cgma
RefEntityName Member List
This is the complete list of members for RefEntityName, including all inherited members.
add_refentity_name(RefEntity *entity, CubitString &name, bool update_attribs=true, bool check_name_validity=true)RefEntityName
add_refentity_name(RefEntity *entity, DLIList< CubitString > &names, bool update_attribs=true, bool check_name_validity=true)RefEntityName
base_name(const CubitString &name)RefEntityName [static]
clean(CubitString &raw_name)RefEntityName [private]
copy_refentity_names(const RefEntity *source, RefEntity *target, CubitBoolean update_attribs=CUBIT_TRUE)RefEntityName
copy_refentity_names(DLIList< RefEntity * > &source_list, RefEntity *target, CubitBoolean unique_base_names=CUBIT_TRUE, CubitBoolean update_attribs=CUBIT_TRUE)RefEntityName
delete_instance()RefEntityName [inline, static]
fixDuplicateNamesRefEntityName [private, static]
generate_unique_name(CubitString &name)RefEntityName [private]
generateDefaultNamesRefEntityName [private, static]
get_character(const CubitString &type) const RefEntityName
get_fix_duplicate_names()RefEntityName [static]
get_generate_default_names()RefEntityName [static]
get_merge_base_names()RefEntityName [inline, static]
get_refentity(const CubitString &name)RefEntityName
get_refentity_id(const CubitString &name)RefEntityName
get_refentity_name(const RefEntity *entity, DLIList< CubitString > &names)RefEntityName
get_refentity_type(const CubitString &name)RefEntityName
get_replacement_setting()RefEntityName [static]
get_suffix_setting()RefEntityName [static]
initialize_settings()RefEntityName [static]
instance()RefEntityName [static]
instance_RefEntityName [private, static]
list_refentity_names(const char *type="all")RefEntityName
merge_refentity_names(RefEntity *retained, RefEntity *dead)RefEntityName
mergeBaseNamesRefEntityName [private, static]
nameEntityListRefEntityName [private]
num_name_change_warnings()RefEntityName [inline]
num_name_change_warnings(int new_val)RefEntityName [inline]
numNameChangeWarningsRefEntityName [private, static]
print_name_change_warnings()RefEntityName [inline]
print_name_change_warnings(bool new_val)RefEntityName [inline]
printNameChangeWarningsRefEntityName [private, static]
RefEntityName()RefEntityName [protected]
remove_refentity_name(RefEntity *entity, const CubitString &name, CubitBoolean update_attribs=CUBIT_TRUE)RefEntityName
remove_refentity_name(RefEntity *entity, CubitBoolean update_attribs=CUBIT_TRUE)RefEntityName
replacementCharacterRefEntityName [private, static]
same_base_name(const CubitString &name1, const CubitString &name2)RefEntityName
set_character(char rep, const CubitString &type)RefEntityName
set_fix_duplicate_names(int on_off)RefEntityName [static]
set_generate_default_names(int on_off)RefEntityName [static]
set_merge_base_names(CubitBoolean flag)RefEntityName [inline, static]
set_replacement_setting(CubitString rep)RefEntityName [static]
set_suffix_setting(CubitString rep)RefEntityName [static]
suffixCharacterRefEntityName [private, static]
switch_refentity_names(RefEntity *entity1, RefEntity *entity2)RefEntityName
~RefEntityName()RefEntityName
