cgma
RefCollection Member List
This is the complete list of members for RefCollection, including all inherited members.
actuate_cubit_attrib(int attrib_type)CubitAttribUser
actuate_cubit_attrib(DLIList< RefEntity * >, int)CubitAttribUser [static]
add_compare_data(RefEntity *partner)RefEntity
add_cubit_attrib(CubitAttrib *cubit_attrib_ptr)CubitAttribUser
add_observer(CubitObserver *observer)CubitObservable [protected, virtual]
add_TD(ToolData *new_td)ToolDataUser [virtual]
append_attrib_internal(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr)CubitAttribUser
append_simple_attribute(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr)CubitAttribUser
assign_default_name(CubitBoolean user_setting=CUBIT_FALSE)RefEntity
auto_actuate_cubit_attrib(CubitBoolean from_constructor=CUBIT_TRUE, CubitBoolean after_geom_changes=CUBIT_FALSE)CubitAttribUser
auto_read_cubit_attrib()CubitAttribUser
auto_update_cubit_attrib()CubitAttribUser
auto_update_cubit_attrib(DLIList< RefEntity * > &entity_list, CubitBoolean write_too=CUBIT_TRUE)CubitAttribUser [static]
autoMergeStatusRefEntity [protected]
bounding_box()=0CubitEntity [pure virtual]
can_modify()RefEntity [virtual]
center_point()RefEntity [virtual]
change_to_parent_ref_entities(DLIList< RefEntity * > &ancestors)RefEntity [static]
children_mergeable()RefEntity [virtual]
class_name() const =0CubitEntity [pure virtual]
clear_all_simple_attrib(DLIList< RefEntity * > &entity_list)CubitAttribUser [static]
clear_all_simple_attrib_set_to_actuate(DLIList< RefEntity * > &entity_list)CubitAttribUser [static]
clear_simple_attribs()CubitAttribUser
clear_simple_attribs_set_to_actuate()CubitAttribUser
collectionEntityPtrRefCollection [protected]
color(int value)RefEntity [virtual]
color() const RefEntity [virtual]
comparison_found(RefEntity *partner)RefEntity
CubitAttribUser(CubitAttrib *=NULL)CubitAttribUser
CubitEntity()CubitEntity [inline]
CubitEventDispatcher classCubitObservable [friend]
CubitObservable()CubitObservable
CubitObservable(const CubitObservable &)CubitObservable [protected]
CubitObserver classCubitObservable [friend]
dag_type() const =0RefEntity [pure virtual]
dag_type(const std::type_info &)RefEntity [static]
dag_type(const char *cli_type_name)RefEntity [static]
delete_TD(IdentityFn specified_type)ToolDataUser [virtual]
delete_TD(ToolData *td)ToolDataUser [virtual]
dimension() const RefEntity [virtual]
entity_name() const RefEntity [virtual]
entity_name(CubitString name)RefEntity
entity_names(DLIList< CubitString > &names) const RefEntity
entity_type_info() const =0RefEntity [pure virtual]
entityIdCubitEntity [protected]
find_cubit_attrib_type(int, DLIList< CubitAttrib * > &) const CubitAttribUser
gather_bdy_entities(DLIList< RefEntity * > &entity_list, DLIList< RefEntity * > &bdy_list)RefEntity [static]
generate_default_name(CubitString &name)RefEntity
get_all_child_ref_entities(DLIList< RefEntity * > &entity_list)RefEntity
get_all_child_ref_entities(DLIList< RefEntity * > &input_list, DLIList< RefEntity * > &output_list)RefEntity [static]
get_all_parent_ref_entities(DLIList< RefEntity * > &entity_list, const int get_bodies=CUBIT_FALSE)RefEntity
get_all_TDs(IdentityFn specified_type, DLIList< ToolData * > *all_tds) const ToolDataUser [virtual]
get_all_TDs(DLIList< ToolData * > *all_tds) const ToolDataUser [virtual]
get_by_name(const CubitString &name)RefEntity [static]
get_child_ref_entities(DLIList< RefEntity * > &entity_list)RefEntity [virtual]
get_child_ref_entity_type() const RefEntity
get_child_ref_entity_type(DagType parent_type)RefEntity [static]
get_collection_entity_ptr()RefCollection [inline]
get_collection_entity_ptr() const RefCollection [inline]
get_compare_partner()RefEntity
get_cubit_attrib(int attrib_type, CubitBoolean create_if_missing=CUBIT_TRUE)CubitAttribUser
get_cubit_attrib_list(DLIList< CubitAttrib * > &)CubitAttribUser
get_entity_type_info(const char *entity_type)RefEntity [static]
get_observer_list(DLIList< CubitObserver * > &observers)CubitObservable
get_parent_ref_entities(DLIList< RefEntity * > &entity_list)=0RefEntity [pure virtual]
get_parent_ref_entity_type() const RefEntity
get_parent_ref_entity_type(DagType child_type)RefEntity [static]
get_ref_class_name(const std::type_info &ref_type)RefEntity [static]
get_related_entity_list(const std::type_info &related_entity_type, DLIList< RefEntity * > &entity_list)RefEntity
get_TD(IdentityFn specified_type)ToolDataUser [virtual]
get_TD(IdentityFn specified_type) const ToolDataUser [virtual]
headAttribCubitAttribUser [protected]
id() const CubitEntity [virtual]
is_child(RefEntity *entity)RefEntity [virtual]
is_mergeable(AutoMergeStatus val)RefEntity [virtual]
is_mergeable()RefEntity
is_merged()RefEntity
is_parent(RefEntity *entity)RefEntity [virtual]
is_transparent(int flag)CubitEntity [virtual]
is_transparent() const CubitEntity [virtual]
is_visible(int flag)CubitEntity [virtual]
is_visible() const CubitEntity [virtual]
join(RefEntity *ref_entity_2, DLIList< RefEntity * > &join_set)RefEntity
join(DLIList< RefEntity * > &ref_entities, DLIList< RefEntity * > &join_set)RefEntity [static]
listFlagRefEntity [protected]
local_tolerance(double value)RefEntity [inline]
local_tolerance(void)RefEntity [inline]
marked(int value)RefEntity [inline, virtual]
marked()RefEntity [inline, virtual]
markedFlagRefEntity [protected]
mColorRefEntity [protected]
measure()RefEntity [virtual]
measure_label()RefEntity [virtual]
meet(RefEntity *ref_entity_2, DLIList< RefEntity * > &join_set)RefEntity
meet(DLIList< RefEntity * > &ref_entities, DLIList< RefEntity * > &join_set)RefEntity [static]
merge_entity_names(RefEntity *dead_entity)RefEntity
merge_owner(RefEntity *deletable_entity)CubitAttribUser
merge_status() const RefEntity
notify_observers(const CubitEvent *event)CubitObservable
notify_sub_all_observers(const GeometryEvent::Type &event)RefEntity
num_cubit_attrib()CubitAttribUser
num_names() const RefEntity
num_parent_ref_entities()RefEntity
observerListCubitObservable [protected]
CubitObservable::operator=(const CubitObservable &)CubitObservable [protected]
read_cubit_attrib(int attrib_type)CubitAttribUser
RefCollection()RefCollection
RefEntity()RefEntity
remove_all_simple_attribute(TopologyBridge *bridge)CubitAttribUser
remove_attrib_geometry_entity(CubitAttrib *)CubitAttribUser
remove_compare_data()RefEntity
remove_cubit_attrib(int attrib_type)CubitAttribUser
remove_cubit_attrib(CubitAttrib *)CubitAttribUser
remove_entity_name(CubitString const &name)RefEntity
remove_entity_names()RefEntity
remove_from_observers()CubitObservable [protected]
remove_observer(CubitObserver *observer)CubitObservable [protected, virtual]
remove_simple_attribute(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr)CubitAttribUser
remove_TD(IdentityFn specified_type)ToolDataUser [virtual]
remove_TD(ToolData *td)ToolDataUser [virtual]
set_collection_entity_ptr(CollectionEntity *collection_entity_ptr)RefCollection
set_id(int i)RefEntity [virtual]
set_id(int i, CubitBoolean emit_event)RefEntity
set_updated_flag(CubitBoolean flag)CubitAttribUser
set_written_flag(CubitBoolean flag)CubitAttribUser
split_owner(DLIList< CubitSimpleAttrib > &csa_list)CubitAttribUser
switch_entity_names(RefEntity *other_entity)RefEntity
ToolDataUser()ToolDataUser [inline]
transf_owner(const CubitVector &matrow1, const CubitVector &matrow2, const CubitVector &matrow3, const CubitVector &translate_vec, const double scale_factor)CubitAttribUser
update_auto_merge_state()RefEntity
update_cubit_attrib(int)CubitAttribUser
valence(RefEntity *parent=NULL)RefEntity
validate()RefEntity [virtual]
write_cubit_attrib_by_type(int attrib_type)CubitAttribUser
write_cubit_attrib_list(DLIList< CubitAttrib * > attrib_list)CubitAttribUser
write_cubit_attribs()CubitAttribUser
write_specific_cubit_attrib(CubitAttrib *cubit_attrib_ptr)CubitAttribUser
~CubitAttribUser()CubitAttribUser [virtual]
~CubitEntity()CubitEntity [virtual]
~CubitObservable()CubitObservable [virtual]
~RefCollection()RefCollection [virtual]
~RefEntity()RefEntity [virtual]
~ToolDataUser()ToolDataUser [virtual]
