cgma
TDSurfaceOverlap Class Reference
#include <TDSurfaceOverlap.hpp>
Inheritance diagram for TDSurfaceOverlap:
ToolData
List of all members.
Public Member Functions
 TDSurfaceOverlap (RefFace *ref_face_ptr, unsigned short ang_facet_tol, double abs_facet_tol, double gap_max)
 ~TDSurfaceOverlap ()
int has_rtree ()
DLIList< SurfaceOverlapFacet * > * get_facet_list ()
AbstractTree
get_facet_rtree ()
DLIList< Body * > * get_body_list ()
Static Public Member Functions
static int is_surface_overlap (const ToolData *td)
Private Attributes
RefFacerefFacePtr
DLIList< SurfaceOverlapFacet * > facetList
AbstractTree
aTree
DLIList< Body * > bodyList
int bodiesRetrieved
int marked
unsigned short angFacetTol
double absFacetTol
double gapMax
Detailed Description
Definition at line 17 of file TDSurfaceOverlap.hpp.
TDSurfaceOverlap::TDSurfaceOverlap ( RefFace ref_face_ptr,
double  gap_max
Definition at line 8 of file TDSurfaceOverlap.cpp.
  refFacePtr = ref_face_ptr;
  aTree = NULL;
  marked = 0;
  bodiesRetrieved = 0;
  angFacetTol = ang_facet_tol;
  absFacetTol = abs_facet_tol;
  gapMax = gap_max;
Definition at line 21 of file TDSurfaceOverlap.cpp.
  while( facetList.size() ) delete facetList.pop();
  if( aTree )
    delete aTree;
Member Function Documentation
Definition at line 96 of file TDSurfaceOverlap.cpp.
Definition at line 29 of file TDSurfaceOverlap.cpp.
  if( facetList.size() )
    return &facetList;
  GMem *gmem_ptr = new GMem;
  CubitStatus stat = refFacePtr->get_graphics( *gmem_ptr, angFacetTol, absFacetTol );
  if( !stat )
    delete gmem_ptr;
    return NULL;
  GPoint* plist = gmem_ptr->point_list();
  int* facet_list = gmem_ptr->facet_list();
  int i;
  GPoint p[3];
  for (i = 0; i < gmem_ptr->fListCount; )
    int sides = facet_list[i++];
    if (sides != 3)
      PRINT_WARNING("Skipping n-sided polygone in triangle list"
                    " in TDSurfaceOverlap.\n");
      i += sides;
    else
      p[0] = plist[facet_list[i++]];
      p[1] = plist[facet_list[i++]];
      p[2] = plist[facet_list[i++]];
      SurfaceOverlapFacet *facet = new SurfaceOverlapFacet( p );
      facetList.append( facet );
  delete gmem_ptr;
  return &facetList;
Definition at line 75 of file TDSurfaceOverlap.cpp.
  if( !aTree && !get_facet_list() )
    return NULL;
  if( !aTree )
    aTree = new RTree<SurfaceOverlapFacet*>( gapMax );
    int i;
    for( i=facetList.size(); i--; )
      SurfaceOverlapFacet *facet_ptr = facetList.get_and_step();
      aTree->add( facet_ptr );
  return aTree;
int TDSurfaceOverlap::has_rtree ( ) [inline]
Definition at line 25 of file TDSurfaceOverlap.hpp.
{if(aTree) return CUBIT_TRUE; else return CUBIT_FALSE;}
static int TDSurfaceOverlap::is_surface_overlap ( const ToolData td) [inline, static]
Definition at line 35 of file TDSurfaceOverlap.hpp.
     {return (CAST_TO(td, const TDSurfaceOverlap) != NULL);}
Member Data Documentation
Definition at line 47 of file TDSurfaceOverlap.hpp.
unsigned short TDSurfaceOverlap::angFacetTol [private]
Definition at line 46 of file TDSurfaceOverlap.hpp.
Definition at line 44 of file TDSurfaceOverlap.hpp.
Definition at line 43 of file TDSurfaceOverlap.hpp.
double TDSurfaceOverlap::gapMax [private]
Definition at line 48 of file TDSurfaceOverlap.hpp.
int TDSurfaceOverlap::marked [private]
Definition at line 45 of file TDSurfaceOverlap.hpp.
Definition at line 40 of file TDSurfaceOverlap.hpp.
