cgma
ParamCubitPlane Class Reference
#include <ParamCubitPlane.hpp>
Inheritance diagram for ParamCubitPlane:
CubitPlane
List of all members.
Public Member Functions
 ParamCubitPlane (const CubitVector &zero_position, const CubitVector &u_direction, const CubitVector &v_direction, CubitStatus &result)
 ParamCubitPlane (const ParamCubitPlane &copy_this)
 ParamCubitPlane (double A, double B, double C, double D)
 ParamCubitPlane (const CubitVector &normal, double D)
 ParamCubitPlane (const CubitVector &normal, const CubitVector &point)
 ParamCubitPlane (DLIList< CubitVector * > &positions)
 ParamCubitPlane (const CubitPlane &copy_this)
CubitStatus closest_point (const CubitVector &position, CubitVector &closest_position) const
CubitStatus move_to_plane (CubitVector &position) const
Private Member Functions
void make_parameterization ()
Private Attributes
CubitVector p_
CubitVector s_
CubitVector t_
CubitBoolean is_plane_valid_
CubitVector n_
double n_epsilon_
Detailed Description
Definition at line 22 of file ParamCubitPlane.hpp.
ParamCubitPlane::ParamCubitPlane ( const CubitVector zero_position,
const CubitVector u_direction,
const CubitVector v_direction,
CubitStatus result
Definition at line 27 of file ParamCubitPlane.cpp.
    if( mk_plane_with_points( zero_position, zero_position + u_direction,
        zero_position + v_direction ) == (int)CUBIT_SUCCESS )
        is_plane_valid_= CUBIT_TRUE;
        result = CUBIT_SUCCESS;
    else
        is_plane_valid_= CUBIT_FALSE;
        result = CUBIT_FAILURE;
        return ;
    p_ = zero_position;
    s_ = u_direction;
    t_ = v_direction;
    n_ = s_ * t_;
    double n_len = n_.length();
    if( 1000 * CUBIT_DBL_MIN > n_len ) n_epsilon_ = CUBIT_DBL_MIN;
    else n_epsilon_ = n_len / 1000;
ParamCubitPlane::ParamCubitPlane ( double  A,
double  B,
double  C,
double  D
ParamCubitPlane::ParamCubitPlane ( const CubitVector normal,
double  D
const CubitVector point
Member Function Documentation
CubitStatus ParamCubitPlane::closest_point ( const CubitVector position,
CubitVector closest_position
) const
Definition at line 65 of file ParamCubitPlane.cpp.
    assert( is_plane_valid_);
    if( !is_plane_valid_) return CUBIT_FAILURE;
    closest_position = position - (normal() * distance(position));
    return CUBIT_SUCCESS;
Definition at line 100 of file ParamCubitPlane.cpp.
    //Choose the zero-point for the parameterization
    //as close to the origin as possible.
//  p_.set( 0.0, 0.0, 0.0);
//  move_to_plane( p_ );
    is_plane_valid_ = CUBIT_TRUE;
    const CubitVector temp_p(0.0, 0.0, 0.0);
    CubitStatus s = closest_point( temp_p, p_ );
    assert( s == CUBIT_SUCCESS );
    if (CUBIT_SUCCESS != s) {
      PRINT_ERROR("ParamCubitPlane::closest_point failed.\n");
      return;
    CubitVector n = normal();
    CubitVector p1;
    p1 = p_;
    double x = fabs( n.x() );
    double y = fabs( n.y() );
    double z = fabs( n.z() );
    //Choose a direction from the zero point (p_) for
    //the second point as the direction of the smallest
    //component of the normal.  The third point defining
    //the plane will be defined by the cross product of
    //the vector from the zero_point to this point and
    //the normal vector of the plane.
    if( (x <= y) && (x <= z) )
        p1.x( p1.x() + 1 );
    else if( (y <= x) && (y <= z) )
        p1.y( p1.y() + 1 );
    else
        p1.z( p1.z() + 1 );
    move_to_plane( p1 );
    s_ = p1 - p_;
    t_ = -(s_ * n);
    n_ = s_ * t_;
Definition at line 84 of file ParamCubitPlane.cpp.
    const CubitVector v = position;
    CubitStatus s = closest_point( v, position );
    return s;
Member Data Documentation
Definition at line 89 of file ParamCubitPlane.hpp.
double ParamCubitPlane::n_epsilon_ [private]
Definition at line 90 of file ParamCubitPlane.hpp.
Definition at line 87 of file ParamCubitPlane.hpp.
