cgma
mcnp2cad.cpp File Reference
#include <iostream>
#include <fstream>
#include <string>
#include <stdexcept>
#include <cctype>
#include <vector>
#include <set>
#include <map>
#include <sstream>
#include <algorithm>
#include <cassert>
#include "iGeom.h"
#include "geometry.hpp"
#include "MCNPInput.hpp"
#include "options.hpp"
#include "volumes.hpp"
#include "ProgOptions.hpp"
#include "version.hpp"
#include <RefEntityFactory.hpp>
#include <Body.hpp>
#include <GeometryQueryTool.hpp>
#include <CubitMessage.hpp>
Classes
class  SilentCubitMessageHandler
class  CubitSilence
class  GeometryContext
class  GeometryContext::NamedGroup
class  GeometryContext::NamedEntity
struct  int_triple
Typedefs
typedef std::vector
< iBase_EntityHandle
entity_collection_t
Functions
static bool intersectIfPossible (iGeom_Instance igm, iBase_EntityHandle h1, iBase_EntityHandle h2, iBase_EntityHandle *result, bool delete_on_failure=true)
static bool boundBoxesIntersect (iGeom_Instance igm, iBase_EntityHandle h1, iBase_EntityHandle h2)
static std::vector< int_triplemakeGridShellOfRadius (int r, int dimensions)
void debugSurfaceDistances (InputDeck &deck, std::ostream &out=std::cout)
std::string mcnp2cad_version (bool full=true)
int main (int argc, char *argv[])
Variables
static bool CGMA_opt_inhibit_intersect_errs = false
struct program_option_struct Gopt
Typedef Documentation
Definition at line 78 of file mcnp2cad.cpp.
Function Documentation
static bool boundBoxesIntersect ( iGeom_Instance  igm,
) [static]
Definition at line 113 of file mcnp2cad.cpp.
  Vector3d h1_min, h1_max, h2_min, h2_max;
  int igm_result;
  iGeom_getEntBoundBox( igm, h1, h1_min.v, h1_min.v+1, h1_min.v+2, h1_max.v, h1_max.v+1, h1_max.v+2, &igm_result );
  CHECK_IGEOM( igm_result, "Getting bounding box h1" );
  iGeom_getEntBoundBox( igm, h2, h2_min.v, h2_min.v+1, h2_min.v+2, h2_max.v, h2_max.v+1, h2_max.v+2, &igm_result );
  CHECK_IGEOM( igm_result, "Getting bounding box h2" );
  bool ret = false;
  for( int i = 0; i < 3 && ret == false; ++i ){
    ret = ret || ( h1_min.v[i] > h2_max.v[i] );
    ret = ret || ( h2_min.v[i] > h1_max.v[i] );
  return !ret;
void debugSurfaceDistances ( InputDeck deck,
std::ostream &  out = std::cout
Definition at line 1110 of file mcnp2cad.cpp.
  InputDeck::surface_card_list& surfaces = deck.getSurfaces();
  for( InputDeck::surface_card_list::iterator i = surfaces.begin(); i!=surfaces.end(); ++i){
    try{
      const SurfaceVolume& s = makeSurface(*i);
      out << "S" << (*i)->getIdent() << " distance from origin: " << s.getFarthestExtentFromOrigin() << std::endl;
    catch(std::runtime_error& e){
      std::cerr << "Error debugging surface distances: " << e.what() << std::endl;
      throw;
static bool intersectIfPossible ( iGeom_Instance  igm,
iBase_EntityHandle result,
bool  delete_on_failure = true
) [static]
Definition at line 81 of file mcnp2cad.cpp.
  int igm_result;
//#ifdef USING_CGMA
  if( CGMA_opt_inhibit_intersect_errs ){
    CubitSilence s;
    iGeom_intersectEnts( igm, h1, h2, result, &igm_result);
  }  else
//#endif
  if( igm_result == iBase_SUCCESS ){
    return true;
  else{
    if( delete_on_failure ){
      iGeom_deleteEnt( igm, h1, &igm_result);
      CHECK_IGEOM(igm_result, "deleting an intersection candidate");
      iGeom_deleteEnt( igm, h2, &igm_result);
    return false;
int main ( int  argc,
char *  argv[]
Definition at line 1131 of file mcnp2cad.cpp.
  // set default options
  Gopt.verbose = Gopt.debug = false;
  Gopt.infinite_lattice_extra_effort = false;
  Gopt.tag_materials = true;
  Gopt.tag_importances = true;
  Gopt.tag_cell_IDs = true;
  Gopt.make_graveyard = true;
  Gopt.imprint_geom = true;
  Gopt.merge_geom = true;
  Gopt.input_file = "";
  Gopt.output_file = OPT_DEFAULT_OUTPUT_FILENAME;
  Gopt.igeom_init_options = "";
  Gopt.override_tolerance = false;
  Gopt.uwuw_names = false;
  bool DiFlag = false, DoFlag = false;
  ProgOptions po("mcnp2cad " + mcnp2cad_version(false) +  ": An MCNP geometry to CAD file converter");
  po.setVersion( mcnp2cad_version() );
  po.addOpt<void>("extra-effort,e","Use extra effort to get infinite lattices right (may be slow)",
                  &Gopt.infinite_lattice_extra_effort );
  po.addOpt<void>("verbose,v", "Verbose output", &Gopt.verbose );
  po.addOpt<void>("debug,D", "Debugging (very verbose) output", &Gopt.debug );
  po.addOpt<void>("Di", "Debug output for MCNP parsing phase only", &DiFlag);
  po.addOpt<void>("Do","Debug output for iGeom output phase only", &DoFlag);
  po.addOptionHelpHeading( "Options controlling CAD output:" );
  po.addOpt<std::string>(",o", "Give name of output file. Default: " + Gopt.output_file, &Gopt.output_file );
  po.addOpt<double>("tol,t", "Specify a tolerance for merging surfaces", &Gopt.specific_tolerance );
  po.addOpt<void>("skip-mats,M", "Do not tag materials using group names",
                  &Gopt.tag_materials, po.store_false );
  po.addOpt<void>("skip-imps,P", "Do not tag cell importances using group names",
                  &Gopt.tag_importances, po.store_false );
  po.addOpt<void>("skip-nums,N", "Do not tag cell numbers using body names",
                  &Gopt.tag_cell_IDs, po.store_false );
  po.addOpt<void>("skip-merge,E", "Do not merge the geometry",
                  &Gopt.merge_geom, po.store_false );
  po.addOpt<void>("skip-imprint,I", "Do not imprint the geometry; implies skip-merge",
                  &Gopt.imprint_geom, po.store_false );
  po.addOpt<void>("skip-graveyard,G", "Do not bound the geometry with a `graveyard' bounding box",
                  &Gopt.make_graveyard, po.store_false );
  po.addOpt<void>("uwuw-names,U", "Use a UWUW compatible name scheme for material groups,"
                                   "i.e. 'mat:mX/rho:Y' where X is material number is Y is density",
                  &Gopt.uwuw_names, po.store_true );
//#ifdef USING_CGMA
  po.addOptionHelpHeading ("Options controlling CGM library:");
  po.addOpt<int>("geomver","Override geometry export engine version");
  po.addOptionHelpHeading ("    (use --geomver 1600 for backward compatibility w/ Cubit 10.2)");
  po.addOpt<void>("Cv", "Verbose messages from CGM" );
  po.addOpt<void>("Cq", "Silence warning messages from CGM" );
  po.addOpt<void>("CIq","Silence ERROR messages from CGM when doing intersect tests.");
  po.addOptionHelpHeading( "         (May be useful for infinite lattices, but use cautiously)" );
//#endif
  po.addRequiredArg( "input_file", "Path to MCNP geometry input file", &Gopt.input_file );
  po.parseCommandLine( argc, argv );
  if( po.numOptSet( "tol,t" ) ){
    Gopt.override_tolerance = true;
    if( Gopt.specific_tolerance <= 0.0 || Gopt.specific_tolerance > .1 ){
      std::cerr << "Warning: you seem to have specified an unusual tolerance ("
                << Gopt.specific_tolerance << ")." << std::endl;
//#ifdef USING_CGMA
  // Enable the info_flag only if --Cv is requested
  if(po.numOptSet( "Cv" )){
    CubitMessage::instance()->set_info_flag( true );
  else{
    CubitMessage::instance()->set_info_flag( false );
  // Silence warnings if --Cq is set
  if(po.numOptSet( "Cq" )){
    CubitMessage::instance()->set_warning_flag( false );
  // Enable silent intersection errors if --CIq is set
  if(po.numOptSet( "CIq" )){
    CGMA_opt_inhibit_intersect_errs = true;
//#endif
  if( Gopt.merge_geom && !Gopt.imprint_geom ) {
    std::cerr << "Warning: cannot merge geometry without imprinting, will skip merge too." << std::endl;
  std::ifstream input(Gopt.input_file.c_str(), std::ios::in );
  if( !input.is_open() ){
    std::cerr << "Error: couldn't open file \"" << Gopt.input_file << "\"" << std::endl;
    return 1;
  std::cout << "Reading input file..." << std::endl;
  // if --Di and not -D, set debugging to be true for InputDeck::build() call only
  if( DiFlag && !OPT_DEBUG){
    Gopt.debug = true;
  else{ DiFlag = false; }
  InputDeck& deck = InputDeck::build(input);
  std::cout << "Done reading input." << std::endl;
  // turn off debug if it was set by --Di only
  if( DiFlag ){ Gopt.debug = false; }
  if( DoFlag && !OPT_DEBUG ){ Gopt.debug = true; }
  if( OPT_DEBUG ){
    debugSurfaceDistances( deck );
#ifdef CGM_HAVE_FACET_ENGINE_ONLY
  FacetModifyEngine::set_modify_enabled(CUBIT_TRUE);
#endif
  iGeom_Instance igm;
  int igm_result;
  iGeom_newGeom( Gopt.igeom_init_options.c_str(), &igm, &igm_result, Gopt.igeom_init_options.length() );
  CHECK_IGEOM( igm_result, "Initializing iGeom");
//#ifdef USING_CGMA
  int export_vers;
  if( po.getOpt( "geomver", &export_vers) ){
    if( CUBIT_SUCCESS == GeometryQueryTool::instance()->set_export_allint_version( export_vers ) ){
      std::cout << "Set export engine version to " << export_vers << std::endl;
    // on failure, an error message will be printed by CGM
//#endif
  GeometryContext context( igm, deck );
  context.createGeometry();
//#ifdef USING_CGMA
  if( CGMA_opt_inhibit_intersect_errs && SilentCubitMessageHandler::num_dropped_errors > 0){
    std::cout << "--CIq: supressed " << SilentCubitMessageHandler::num_dropped_errors << " intersection errors." << std::endl;
//#endif
  return 0;
static std::vector<int_triple> makeGridShellOfRadius ( int  r,
int  dimensions
) [static]
Definition at line 601 of file mcnp2cad.cpp.
  if( r == 0 ){
    int_triple v; v.v[0] = v.v[1] = v.v[2] = 0;
    return std::vector<int_triple>(1,v);
  else{
    std::vector<int_triple> ret;
    int jmin = dimensions > 1 ? -r : 0;
    int jmax = dimensions > 1 ?  r : 0;
    int kmin = dimensions > 2 ? -r : 0;
    int kmax = dimensions > 2 ?  r : 0;
    for( int i = -r; i <= r; ++i ){
      for( int j = jmin;j <= jmax; ++j ){
        for( int k = kmin; k <= kmax; ++k ){
          if( i == -r || i == r ||
              j == -r || j == r ||
              k == -r || k == r ){
            int_triple v;
            v.v[0] = i;
            v.v[1] = j;
            v.v[2] = k;
            ret.push_back(v);
    return ret;
std::string mcnp2cad_version ( bool  full)
Return the version string
Return only numbers ("1.2.3") if full is false, else dated format
Definition at line 1290 of file mcnp2cad.cpp.
  std::stringstream str;
  str << (full ? "mcnp2cad version " : "")
      << MCNP2CAD_VERSION_MAJOR << "."
      << MCNP2CAD_VERSION_MINOR << "."
      << MCNP2CAD_VERSION_REV;
  if(full)
      str << "\nCompiled on " << __DATE__ << " at " << __TIME__ ;
  return str.str();
Variable Documentation
bool CGMA_opt_inhibit_intersect_errs = false [static]
Definition at line 36 of file mcnp2cad.cpp.
Definition at line 1129 of file mcnp2cad.cpp.
