cgma
OffsetSplitTool Member List
This is the complete list of members for OffsetSplitTool, including all inherited members.
create_divide_curves(DLIList< Curve * > &curve_list, Surface *surface_in, double distance)OffsetSplitTool [private]
create_ref_edges(DLIList< Curve * > &curve_list)OffsetSplitTool [private]
create_sweep_body(Surface *section, Curve *path)OffsetSplitTool [private]
create_sweep_curve(Curve *curve_in, double distance, double chord_tol, CubitBoolean iterate=CUBIT_FALSE)OffsetSplitTool [private]
create_sweep_section(Curve *path, double distance, CubitVector up_vector, double fraction=0.0)OffsetSplitTool [private]
draw_preview(DLIList< Curve * > &curve_list, int color=CUBIT_BLUE_INDEX)OffsetSplitTool [private]
draw_preview(Curve *curve_ptr, CubitBoolean flush=CUBIT_TRUE, int color=CUBIT_BLUE_INDEX)OffsetSplitTool [private]
OffsetSplitTool()OffsetSplitTool
sourceCurvesOffsetSplitTool [private]
split_surfaces_offset(DLIList< RefFace * > &ref_face_list, DLIList< RefEdge * > &edge_list, int num_segs, double distance, CubitBoolean divide_flg=CUBIT_FALSE, CubitBoolean blunt_flg=CUBIT_FALSE, CubitBoolean preview_flg=CUBIT_FALSE, CubitBoolean create_ref_edges_flg=CUBIT_FALSE)OffsetSplitTool
toleranceOffsetSplitTool [private, static]
~OffsetSplitTool()OffsetSplitTool [inline]
