cgma
SphereEvaluator Class Reference
#include <SphereEvaluator.hpp>
Inheritance diagram for SphereEvaluator:
CubitEvaluator
List of all members.
Public Member Functions
 SphereEvaluator (const SphereEvaluatorData *data)
virtual ~SphereEvaluator ()
virtual GeometryType ask_type ()
virtual CubitBoolean is_parametric () const
virtual CubitBoolean is_periodic () const
virtual CubitBoolean is_periodic_in_U (double &period) const
virtual CubitBoolean is_periodic_in_V (double &period) const
virtual CubitBoolean is_singular_in_U () const
virtual CubitBoolean is_singular_in_V () const
virtual CubitBoolean is_closed_in_U () const
virtual CubitBoolean is_closed_in_V () const
virtual CubitBoolean get_param_range_U (double &lower_bound, double &upper_bound) const
virtual CubitBoolean get_param_range_V (double &lower_bound, double &upper_bound) const
virtual const CubitEvaluatorDataevaluator_data () const
virtual CubitVector position_from_u_v (double u, double v) const
virtual CubitStatus u_v_from_position (CubitVector const &location, double &u, double &v, CubitVector *closest_location) const
virtual CubitBox bounding_box () const
virtual CubitStatus principal_curvatures (CubitVector const &location, double &curvature_1, double &curvature_2, CubitVector *closest_location=NULL)
virtual CubitStatus closest_point (CubitVector const &location, CubitVector *closest_location=NULL, CubitVector *unit_normal_ptr=NULL, CubitVector *curvature1_ptr=NULL, CubitVector *curvature2_ptr=NULL) const
Private Attributes
SphereEvaluatorData mEvalData
Detailed Description
Definition at line 34 of file SphereEvaluator.hpp.
Definition at line 46 of file SphereEvaluator.hpp.
{ mEvalData = *data; }
virtual SphereEvaluator::~SphereEvaluator ( ) [inline, virtual]
Definition at line 48 of file SphereEvaluator.hpp.
Member Function Documentation
virtual GeometryType SphereEvaluator::ask_type ( ) [inline, virtual]
Reimplemented from CubitEvaluator.
Definition at line 51 of file SphereEvaluator.hpp.
{ return SPHERE_SURFACE_TYPE; }
CubitBox SphereEvaluator::bounding_box ( void  ) const [virtual]
Implements CubitEvaluator.
Definition at line 33 of file SphereEvaluator.cpp.
    CubitVector center = mTmatrix * mEvalData.center;
    CubitVector min( center.x() - mEvalData.radius,
                     center.y() - mEvalData.radius,
                     center.z() - mEvalData.radius );
    CubitVector max( center.x() + mEvalData.radius,
                     center.y() + mEvalData.radius,
                     center.z() + mEvalData.radius );
    CubitBox thebbox( min, max );
    return thebbox;
CubitStatus SphereEvaluator::closest_point ( CubitVector const &  location,
CubitVector closest_location = NULL,
CubitVector unit_normal_ptr = NULL,
CubitVector curvature1_ptr = NULL,
CubitVector curvature2_ptr = NULL
) const [virtual]
Definition at line 81 of file SphereEvaluator.cpp.
    CubitTransformMatrix inverse_Tmatrix = mTmatrix;
    inverse_Tmatrix.inverse();
    CubitVector new_pt = inverse_Tmatrix * location;
    // If requested, compute the normal at the input point.
    if ( unit_normal_ptr != NULL )
        CubitVector origin( 0.0, 0.0, 0.0 );
        CubitVector endpt = new_pt - mEvalData.center;
        origin = mTmatrix * origin;
        endpt  = mTmatrix * endpt;
        *unit_normal_ptr = endpt - origin;
        unit_normal_ptr->normalize();
    // If requested, compute the closest point to the input point.
    if ( closest_location != NULL )
        if ( location.within_tolerance( mEvalData.center, GEOMETRY_RESABS ) )
            closest_location->set( mEvalData.center.x() + mEvalData.radius,
                                   mEvalData.center.y(),
                                   mEvalData.center.z() );
        else
            CubitVector vec = new_pt - mEvalData.center;
            vec.normalize();
            *closest_location = mEvalData.center + ( vec * mEvalData.radius );
            *closest_location = mTmatrix * (*closest_location);
    // If requested, compute the curvature directions.
    if ( curvature1_ptr &&
         curvature2_ptr )
        PRINT_ERROR("Sphere's do not current support curvature pointer requests.\n");
        return CUBIT_FAILURE;
    return CUBIT_SUCCESS;
const CubitEvaluatorData * SphereEvaluator::evaluator_data ( void  ) const [virtual]
Definition at line 213 of file SphereEvaluator.cpp.
    return &mEvalData;
CubitBoolean SphereEvaluator::get_param_range_U ( double &  lower_bound,
double &  upper_bound
) const [virtual]
Definition at line 223 of file SphereEvaluator.cpp.
   lower_bound = 0.0;
   upper_bound = 2.0*CUBIT_PI;
   return CUBIT_TRUE;
CubitBoolean SphereEvaluator::get_param_range_V ( double &  lower_bound,
) const [virtual]
Definition at line 238 of file SphereEvaluator.cpp.
   lower_bound = 0;
   upper_bound = CUBIT_PI;
   return CUBIT_TRUE;
virtual CubitBoolean SphereEvaluator::is_closed_in_U ( ) const [inline, virtual]
Definition at line 60 of file SphereEvaluator.hpp.
{ return CUBIT_TRUE; }
virtual CubitBoolean SphereEvaluator::is_closed_in_V ( ) const [inline, virtual]
Definition at line 61 of file SphereEvaluator.hpp.
{ return CUBIT_FALSE; }
virtual CubitBoolean SphereEvaluator::is_parametric ( ) const [inline, virtual]
Definition at line 52 of file SphereEvaluator.hpp.
virtual CubitBoolean SphereEvaluator::is_periodic ( ) const [inline, virtual]
Definition at line 53 of file SphereEvaluator.hpp.
virtual CubitBoolean SphereEvaluator::is_periodic_in_U ( double &  period) const [inline, virtual]
Definition at line 54 of file SphereEvaluator.hpp.
        { period = 2*CUBIT_PI;
virtual CubitBoolean SphereEvaluator::is_periodic_in_V ( double &  period) const [inline, virtual]
Definition at line 56 of file SphereEvaluator.hpp.
virtual CubitBoolean SphereEvaluator::is_singular_in_U ( ) const [inline, virtual]
Definition at line 58 of file SphereEvaluator.hpp.
virtual CubitBoolean SphereEvaluator::is_singular_in_V ( ) const [inline, virtual]
Definition at line 59 of file SphereEvaluator.hpp.
CubitVector SphereEvaluator::position_from_u_v ( double  u,
double  v
) const [virtual]
Definition at line 146 of file SphereEvaluator.cpp.
    double two_pi = 2.0 * CUBIT_PI;
    while ( u > two_pi ) u -= two_pi;
    while ( u < 0.0    ) u += two_pi;
    double radius_modified = mEvalData.radius * sin ( v );
    double x = radius_modified * cos( u );
    double y = radius_modified * sin( u );
    double z = mEvalData.radius * cos( v );
    CubitVector position( x, y, z );
    position = mTmatrix * position;
    return position;
CubitStatus SphereEvaluator::principal_curvatures ( CubitVector const &  location,
double &  curvature_1,
double &  curvature_2,
) [virtual]
Definition at line 58 of file SphereEvaluator.cpp.
    curvature_1 = curvature_2 = 1.0 / mEvalData.radius;
    if ( closest_location )
        closest_point( location, closest_location );
CubitStatus SphereEvaluator::u_v_from_position ( CubitVector const &  location,
double &  u,
double &  v,
) const [virtual]
Definition at line 169 of file SphereEvaluator.cpp.
    CubitVector transformed_pt = inverse_Tmatrix * location;
    CubitVector dir( transformed_pt );
    dir.normalize();
    v = acos( dir.z() );
    if ( v < GEOMETRY_RESABS )
        u = 0.0;
    else
        dir.set( dir.x(), dir.y(), 0.0 );
        dir.normalize();
        u = acos( dir.x() );
        if ( dir.y() < 0.0 )
            u = 2*CUBIT_PI - u;
        while ( u < 0.0 ) u += 2*CUBIT_PI;
        while ( u >= 2*CUBIT_PI ) u -= 2*CUBIT_PI;
Member Data Documentation
