cgma
RStarTreeNode< Y > Member List
This is the complete list of members for RStarTreeNode< Y >, including all inherited members.
add_child(RStarTreeNode< Y > *child_node, CubitBoolean recalc_b_box)RStarTreeNode< Y >
adjust_tree(RStarTreeNode< Y > *l, RStarTreeNode< Y > *ll, RStarTreeNode< Y > *root_node, RStarTreeNode< Y > *&new_root, int *overflow_flags, int levels)RStarTreeNode< Y > [private]
bounding_box()RStarTreeNode< Y > [inline]
calc_enlargement(RStarTreeNode< Y > *current, RStarTreeNode< Y > *add_to)RStarTreeNode< Y > [private]
calc_enlargement(CubitBox &current, CubitBox &add_to)RStarTreeNode< Y > [private]
calc_overlap(RStarTreeNode< Y > *current, RStarTreeNode< Y > *add_to)RStarTreeNode< Y > [private]
can_add()RStarTreeNode< Y >
choose_sub_tree(RStarTreeNode< Y > *n, RStarTreeNode< Y > *e)RStarTreeNode< Y > [private]
condense_tree(RStarTreeNode< Y > *l, RStarTreeNode< Y > *root, RStarTreeNode< Y > *&new_root)RStarTreeNode< Y > [private]
dist_is_box()RStarTreeNode< Y > [inline]
distIsBoxRStarTreeNode< Y > [private]
find_leaf(Y e, CubitBox &e_box, RStarTreeNode< Y > *t, RStarTreeNode< Y > *&l)RStarTreeNode< Y > [private]
flush(CubitBox &new_box)RStarTreeNode< Y >
get_child(int i)RStarTreeNode< Y > [inline]
get_data()RStarTreeNode< Y > [inline]
get_dist()RStarTreeNode< Y > [inline]
get_leaf_level()RStarTreeNode< Y > [inline]
get_parent()RStarTreeNode< Y > [inline]
insert(RStarTreeNode< Y > *e, RStarTreeNode< Y > *&new_root, int *overflow_flags, int levels)RStarTreeNode< Y >
is_data()RStarTreeNode< Y > [inline]
is_leaf()RStarTreeNode< Y > [inline]
margin(CubitBox &bounding_box)RStarTreeNode< Y > [private]
markedFlagRStarTreeNode< Y > [private]
maxChildrenRStarTreeNode< Y > [private]
minChildrenRStarTreeNode< Y > [private]
myBoundingBoxRStarTreeNode< Y > [private]
myChildrenNodesRStarTreeNode< Y > [private]
myDataRStarTreeNode< Y > [private]
myDistRStarTreeNode< Y > [private]
myIdRStarTreeNode< Y > [private]
myLevelRStarTreeNode< Y > [private]
myParentRStarTreeNode< Y > [private]
nextChildIndexRStarTreeNode< Y > [private]
num_children()RStarTreeNode< Y > [inline]
overflow_treatment(RStarTreeNode< Y > *l, RStarTreeNode< Y > *e, RStarTreeNode< Y > *&ll, RStarTreeNode< Y > *root, RStarTreeNode< Y > *&new_root, int *overflow_flags, int levels)RStarTreeNode< Y > [private]
recalc_b_box()RStarTreeNode< Y >
reinsert(RStarTreeNode< Y > *l, RStarTreeNode< Y > *e, RStarTreeNode< Y > *root, RStarTreeNode< Y > *&new_root, int *overflow_flags, int levels)RStarTreeNode< Y > [private]
remove(Y e, RStarTreeNode< Y > *&new_root, CubitBoolean &delete_root)RStarTreeNode< Y >
remove_child(RStarTreeNode< Y > *child)RStarTreeNode< Y >
RStarTreeNode(Y data, double tol, int max_children, int min_children)RStarTreeNode< Y >
RStarTreeNode(CubitBox &bounding_box, int max_children, int min_children)RStarTreeNode< Y >
set_dist(double dis)RStarTreeNode< Y > [inline]
set_dist_is_box(int val)RStarTreeNode< Y > [inline]
set_leaf_level(int r_type)RStarTreeNode< Y > [inline]
set_parent(RStarTreeNode< Y > *parent)RStarTreeNode< Y > [inline]
sort_center_distance(RStarTreeNode< Y > *&n_1, RStarTreeNode< Y > *&n_2)RStarTreeNode< Y > [private, static]
sort_high_x(RStarTreeNode< Y > *&n_1, RStarTreeNode< Y > *&n_2)RStarTreeNode< Y > [private, static]
sort_high_y(RStarTreeNode< Y > *&n_1, RStarTreeNode< Y > *&n_2)RStarTreeNode< Y > [private, static]
sort_high_z(RStarTreeNode< Y > *&n_1, RStarTreeNode< Y > *&n_2)RStarTreeNode< Y > [private, static]
sort_low_x(RStarTreeNode< Y > *&n_1, RStarTreeNode< Y > *&n_2)RStarTreeNode< Y > [private, static]
sort_low_y(RStarTreeNode< Y > *&n_1, RStarTreeNode< Y > *&n_2)RStarTreeNode< Y > [private, static]
sort_low_z(RStarTreeNode< Y > *&n_1, RStarTreeNode< Y > *&n_2)RStarTreeNode< Y > [private, static]
space_left()RStarTreeNode< Y >
split_node(RStarTreeNode< Y > *l, RStarTreeNode< Y > *e, RStarTreeNode< Y > *&ll)RStarTreeNode< Y > [private]
super_box(DLIList< RStarTreeNode< Y > * > &node_list)RStarTreeNode< Y > [private]
validate_tree(int print)RStarTreeNode< Y >
volume(CubitBox &box)RStarTreeNode< Y > [inline, private]
volume(RStarTreeNode< Y > *curr)RStarTreeNode< Y > [inline, private]
~RStarTreeNode()RStarTreeNode< Y >
