cgma
testgeom.cc File Reference
#include "iGeom.h"
#include <iostream>
#include <set>
#include <algorithm>
#include <vector>
#include <iterator>
#include <iomanip>
#include <assert.h>
#include <string.h>
#include <math.h>
Classes
class  SimpleArray< T >
Defines
#define CHECK(STR)   if (err != iBase_SUCCESS) return print_error( STR, err, geom, __FILE__, __LINE__ )
#define STRINGIFY(S)   XSTRINGIFY(S)
#define XSTRINGIFY(S)   #S
#define ARRAY_INOUT(A)   A.ptr(), &A.capacity(), &A.size()
#define ARRAY_IN(A)   &A[0], A.size()
Typedefs
typedef iBase_TagHandle TagHandle
typedef iBase_EntityHandle GentityHandle
typedef iBase_EntitySetHandle GentitysetHandle
Functions
static bool print_error (const char *desc, int err, iGeom_Instance geom, const char *file, int line)
bool gLoad_test (const std::string filename, iGeom_Instance)
bool tags_test (iGeom_Instance geom)
bool tag_get_set_test (iGeom_Instance geom)
bool tag_info_test (iGeom_Instance geom)
bool gentityset_test (iGeom_Instance geom, bool, bool)
bool topology_adjacencies_test (iGeom_Instance geom)
bool construct_test (iGeom_Instance geom)
bool primitives_test (iGeom_Instance geom)
bool transforms_test (iGeom_Instance geom)
bool booleans_test (iGeom_Instance geom)
bool faceting_test (iGeom_Instance geom)
bool shutdown_test (iGeom_Instance geom, std::string &engine_opt)
bool save_entset_test (iGeom_Instance geom)
bool mesh_size_test (iGeom_Instance geom)
void handle_error_code (const bool result, int &number_failed, int &, int &number_successful)
int main (int argc, char *argv[])
static bool compare_box (const double *expected_min, const double *expected_max, const double *actual_min, const double *actual_max)
static int get_entities (iGeom_Instance geom, int entity_type, std::vector< iBase_EntityHandle > &entities_out, iBase_TagHandle id_tag=0, std::vector< int > *ids_out=0)
static int count_num_with_tag (iGeom_Instance geom, const std::vector< iBase_EntityHandle > &ents, iBase_TagHandle tag)
Define Documentation
#define ARRAY_IN (   A)    &A[0], A.size()
Definition at line 98 of file testgeom.cc.
#define ARRAY_INOUT (   A)    A.ptr(), &A.capacity(), &A.size()
Definition at line 97 of file testgeom.cc.
#define CHECK (   STR)    if (err != iBase_SUCCESS) return print_error( STR, err, geom, __FILE__, __LINE__ )
Definition at line 29 of file testgeom.cc.
#define STRINGIFY (   S)    XSTRINGIFY(S)
Definition at line 31 of file testgeom.cc.
#define XSTRINGIFY (   S)    #S
Definition at line 32 of file testgeom.cc.
Typedef Documentation
Definition at line 54 of file testgeom.cc.
Definition at line 55 of file testgeom.cc.
Definition at line 53 of file testgeom.cc.
Function Documentation
bool booleans_test ( iGeom_Instance  geom)
Definition at line 1119 of file testgeom.cc.
  int err;
    // construct a brick size 1, and a cylinder rad 0.25 height 2
  iBase_EntityHandle brick = 0, cyl = 0;
  iGeom_createBrick( geom, 1.0, 0.0, 0.0, &brick, &err );
  CHECK( "Problems creating brick for booleans test." );
  iGeom_createCylinder( geom, 1.0, 0.25, 0.0, &cyl, &err );
  CHECK( "Problems creating cylinder for booleans test." );
    // subtract the cylinder from the brick
  iBase_EntityHandle subtract_result = 0;
  iGeom_subtractEnts( geom, brick, cyl, &subtract_result, &err );
  CHECK( "Problems subtracting for booleans subtract test." );
    // section the brick
  iBase_EntityHandle section_result = 0;
  iGeom_sectionEnt( geom, subtract_result, 1.0, 0.0, 0.0, 0.25, true, &section_result, &err );
  CHECK( "Problems sectioning for booleans section test." );
    // unite the section result with a new cylinder
  CHECK( "Problems creating cylinder for unite test." );
  iBase_EntityHandle unite_results;
  iBase_EntityHandle unite_input[] = { section_result, cyl };
  iGeom_uniteEnts( geom, unite_input, 2, &unite_results, &err );
  CHECK( "Problems uniting for booleans unite test." );
  iGeom_deleteEnt( geom, unite_results, &err );
  CHECK( "Problems deleting for booleans unite test." );
  return true;
static bool compare_box ( const double *  expected_min,
const double *  expected_max,
const double *  actual_min,
const double *  actual_max
) [static]
Definition at line 965 of file testgeom.cc.
  bool same = true;
  double dtol = 1.0e-6;
  for (int i = 0; i < 3; ++i)
    if (expected_min[i] < actual_min[i] - dtol ||
        expected_min[i]*10 >  actual_min[i] ||
        expected_max[i] > actual_max[i] + dtol ||
        expected_max[i]*10 < actual_max[i])
      same = false;
  return same;
Test:
TSTTG construct Test
  • Check construction of geometry
Definition at line 909 of file testgeom.cc.
  int err;
  iBase_EntityHandle new_body = 0;
    // construct a cylinder, sweep it about an axis, and delete the result
  iBase_EntityHandle cyl = 0;
  iGeom_createCylinder( geom, 1.0, 1.0, 0.0, &cyl, &err );
    // Is the minor radius really supposed to be zero??? - JK
  CHECK( "Creating cylinder failed." );
    // move it onto the y axis
  iGeom_moveEnt( geom, cyl, 0.0, 1.0, -0.5, &err );
  CHECK( "Problems moving surface." );
      // get the surface with max z
  iBase_EntityHandle max_surf = 0;
  SimpleArray<iBase_EntityHandle> surfs;
  iGeom_getEntAdj( geom, cyl, iBase_FACE, ARRAY_INOUT(surfs), &err );
  CHECK( "Problems getting max surf for rotation." );
  SimpleArray<double> max_corn, min_corn;
  iGeom_getArrBoundBox( geom, ARRAY_IN(surfs), iBase_INTERLEAVED,
                        ARRAY_INOUT( min_corn ),
                        ARRAY_INOUT( max_corn ),
                        &err );
  for (int i = 0; i < surfs.size(); ++i) {
    if ((max_corn[3*i+2]) <= dtol && (max_corn[3*i+2]) >= -dtol &&
        (min_corn[3*i+2]) <= dtol && (min_corn[3*i+2]) >= -dtol) {
      max_surf = surfs[i];
      break;
  if (0 == max_surf) {
    std::cerr << "Couldn't find max surf for rotation." << std::endl;
    return false;
    // sweep it around the x axis
  iGeom_moveEnt( geom, cyl, 0.0, 1.0, 0.0, &err );
  iGeom_sweepEntAboutAxis( geom, max_surf, 360.0, 1.0, 0.0, 0.0, &new_body, &err );
  CHECK( "Problems sweeping surface about axis." );
    // now delete
  iGeom_deleteEnt( geom, new_body, &err );
  CHECK( "Problems deleting cylinder or swept surface body." );
    // if we got here, we were successful
  return true;
static int count_num_with_tag ( iGeom_Instance  geom,
const std::vector< iBase_EntityHandle > &  ents,
iBase_TagHandle  tag
) [static]
Definition at line 1222 of file testgeom.cc.
  int err, bytes;
  iGeom_getTagSizeBytes( geom, tag, &bytes, &err );
  if (iBase_SUCCESS != err)
    return -1;
  std::vector<char> data(bytes);
  int success_count = 0;
  for (size_t i = 0; i < ents.size(); ++i) {
    void* ptr = &data[0];
    int junk1 = bytes, junk2;
    iGeom_getData( geom, ents[i], tag, (void**)&ptr, &junk1, &junk2, &err );
    if (iBase_TAG_NOT_FOUND == err)
      continue;
      return -1;
    ++success_count;
  return success_count;
bool faceting_test ( iGeom_Instance  geom)
Definition at line 1346 of file testgeom.cc.
  const char* filename = STRINGIFY(SRCDIR) "/size.step";
  int err;
  double dist_tolerance=0.001;
  iGeom_deleteAll( geom, &err ); CHECK("");
  iGeom_load( geom, filename, 0, &err, strlen(filename), 0 );
  CHECK( "Failed to load input file: 'size.step'" );
  // get entity lists
  iBase_TagHandle id;
  iGeom_getTagHandle( geom, "GLOBAL_ID", &id, &err, strlen("GLOBAL_ID") );
  CHECK( "iGeom_getTagHandle(\"GLOBAL_ID\")" );
  std::vector<iBase_EntityHandle> verts, curves, surfs, vols;
  std::vector<int> vert_ids, curve_ids, surf_ids, vol_ids;
  err = get_entities( geom, iBase_VERTEX, verts,  id, &vert_ids  ); CHECK("");
  err = get_entities( geom, iBase_EDGE,   curves, id, &curve_ids ); CHECK("");
  err = get_entities( geom, iBase_FACE,   surfs,  id, &surf_ids  ); CHECK("");
  err = get_entities( geom, iBase_REGION, vols,   id, &vol_ids   ); CHECK("");
  unsigned int ent;
  std::vector<double> points;
  double *p_ptr = &points[0];
  int p_size = 0, p_alloc=points.size();
  std::vector<int> facets;
  int *f_ptr = &facets[0];
  int f_size = 0, f_alloc=facets.size();
  for (ent=0; ent < verts.size(); ent++)
      iGeom_getFacets(geom, verts[ent], dist_tolerance,
              &p_ptr, &p_alloc, &p_size,
              &f_ptr, &f_alloc, &f_size,
              &err);
      if (iBase_INVALID_ENTITY_TYPE != err)
      err = iBase_FAILURE;
      CHECK("getFacets should fail for vertices.");
   for (ent=0; ent < curves.size(); ent++)
      iGeom_getFacets(geom, curves[ent], dist_tolerance,
              &err);
      points.resize(p_size);
      facets.resize(f_size);
      if ( iBase_BAD_ARRAY_DIMENSION == err || iBase_BAD_ARRAY_SIZE == err)
      p_ptr = &points[0];
      p_alloc = points.size();
      f_ptr = &facets[0];
      f_alloc = facets.size();
              &err);
      CHECK("getFacets failed for a curve.");
      err = (6 != p_size); CHECK("wrong number of points in curve");
      err = (0 != f_size); CHECK("Non-zero number of facets in curve");
      // should check for known sizes and values of these facets & points
   for (ent=0; ent < surfs.size(); ent++)
      iGeom_getFacets(geom, surfs[ent], dist_tolerance,
              &err);
      p_ptr = &points[0];
      f_ptr = &facets[0];
              &err);
      std::cerr << "surface " << ent << ": " << p_size << " points and " << f_size << " facets." << std::endl;
      CHECK("getFacets failed for a surface.");
      err = (12 != p_size); CHECK("wrong number of points in curve");
      err = (6 != f_size); CHECK("wrong number of facets in curve");
  for (ent=0; ent < vols.size(); ent++)
      iGeom_getFacets(geom, vols[ent], dist_tolerance,
              &err);
      CHECK("getFacets should fail for volumes.");
   return true;
bool gentityset_test ( iGeom_Instance  geom,
bool  ,
bool
Test:
TSTT gentity sets test (just implemented parts for now)
  • Check gentity sets
Definition at line 499 of file testgeom.cc.
  int num_type = 4;
  iBase_EntitySetHandle ges_array[4];
  int number_array[4];
  int num_all_gentities_super = 0;
  int ent_type = iBase_VERTEX;
  int err;
  iBase_EntitySetHandle root_set;
  iGeom_getRootSet( geom, &root_set, &err );
  CHECK( "ERROR : getRootSet failed!" );
    // get the number of sets in the whole model
  int all_sets = 0;
  iGeom_getNumEntSets( geom, root_set, 0, &all_sets, &err );
  CHECK( "Problem getting the number of all gentity sets in whole model." );
    // add gentities to entitysets by type
  for (; ent_type < num_type; ent_type++) {
      // initialize the entityset
    iGeom_createEntSet( geom, true, &ges_array[ent_type], &err );
    CHECK( "Problem creating entityset." );
      // get entities by type in total "mesh"
    SimpleArray<iBase_EntityHandle> gentities;
    iGeom_getEntities( geom, root_set, ent_type, ARRAY_INOUT(gentities), &err );
    CHECK( "Failed to get gentities by type in gentityset_test." );
      // add gentities into gentity set
    iGeom_addEntArrToSet( geom, ARRAY_IN( gentities ), ges_array[ent_type], &err );
    CHECK( "Failed to add gentities in entityset_test." );
      // Check to make sure entity set really has correct number of entities in it
    iGeom_getNumOfType( geom, ges_array[ent_type], ent_type, &number_array[ent_type], &err );
    CHECK( "Failed to get number of gentities by type in entityset_test." );
      // compare the number of entities by type
    int num_type_gentity = gentities.size();
    if (number_array[ent_type] != num_type_gentity)
      std::cerr << "Number of gentities by type is not correct"
                << std::endl;
      return false;
      // add to number of all entities in super set
    num_all_gentities_super += num_type_gentity;
    // make a super set having all entitysets
  iBase_EntitySetHandle super_set;
  iGeom_createEntSet( geom, true, &super_set, &err );
  CHECK( "Failed to create a super set in gentityset_test." );
  for (int i = 0; i < num_type; i++) {
    iGeom_addEntSet( geom, ges_array[i], super_set, &err );
    //----------TEST BOOLEAN OPERATIONS----------------//
  iBase_EntitySetHandle temp_ges1;
  iGeom_createEntSet( geom, true, &temp_ges1, &err );
    // Subtract
    // add all EDGEs and FACEs to temp_es1
    // get all EDGE entities
  SimpleArray<iBase_EntityHandle> gedges, gfaces, temp_gentities1;
  iGeom_getEntities( geom, ges_array[iBase_EDGE], iBase_EDGE, ARRAY_INOUT(gedges), &err );
  CHECK( "Failed to get gedge gentities in gentityset_test." );
    // add EDGEs to ges1
  iGeom_addEntArrToSet( geom, ARRAY_IN(gedges), temp_ges1, &err );
  CHECK( "Failed to add gedge gentities in gentityset_test." );
    // get all FACE gentities
  iGeom_getEntities( geom, ges_array[iBase_FACE], iBase_FACE, ARRAY_INOUT(gfaces), &err );
  CHECK( "Failed to get gface gentities in gentityset_test." );
    // add FACEs to es1
  iGeom_addEntArrToSet( geom, ARRAY_IN(gfaces), temp_ges1, &err );
  CHECK( "Failed to add gface gentities in gentityset_test." );
    // subtract EDGEs
  iGeom_subtract( geom, temp_ges1, ges_array[iBase_EDGE], &temp_ges1, &err );
  CHECK( "Failed to subtract gentitysets in gentityset_test." );
  iGeom_getEntities( geom, temp_ges1, iBase_FACE, ARRAY_INOUT(temp_gentities1), &err );
  if (gfaces.size() != temp_gentities1.size()) {
    std::cerr << "Number of entitysets after subtraction not correct \
             in gentityset_test." << std::endl;
    return false;
    // check there's nothing but gfaces in temp_ges1
  int num_gents;
  iGeom_getNumOfType( geom, temp_ges1, iBase_EDGE, &num_gents, &err );
  CHECK( "Failed to get dimensions of gentities in gentityset_test." );
  if (0 != num_gents) {
    std::cerr << "Subtraction failed to remove all edges" << std::endl;
    return false;
    //------------Intersect------------
    // clean out the temp_ges1
  iGeom_rmvEntArrFromSet( geom, ARRAY_IN(gfaces), temp_ges1, &err );
  CHECK( "Failed to remove gface gentities in gentityset_test." );
    // check if it is really cleaned out
  iGeom_getNumOfType( geom, temp_ges1, iBase_FACE, &num_gents, &err );
  CHECK( "Failed to get number of gentities by type in gentityset_test." );
  if (num_gents != 0) {
    std::cerr << "failed to remove correctly." << std::endl;
    return false;
    // add EDGEs to temp ges1
    // add FACEs to temp ges1
    // intersect temp_ges1 with gedges set
    // temp_ges1 entityset is altered
  iGeom_intersect( geom, temp_ges1, ges_array[iBase_EDGE], &temp_ges1, &err );
  CHECK( "Failed to intersect in gentityset_test." );
    // try to get FACEs, but there should be nothing but EDGE
    std::cerr << "wrong number of gfaces." << std::endl;
    return false;
    //-------------Unite--------------
    // get all regions
  iBase_EntitySetHandle temp_ges2;
  SimpleArray<iBase_EntityHandle> gregions;
  iGeom_createEntSet( geom, true, &temp_ges2, &err );
  CHECK( "Failed to create a temp gentityset in gentityset_test." );
  iGeom_getEntities( geom, ges_array[iBase_REGION], iBase_REGION, ARRAY_INOUT(gregions), &err );
  CHECK( "Failed to get gregion gentities in gentityset_test." );
    // add REGIONs to temp es2
  iGeom_addEntArrToSet( geom, ARRAY_IN(gregions), temp_ges2, &err );
  CHECK( "Failed to add gregion gentities in gentityset_test." );
    // unite temp_ges1 and temp_ges2
    // temp_ges1 gentityset is altered
  iGeom_unite( geom, temp_ges1, temp_ges2, &temp_ges1, &err );
  CHECK( "Failed to unite in gentityset_test." );
    // perform the check
  iGeom_getNumOfType( geom, temp_ges1, iBase_REGION, &num_gents, &err );
  CHECK( "Failed to get number of gregion gentities by type in gentityset_test." );
  if (num_gents != number_array[iBase_REGION]) {
    std::cerr << "different number of gregions in gentityset_test." << std::endl;
    return false;
    //--------Test parent/child stuff in entiysets-----------
    // Add 2 sets as children to another
  iBase_EntitySetHandle parent_child;
  iGeom_createEntSet( geom, true, &parent_child, &err );
  CHECK( "Problem creating gentityset in gentityset_test." );
  iGeom_addPrntChld( geom, ges_array[iBase_VERTEX], parent_child, &err );
  CHECK( "Problem add parent in gentityset_test." );
    // check if parent is really added
  SimpleArray<iBase_EntitySetHandle> parents;
  iGeom_getPrnts( geom, parent_child, 1, ARRAY_INOUT(parents), &err );
  CHECK( "Problem getting parents in gentityset_test." );
  if (parents.size() != 1) {
    std::cerr << "number of parents is not correct in gentityset_test."
              << std::endl;
    return false;
    // add parent and child
  //sidl::array<void*> parent_child_array = sidl::array<void*>::create1d(1);
  //int num_parent_child_array;
  //sidl::array<void*> temp_gedge_array = sidl::array<void*>::create1d(1);
  //int num_temp_gedge_array;
  //parent_child_array.set(0, parent_child);
  //temp_gedge_array.set(0, ges_array[TSTTG::EntityType_EDGE]);
  iGeom_addPrntChld( geom, ges_array[iBase_EDGE], parent_child, &err );
  CHECK( "Problem adding parent and child in gentityset_test." );
  //sidl::array<void*> temp_gface_array = sidl::array<void*>::create1d(1);
  //int num_temp_gface_array;
  //temp_gface_array.set(0, ges_array[TSTTG::EntityType_FACE]);
  iGeom_addPrntChld( geom, parent_child, ges_array[iBase_FACE], &err );
    // add child
  iGeom_addPrntChld( geom, parent_child, ges_array[iBase_REGION], &err );
  CHECK( "Problem adding child in gentityset_test." );
    // get the number of parent gentitysets
  num_gents = -1;
  iGeom_getNumPrnt( geom, parent_child, 0, &num_gents, &err );
  CHECK( "Problem getting number of parents in gentityset_test." );
  if (num_gents != 2) {
              << std::endl;
    return false;
    // get the number of child gentitysets
  num_gents = -1;
  iGeom_getNumChld( geom, parent_child, 0, &num_gents, &err );
  CHECK( "Problem getting number of children in gentityset_test." );
    std::cerr << "number of children is not correct in gentityset_test."
              << std::endl;
    return false;
  SimpleArray<iBase_EntitySetHandle> children;
  iGeom_getChldn( geom, parent_child, 0, ARRAY_INOUT(children), &err );
  CHECK( "Problem getting children in gentityset_test." );
  if (children.size() != 2) {
              << std::endl;
    return false;
    // remove children
  iGeom_rmvPrntChld( geom, parent_child, ges_array[iBase_FACE], &err );
  CHECK( "Problem removing parent child in gentityset_test." );
  if (num_gents != 1) {
              << std::endl;
    return false;
    // parent_child and ges_array[TSTTG::EntityType_EDGE] should be related
  int result = 0;
  iGeom_isChildOf( geom, ges_array[iBase_EDGE], parent_child, &result, &err );
  CHECK( "Problem checking relation in gentityset_test." );
  if (!result) {
    std::cerr << "parent_child and ges_array[TSTTG::EntityType_EDGE] should be related" << std::endl;
    return false;
    // ges_array[TSTTG::EntityType_FACE] and ges_array[TSTTG::REGION] are not related
  result = 2;
  iGeom_isChildOf( geom, ges_array[iBase_FACE], ges_array[iBase_REGION], &result, &err );
  if (result) {
    std::cerr << "ges_array[TSTTG::REGION] and ges_array[TSTTG::EntityType_FACE] should not be related" << std::endl;
    return false;
    //--------test modify and query functions-----------------------------
    // check the number of gentity sets in whole mesh
  SimpleArray<iBase_EntitySetHandle> gentity_sets;
  iGeom_getEntSets( geom, root_set, 0, ARRAY_INOUT( gentity_sets ), &err );
  CHECK( "Problem to get all gentity sets in mesh." );
  if (gentity_sets.size() != all_sets + 8) {
    std::cerr << "the number of gentity sets in whole mesh should be 8 times of num_iter."
              << std::endl;
    return false;
    // get all gentity sets in super set
  SimpleArray<iBase_EntitySetHandle> ges_array1;
  iGeom_getEntSets( geom, super_set, 0, ARRAY_INOUT( ges_array1 ), &err );
  CHECK( "Problem to get gentity sets in super set." );
    // get the number of gentity sets in super set
  int num_super;
  iGeom_getNumEntSets( geom, super_set, 0, &num_super, &err );
  CHECK( "Problem to get the number of all gentity sets in super set." );
    // the number of gentity sets in super set should be same
  if (num_super != ges_array1.size()) {
    std::cerr << "the number of gentity sets in super set should be same." << std::endl;
    return false;
    // get all entities in super set
  SimpleArray<iBase_EntitySetHandle> all_gentities;
  iGeom_getEntSets( geom, super_set, 0, ARRAY_INOUT( all_gentities ), &err );
  CHECK( "Problem to get all gentities in super set." );
    // compare the number of all gentities in super set
  // HJK : num_hops is not implemented
  //if (num_all_gentities_super != ARRAY_SIZE(all_gentities)) {
  //std::cerr << "number of all gentities in super set should be same." << std::endl;
  //success = false;
  return true;
static int get_entities ( iGeom_Instance  geom,
int  entity_type,
std::vector< iBase_EntityHandle > &  entities_out,
iBase_TagHandle  id_tag = 0,
std::vector< int > *  ids_out = 0
) [static]
Definition at line 1153 of file testgeom.cc.
  int err, num;
  iBase_EntitySetHandle root;
  iGeom_getRootSet( geom, &root, &err );
    return err;
  iGeom_getNumOfType( geom, root, entity_type, &num, &err );
    return err;
  entities_out.resize(num);
  int junk1 = entities_out.size(), junk2;
  iBase_EntityHandle* junk_ptr = &entities_out[0];;
  iGeom_getEntities( geom, root, entity_type, &junk_ptr, &junk1, &junk2, &err );
    return err;
  assert( num == junk1 && num == junk2 );
  if (!ids_out)
    return iBase_SUCCESS;
  ids_out->resize(num);
  int* int_ptr = &(*ids_out)[0];
  iGeom_getIntArrData( geom, &entities_out[0], num, id_tag, &int_ptr, &junk1, &junk2, &err );
    return err;
bool gLoad_test ( const std::string  filename,
iGeom_Instance  geom
Test:
Load Mesh
  • Load a mesh file
Definition at line 298 of file testgeom.cc.
  int err;
  iGeom_load( geom, &filename[0], 0, &err, filename.length(), 0 );
  CHECK( "ERROR : can not load a geometry" );
    // print out the number of entities
  std::cout << "Model contents: " << std::endl;
  const char *gtype[] = {"vertices: ", "edges: ", "faces: ", "regions: "};
  for (int i = 0; i <= 3; ++i) {
    int count;
    iGeom_getNumOfType( geom, root_set, i, &count, &err );
    CHECK( "Error: problem getting entities after gLoad." );
    std::cout << gtype[i] << count << std::endl;
  return true;
void handle_error_code ( const bool  result,
int &  number_failed,
int &  ,
int &  number_successful
Definition at line 116 of file testgeom.cc.
  if (result) {
    std::cout << "Success";
    number_successful++;
  else {
    std::cout << "Failure";
    number_failed++;
int main ( int  argc,
char *  argv[]
Definition at line 131 of file testgeom.cc.
    // Check command line arg
  #ifdef FORCE_OCC
    #ifndef HAVE_OCC
      #error "Cannot force use of OCC w/out OCC support"
    #endif
    std::string filename = STRINGIFY(SRCDIR) "/../test/LeverArm.brep";
    std::string engine_opt = ";engine=OCC";
  #elif defined(HAVE_OCC)
  #else
    std::string filename = STRINGIFY(SRCDIR) "/brick.facet";
    std::string engine_opt = ";engine=FACET";
  #endif
  if (argc == 1) {
    std::cout << "Using default input file: " << filename << std::endl;
  else if (argc == 2) {
    filename = argv[1];
  else {
    std::cerr << "Usage: " << argv[0] << " [geom_filename]" << std::endl;
    return 1;
  bool result;
  int number_tests = 0;
  int number_tests_successful = 0;
  int number_tests_not_implemented = 0;
  int number_tests_failed = 0;
    // initialize the Mesh
  int err;
  iGeom_Instance geom;
  iGeom_newGeom( engine_opt.c_str(), &geom, &err, engine_opt.length() );
    // Print out Header information
  std::cout << "\n\nITAPS GEOMETRY INTERFACE TEST PROGRAM:\n\n";
    // gLoad test
  std::cout << "   gLoad: ";
  result = gLoad_test(filename, geom);
  handle_error_code(result, number_tests_failed,
                    number_tests_not_implemented,
                    number_tests_successful);
  number_tests++;
  std::cout << "\n";
    // tags test
  std::cout << "   tags: ";
  result = tags_test(geom);
  number_tests++;
  std::cout << "\n";
    // gentitysets test
  std::cout << "   gentity sets: ";
  result = gentityset_test(geom, false, false);
  number_tests++;
  std::cout << "\n";
    // topology adjacencies test
  std::cout << "   topology adjacencies: ";
  result = topology_adjacencies_test(geom);
  number_tests++;
  std::cout << "\n";
#if defined(HAVE_OCC)
    // construct test
  std::cout << "   construct: ";
  result = construct_test(geom);
  number_tests++;
  std::cout << "\n";
    // primitives test
  std::cout << "   primitives: ";
  result = primitives_test(geom);
  number_tests++;
  std::cout << "\n";
    // transforms test
  std::cout << "   transforms: ";
  result = transforms_test(geom);
  number_tests++;
  std::cout << "\n";
    // booleans test
  std::cout << "   booleans: ";
  result = booleans_test(geom);
  number_tests++;
  std::cout << "\n";
#endif
  // this is not run for occ or facet; keep it for the time being
#if 0
    // save entset test
  std::cout << "   save entset: ";
  result = save_entset_test(geom);
  number_tests++;
  std::cout << "\n";
#endif
//not working for cubit13.1 cgm at iGeom_CGMA.cc, line 7428, get_graphics for
//faces, comment out
    // facet tests
#ifdef HAVE_OCC
  std::cout << "   faceting: ";
  result = faceting_test(geom);
  number_tests++;
  std::cout << "\n";
#endif
    // shutdown test
  std::cout << "   shutdown: ";
  result = shutdown_test(geom, engine_opt);
  number_tests++;
  std::cout << "\n";
    // summary
  std::cout << "\nTSTT TEST SUMMARY: \n"
            << "   Number Tests:           " << number_tests << "\n"
            << "   Number Successful:      " << number_tests_successful << "\n"
            << "   Number Not Implemented: " << number_tests_not_implemented << "\n"
            << "   Number Failed:          " << number_tests_failed
            << "\n\n" << std::endl;
  return number_tests_failed;
Definition at line 1248 of file testgeom.cc.
  const char* filename = STRINGIFY(SRCDIR) "/size.sat";
  int err;
  CHECK( "Failed to load input file: 'size.sat'" );
    // get tag handles
  iBase_TagHandle interval, size, firmness, id;
  iGeom_getTagHandle( geom, "MESH_INTERVAL", &interval, &err, strlen("MESH_INTERVAL") );
  CHECK( "iGeom_getTagHandle(\"MESH_INTERVAL\")" );
  iGeom_getTagHandle( geom, "MESH_SIZE", &size, &err, strlen("MESH_SIZE") );
  CHECK( "iGeom_getTagHandle(\"MESH_SIZE\")" );
  iGeom_getTagHandle( geom, "SIZE_FIRMNESS", &firmness, &err, strlen("SIZE_FIRMNESS") );
  CHECK( "iGeom_getTagHandle(\"SIZE_FIRMNESS\")" );
    // get entity lists
    // expect interval count to be the same as ID for every curve
/* testgeom didn't pass with the following call, uncomment it when fixed.
  std::vector<int> intervals(curves.size());
  int *int_ptr = &intervals[0];
  junk1 = junk2 = curves.size();
  iGeom_getIntArrData( geom, &curves[0], curves.size(), interval, &int_ptr, &junk1, &junk2, &err );
  CHECK("Failed to get intervals for curves");
  if (intervals != curve_ids) {
    std::cout << "ERROR: Incorrect curve intervals for one or more curves." << std::endl;
    std::cout << "ID  Expected  Actual" << std::endl;
    for (unsigned i = 0; i < curves.size(); ++i)
      std::cout << std::setw(2) << curve_ids[i] << "  "
                << std::setw(8) << curve_ids[i] << "  "
                << std::setw(6) << intervals[i] << std::endl;
    result = false;
    // expect size to be the same as ID for every surface
  std::vector<double> sizes(surfs.size());
  double* dbl_ptr = &sizes[0];
  junk1 = junk2 = surfs.size();
  iGeom_getDblArrData( geom, &surfs[0], surfs.size(), size, &dbl_ptr, &junk1, &junk2, &err );
  CHECK("Failed to get sizes for surfaces");
  bool all_correct = true;
  for (unsigned i = 0; i < surfs.size(); ++i)
    if (fabs(sizes[i] - (double)surf_ids[i] ) > 1e-8)
      all_correct = false;
  if (!all_correct) {
    std::cout << "ERROR: Incorrect mesh size for one or more surfaces." << std::endl;
    std::cout << "ID  Expected  Actual  " << std::endl;
      std::cout << std::setw(2) << surf_ids[i] << "  "
                << std::setw(8) << (double)surf_ids[i] << "  "
                << std::setw(8) << sizes[i] << std::endl;
    result = false;
  err = result ? iBase_SUCCESS : iBase_FAILURE;
  CHECK("Invalid size or interval data");
    // expect "HARD" firmness on all curves
  err = check_firmness( geom, curves, curve_ids, firmness, "HARD", "curves" );
  CHECK("Invalid curve firmness");
    // expect "SOFT" firmness on all surfaces
  err = check_firmness( geom, surfs, surf_ids, firmness, "SOFT", "surfaces" );
  CHECK("Invalid surface firmness");
    // expect no firmnes on other entities
  err = count_num_with_tag( geom, verts, firmness ) ? iBase_FAILURE : iBase_SUCCESS;
  CHECK("Got firmness for vertex.");
  err = count_num_with_tag( geom, vols, firmness ) ? iBase_FAILURE : iBase_SUCCESS;
  CHECK("Got firmness for volume.");
    // expect no interval tag on any entities except curves
  err = count_num_with_tag( geom, verts, interval ) ? iBase_FAILURE : iBase_SUCCESS;
  CHECK("Got interval count for vertex.");
  err = count_num_with_tag( geom, vols, interval ) ? iBase_FAILURE : iBase_SUCCESS;
  CHECK("Got interval count for volume.");
    // expect no size tag on any entities except surfaces
    // curves should have size of one of their parent surfaces
  err = count_num_with_tag( geom, verts, size ) ? iBase_FAILURE : iBase_SUCCESS;
  CHECK("Got mesh size for vertex.");
  err = count_num_with_tag( geom, vols, size ) ? iBase_FAILURE : iBase_SUCCESS;
  CHECK("Got mesh size for volume.");
  return true;
Definition at line 984 of file testgeom.cc.
  int err;
  SimpleArray<iBase_EntityHandle> prims(3);
  iBase_EntityHandle prim;
  iGeom_createBrick( geom, 1.0, 2.0, 3.0, &prim, &err );
  CHECK( "createBrick failed." );
  prims[0] = prim;
  iGeom_createCylinder( geom, 1.0, 4.0, 2.0, &prim, &err );
  CHECK( "createCylinder failed." );
  prims[1] = prim;
  iGeom_createTorus( geom, 2.0, 1.0, &prim, &err );
  CHECK( "createTorus failed." );
  prims[2] = prim;
    // verify the bounding boxes forentities
  iGeom_getArrBoundBox( geom, ARRAY_IN(prims), iBase_INTERLEAVED,
                        ARRAY_INOUT(min_corn), ARRAY_INOUT(max_corn), &err );
  double preset_min_corn[] =
      // min brick corner xyz
    {-0.5, -1.0, -1.5,
      // min cyl corner xyz
     -4.0, -2.0, -0.5,
      // min torus corner xyz
     -3.0, -3.0, -1.0
  double preset_max_corn[] =
      // max brick corner xyz
    {0.5, 1.0, 1.5,
      // max cyl corner xyz
     4.0, 2.0, 0.5,
      // max torus corner xyz
     3.0, 3.0, 1.0
  if (!compare_box( preset_min_corn, preset_max_corn,
                    &min_corn[0], &max_corn[0] )) {
    std::cerr << "Box check failed for brick" << std::endl;
    return false;
  if (!compare_box( preset_min_corn+3, preset_max_corn+3,
                    &min_corn[3], &max_corn[3] )) {
    std::cerr << "Box check failed for cylinder" << std::endl;
    return false;
  if (!compare_box( preset_min_corn+6, preset_max_corn+6,
                    &min_corn[6], &max_corn[6] )) {
    std::cerr << "Box check failed for torus" << std::endl;
    return false;
    // must have worked; delete the entities then return
  for (int i = 0; i < 3; ++i) {
    iGeom_deleteEnt( geom, prims[i], &err );
    CHECK( "Problems deleting primitive after boolean check." );
  return true;
static bool print_error ( const char *  desc,
int  err,
const char *  file,
int  line
) [static]
Definition at line 34 of file testgeom.cc.
  char buffer[1024];
  iGeom_getDescription( geom, buffer, sizeof(buffer) );
  buffer[sizeof(buffer)-1] = '\0';
  std::cerr << "ERROR: " << desc << std::endl
            << "  Error code: " << err << std::endl
            << "  Error desc: " << buffer << std::endl
            << "  At        : " << file << ':' << line << std::endl
  return false; // must always return false or CHECK macro will break
Definition at line 1477 of file testgeom.cc.
  int err;
  std::string filename = "testout.brep";
    // initialize number of ents and sets to compare with later
  int num_ents_bef, num_sets_bef;
  CHECK("Failed to get root set.");
  iGeom_getNumEntSets(geom, root, 0, &num_sets_bef, &err);
  CHECK("Failed to get number of ent sets.");
  iGeom_getNumOfType(geom, root, iBase_REGION, &num_ents_bef, &err);
  CHECK("Failed to get number of entities.");
    // create set, and entity to add to set
  iBase_EntityHandle cyl;
  CHECK( "Problems creating cylinder for save entset test." );
  iBase_EntitySetHandle seth;
  iGeom_createEntSet(geom, true, &seth, &err);
  CHECK( "Problems creating entity set for save entset test." );
    // add the entity
  iGeom_addEntToSet(geom, cyl, seth, &err);
  CHECK( "Problems adding entity to set for save entset test." );
    // save/restore the model, and see if the entity is there
  iGeom_save(geom, filename.c_str(), NULL, &err, filename.length(), 0);
  CHECK( "Problems saving file for save entset test." );
  iGeom_destroyEntSet(geom, seth, &err);
  CHECK("Failed to destroy entity set.");
  iGeom_deleteEnt(geom, cyl, &err);
  CHECK("Failed to destroy entity.");
    // read the file back in
  iGeom_load(geom, filename.c_str(), NULL, &err,
  CHECK( "Problems reading file for save entset test." );
    // check number of sets and entities
  int num_ents_aft, num_sets_aft;
  iGeom_getNumEntSets(geom, root, 0, &num_sets_aft, &err);
  iGeom_getNumOfType(geom, root, iBase_REGION, &num_ents_aft, &err);
  bool success = true;
  if (num_ents_aft != 2*num_ents_bef + 1) {
    print_error("Failed to get the right number of entities.",
                iBase_FAILURE, geom, __FILE__, __LINE__);
    success = false;
  else if (num_sets_aft != 2*num_sets_bef + 1) {
    print_error("Failed to get the right number of entity sets.",
    success = false;
    // otherwise, we succeeded
  return success;
bool shutdown_test ( iGeom_Instance  geom,
std::string &  engine_opt
Definition at line 1460 of file testgeom.cc.
  int err;
    // test shutdown & startup of interface
  iGeom_dtor(geom, &err);
  CHECK( "Interface destruction didn't work properly." );
  iGeom_newGeom(engine_opt.c_str(), &geom, &err, engine_opt.length());
  CHECK( "Interface re-construction didn't work properly." );
  CHECK( "2nd Interface destruction didn't work properly." );
  return true;
Definition at line 430 of file testgeom.cc.
  int err;
    // create an arbitrary tag, size 4
  iBase_TagHandle this_tag;
  std::string tag_name("tag_get_set tag");
  iGeom_createTag( geom, &tag_name[0], sizeof(int), iBase_BYTES, &this_tag, &err, tag_name.length() );
  CHECK( "ERROR : can not create a tag for get_set test." );
    // set this tag to an integer on each entity; keep track of total sum
  int sum = 0, num = 0, dim;
  for (dim = 0; dim <= 3; dim++) {
    SimpleArray<iBase_EntityHandle> gentity_handles;
    iGeom_getEntities( geom, root_set, dim, ARRAY_INOUT( gentity_handles ), &err );
    int num_ents = gentity_handles.size();
    std::vector<int> tag_vals( num_ents );
    for (int i = 0; i < num_ents; ++i) {
      tag_vals[i] = num;
      sum += num;
      ++num;
    iGeom_setArrData( geom, ARRAY_IN( gentity_handles ),
                      this_tag,
                      &tag_vals[0], tag_vals.size()*sizeof(int),
                      &err );
    CHECK( "ERROR : can't set tag on entities" );
    // check tag values for entities now
  int get_sum = 0;
    void* vals_ptr = &tag_vals[0];
    int vals_size = tag_vals.size(), vals_alloc = tag_vals.size()*sizeof(int);
    iGeom_getArrData( geom, ARRAY_IN( gentity_handles ), this_tag,
                      &vals_ptr, &vals_alloc, &vals_size, &err );
    CHECK( "ERROR : can't get tag on entities" );
      get_sum += tag_vals[i];
  if (get_sum != sum) {
    std::cerr << "ERROR: getData didn't return consistent results." << std::endl;
    return false;
  iGeom_destroyTag( geom, this_tag, true, &err );
  CHECK( "ERROR : couldn't delete tag." );
  return true;
bool tag_info_test ( iGeom_Instance  geom)
Definition at line 339 of file testgeom.cc.
  int err;
  iBase_TagHandle this_tag, tmp_handle;
  std::string tag_name("tag_info tag"), tmp_name;
  iGeom_createTag( geom, &tag_name[0], 4, iBase_BYTES, &this_tag, &err, tag_name.length() );
  CHECK( "ERROR : can not create a tag." );
    // get information on the tag
  char name_buffer[256];
  iGeom_getTagName( geom, this_tag, name_buffer, &err, sizeof(name_buffer) );
  CHECK( "ERROR : Couldn't get tag name." );
  if (tag_name != name_buffer) {
    std::cerr << "ERROR: getTagName returned '" << name_buffer
              << "' for tag created as '" << tag_name << "'" << std::endl;
    return false;
  iGeom_getTagHandle( geom, &tag_name[0], &tmp_handle, &err, tag_name.length() );
  CHECK( "ERROR : Couldn't get tag handle." );
  if (tmp_handle != this_tag) {
    std::cerr << "ERROR: getTagHandle didn't return consistent result." << std::endl;
    return false;
  int tag_size;
  iGeom_getTagSizeBytes( geom, this_tag, &tag_size, &err );
  CHECK( "ERROR : Couldn't get tag size." );
  if (tag_size != 4) {
    std::cerr << "ERROR: getTagSizeBytes: expected 4, got " << tag_size << std::endl;
    return false;
  iGeom_getTagSizeValues( geom, this_tag, &tag_size, &err );
    std::cerr << "ERROR: getTagSizeValues: expected 4, got " << tag_size << std::endl;
    return false;
  int tag_type;
  iGeom_getTagType( geom, this_tag, &tag_type, &err );
  CHECK( "ERROR : Couldn't get tag type." );
  if (tag_type != iBase_BYTES) {
    std::cerr << "ERROR: getTagType: expected " << iBase_BYTES
              << ", got " << tag_type << std::endl;
    return false;
  CHECK( "ERROR : Couldn't delete a tag." );
    // print information about all the tags in the model
  std::set<iBase_TagHandle> tags;
  SimpleArray<iBase_EntityHandle> entities;
  iGeom_getEntities( geom, root_set, iBase_ALL_TYPES,
                     ARRAY_INOUT(entities),  &err );
  CHECK( "getEntities( ..., iBase_ALL_TYPES, ... ) failed." );
  for (int i = 0; i < entities.size(); ++i) {
    SimpleArray<iBase_TagHandle> tag_arr;
    iGeom_getAllTags( geom, entities[i], ARRAY_INOUT(tag_arr), &err);
    CHECK( "getAllTags failed." );
    std::copy( tag_arr.begin(), tag_arr.end(), std::inserter( tags, tags.begin() ) );
  std::cout << "Tags defined on model: ";
  bool first = true;
  for (std::set<iBase_TagHandle>::iterator sit = tags.begin(); sit != tags.end(); ++sit) {
    iGeom_getTagName( geom, *sit, name_buffer, &err, sizeof(name_buffer) );
    name_buffer[sizeof(name_buffer)-1] = '\0'; // mnake sure of NUL termination
    CHECK( "getTagName failed." );
    if (!first) std::cout << ", ";
    std::cout << name_buffer;
    first = false;
  if (first) std::cout << "<none>";
  std::cout << std::endl;
  return true;
bool tags_test ( iGeom_Instance  geom)
Test:
Test tag creating, reading, writing, deleting
  • Load a mesh file
Definition at line 326 of file testgeom.cc.
  success = tag_info_test(geom);
  if (!success) return success;
  success = tag_get_set_test(geom);
  return true;
Test:
TSTTG topology adjacencies Test
  • Check topology information
  • Check adjacency
Definition at line 834 of file testgeom.cc.
  int i, err;
  int top = iBase_VERTEX;
  int num_test_top = iBase_ALL_TYPES;
  std::vector< std::vector<iBase_EntityHandle> > gentity_vectors(num_test_top);
  // fill the vectors of each topology entities
  // like lines vector, polygon vector, triangle vector,
  // quadrilateral, polyhedrron, tet, hex, prism, pyramid,
  // septahedron vectors
  for (i = top; i < num_test_top; i++) {
    iGeom_getEntities( geom, root_set, i, ARRAY_INOUT( gentities ), &err );
    CHECK("Failed to get gentities in adjacencies_test.");
    gentity_vectors[i].resize( gentities.size() );
    std::copy( gentities.begin(), gentities.end(), gentity_vectors[i].begin() );
  // check number of entities for each topology
    int num_tops = 0;
    iGeom_getNumOfType( geom, root_set, i, &num_tops, &err );
    CHECK( "Failed to get number of gentities in adjacencies_test." );
    if (static_cast<int>(gentity_vectors[i].size()) != num_tops) {
      std::cerr << "Number of gentities doesn't agree with number returned for dimension "
                << i << std::endl;
      return false;
  // check adjacencies in both directions
  std::vector<iBase_EntityHandle>::iterator vit;
  for (i = iBase_REGION; i >= iBase_VERTEX; i--) {
    for (vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); vit++) {
      iBase_EntityHandle this_gent = *vit;
        // check downward adjacencies
      for (int j = iBase_VERTEX; j < i; j++) {
        SimpleArray<iBase_EntityHandle> lower_ents;
        iGeom_getEntAdj( geom, this_gent, j, ARRAY_INOUT(lower_ents), &err );
        CHECK( "Bi-directional adjacencies test failed." );
          // for each of them, make sure they are adjacent to the upward ones
        int num_lower = lower_ents.size();
        for (int k = 0; k < num_lower; k++) {
          SimpleArray<iBase_EntityHandle> upper_ents;
          iGeom_getEntAdj( geom, lower_ents[k], i, ARRAY_INOUT(upper_ents), &err );
          if (std::find(upper_ents.begin(),upper_ents.end(), this_gent) ==
              upper_ents.end()) {
            std::cerr << "Didn't find lower-upper adjacency which was supposed to be there, dims = "
                 << i << ", " << j << std::endl;
            return false;
  return true;
Definition at line 1051 of file testgeom.cc.
  int err;
  iBase_EntityHandle brick = 0;
  iGeom_createBrick( geom, 1.0, 2.0, 3.0, &brick, &err );
  CHECK( "Problems creating brick for transforms test." );
    // move it, then test bounding box
  iGeom_moveEnt( geom, brick, 0.5, 1.0, 1.5, &err );
  CHECK( "Problems moving brick for transforms test." );
  double bb_min[3], bb_max[3];
  iGeom_getEntBoundBox( geom, brick, bb_min, bb_min+1, bb_min+2, bb_max, bb_max+1, bb_max+2, &err );
  CHECK( "Problems getting bounding box after move." );
  if ((bb_min[0]) >= dtol || (bb_min[0]) <= -dtol ||
      (bb_min[1]) >= dtol || (bb_min[1]) <= -dtol ||
      (bb_min[2]) >= dtol || (bb_min[2]) <= -dtol ||
      (bb_max[0]-1) >= dtol || 1-bb_max[0] >=dtol ||
      (bb_max[1]-2) >= dtol || 2 - bb_max[1] >=dtol||
      (bb_max[2]-3) >= dtol || 3 - bb_max[2] >= dtol) {
    std::cerr << "Wrong bounding box after move." << std::endl;
    return false;
    // now rotate it about +x, then test bounding box
  iGeom_rotateEnt( geom, brick, 90, 1.0, 0.0, 0.0, &err );
  CHECK( "Problems rotating brick for transforms test." );
  CHECK( "Problems getting bounding box after rotate." );
  if ((bb_min[0]) >= dtol || -bb_min[0] >= dtol ||
      (bb_min[1]+3) >= dtol || -(bb_min[1]+3) >= dtol ||
      (bb_min[2]) >= dtol || -(bb_min[2]) >= dtol ||
      (bb_max[0]-1) >= dtol || 1-bb_max[0] >= dtol ||
      (bb_max[1]) >= dtol || -(bb_max[1]) >= dtol ||
      (bb_max[2]-2) >= dtol || 2-bb_max[2] >=dtol) {
    std::cerr << "Wrong bounding box after rotate." << std::endl;
    return false;
    // now reflect through y plane; should recover original bb
  iGeom_reflectEnt( geom, brick, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, &err );
  CHECK( "Problems reflecting brick for transforms test." );
  CHECK( "Problems getting bounding box after reflect." );
  if ((bb_min[0]) >= dtol || -(bb_min[0]) >= dtol ||(bb_min[1]) >= dtol ||
      (bb_min[2]) >= dtol || -(bb_min[1]) >= dtol || -(bb_min[2]) >= dtol ||
      (bb_max[0]-1) >= dtol || 1- bb_max[0] >= dtol ||
      (bb_max[1]-3) >= dtol || 3 - bb_max[1] >= dtol ||
      (bb_max[2]-2) >= dtol || 2 - bb_max[2] >= dtol) {
    std::cerr << "Wrong bounding box after reflect." << std::endl;
    return false;
  iGeom_deleteEnt( geom, brick, &err );
  CHECK( "Problems deleting brick after transforms check." );
  return true;
