cgma
PointGridSearch Member List
This is the complete list of members for PointGridSearch, including all inherited members.
add_point(CubitPoint *point)PointGridSearch
add_point_to_cell(CubitPoint *point, int i)PointGridSearch [private]
average_points_per_occupied_cell()PointGridSearch
bounding_cell_maximum_x()PointGridSearch [inline]
bounding_cell_maximum_y()PointGridSearch [inline]
bounding_cell_maximum_z()PointGridSearch [inline]
bounding_cell_minimum_x()PointGridSearch [inline]
bounding_cell_minimum_y()PointGridSearch [inline]
bounding_cell_minimum_z()PointGridSearch [inline]
bounding_range(DLIList< CubitPoint * > &point_list)PointGridSearch [protected]
bounding_range(DLIList< CubitFacet * > &facet_list)PointGridSearch [protected]
bounding_range(CubitPoint *point)PointGridSearch [inline, protected]
bounding_range(const CubitVector &vec)PointGridSearch [inline, protected]
bounding_range_maximum()PointGridSearch [inline]
bounding_range_minimum()PointGridSearch [inline]
boundingCellMaximumXPointGridSearch [protected]
boundingCellMaximumYPointGridSearch [protected]
boundingCellMaximumZPointGridSearch [protected]
boundingCellMinimumXPointGridSearch [protected]
boundingCellMinimumYPointGridSearch [protected]
boundingCellMinimumZPointGridSearch [protected]
boundingRangeMaximumPointGridSearch [protected]
boundingRangeMinimumPointGridSearch [protected]
cell_from_range()PointGridSearch [protected, virtual]
change_cell(CubitPoint *point)PointGridSearch
fraction_empty_cells()PointGridSearch
get_neighborhood_facets(DLIList< CubitFacet * > &facet_list)PointGridSearch
get_neighborhood_points(DLIList< CubitPoint * > &point_list)PointGridSearch
get_neighborhood_points_sorted(DLIList< CubitPoint * > &point_list, const CubitVector &center, double cut_off)PointGridSearch
grid_cell_index(CubitPoint *point)PointGridSearch [inline, protected]
grid_cell_width()PointGridSearch [inline]
grid_range_maximum()PointGridSearch [inline]
grid_range_minimum()PointGridSearch [inline]
gridCellWidthPointGridSearch [protected]
gridCellWidthInversePointGridSearch [protected]
gridRangeMaximumPointGridSearch [protected]
gridRangeMinimumPointGridSearch [protected]
in_grid(const CubitVector &position)PointGridSearch
maxEdgeLengthPointGridSearch [private]
neighborhoodListPointGridSearch [private]
number_grid_cells()PointGridSearch [inline]
number_grid_cells_x()PointGridSearch [inline]
number_grid_cells_y()PointGridSearch [inline]
number_grid_cells_z()PointGridSearch [inline]
numberGridCellsPointGridSearch [protected]
numberGridCellsXPointGridSearch [protected]
numberGridCellsYPointGridSearch [protected]
numberGridCellsZPointGridSearch [protected]
PointGridSearch(DLIList< CubitPoint * > *point_list, DLIList< CubitFacet * > *facet_list, float grid_scale=2.0)PointGridSearch
PointGridSearch(DLIList< CubitPoint * > &point_list, double grid_cell_size, double grid_scale)PointGridSearch
remove_point(CubitPoint *point)PointGridSearch
remove_point_from_cell(CubitPoint *point, int i)PointGridSearch [private]
set_neighborhood_bounds(CubitVector &vec)PointGridSearch
set_neighborhood_bounds(const CubitVector &center, double size)PointGridSearch
set_neighborhood_bounds(CubitVector &center, double x, double y, double z)PointGridSearch
set_neighborhood_bounds(CubitVector &vec_1, CubitVector &vec_2)PointGridSearch
set_neighborhood_bounds(CubitPoint *point, CubitVector &vec)PointGridSearch
set_neighborhood_bounds(CubitPoint *point)PointGridSearch
set_neighborhood_bounds(CubitPoint *point_1, CubitPoint *point_2)PointGridSearch
set_neighborhood_bounds(DLIList< CubitPoint * > &point_list)PointGridSearch
set_neighborhood_bounds(CubitFacet *facet)PointGridSearch
set_neighborhood_bounds(DLIList< CubitFacet * > &facet_list)PointGridSearch
set_neighborhood_bounds_max_edge(const CubitVector &center, double factor=1.0)PointGridSearch
total_points_in_grid_cells()PointGridSearch
~PointGridSearch()PointGridSearch [virtual]
