cgma
SDLList Member List
This is the complete list of members for SDLList, including all inherited members.
append_link(void *newBody)SDLList [inline]
append_unique(void *new_item)DLList
ArrayBasedContainer(int size)ArrayBasedContainer
ArrayBasedContainer(const ArrayBasedContainer &copy_from)ArrayBasedContainer
back()DLList [inline]
back(int n)DLList [inline]
binary_search(int *min_location, int *max_location, void *item) const SDLList [private]
change_item_to(void *newBody)SDLList
clean_out()DLList [inline]
compare_equalSDLList
compare_orderSDLList
compare_order_objSDLList
compress()DLList [virtual]
current_allocated_memory()ArrayBasedContainer [static]
cut_link()DLList [protected]
distance_to_nearby_item(void *body)DLList [protected]
DLList(int list_size)DLList
DLList(const DLList &copy_from)DLList
extract_link()SDLList
get_index()DLList
get_item() const DLList [inline, protected]
get_item_and_back()DLList [protected]
get_item_and_step()DLList [inline, protected]
indexDLList [protected]
insert_item_sorted(void *value, void *new_item)SDLList
insert_link(void *newBody)DLList [protected]
insert_link_first(void *new_item)SDLList
intersect(DLList &merge_list)DLList
is_at_beginning() const DLList [inline]
is_at_end() const DLList [inline]
itemCountArrayBasedContainer [protected]
last()DLList [inline]
lengthen_list()ArrayBasedContainer [protected]
listArrayArrayBasedContainer [protected]
listIncrementArrayBasedContainer [protected]
listIsSortedArrayBasedContainer [protected]
listLengthArrayBasedContainer [protected]
maximum_allocated_memory()ArrayBasedContainer [static]
memoryManagerSDLList [private, static]
merge_unique(DLList &merge_list, int merge_list_unique)SDLList [virtual]
move_between_items(void *body1, void *body2)DLList [protected]
move_to_and_remove_item(void *item)DLList [protected]
move_to_and_remove_item_sorted(void *value)SDLList
move_to_item(void *body)DLList [protected]
move_to_item_sorted(void *value)SDLList
move_to_nearby_item(void *body)DLList [protected]
next_item(int n=1) const DLList [inline, protected]
nullify_link()DLList [protected]
nullItemDLList [protected]
omit_link(void *)DLList [protected]
operator!=(const DLList &list) const DLList
operator+=(const ArrayBasedContainer &)ArrayBasedContainer
operator-=(const ArrayBasedContainer &)ArrayBasedContainer
operator<=(const DLList &list) const DLList
operator=(const SDLList &)SDLList
DLList::operator=(const DLList &)DLList
ArrayBasedContainer::operator=(const ArrayBasedContainer &)ArrayBasedContainer
operator==(const DLList &list) const DLList
operator>(const DLList &list) const DLList
operator>=(const DLList &list) const DLList
poolAllocatedArrayBasedContainer [protected]
prev_item(int n=1) const DLList [protected]
reset()DLList [inline]
reverse()DLList
SDLList(int size)SDLList
SDLList(const SDLList &copy_from)SDLList
SDLList(const DLList &copy_from)SDLList
set_index(int new_index)DLList
set_sorted_flag(const int sorted_flag)SDLList [inline]
SetDynamicMemoryAllocation(memoryManager) int operator<(const DLList &list) const DLList
shrink(int k)DLList
size() const ArrayBasedContainer [inline]
sort_list()SDLList
step()DLList [inline]
step(int n)DLList [inline]
step_and_get_item()DLList [protected]
where_is_item(void *item) const DLList [protected]
where_is_item_sorted(void *value, int &item_index)SDLList
~ArrayBasedContainer()ArrayBasedContainer [virtual]
~DLList()DLList [virtual]
~SDLList()SDLList [virtual]
