cgma
PartitionCurve Member List
This is the complete list of members for PartitionCurve, including all inherited members.
add(PartitionCoEdge *coedge)PartitionCurve
append_simple_attribute_virt(const CubitSimpleAttrib &)PartitionCurve [virtual]
bodysm()TopologyBridge
bodysms(DLIList< BodySM * > &bodies, bool unique=true)TopologyBridge
Curve::bounding_box() const =0GeometryEntity [pure virtual]
PartitionEntity::bounding_box() const =0PartitionEntity [pure virtual]
bridge_manager() const TopologyBridge
bridge_manager(BridgeManager *manager)TopologyBridge
bridge_sense()TopologyBridge [inline]
center_point()Curve [inline, virtual]
ChildType typedefCurve
closest_point(CubitVector const &location, CubitVector &closest_location, CubitVector *tangent_ptr=NULL, CubitVector *curvature_ptr=NULL, double *param=NULL)=0Curve [pure virtual]
closest_point_trimmed(CubitVector const &from_pt, CubitVector &result_pt)Curve [virtual]
coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true)TopologyBridge
combine(PartitionCurve *dead_curve)=0PartitionCurve [pure virtual]
Curve()Curve
curves(DLIList< Curve * > &curves, bool unique=true)TopologyBridge
curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true)TopologyBridge
do_facet_cleanup()PartitionCurve
draw_facets(int color)PartitionCurve
end_param()=0Curve [pure virtual]
end_point() const PartitionCurve [inline]
end_point(PartitionPoint *point)PartitionCurve
endNextPartitionCurve [private]
endPointPartitionCurve [private]
facetEdgesPartitionCurve [private]
firstCoEdgePartitionCurve [private]
fix_facet_data(PartitionCurve *new_curve)PartitionCurve
G1_discontinuous(double u, CubitVector *minus_tangent=NULL, CubitVector *plus_tangent=NULL)Curve [virtual]
geometry_type()Curve [inline, virtual]
GeometryEntity()GeometryEntity [inline]
get_arc_length()Curve [inline, virtual]
get_arc_length(const CubitVector &point1, const CubitVector &point2)Curve [inline, virtual]
get_arc_length(const CubitVector &point1, const int which_end)Curve [inline, virtual]
get_center_radius(CubitVector &center, double &radius)=0Curve [pure virtual]
get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER)TopologyBridge
get_children_virt(DLIList< TopologyBridge * > &)PartitionCurve [virtual]
get_ellipse_params(CubitVector &center, CubitVector &normal, CubitVector &major_axis, double &radius_ratio) const =0Curve [pure virtual]
get_facet_data(DLIList< CubitFacetEdgeData * > &result_list) const PartitionCurve
get_geometry_query_engine() const PartitionCurve [virtual]
get_graphics(GMem &result, double angle_tolerance=0, double distance_tolerance=0, double max_edge_length=0)=0PartitionCurve [pure virtual]
get_interior_extrema(DLIList< CubitVector * > &interior_points, CubitSense &return_sense)=0Curve [pure virtual]
get_param_range(double &lower_bound, double &upper_bound)=0Curve [pure virtual]
get_parents(DLIList< TopologyBridge * > &parents)TopologyBridge
get_parents_virt(DLIList< TopologyBridge * > &)PartitionCurve [virtual]
get_point_direction(CubitVector &origin, CubitVector &direction)Curve [virtual]
get_save_topology(DLIList< int > &points)PartitionCurve [protected]
get_saved_id() const GeometryEntity [inline]
get_saved_names(std::vector< CubitString > &names)GeometryEntity
get_simple_attribute(DLIList< CubitSimpleAttrib > &)PartitionCurve [virtual]
get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &)PartitionCurve [virtual]
get_spline_params(bool &rational, int &degree, DLIList< CubitVector > &cntrl_pts, DLIList< double > &cntrl_pt_weights, DLIList< double > &knots, bool &spline_is_reversed) const =0Curve [pure virtual]
has_facet_data() const PartitionCurve [inline]
is_in_surface(const PartitionSurface *surf, bool manifold_only=false) const PartitionCurve
is_nonmanifold(const PartitionSurface *in_this_surf) const PartitionCurve
is_periodic(double &period)=0Curve [pure virtual]
is_position_on(const CubitVector &test_position)=0Curve [pure virtual]
is_tolerant()Curve [inline, virtual]
layer() const PartitionCurve [inline, virtual]
length_from_u(double parameter1, double parameter2)=0Curve [pure virtual]
loopsm()TopologyBridge
loopsms(DLIList< LoopSM * > &loopsms, bool unique=true)TopologyBridge
lump()TopologyBridge
lumps(DLIList< Lump * > &lumps, bool unique=true)TopologyBridge
markPartitionEntity
MAX_TB_LAYER enum valueTopologyBridge
measure()=0GeometryEntity [pure virtual]
mid_point(const CubitVector &point1, const CubitVector &point2, CubitVector &mid_point)Curve [inline, virtual]
mid_point(CubitVector &mid_point)Curve [inline, virtual]
move_to_geometry(CubitVector &position)PartitionCurve [virtual]
move_to_geometry(CubitPoint *facetPoint)PartitionCurve
next_coedge(const PartitionCoEdge *prev=0) const PartitionCurve [inline]
next_curve(const PartitionPoint *about_this) const PartitionCurve [inline]
notify_split(FacetEntity *old_entity, FacetEntity *new_entity)PartitionCurve [virtual]
num_coedges() const PartitionCurve
other_point(const PartitionPoint *pt) const PartitionCurve [inline]
owner() const TopologyBridge [inline]
owner(TBOwner *new_owner)TopologyBridge [inline]
PartitionCurve()PartitionCurve [protected]
partitioned_entity() const PartitionEntity [inline]
PartitionEntity()PartitionEntity [protected]
point_containment(const CubitVector &point)=0Curve [pure virtual]
point_from_arc_length(double root_param, const double arc_length, CubitVector &new_point)Curve [virtual]
point_from_arc_length(const CubitVector &root_point, double const arc_length, CubitVector &new_point)Curve [virtual]
points(DLIList< TBPoint * > &points, bool unique=true)TopologyBridge
position_from_fraction(const double fraction_along_curve, CubitVector &output_position)Curve [inline, virtual]
position_from_u(double u_value, CubitVector &output_position)=0Curve [pure virtual]
print_debug_info(const char *prefix=0, bool print_subentity_set=true) const PartitionCurve [virtual]
print_partitioned_entity(const char *prefix=0) const PartitionEntity
relative_sense(Curve *other_curve)Curve [virtual]
relax_to_geometry(CubitPoint *facet_point, const CubitVector *input_position=0)PartitionEntity
remove(PartitionCoEdge *coedge)PartitionCurve
remove_all_coedges()PartitionCurve
remove_all_simple_attribute_virt()PartitionCurve [virtual]
remove_dead_facet(CubitFacetEdgeData *edge)PartitionCurve
remove_end_point()PartitionCurve [private]
remove_facet_data()PartitionCurve
remove_from_point(PartitionPoint *point, PartitionCurve *next)PartitionCurve [private]
remove_simple_attribute_virt(const CubitSimpleAttrib &)PartitionCurve [virtual]
remove_start_point()PartitionCurve [private]
replace_facet(CubitFacetEdgeData *dead_facet, DLIList< CubitFacetEdgeData * > &new_facets)PartitionCurve
reverse_bridge_sense()TopologyBridge [inline]
reverse_point_order()PartitionCurve [protected]
reverse_sense()=0PartitionEntity [pure virtual]
save(CubitSimpleAttrib &attrib)=0PartitionEntity [pure virtual]
set_facet_data(const DLIList< CubitFacetEdgeData * > &new_list)PartitionCurve
set_saved_id(int value)GeometryEntity [inline]
set_saved_names(const std::vector< CubitString > &names)GeometryEntity
shellsms(DLIList< ShellSM * > &shellsms, bool unique=true)TopologyBridge
split(double param)=0PartitionCurve [pure virtual]
start_param()=0Curve [pure virtual]
start_point() const PartitionCurve [inline]
start_point(PartitionPoint *point)PartitionCurve
startNextPartitionCurve [private]
startPointPartitionCurve [private]
sub_entity_set() const PartitionEntity [inline]
surfaces(DLIList< Surface * > &surfaces, bool unique=true)TopologyBridge
surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true)TopologyBridge
topology_entity() const TopologyBridge
TopologyBridge()TopologyBridge [inline]
transform(const CubitTransformMatrix &)PartitionCurve [virtual]
u_from_arc_length(double root_param, double arc_length)=0Curve [pure virtual]
u_from_position(const CubitVector &input_position)=0Curve [pure virtual]
validate(const CubitString &, DLIList< TopologyEntity * > &)TopologyBridge [inline, virtual]
~Curve()Curve [virtual]
~GeometryEntity()GeometryEntity [virtual]
~PartitionCurve()PartitionCurve [virtual]
~PartitionEntity()PartitionEntity [virtual]
~TopologyBridge()TopologyBridge [virtual]
