iMOAB
fex.F
00001
00002       SUBROUTINE errorout(ierr, message)
00003       integer ierr
00004       character (*) message
00005       if (ierr.ne.0) then
00006         print *, message
00007         call exit (1)
00008       end if
00009       return
00010       end
00011
00012
00013       program fdriver
00014 C      include '/home/iulian/3rdparty/mpich-3.1/install/include/mpif.h'
00015       include 'mpif.h'
00016       integer ierr, num_procs, my_id
00017       integer pid
00018       character*10 appname
00019       character*132 filename
00020       character*150 readopts
00021       integer ngv, nge, ndim, nparts
00022       integer nghlay
00023       integer nverts(3), nelem(3), nblocks(3), nsbc(3), ndbc(3);
00024 C      large enough work arrays
00025       integer iwork(100000)
00026       real*8  dwork(100000)
00027 C      indices in work arrays for vertex ids, ranks, coordinates
00028       integer vID, vRA, vCO
00029 C
00030 C       indices for free memory (index in integer or double work arrays)
00031       integer ifree, dfree
00032 C      size of coordinates array
00033       integer  nCO
00034       integer  bID
00035 C       for some tags in the file
00036       character*20 tagname1, tagname2
00037       integer      tagtype(2), enttype(2), num_co
00038       integer      tagindex(2)
00039       integer      stags(2), itags(2), ntsync
00040
00041       integer      eRA, beID, eID
00042 C  vertice per element, number of elements in block
00043       integer  vpere, nebl, blockID
00044 C      iWORK(eCO) start for connectivity
00045       integer    sizeconn, eCO
00046 C      IWORK(egID) , IWORK(elID) starts for global el ID, local elem ID
00047       integer    egID, elID, eOWN
00048       integer    iTAG, dTAG
00049
00050 C       indices for surface BC element, reference surf BC, value
00051       integer    isBC, irBC, ivBC
00052
00053
00054
00055       character*100 outfile, wopts
00056
00057       call MPI_INIT ( ierr )
00058       call errorout(ierr, 'fail to initialize MPI')
00059
00060 c     find out MY process ID, and how many processes were started.
00061
00062       call MPI_COMM_RANK (MPI_COMM_WORLD, my_id, ierr)
00063       call errorout(ierr, 'fail to get MPI rank')
00064
00065       call MPI_COMM_SIZE (MPI_COMM_WORLD, num_procs, ierr)
00066       call errorout(ierr, 'fail to get MPI size')
00067
00068       if (my_id .eq. 0) then
00069         print *, " I'm process ", my_id, " out of ",
00070      &      num_procs, " processes."
00071
00072       end if
00073
00074       ierr = iMOAB_InitializeFortran()
00075       call errorout(ierr, 'fail to initialize iMOAB')
00076
00077       appname = 'PROTEUS'//CHAR(0)
00078
00079       ierr = iMOAB_RegisterFortranApplication(appname, MPI_COMM_WORLD,
00080      & pid)
00081       call errorout(ierr, 'fail to register application')
00082 C
00083       filename ='p8ex1.h5m'//CHAR(0)
00084       ierr = iMOAB_ReadHeaderInfo ( filename, ngv, nge, ndim, nparts)
00085       call errorout(ierr, 'fail to read header info')
00086
00087
00088       if (0.eq.my_id) then
00089        print *, filename, ' has ', nparts, ' parts in partition',
00090      &    ngv, ' vertices ', nge, ' elements of dimension ', ndim
00091       endif
00092
00093       readopts='PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;'//
00094      & 'PARALLEL_RESOLVE_SHARED_ENTS'//CHAR(0)
00095
00096 C  number of ghost layers needed by application
00097       nghlay = 1
00098       ierr = iMOAB_LoadMesh(pid, filename, readopts, nghlay)
00099       call errorout(ierr, 'fail to read file in parallel')
00100
00101 C  number of
00102       ierr = iMOAB_GetMeshInfo(pid, nverts, nelem, nblocks, nsbc, ndbc)
00103       call errorout(ierr, 'fail to get mesh info')
00104
00105       vID = 1
00106       ierr = iMOAB_GetVertexID(pid, nverts(3), IWORK(vID) )
00107       call errorout(ierr, 'failed to get vertex id info')
00108
00109       vRA = vID + nverts(3)
00110       ierr = iMOAB_GetVertexOwnership(pid, nverts(3), IWORK(vRA) )
00111       call errorout(ierr, 'failed to get vertex owner ranks')
00112
00113       ifree = vRA + nverts(3)
00114
00115 C  double * coords = (double*) malloc(3*nverts[2]*sizeof(double));
00116       vCO = 1
00117       nCO = 3 * nverts(3)
00118
00119       ierr = iMOAB_GetVisibleVerticesCoordinates(pid, nCO, DWORK(vCO))
00120       call errorout(ierr, 'failed to get coordinates')
00121       dfree = vCO + 3 * nverts(3)
00122
00123       bID = ifree
00124       ierr = iMOAB_GetBlockID(pid, nblocks(3), IWORK(bID))
00125       call errorout(ierr, 'failed to get block info')
00126       ifree = ifree + nblocks(3)
00127
00128 C      the 2 tags used in this example exist in the file, already
00129 C first tag, INTFIELD is on vertices, integer
00130 C second tag DFIELD is on elements, double
00131       tagtype(1)=0                                                       !dense, int
00132       tagtype(2)=1                                                       !dense, double
00133       enttype(1)=0                                                       ! on verts
00134       enttype(2)=1                                                       ! on elem
00135       num_co = 1
00136       tagname1 ='INTFIELD'//CHAR(0)
00137       ierr = iMOAB_DefineTagStorage(pid, tagname1, tagtype(1), num_co,
00138      &   tagindex(1) )
00139       call errorout(ierr, 'failed to get tag INTFIELD')
00140
00141       tagname2 ='DFIELD'//CHAR(0)
00142       ierr = iMOAB_DefineTagStorage(pid, tagname2, tagtype(2), num_co,
00143      &  tagindex(2) )
00144       call errorout(ierr, 'failed to get tag DFIELD')
00145
00146
00147 C       synchronize one of the tags only, just to see what happens
00148 C        put in the sync array just first tag index (INTFIELD)
00149       ntsync =1
00150       stags(1) = tagIndex(1)
00151       itags(1) = tagType(1)
00152
00153       ierr = iMOAB_SynchronizeTags(pid, ntsync, stags, itags )
00154       call errorout(ierr, 'failed to sync tag INTFIELD')
00155
00156 C  start printing some information, retrieved from each task
00157       do irk=0, num_procs-1
00158       if (irk .eq. my_id) then
00159
00160 C printf some of the block info */
00161         print *, 'on rank ', my_id, ' there are '
00162         print *, nverts(3), ' visible vertices of which ',nverts(1),
00163      &    ' local ', nverts(2), ' ghost'
00164         print *,  nblocks(3), ' visible blocks'
00165         print *,  nsbc(3), ' visible Neumann BCs'
00166         print *,   ndbc(3), ' visible dirichlet BCs'
00167
00168         print *, 'on rank ', my_id, ' vertex info:'
00169         do i=1,nverts(3)
00170           write(*, 100)  i, IWORK(vRA+i-1), IWORK( vID+i-1),
00171      &         DWORK(vCO+3*i-3), DWORK(vCO+3*i-2), DWORK(vCO+3*i-1)
00172 100       FORMAT(' vertex local id ', I3, ' rank ID', I3, ' global ID:'
00173      &    , I3, '  coords:',  3F11.3)
00174         enddo
00175         eID = ifree
00176         beID = eID + nelem(3)
00177         eRA = beID + nelem(3)
00178         ierr = iMOAB_GetVisibleElementsInfo(pid, nelem(3),IWORK(eID),
00179      &    IWORK(eRA), IWORK(beID) )
00180         call errorout(ierr, 'failed to get all elem info')
00181         ifree = eRA + nelem(3)
00182         do i=1, nelem(3)
00183           write(*, 101) IWORK(eID+i-1), IWORK(eRA+i-1), IWORK(beID+i-1)
00184 101       FORMAT( ' global ID ', I5, ' rank: ',
00185      &       I3, ' block ID: ' I4)
00186         enddo
00187
00188         do  i=1,nblocks(3)
00189
00190           print *,' block index:', i, ' block ID ', IWORK(bID+i-1)
00191           blockID = IWORK(bID+i-1)
00192           ierr = iMOAB_GetBlockInfo(pid, blockID , vpere, nebl)
00193           call errorout(ierr, 'failed to elem block info')
00194           print *, '  has' , nebl, ' elements with ', vpere, 'verts'
00195
00196           sizeconn = nebl * vpere
00197           eCO = ifree
00198           ierr = iMOAB_GetBlockElementConnectivities(pid, blockID,
00199      &       sizeconn, IWORK(eCO) )
00200           call errorout(ierr, 'failed to get block elem connectivity')
00201
00202           ifree = ifree + sizeconn
00203           eOWN = ifree
00204           ierr = iMOAB_GetElementOwnership(pid, blockID, nebl,
00205      &           IWORK(eOWN))
00206           call errorout(ierr, 'failed to get block elem ownership')
00207           ifree = ifree+nebl
00208
00209           egID = ifree
00210           elID = ifree + nebl
00211           ierr = iMOAB_GetElementID(pid, blockID, nebl,
00212      &          IWORK(egID), IWORK(elID)  )
00213           call errorout(ierr, 'failed to get block elem IDs')
00214           ifree = elID + nebl
00215
00216           do j=1, nebl
00217             write (*, 102) j,  IWORK(eOWN+j-1),IWORK(egID+j-1),
00218      &        IWORK(elID+j-1), (IWORK(eCO-1+(j-1)*vpere+k), k=1,vpere)
00219 102         FORMAT(' elem ', I3, ' owned by', I3, ' gid:', I3, ' lid:',
00220      &       I3, ' : ', 10I5)
00221           enddo
00222
00223         enddo
00224
00225
00226 C      query int tag values on vertices
00227         iTAG= ifree
00228
00229         ierr = iMOAB_GetIntTagStorage(pid, tagname1, nverts(3),
00230      &    enttype(1), IWORK(iTAG) )
00231         call errorout(ierr, 'failed to get INTFIELD tag')
00232         ifree = iTAG + nverts(3)
00233         print * , 'INTFIELD tag values'
00234         write(*, 103) (IWORK(iTAG+k-1), k=1,nverts(3) )
00235 103     FORMAT (10I8)
00236
00237         dTAG = dfree
00238 C         query double tag values on elements
00239
00240         ierr = iMOAB_GetDoubleTagStorage(pid, tagname2, nelem(3),
00241      &   entType(2), DWORK(dTAG) )
00242         call errorout(ierr, 'failed to get DFIELD tag')
00243         dfree = dTAG + nelem(3)
00244         print *, 'DFIELD tag values: (not exchanged) '
00245         write (*, 104) (DWORK(dTAG+k-1), k=1,nelem(3) )
00246 104     FORMAT ( 10F7.2 )
00247
00248
00249 C       query surface BCs
00250         isBC = ifree
00251         irBC = isBC + nsbc(3)
00252         ivBC = irBC + nsbc(3)
00253
00254         ierr = iMOAB_GetPointerToSurfaceBC(pid, nsbc(3), IWORK(isBC),
00255      &     IWORK(irBC), IWORK(ivBC))
00256         call errorout(ierr, 'failed to get surf boundary conditions')
00257         ifree = ivBC + nsbc(3)
00258         print * , 'Surface boundary conditions '
00259         write (*, 105) (IWORK(isBC+k-1),
00260      &     IWORK(irBC+k-1), IWORK(ivBC+k-1), k=1, nsbc(3))
00261 105     FORMAT (' elem localID: ', I3, ' side:', I1, ' val:', I4)
00262
00263 C       query vertex BCs
00264
00265         iveBC = ifree
00266         ivaBC = iveBC + ndbc(3)
00267
00268         ierr = iMOAB_GetPointerToVertexBC(pid, ndbc(3), IWORK(iveBC),
00269      &        IWORK(ivaBC))
00270         call errorout(ierr, 'failed to get vertex boundary conditions')
00271         ifree = ivaBC + ndbc(3)
00272
00273         print *, '  Vertex boundary conditions:'
00274         write (*, 106) (IWORK(iveBC+k-1),
00275      &     IWORK(ivaBC+k-1), k=1, ndbc(3))
00276 106     FORMAT (' vertex: ', I3, ' BC:', I6 )
00277
00278        endif
00279        call MPI_Barrier(MPI_COMM_WORLD, ierr)
00280        call errorout(ierr, 'fail at barrier')
00281
00282       enddo
00283
00284
00285       outfile = 'fnew.h5m'//CHAR(0)
00286       wopts   = 'PARALLEL=WRITE_PART'//CHAR(0)
00287       ierr = iMOAB_WriteMesh(pid, outfile, wopts)
00288       call errorout(ierr, 'fail to write the mesh file')
00289
00290
00291       ierr = iMOAB_DeregisterApplication(pid)
00292       call errorout(ierr, 'fail to deregister application')
00293
00294       ierr = iMOAB_Finalize()
00295       call errorout(ierr, 'fail to finalize iMOAB')
00296
00297
00298       call MPI_FINALIZE ( ierr )
00299       call errorout(ierr, 'fail to finalize MPI')
00300
00301       stop
00302       end
 All Files Functions Enumerations Enumerator Defines
