cgma
MemoryManager Member List
This is the complete list of members for MemoryManager, including all inherited members.
compress_all_object_memory()MemoryManager [static]
compress_memory()MemoryManager
compress_object_memory(const char *s)MemoryManager [static]
destroy_memory(int static_flag=0)MemoryManager
get_allocated_objects()MemoryManager
get_free_objects()MemoryManager
get_memory_allocation_increment() const MemoryManager
get_object_size() const MemoryManager
get_used_objects()MemoryManager
headOfFreeListMemoryManager [private]
memAllocatnSizeMemoryManager [private]
memBlockStackMemoryManager [private]
MemoryManager()MemoryManager [private]
MemoryManager(const MemoryManager &)MemoryManager [private]
MemoryManager(const char *name, std::size_t size, int mem_size=0, int static_flag=0)MemoryManager
memoryManagerListHeadMemoryManager [private, static]
nextMemoryManager [private]
objectNameMemoryManager [private]
objectSizeMemoryManager [private]
operator_delete(void *deadObject, std::size_t size)MemoryManager
operator_new(std::size_t size)MemoryManager
process_file_io(unsigned long &read, unsigned long &write)MemoryManager [private, static]
process_mem_usage(unsigned long &vm_usage, unsigned long &resident_set)MemoryManager [private, static]
set_memory_allocation_increment(int mem_size=0)MemoryManager
show_all_object_memory()MemoryManager [static]
show_object_memory(const char *s)MemoryManager [static]
staticManagerMemoryManager [private]
useNewMemoryManager [private]
~MemoryManager()MemoryManager
