
double &  face_hydraulic_radius
) [static]
Definition at line 991 of file GeomMeasureTool.cpp.
  int ii;
  double total_edge_length = 0.0, curr_edge_length;
  RefEdge *curr_edge;
  DLIList <CoEdge*> my_co_edges;
  face_area = measure_area(curr_face);
  curr_face->co_edges(my_co_edges);
  for( ii = my_co_edges.size(); ii > 0; ii-- )
    curr_edge = my_co_edges.get_and_step()->get_ref_edge_ptr();
    curr_edge_length = curr_edge->measure();
    total_edge_length += curr_edge_length;
  if (total_edge_length != 0)
    face_hydraulic_radius = 4.0*(face_area / total_edge_length);
void GeomMeasureTool::measure_face_curves ( RefFace ref_face,
double &  min_curve_length,
double &  max_curve_ratio,
RefEdge *&  min_ref_edge
) [static]
Finds the curve with the smallest length on the surface. Also find the biggest change in curve lengths where the ratio is the largest curve divided by the smallest curve.
Definition at line 221 of file GeomMeasureTool.cpp.
  CoEdge *curr_co_edge, *next_co_edge;
  min_curve_length = CUBIT_DBL_MAX;
  double curve_length, next_curve_length, ratio;
  max_curve_ratio = -CUBIT_DBL_MAX;
  CubitBoolean ratio_set = CUBIT_FALSE;
  int ii, jj;
    DLIList <CoEdge*> &co_edge_list = co_edge_loops.get_and_step();
    curve_length = co_edge_list.get()->get_ref_edge_ptr()->measure();
    for ( jj = co_edge_list.size(); jj > 0; jj-- )
      curr_co_edge = co_edge_list.get_and_step();
      next_co_edge = co_edge_list.get();
      next_curve_length = next_co_edge->get_ref_edge_ptr()->measure();
        //find the smallest curve
      if ( curve_length < min_curve_length )
        min_curve_length = curve_length;
        min_ref_edge = curr_co_edge->get_ref_edge_ptr();
      if ( co_edge_list.size() > 1 )
          //find the biggest change in curve lengths.
        if ( curve_length > next_curve_length )
          if ( next_curve_length < CUBIT_RESABS )
            ratio = CUBIT_DBL_MAX;
          else
            ratio = curve_length / next_curve_length;
        else
          if ( curve_length < CUBIT_RESABS )
          else
            ratio = next_curve_length /curve_length;
        curve_length = next_curve_length;
        if ( ratio > max_curve_ratio )
          ratio_set = CUBIT_TRUE;
          max_curve_ratio = ratio;
  if ( !ratio_set )
    max_curve_ratio = -1.0;
CubitStatus GeomMeasureTool::measure_face_loops ( RefFace face,
double &  min_distance_between_loops,
double &  min_distance_in_one_loop,
double &  min_angle,
double &  max_angle,
double  tolerance
) [static]
Find the smallest distance between multiple loops on the surface. Find the smallest distance between two curves. This could be the length of the smallest curve... Also calculate the angles between curves on the faces. The tolerance is used to specify the faceting to approximate the boundaries.
Definition at line 282 of file GeomMeasureTool.cpp.
    //This is the most tricky of these functions.
    //To do this I'm going to facet the edges, then use an AbstractTree to
    //find the minimum distance between the loops and between a single
    //loop.
  PointLoopList boundary_point_loops;
  CubitStatus stat;
  stat = get_boundary_points(face, boundary_point_loops, tolerance);
  if ( stat != CUBIT_SUCCESS )
  SegLoopList boundary_seg_loops;
  stat = convert_to_lines( boundary_point_loops,
                           boundary_seg_loops,
                           face);
    return stat;
    //Now add the points to the AbstractTree.
  DLIList<AbstractTree<GeomSeg*>*> atree_list;
  AbstractTree<GeomSeg*> *curr_tree;
  SegList *seg_list;
  GeomSeg  *curr_seg, *next_seg;
  int ii,jj, kk;
  double angle;
  min_angle = CUBIT_DBL_MAX;
  max_angle = 0.0;
  double creation_time=0.0;
  CpuTimer creation_timer;
  const double angle_convert = 180.0/CUBIT_PI;
  boundary_seg_loops.reset();
  int num_segs = 0;
  for (ii = 0; ii < boundary_seg_loops.size(); ii++ )
    seg_list = boundary_seg_loops.get_and_step();
    creation_timer.cpu_secs();
    curr_tree = new RTree<GeomSeg*>(GEOMETRY_RESABS);
    creation_time += creation_timer.cpu_secs();
    for ( jj = seg_list->size(); jj > 0; jj-- )
        //build the r-tree.
      num_segs++;
      curr_seg = seg_list->get_and_step();
      curr_tree->add(curr_seg);
        //calculate the interior angles.
      next_seg = seg_list->get();
      RefEntity* temp_ent = curr_seg->get_end()->owner();
        //only measure the angle at vertices.  This
        //should make things slightly faster.
      if ( CAST_TO(temp_ent, RefVertex) )
        stat = interior_angle(curr_seg, next_seg,
                              face, angle);
          min_angle = 0.0;
          max_angle = 360.0;
        else if ( angle < min_angle )
          min_angle = angle;
        else if ( angle > max_angle )
          max_angle = angle;
    atree_list.append(curr_tree);
  min_angle *= angle_convert;
  max_angle *= angle_convert;
  if ( atree_list.size() <= 1 )
    min_distance_between_loops = -1.0;
  else
      //determine the minimum distance between the loops.
    CpuTimer atree_time;
    atree_time.cpu_secs();
    PointList *curr_points;
    GeomPoint *curr_point;
    DLIList <GeomSeg*> nearest_neighbors;
    CubitVector curr_loc;
    double closest_dist;
    min_distance_between_loops = CUBIT_DBL_MAX;
    atree_list.reset();
    for ( ii = 0; ii < atree_list.size(); ii++ )
      curr_points = boundary_point_loops.get_and_step();
      for ( jj = ii+1; jj < atree_list.size(); jj++ )
        curr_tree = atree_list.next(jj);
          //now for every point in curr_points, find it's closest_point
          //in the curr_tree.
        for ( kk = 0; kk < curr_points->size(); kk++ )
          curr_point = curr_points->get_and_step();
          curr_loc.set(curr_point->coordinates());
          nearest_neighbors.clean_out();
          curr_tree->k_nearest_neighbor(curr_loc,
                                        1, closest_dist, nearest_neighbors,
                                        dist_sq_point_data);
          if ( nearest_neighbors.size() == 0)
              //hmm, not sure what is wrong here.
            PRINT_ERROR("Can't find closest point between loops.\n");
          if (closest_dist < min_distance_between_loops)
            min_distance_between_loops = closest_dist;
    double time =  atree_time.cpu_secs();
    PRINT_DEBUG_139("Time to create atree: %f\n", creation_time);
    PRINT_DEBUG_139("Time for atree nn search: %f\n", time);
  if ( min_distance_between_loops != -1.0 )
  min_distance_between_loops = sqrt(min_distance_between_loops);
    //Now find the min distance inside a loop.  This is tricky
    //in that we want to find distances that are across some area
    //and not just between adjacent curves.
  atree_list.reset();
  GeomSeg *tmp_seg;
  double dist;
  min_distance_in_one_loop = CUBIT_DBL_MAX;
  int k=5;
  RefEntity *ent_1, *ent_2;
  TopologyEntity *top_1, *top_2;
  for ( ii = atree_list.size(); ii > 0; ii-- )
    curr_tree = atree_list.get_and_step();
        //get the k closest segments.
      curr_loc.set(curr_seg->get_start()->coordinates());
                                    k, dist, nearest_neighbors,
        //go through these nearest_neighbors and through out
        //the segments that are attached to curr_seg.
      for ( kk = 0; kk < nearest_neighbors.size(); kk++ )
        tmp_seg = nearest_neighbors.get();
        if ( tmp_seg == curr_seg ||
             tmp_seg == curr_seg->get_prev() ||
             tmp_seg == curr_seg->get_next() )
          nearest_neighbors.remove();
      if ( nearest_neighbors.size() == 0 )
        continue;
        //The min distance is the distance between the curr_loc
        //and the top nearest_neighbor.
      nearest_neighbors.reset();
      ent_1 = tmp_seg->owner();
      ent_2 = curr_seg->get_start()->owner();
      top_1 = CAST_TO(ent_1, TopologyEntity);
      top_2 = CAST_TO(ent_2, TopologyEntity);
      if ( top_1->is_directly_related(top_2) )
        continue;
        //we'll need to recompute it...
      dist = dist_sq_point_data(curr_loc, tmp_seg);
      if ( dist < min_distance_in_one_loop )
        min_distance_in_one_loop = dist;
  if ( min_distance_in_one_loop == CUBIT_DBL_MAX )
    ent_1 = (RefEntity*)face;
    DLIList<RefEntity*> entities;
    entities.append(ent_1);
    double smallest, largest, ave, sum;
    RefEdge *small_e, *large_e;
    measure_curve_length(entities, smallest, small_e,
                         largest, large_e, ave, sum);
    min_distance_in_one_loop = smallest;
  else
    min_distance_in_one_loop = sqrt(min_distance_in_one_loop);
    //clean up the memory.
  int ll,mm;
  atree_list.reset();
  for ( ll = boundary_seg_loops.size(); ll > 0; ll-- )
    delete atree_list.pop();
    seg_list = boundary_seg_loops.pop();
    for ( mm = seg_list->size(); mm > 0; mm-- )
      delete seg_list->pop();
    delete seg_list;
  PointList *point_list;
  for ( ll = boundary_point_loops.size(); ll > 0; ll-- )
    point_list = boundary_point_loops.pop();
    for ( mm = point_list->size(); mm > 0; mm-- )
      GeomPoint *tmp_point = point_list->pop();
        //delete the CubitPointData
      delete tmp_point;
    delete point_list;
void GeomMeasureTool::measure_volume_volume ( DLIList< RefEntity * > &  entity_list,
double &  smallest,
RefVolume *&  smallest_volume,
double &  largest,
RefVolume *&  largest_volume,
double &  average,
double &  sum
) [static]
Find the smallest, largest, and average volume. Compute the sum of all the volumes for the volumes contained by the entities in the entity list.
Definition at line 940 of file GeomMeasureTool.cpp.
  DLIList<RefVolume*> ref_volumes;
  get_volumes_from_list(entity_list, ref_volumes);
  measure_volume_volume(ref_volumes, smallest, smallest_volume,
                        largest, largest_volume, average, sum);
void GeomMeasureTool::measure_volume_volume ( DLIList< RefVolume * > &  ref_volumes,
double &  smallest,
double &  largest,
double &  average,
double &  sum
) [static]
Find the smallest, largest, and average volume. Compute the sum of all the volumes in the list.
Definition at line 955 of file GeomMeasureTool.cpp.
  int ii;
  double curr_volume, total_volume = 0.0;
  largest = 0.0;
  RefVolume *curr_solid;
    curr_solid = ref_volumes.get_and_step();
    curr_volume = curr_solid->measure();
    if ( curr_volume < smallest )
      smallest = curr_volume;
      smallest_volume = curr_solid;
    if ( curr_volume > largest )
      largest = curr_volume;
      largest_volume = curr_solid;
    total_volume += curr_volume;
  if (ref_volumes.size() != 0 )
    average = total_volume/ref_volumes.size();
  sum = total_volume;
void GeomMeasureTool::measure_volume_volume_and_hydraulic_radius ( RefVolume curr_volume,
double &  volume_volume,
double &  volume_hydraulic_radius
) [static]
Definition at line 1012 of file GeomMeasureTool.cpp.
  int ii;
  double curr_face_area, total_surface_area = 0.0;
  DLIList <RefFace*> ref_face_list;
  RefFace *curr_face;
  volume_volume = curr_volume->measure();
  curr_volume->ref_faces(ref_face_list);
  for ( ii = ref_face_list.size(); ii > 0; ii-- )
    curr_face = ref_face_list.get_and_step();
    curr_face_area = measure_area(curr_face);
    total_surface_area += curr_face_area;
  if (total_surface_area != 0)
    volume_hydraulic_radius = 6.0*(volume_volume / total_surface_area);
void GeomMeasureTool::merged_unmerged_surface_ratio ( DLIList< RefVolume * > &  ref_volumes,
int &  merged,
int &  unmerged,
double &  ratio
) [static]
Given a list of volumes, return number of surface merged, unmerged, and ratio between the two.
Definition at line 1125 of file GeomMeasureTool.cpp.
  int ii, jj;
  RefVolume *curr_volume_1;
  DLIList <RefFace*> surface_list_1, surface_list_2;
  RefFace *curr_face_1;
  int merged_surfaces = 0, unmerged_surfaces = 0;
  for( ii = ref_volumes.size(); ii > 0; ii-- )
    curr_volume_1 = ref_volumes.get_and_step();
    surface_list_1.clean_out();
    curr_volume_1->ref_faces(surface_list_1);
    for( jj = surface_list_1.size(); jj > 0; jj-- )
      curr_face_1 = surface_list_1.get_and_step();
      if ( curr_face_1->marked() )
        continue;
      else
        curr_face_1->marked(1);
        surface_list_2.append(curr_face_1);
      if ( curr_face_1->num_ref_volumes() == 2 )
        merged_surfaces++;
      else
        unmerged_surfaces++;
  for ( ii = surface_list_2.size(); ii > 0; ii-- )
    surface_list_2.get_and_step()->marked(0);
  merged = merged_surfaces;
  unmerged = unmerged_surfaces;
  if ( unmerged_surfaces == 0 )
    ratio = 100.0;
  else
    ratio = (double) ((double)merged_surfaces / (double)unmerged_surfaces);
int GeomMeasureTool::narrow_region_exists ( RefFace face,
RefEdge edge,
const double &  tol
) [static]
Determines if a narrow region exists between the passed-in edge and any other edge in the passed-in face. 'tol' defines what is 'narrow'. A non-zero int is returned if a narrow region exists.
Definition at line 2353 of file GeomMeasureTool.cpp.
  int k, ret = 0;
  if(edges.move_to(edge))
    edges.extract();
    // Compare this edge with the remaining edges on the face.
    for(k=edges.size(); k && !ret; k--)
      ret = narrow_region_exists(edge, other_edge, face, tol,
        e1_pos_list, e2_pos_list, e1_vert_list, e2_vert_list);
  return ret;
int GeomMeasureTool::narrow_region_exists ( RefEdge e1,
RefEdge e2,
RefFace face,
const double &  tol,
DLIList< CubitVector * > &  e1_pos_list,
DLIList< CubitVector * > &  e2_pos_list,
DLIList< RefVertex * > &  e1_vert_list,
DLIList< RefVertex * > &  e2_vert_list
) [static]
Determines whether a narrow region exists between the two passed-in edges on the passed-in face. 'tol' specifies what 'narrow' is. The four lists that are returned contain points at which the face can be split in order to separate off the narrow region. The 'pos' lists contain split points on the edges that are not on pre-existing vertices. If a split point falls on a pre-existing vertex it will show up in the 'vert' list. The points/vertices in the lists are ordered so that a point/vertex in an 'e1' list will correspond with a point/vertex in an 'e2' list. If a narrow region exists between the edges a non-zero value will be returned.
Definition at line 2385 of file GeomMeasureTool.cpp.
  int ret = 0;
  double tol_sq = tol*tol;
  double max_dist_sq = 0.0;
  RefVertex *e1_start_vert = e1->start_vertex();
  RefVertex *e1_end_vert = e1->end_vertex();
  CubitVector closest;
  DLIList<RefVertex*> e1_verts, e2_verts;
  e1->ref_vertices(e1_verts);
  e2->ref_vertices(e2_verts);
  e1_verts.intersect_unordered(e2_verts);
  int num_shared_verts = e1_verts.size();
  RefVertex *shared_vert = NULL;
  RefEdge *edge1 = NULL;
  RefEdge *edge2 = NULL;
  if(num_shared_verts == 1)
    shared_vert = e1_verts.get();
      CubitSense facevol_sense = face->sense(vol);
      if((coes.get()->start_vertex() == shared_vert) ==
        (facevol_sense == CUBIT_FORWARD))
        edge1 = e1;
        edge2 = e2;
      else
        edge1 = e2;
        edge2 = e1;
  // Project cur endpoints onto other.
  // First check the endpoints of e1 agaisnt e2
  int do_narrow_region_check = 1;
  if(num_shared_verts == 1 && shared_vert == e1_start_vert)
    // Edges are next to each other.  Check the angle between them
    // before doing anything else.
    double interior_angle = edge1->angle_between(edge2, face);
    if(interior_angle > CUBIT_PI/4.0)
      do_narrow_region_check = 0;
  if(do_narrow_region_check &&
     is_narrow_region_at_point(e1, face, e1_start_vert->coordinates(), e2, tol_sq, closest))
    max_dist_sq = (closest - e1_start_vert->coordinates()).length_squared();
    e1_pos_list.append(new CubitVector(e1_start_vert->coordinates()));
    e2_pos_list.append(new CubitVector(closest));
    e1_vert_list.append(e1_start_vert);
    e2_vert_list.append(NULL);
  if(num_shared_verts == 1 && shared_vert == e1_end_vert)
     is_narrow_region_at_point(e1, face, e1_end_vert->coordinates(), e2, tol_sq, closest))
    double cur_dist_sq = (closest - e1_end_vert->coordinates()).length_squared();
    max_dist_sq = max_dist_sq > cur_dist_sq ? max_dist_sq : cur_dist_sq;
    e1_pos_list.append(new CubitVector(e1_end_vert->coordinates()));
    e1_vert_list.append(e1_end_vert);
  if(e1_pos_list.size() < 2)
    RefVertex *e2_start_vert = e2->start_vertex();
    RefVertex *e2_end_vert = e2->end_vertex();
    // Now check the end points of e2 against e1
    if(num_shared_verts == 1 && shared_vert == e2_start_vert)
       is_narrow_region_at_point(e2, face, e2_start_vert->coordinates(), e1, tol_sq, closest))
      if(e1_pos_list.size() == 0 || !closest.about_equal(*e1_pos_list.get()))
        double cur_dist_sq = (closest - e2_start_vert->coordinates()).length_squared();
        e2_pos_list.append(new CubitVector(e2_start_vert->coordinates()));
        e1_pos_list.append(new CubitVector(closest));
        e2_vert_list.append(e2_start_vert);
        e1_vert_list.append(NULL);
      if(num_shared_verts == 1 && shared_vert == e2_end_vert)
         is_narrow_region_at_point(e2, face, e2_end_vert->coordinates(), e1, tol_sq, closest))
          double cur_dist_sq = (closest - e2_end_vert->coordinates()).length_squared();
          e2_pos_list.append(new CubitVector(e2_end_vert->coordinates()));
          e2_vert_list.append(e2_end_vert);
  // At this point we have projected each curves endpoints onto the other curve
  // and if the projection was "close" we have recorded these as in the lists
  // as close positions.
  // If we have two sets of narrow points check to see if the region
  // between them is all narrow.
  if(e1_pos_list.size() == 2)
    int w;
    int all_good = 1;
 //   double dist_tol = sqrt(max_dist_sq)*5.0;
    CubitVector *cur1 = e1_pos_list.get_and_step();
    CubitVector *cur2 = e1_pos_list.get();
    CubitVector *other1 = e2_pos_list.get_and_step();
    CubitVector *other2 = e2_pos_list.get();
    double len1 = e1->get_arc_length(*cur1, *cur2);
    //We have to check for periodic edges because the narrow points
    //will be the same when one or both of the edges is periodic.
    if(len1 > tol || (e1->is_periodic()|| e2->is_periodic()))
      double len2 = e2->get_arc_length(*other1, *other2);
      if(len2 > tol || (e1->is_periodic()|| e2->is_periodic()))
        double cur_param1 = e1->u_from_position(*cur1);
        double cur_param2 = e1->u_from_position(*cur2);
        int num_divisions = 2;
        CubitVector cur_pos;
        double param_step = (cur_param2-cur_param1)/num_divisions;
        double cur_param = cur_param1 + param_step;
        for(w=1; w<num_divisions && all_good; w++)
          e1->position_from_u(cur_param, cur_pos);
          cur_param += param_step;
          if(is_narrow_region_at_point(e1, face, cur_pos, e2, tol_sq, closest))
            // Sanity check to make sure we aren't splitting off negative space.
            CubitVector mid = (cur_pos + closest)/2.0;
            CubitVector tmp_pt;
            face->get_surface_ptr()->closest_point_trimmed(mid, tmp_pt);
            // If it didn't move we are fine but if it did we need to check
            // a little more.
            if(!mid.about_equal(tmp_pt))
              // It is possible that the midpoint between the two curves does not lie on the
              // surface.  This would be the case in a blend surface.  Check to see that
              // the projected point is just an offset along the normal of the surface
              // rather than a laterl movement because the space between the two
              // curves was actually negative space and not part of the surface.
              CubitVector norm = face->normal_at(tmp_pt);
              CubitVector dir(tmp_pt - mid);
              dir.normalize();
              if(fabs(norm % dir) < .9)
                all_good = 0;
      else
        all_good = 0;
    else
      all_good = 0;
    if(all_good)
      ret = 1;
    else
      e1_pos_list.remove(cur1);
      e1_pos_list.remove(cur2);
      e2_pos_list.remove(other1);
      e2_pos_list.remove(other2);
      delete cur1;
      delete cur2;
      delete other1;
      delete other2;
  // If we didn't find a continous region that was narrow we may curves
  // that start narrow at one or more of the ends and then move away from each other.
  // We need to find if there is a significant region that is narrow and identify
  // where the two curves start diverging.  Add additional points to the lists
  // at the points where things start diverging.
  if(!ret && e1_pos_list.size() > 0)
    int i;
      RefVertex *cur_vert = NULL;
      RefEdge *cur_edge = NULL, *other_edge = NULL;
      if(e1_vert)
        cur_edge = e1;
        other_edge = e2;
        cur_vert = e1_vert;
      else if(e2_vert)
        cur_edge = e2;
        other_edge = e1;
        cur_vert = e2_vert;
      if(cur_vert)
        CubitVector next_pos;
        CubitVector prev_pos = cur_vert->coordinates();
        int num_incs = 20;
        double step = cur_edge->get_arc_length()/(double)num_incs;
        int still_good = 1;
        int cntr = 0;
        double direction = (cur_vert == cur_edge->start_vertex() ? 1.0 : -1.0);
        // Do coarse traversal along curve to see where we start deviating from
        // narrow.
        while(still_good)
          cur_edge->point_from_arc_length(prev_pos, step*direction, next_pos);
          if(is_narrow_region_at_point(cur_edge, face, next_pos, other_edge, tol_sq, closest) &&
                      cntr < num_incs)
            prev_pos = next_pos;
            cntr++;
          else
            still_good = 0;
        if(cntr < num_incs)
          cntr = 0;
          double cur_arc_length = cur_edge->get_arc_length(prev_pos, next_pos);
          // Do bisection on remaining interval to zero in on point where
          // we go from narrow to non-narrow.
          CubitVector mid_pos;
          double close_enough = tol/20.0;
          while(cur_arc_length > close_enough && cntr < 100)
            cntr++;  // prevent infinite looping
            cur_edge->point_from_arc_length(prev_pos, cur_arc_length*direction/2.0, mid_pos);
            if(is_narrow_region_at_point(cur_edge, face, mid_pos, other_edge, tol_sq, closest))
              prev_pos = mid_pos;
            else
              next_pos = mid_pos;
          if(cur_edge->get_arc_length(cur_vert->coordinates(), prev_pos) > tol)
            // end up with the position that guarantees a new split curve that
            // is smaller than the small curve size.
            other_edge->closest_point_trimmed(prev_pos, closest);
            if(cur_edge == e1)
              e1_pos_list.append(new CubitVector(prev_pos));
            else
              e2_pos_list.append(new CubitVector(prev_pos));
            ret = 1;
  // Now remove and regions of close curves between which
  // there is negative space (not actually part of the surface).
  if(ret)
    int i, j;
      CubitVector *e1_pos = e1_pos_list.get();
      CubitVector *e2_pos = e2_pos_list.get();
      int num_divisions = 6;
      CubitVector step = (*e2_pos - *e1_pos)/num_divisions;
      CubitVector cur_pos = *e1_pos + step;
      int removed = 0;
      for(j=1; j<num_divisions; j++)
        CubitVector tmp_pt;
        face->get_surface_ptr()->closest_point_trimmed(cur_pos, tmp_pt);
        if(!cur_pos.about_equal(tmp_pt))
          CubitVector dir(tmp_pt - cur_pos);
          dir.normalize();
            removed = 1;
            j=num_divisions;
            delete e1_pos_list.remove();
            delete e2_pos_list.remove();
            e1_vert_list.remove();
            e2_vert_list.remove();
        else
          cur_pos += step;
      if(!removed)
        e1_pos_list.step();
        e2_pos_list.step();
        e1_vert_list.step();
        e2_vert_list.step();
    if(e1_pos_list.size() == 0)
      ret = 0;
  return ret;
const double &  tol
) [static]
Determine if a narrow region exists on the given face. The passed-in tolerance defines the narrow size. Returns a non-zero value if a narrow region exists.
Definition at line 2305 of file GeomMeasureTool.cpp.
  int k, ret = 0;
  int num_curves = edges.size();
  // if the surface has no bounding edges then we won't consider
  // it narrow.  This can happen with complete sphere surfaces.
  if (0 == num_curves)
    return 0;
  int num_small_curves = 0;
  while(edges.size() > 1 && !ret)
    // Remove the current edge each time so that we aren't
    // doing redundant comparisons.
    if(cur_edge->get_arc_length() < tol)
      num_small_curves++;
      ret = narrow_region_exists(cur_edge, other_edge, face, tol,
  if(!ret)
    if(edges.size() == 1 && edges.get()->get_arc_length() < tol)
      num_small_curves++;
  ret = ret || (num_small_curves == num_curves);
  return ret;
void GeomMeasureTool::print_surface_measure_summary ( DLIList< RefFace * > &  ref_faces) [static]
Prints a summary of all of the surface information. min curve length, max adjacent curve ratios, min angle, max angle, min area, max area, min hydraulic radius, min distance between loops, min distance between a single loop.
Definition at line 1437 of file GeomMeasureTool.cpp.
  double min_dist_loops=CUBIT_DBL_MAX, min_dist_loop=CUBIT_DBL_MAX;
  double curr_min_dist_loops=CUBIT_DBL_MAX, curr_min_dist_loop=CUBIT_DBL_MAX;
  double min_angle=CUBIT_DBL_MAX, max_angle=-CUBIT_DBL_MAX;
  double curr_min_angle=CUBIT_DBL_MAX, curr_max_angle=-CUBIT_DBL_MAX;
  double curr_face_area, curr_face_hydraulic_radius;
  double min_face_area=CUBIT_DBL_MAX, min_face_hydraulic_radius=CUBIT_DBL_MAX;
  double max_face_area=-CUBIT_DBL_MAX;
  int counter = 0;
  double total_area= 0.0;
  double min_curve_length = CUBIT_DBL_MAX;
  double max_curve_ratio = -CUBIT_DBL_MAX;
  double curve_length, curve_ratio;
  int ii;
  RefFace *curr_face;
  RefFace *face_min_dist_loops=NULL, *face_min_dist_loop=NULL;
  RefFace *face_min_angle=NULL, *face_max_angle=NULL;
  RefFace *face_min_area=NULL, *face_min_hydraulic_radius=NULL;
  RefFace *face_max_area=NULL;
  RefFace *face_min_curve_length=NULL, *face_max_curve_ratio=NULL;
  RefEdge *smallest_edge=NULL, *curr_small_edge=NULL;
  for( ii = 0; ii < ref_faces.size(); ii++ )
    if ( curr_face->num_ref_edges() > 0 )
      GeomMeasureTool::measure_face_loops(curr_face,
                                          curr_min_dist_loops,
                                          curr_min_dist_loop,
                                          curr_min_angle,
                                          curr_max_angle,
                                          GEOMETRY_RESABS*500);
      GeomMeasureTool::measure_face_area_and_hydraulic_radius(curr_face,
                                                              curr_face_area,
                                                              curr_face_hydraulic_radius);
      GeomMeasureTool::measure_face_curves(curr_face, curve_length,
                                           curve_ratio, curr_small_edge);
    else
      curr_face_area = curr_face->measure();
    total_area += curr_face_area;
    counter++;
        smallest_edge = curr_small_edge;
        face_min_curve_length = curr_face;
      if ( curve_ratio != -1.0 && curve_ratio > max_curve_ratio )
        max_curve_ratio = curve_ratio;
        face_max_curve_ratio = curr_face;
      if ( curr_min_dist_loops != -1.0 && curr_min_dist_loops < min_dist_loops )
        face_min_dist_loops = curr_face;
        min_dist_loops = curr_min_dist_loops;
      if ( curr_min_dist_loop < min_dist_loop )
        face_min_dist_loop = curr_face;
        min_dist_loop = curr_min_dist_loop;
      if ( curr_min_angle < min_angle )
        face_min_angle = curr_face;
        min_angle = curr_min_angle;
      if ( curr_max_angle > max_angle )
        face_max_angle = curr_face;
        max_angle = curr_max_angle;
      if ( curr_face_hydraulic_radius < min_face_hydraulic_radius )
        min_face_hydraulic_radius = curr_face_hydraulic_radius;
        face_min_hydraulic_radius = curr_face;
    if ( curr_face_area < min_face_area )
      min_face_area = curr_face_area;
      face_min_area = curr_face;
    if ( curr_face_area > max_face_area )
      max_face_area = curr_face_area;
      face_max_area = curr_face;
  if ( counter > 0 )
    PRINT_INFO("\n******Summary of Surface Measure Info*******\n\n");
    PRINT_INFO("Measured %d surfaces: Average Area: %f \n\n", counter, total_area/counter );
    PRINT_INFO("Minimum Surface Area is: %f on surface %d\n\n",
               min_face_area, face_min_area->id());
    PRINT_INFO("Maximum Surface Area is: %f on surface %d\n\n",
               max_face_area, face_max_area->id());
    if ( face_min_hydraulic_radius )
      PRINT_INFO("Minimum Hydraulic Radius (Area/Perimeter) is: %f on surface %d\n\n",
                 min_face_hydraulic_radius, face_min_hydraulic_radius->id());
    if ( smallest_edge )
      PRINT_INFO("Minimum Curve Length is: %f for curve %d on surface %d\n\n",
                 min_curve_length, smallest_edge->id(), face_min_curve_length->id());
    if ( face_max_curve_ratio )
      PRINT_INFO("Maximum Ratio of Adjacent Curve Lengths is: %f on surface %d\n\n",
                 max_curve_ratio, face_max_curve_ratio->id());
    if ( face_min_dist_loops && face_min_dist_loops->num_loops() > 1 )
      PRINT_INFO("Minimum Distance Between Loops is: %f on surface %d\n\n",
                 min_dist_loops, face_min_dist_loops->id());
    if ( face_min_dist_loop )
      PRINT_INFO("Minimum Distance Between a Single Loop is: %f on surface %d\n\n",
                 min_dist_loop, face_min_dist_loop->id());
    if ( face_min_angle )
      PRINT_INFO("Minimum Interior Angle Between Curves is: %f Degrees on surface %d\n\n",
                 min_angle, face_min_angle->id());
    if ( face_max_angle )
      PRINT_INFO("Maximum Interior Angle Between Curves is: %f Degrees on surface %d\n\n",
                 max_angle, face_max_angle->id());
    center(ref_faces);
    PRINT_INFO("************End of Summary***********\n\n");
void GeomMeasureTool::print_volume_measure_summary ( DLIList< RefVolume * > &  ref_volumes) [static]
Prints summary of all the volume information, including the information of the surfaces in the volumes.
Definition at line 1728 of file GeomMeasureTool.cpp.
  int ii;
  RefVolume *curr_volume;
  RefFace *curr_face;
  DLIList <RefFace*> ref_faces, tmp_faces;
    //First get a list of all the ref_faces.
    //Get them uniquely.
  for ( ii = 0; ii< ref_volumes.size(); ii++ )
    curr_volume = ref_volumes.get_and_step();
    curr_volume->ref_faces(tmp_faces);
    int jj;
    for ( jj = 0; jj < tmp_faces.size(); jj++ )
      curr_face = tmp_faces.get_and_step();
      if ( curr_face->marked() )
        continue;
      else
        ref_faces.append(curr_face);
    //reset the mark.
  for ( ii = 0; ii< ref_faces.size(); ii++ )
  double volume_volume, volume_hydraulic_radius;
  double total_volume = 0.0, min_volume_hydraulic_radius = CUBIT_DBL_MAX;
  double min_volume=CUBIT_DBL_MAX; //, max_volume=-CUBIT_DBL_MAX;
  double curr_min_angle = 361.0, curr_max_angle =361.;
  double max_face_ratio = -CUBIT_DBL_MAX, curr_face_ratio=CUBIT_DBL_MAX;
  RefVolume *volume_min_volume = NULL, *volume_min_hydraulic_radius=NULL;
  RefVolume *volume_min_angle=NULL, *volume_max_angle=NULL;
  RefVolume *volume_face_ratio= NULL;
  RefFace *max_small_face=NULL, *max_big_face=NULL;
  RefFace *small_face=NULL, *big_face=NULL;
  RefFace *face_min_1=NULL, *face_min_2=NULL;
  RefFace *face_max_1=NULL, *face_max_2=NULL;
  RefFace *face_min_angle_1=NULL, *face_min_angle_2=NULL;
  RefFace *face_max_angle_1=NULL, *face_max_angle_2=NULL;
  int counter = 0;
  for( ii = 0; ii< ref_volumes.size(); ii++ )
    GeomMeasureTool::measure_volume_volume_and_hydraulic_radius(curr_volume,
        volume_volume,
        volume_hydraulic_radius);
    if ( curr_volume->num_ref_faces() > 1 )
      GeomMeasureTool::angles_between_volume_surfaces(curr_volume,
                                                      curr_min_angle,
                                                      curr_max_angle,
                                                      face_min_1, face_min_2,
                                                      face_max_1, face_max_2);
      GeomMeasureTool::find_adjacent_face_ratios(curr_volume,
                                                 curr_face_ratio,
                                                 big_face, small_face);
    total_volume += volume_volume;
    counter++;
    if ( volume_volume < min_volume )
      volume_min_volume = curr_volume;
      min_volume = volume_volume;
    if ( volume_hydraulic_radius < min_volume_hydraulic_radius )
      volume_min_hydraulic_radius = curr_volume;
      min_volume_hydraulic_radius = volume_hydraulic_radius;
    if ( curr_volume->num_ref_faces() > 1 &&  curr_min_angle < min_angle )
      volume_min_angle = curr_volume;
      face_min_angle_1 = face_min_1;
      face_min_angle_2 = face_min_2;
    if ( curr_volume->num_ref_faces() > 1 && curr_max_angle > max_angle )
      volume_max_angle = curr_volume;
      face_max_angle_1 = face_max_1;
      face_max_angle_2 = face_max_2;
    if ( curr_volume->num_ref_faces() > 1 && curr_face_ratio > max_face_ratio )
      volume_face_ratio = curr_volume;
      max_face_ratio = curr_face_ratio;
      max_small_face = small_face;
      max_big_face = big_face;
  if ( counter > 0 )
    PRINT_INFO("*************Volume Summary************\n\n");
    PRINT_INFO("Measured %d Volumes: Average Volume was %f.\n\n",
               counter, total_volume/counter);
    PRINT_INFO("Minimum Volume was %f in volume %d\n\n",
               min_volume, volume_min_volume->id());
    PRINT_INFO("Minimum Volume Hydraulic Radius (volume/surface area) was %f in volume %d\n\n",
               min_volume_hydraulic_radius, volume_min_hydraulic_radius->id());
    if ( volume_min_angle )
      PRINT_INFO("Minimum Interior Angle Between Two Surfaces was %f,\n"
                 "\tsurfaces %d and %d in volume %d\n\n",
                 min_angle, face_min_angle_1->id(), face_min_angle_2->id(), volume_min_angle->id());
    if ( volume_max_angle )
      PRINT_INFO("Maximum Interior Angle Between Two Surfaces was %f,\n"
                 max_angle, face_max_angle_1->id(), face_max_angle_2->id(), volume_max_angle->id());
    if ( volume_face_ratio )
      PRINT_INFO("Maximum Area Ratios Between Adjacent Faces was %f,\n"
                 "\tsurfaces %d and %d in volume %d.\n\n",
                 max_face_ratio, max_big_face->id(), max_small_face->id(), volume_face_ratio->id());
    int merged, unmerged;
    double ratio;
    GeomMeasureTool::merged_unmerged_surface_ratio(ref_volumes, merged, unmerged, ratio);
    PRINT_INFO("Total number of merged surfaces:\t%d\n"
               "Total number of unmerged surfaces:\t%d\n"
               "Ratio of merged to unmerged surfaces:\t%f\n\n", merged, unmerged, ratio);
    RefGroup *group_of_shells;
    int number_shells;
    GeomMeasureTool::find_shells(ref_volumes, group_of_shells, number_shells);
    if ( number_shells > 0 )
      if ( number_shells == 1 )
        PRINT_INFO("Found %d shell of connected surfaces.\n", number_shells);
        PRINT_INFO("These shell is contained in the group %s\n",
                   group_of_shells->entity_name().c_str());
      else
        PRINT_INFO("Found %d shells of connected surfaces.\n", number_shells);
        PRINT_INFO("These shells are contained in the group %s\n",
    PRINT_INFO("\n\n");
    PRINT_INFO("Now Printing Summaries of Surfaces contained by these volumes.\n");
    GeomMeasureTool::print_surface_measure_summary(ref_faces);
  return;
void GeomMeasureTool::report_intersected_bodies ( DLIList< Body * > &  ref_bodies,
DLIList< Body * > &  intersection_list
) [static]
From a list of bodies, find ones that intersect.
Definition at line 1251 of file GeomMeasureTool.cpp.
  Body *curr_body, *curr_body_2;
  int ii, jj;
  ProgressTool *progress_ptr = NULL;
  int total_bodies = ref_bodies.size();
  if (total_bodies > 5)
    progress_ptr = AppUtil::instance()->progress_tool();
    assert(progress_ptr != NULL);
    progress_ptr->start(0, 100, "Overlapping Volumes Progress",
      NULL, CUBIT_TRUE, CUBIT_TRUE);
  double curr_percent = 0.0;
  for( ii = 0; ii < ref_bodies.size(); ii++ )
    curr_body = ref_bodies.next(ii);
    for( jj = (ii + 1); jj < ref_bodies.size(); jj++ )
      curr_body_2 = ref_bodies.next(jj);
      if ( AppUtil::instance()->interrupt() )
          //interrpt.  We need to exit.
        if ( progress_ptr != NULL )
          progress_ptr->end();
          //just leave what has been calculated...
        return;
      if (GeometryQueryTool::instance()->bodies_overlap(curr_body,
                                                        curr_body_2) )
        intersection_list.append(curr_body);
        intersection_list.append(curr_body_2);
       //update the progress..
      curr_percent = ((double)(ii+1))/((double)(total_bodies));
      progress_ptr->percent(curr_percent);
void GeomMeasureTool::report_intersected_volumes ( DLIList< RefVolume * > &  volume_list,
DLIList< RefVolume * > &  intersection_list
) [static]
From a list of volumes, find ones that intersect.
Definition at line 1172 of file GeomMeasureTool.cpp.
  DLIList <RefVolume*> results;
  RefVolume *curr_vol;
  int i, j;
  int total_volumes = ref_vols.size();
  if (total_volumes > 5)
  for( i = 0; i < ref_vols.size(); i++ )
    curr_vol = ref_vols.next(i);
    //is this body a multi-volume-body?
    Body *single_volume_body = curr_vol->body();
    DLIList<RefVolume*> body_vols;
    single_volume_body->ref_volumes( body_vols );
    if( body_vols.size() > 1 )
      single_volume_body = NULL;
    for( j = (i + 1); j < ref_vols.size(); j++ )
      RefVolume *curr_vol2 = ref_vols.next(j);
        return;
      Body *single_volume_body2 = curr_vol2->body();
      DLIList<RefVolume*> body_vols2;
      single_volume_body2->ref_volumes( body_vols2 );
      if( body_vols2.size() > 1 )
        single_volume_body2 = NULL;
        curr_percent = ((double)(i+1))/((double)(total_volumes));
      //if both are single-volume-bodies
      if( single_volume_body && single_volume_body2 )
        if( GeometryQueryTool::instance()->bodies_overlap( single_volume_body,
                                                       single_volume_body2 ) )
          intersection_list.append( curr_vol );
          intersection_list.append( curr_vol2 );
      else if( GeometryQueryTool::instance()->volumes_overlap( curr_vol, curr_vol2 ) )
RefFace * GeomMeasureTool::valid_start ( DLIList< RefFace * > &  all_faces) [static, private]
Tests to see if the two double values are within CUBIT_RESABS. Returns TRUE if they are, false if they aren't.
Definition at line 1339 of file GeomMeasureTool.cpp.
  int ii;
  RefFace *start_face;
  for( ii = 0; ii < all_faces.size(); ii++ )
    start_face = all_faces.get_and_step();
    if( !start_face->marked() && start_face->num_ref_volumes()== 1 )
      return start_face;
  return NULL;
