cgma
OCCSurface Member List
This is the complete list of members for OCCSurface, including all inherited members.
add_hardpoint(OCCPoint *HardPoint)OCCSurface [inline]
append_simple_attribute_virt(const CubitSimpleAttrib &)OCCSurface [virtual]
are_positions_on(DLIList< CubitVector * > &test_position_list, DLIList< CubitBoolean * > &is_on_list)Surface [virtual]
bodysm()TopologyBridge
bodysms(DLIList< BodySM * > &bodies, bool unique=true)TopologyBridge
bounding_box() const OCCSurface [virtual]
bridge_manager() const TopologyBridge
bridge_manager(BridgeManager *manager)TopologyBridge
bridge_sense()TopologyBridge [inline]
center_point()OCCSurface
ChildType typedefSurface
closest_point(CubitVector const &location, CubitVector *closest_location=NULL, CubitVector *unit_normal_ptr=NULL, CubitVector *curvature1_ptr=NULL, CubitVector *curvature2_ptr=NULL)OCCSurface [virtual]
closest_point_along_vector(CubitVector &from_point, CubitVector &along_vector, CubitVector &point_on_surface)OCCSurface [virtual]
closest_point_trimmed(CubitVector from_point, CubitVector &point_on_surface)OCCSurface [virtual]
closest_point_uv_guess(CubitVector const &location, double &u, double &v, CubitVector *closest_location=NULL, CubitVector *unit_normal=NULL)OCCSurface [virtual]
closest_points(DLIList< CubitVector * > &location_list, DLIList< CubitVector * > *closest_location_list=NULL, DLIList< CubitVector * > *unit_normal_list=NULL, DLIList< CubitVector * > *curvature1_list=NULL, DLIList< CubitVector * > *curvature2_list=NULL)Surface [virtual]
closest_points_trimmed(std::vector< CubitVector > &from_points_list, std::vector< CubitVector > &points_on_surface_list)Surface [virtual]
coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true)TopologyBridge
curves(DLIList< Curve * > &curves, bool unique=true)TopologyBridge
curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true)TopologyBridge
evaluate(double u, double v, CubitVector *position, CubitVector *normal, CubitVector *curvature1, CubitVector *curvature2)OCCSurface [virtual]
Surface::evaluate(double u, double v, CubitVector &pos, CubitVector deriv1[2], CubitVector deriv2[3])Surface [virtual]
geometry_type()OCCSurface [virtual]
GeometryEntity()GeometryEntity [inline]
get_bodies(DLIList< OCCBody * > &bodies)OCCSurface
get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER)TopologyBridge
get_children_virt(DLIList< TopologyBridge * > &children)OCCSurface [virtual]
get_coedges(DLIList< OCCCoEdge * > &)OCCSurface
get_cone_params(CubitVector &center, CubitVector &normal, CubitVector &major_axis, double &radius_ratio, double &sine_angle, double &cos_angle) const OCCSurface [virtual]
get_curves(DLIList< OCCCurve * > &)OCCSurface
get_geometry_query_engine() const OCCSurface [virtual]
get_geometry_sense()OCCSurface [virtual]
get_hardpoints()OCCSurface [inline]
get_loops(DLIList< OCCLoop * > &)OCCSurface
get_nurb_params(bool &rational, int &degree_u, int &degree_v, int &num_cntrl_pts_u, int &num_cntrl_pts_v, DLIList< CubitVector > &cntrl_pts, DLIList< double > &weights, DLIList< double > &u_knots, DLIList< double > &v_knots) const OCCSurface [virtual]
get_param_range_U(double &lower_bound, double &upper_bound)OCCSurface [virtual]
get_param_range_V(double &lower_bound, double &upper_bound)OCCSurface [virtual]
get_parents(DLIList< TopologyBridge * > &parents)TopologyBridge
get_parents_virt(DLIList< TopologyBridge * > &parents)OCCSurface [virtual]
get_point_normal(CubitVector &, CubitVector &)OCCSurface [virtual]
get_points(DLIList< OCCPoint * > &points)OCCSurface
get_projected_distance_on_surface(CubitVector *pos1, CubitVector *pos2, double &distance)OCCSurface [virtual]
get_saved_id() const GeometryEntity [inline]
get_saved_names(std::vector< CubitString > &names)GeometryEntity
get_shell_sense(ShellSM *) const OCCSurface [virtual]
get_simple_attribute(DLIList< CubitSimpleAttrib > &)OCCSurface [virtual]
get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &)OCCSurface [virtual]
get_sphere_params(CubitVector &center, double &radius) const OCCSurface [virtual]
get_TopoDS_Face()OCCSurface [inline]
get_torus_params(CubitVector &center, CubitVector &normal, double &major_radius, double &minor_radius) const OCCSurface [virtual]
get_uv_sense()Surface [inline, virtual]
is_closed_in_U()OCCSurface [virtual]
is_closed_in_V()OCCSurface [virtual]
is_conical()OCCSurface
is_cylindrical()Surface [inline, virtual]
is_flat()OCCSurface
is_parametric()OCCSurface [virtual]
is_periodic()OCCSurface [virtual]
is_periodic_in_U(double &period)OCCSurface [virtual]
is_periodic_in_V(double &period)OCCSurface [virtual]
is_position_on(CubitVector &test_position)OCCSurface [virtual]
is_singular_in_U(double u_param)OCCSurface [virtual]
is_singular_in_V(double v_param)OCCSurface [virtual]
is_spherical()OCCSurface
layer() const TopologyBridge [inline, virtual]
loopsm()TopologyBridge
loopsms(DLIList< LoopSM * > &loopsms, bool unique=true)TopologyBridge
lump()TopologyBridge
lumps(DLIList< Lump * > &lumps, bool unique=true)TopologyBridge
MAX_TB_LAYER enum valueTopologyBridge
measure()OCCSurface [virtual]
my_body()OCCSurface [inline]
my_lump()OCCSurface [inline]
my_shell()OCCSurface [inline]
myBodyOCCSurface [private]
myHardPointsOCCSurface [private]
myLumpOCCSurface [private]
myShellOCCSurface [private]
myTopoDSFaceOCCSurface [private]
OCCSurface(TopoDS_Face *theFace)OCCSurface
owner() const TopologyBridge [inline]
owner(TBOwner *new_owner)TopologyBridge [inline]
param_dir(CubitVector &, CubitVector &, double &, double &)Surface [inline, virtual]
point_containment(const CubitVector &point)OCCSurface [virtual]
point_containment(double u, double v)OCCSurface [virtual]
points(DLIList< TBPoint * > &points, bool unique=true)TopologyBridge
position_from_u_v(double u, double v)OCCSurface [virtual]
principal_curvatures(CubitVector const &location, double &curvature_1, double &curvature_2, CubitVector *closest_location=NULL)OCCSurface [virtual]
remove_all_simple_attribute_virt()OCCSurface [virtual]
remove_hardpoint(OCCPoint *HardPoint)OCCSurface [inline]
remove_simple_attribute_virt(const CubitSimpleAttrib &)OCCSurface [virtual]
reverse_bridge_sense()TopologyBridge [inline]
set_body(OCCBody *body)OCCSurface [inline]
set_lump(OCCLump *lump)OCCSurface [inline]
set_saved_id(int value)GeometryEntity [inline]
set_saved_names(const std::vector< CubitString > &names)GeometryEntity
set_shell(OCCShell *shell)OCCSurface [inline]
set_TopoDS_Face(TopoDS_Face &face)OCCSurface
shellsms(DLIList< ShellSM * > &shellsms, bool unique=true)TopologyBridge
Surface()Surface
surfaces(DLIList< Surface * > &surfaces, bool unique=true)TopologyBridge
surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true)TopologyBridge
topology_entity() const TopologyBridge
TopologyBridge()TopologyBridge [inline]
u_v_from_position(CubitVector const &location, double &u, double &v, CubitVector *closest_location=NULL)OCCSurface [virtual]
update_OCC_entity(TopoDS_Face &old_surface, TopoDS_Shape &new_surface, BRepBuilderAPI_MakeShape *op, TopoDS_Vertex *removed_vertex=NULL, LocOpe_SplitShape *sp=NULL)OCCSurface [static]
update_OCC_entity(BRepBuilderAPI_ModifyShape *aBRepTrsf, BRepAlgoAPI_BooleanOperation *op=NULL)OCCSurface
uv_derivitives(double u_param, double v_param, CubitVector &du, CubitVector &dv)OCCSurface [virtual]
validate(const CubitString &, DLIList< TopologyEntity * > &)TopologyBridge [inline, virtual]
~GeometryEntity()GeometryEntity [virtual]
~OCCSurface()OCCSurface [virtual]
~Surface()Surface [virtual]
~TopologyBridge()TopologyBridge [virtual]
