lasso
GeomAssocPairSide.cpp
00001 #include "GeomAssocPairSide.hpp"
00002
00003 #include <cstring>
00004 #include <sstream>
00005 #include <string>
00006
00007 #include "Lasso.hpp"
00008 #include "iRel_Lasso.hpp"
00009
00010 #define PROCESS_ERROR do {                              \
00011     if (iBase_SUCCESS != result) {                      \
00012       char this_descr[120];                             \
00013       iGeom_getDescription(instance_, this_descr, 120); \
00014       ERRORR(result, this_descr);                       \
00015     }                                                   \
00016   } while(false)
00017
00018 // Redefine LASSOI
00019 #undef LASSOI
00020 #define LASSOI lasso_instance(relation)
00021
00022 static const char *GLOBAL_ID_TAG_NAME = "GLOBAL_ID";
00023 static const char *RELATION_TAG_NAME = "__GEOM_ASSOCIATION";
00024
00025 GeomAssocPairSide::GeomAssocPairSide(iRel_Instance relation,
00026                                      iBase_Instance instance, int id) :
00027   relation(relation),
00028   instance_(reinterpret_cast<iGeom_Instance>(instance)),
00029   id(id)
00030 {
00031   int result;
00032
00033   create_relation_side();
00034
00035   iGeom_getTagHandle(instance_, GLOBAL_ID_TAG_NAME, &gid_tag, &result,
00036                      strlen(GLOBAL_ID_TAG_NAME));
00037   if (result == iBase_TAG_NOT_FOUND) {
00038     iGeom_createTag(instance_, GLOBAL_ID_TAG_NAME, 1, iBase_INTEGER,
00039                     &gid_tag, &result, strlen(GLOBAL_ID_TAG_NAME));
00040   }
00041 }
00042
00043 GeomAssocPairSide::~GeomAssocPairSide()
00044 {
00045   destroy_relation_side();
00046 }
00047
00048 iBase_Instance GeomAssocPairSide::instance() const
00049 {
00050   return instance_;
00051 }
00052
00053 iRel_IfaceType GeomAssocPairSide::type() const
00054 {
00055   return iRel_IGEOM_IFACE;
00056 }
00057
00058 int GeomAssocPairSide::create_relation_side()
00059 {
00060   int result;
00061   std::stringstream ss;
00062   ss << RELATION_TAG_NAME << id;
00063   std::string rel_tag_name(ss.str());
00064
00065   iGeom_getTagHandle(instance_, rel_tag_name.c_str(), &relation_tag, &result,
00066                      rel_tag_name.size());
00067   if (result == iBase_TAG_NOT_FOUND) {
00068     iGeom_createTag(instance_, rel_tag_name.c_str(), 1, iBase_ENTITY_HANDLE,
00069                     &relation_tag, &result, rel_tag_name.size());
00070   }
00071
00072   PROCESS_ERROR;
00073   RETURNR(iBase_SUCCESS);
00074 }
00075
00076 int GeomAssocPairSide::destroy_relation_side()
00077 {
00078   if (relation_tag) {
00079     int result;
00080
00081     iGeom_destroyTag(instance_, relation_tag, true, &result);
00082     relation_tag = NULL;
00083
00084     PROCESS_ERROR;
00085   }
00086   RETURNR(iBase_SUCCESS);
00087 }
00088
00089 int GeomAssocPairSide::get_all_entities(int dimension,
00090                                         iBase_EntityHandle **entities,
00091                                         int *entities_alloc,
00092                                         int *entities_size)
00093 {
00094   int this_type = (dimension == -1 ? iBase_ALL_TYPES : dimension);
00095   int result;
00096
00097   iGeom_getEntities(instance_, 0, this_type, entities, entities_alloc,
00098                     entities_size, &result);
00099   PROCESS_ERROR;
00100   RETURNR(iBase_SUCCESS);
00101 }
00102
00103 int GeomAssocPairSide::get_all_sets(iBase_EntitySetHandle **sets,
00104                                     int *sets_alloc, int *sets_size)
00105 {
00106   int result;
00107
00108   iGeom_getEntSets(instance_, 0, 0, sets, sets_alloc, sets_size, &result);
00109   PROCESS_ERROR;
00110   RETURNR(iBase_SUCCESS);
00111 }
00112
00113 int GeomAssocPairSide::get_entities(int dimension,
00114                                     iBase_EntitySetHandle set_handle,
00115                                     iBase_EntityHandle **entities,
00116                                     int *entities_alloc,
00117                                     int *entities_size)
00118 {
00119   int this_type = (dimension == -1 ? iBase_ALL_TYPES : dimension);
00120   int result;
00121
00122   iGeom_getEntities(instance_, set_handle, this_type, entities, entities_alloc,
00123                     entities_size, &result);
00124   PROCESS_ERROR;
00125   RETURNR(iBase_SUCCESS);
00126 }
00127
00128 int GeomAssocPairSide::get_ents_dims(iBase_EntityHandle *entities,
00129                                      int entities_size,
00130                                      int **ent_types,
00131                                      int *ent_types_alloc,
00132                                      int *ent_types_size)
00133 {
00134   int result;
00135
00136   iGeom_getArrType(instance_, entities, entities_size, ent_types,
00137                    ent_types_alloc, ent_types_size, &result);
00138   PROCESS_ERROR;
00139   RETURNR(iBase_SUCCESS);
00140 }
00141
00142 int GeomAssocPairSide::get_related_ents(iBase_EntityHandle **entities,
00143                                         int *entities_alloc, int *entities_size)
00144 {
00145   RETURNR(iBase_FAILURE);
00146 }
00147
00148 int GeomAssocPairSide::get_related_sets(iBase_EntitySetHandle **sets,
00149                                         int *sets_alloc, int *sets_size)
00150 {
00151   RETURNR(iBase_FAILURE);
00152 }
00153
00154 int GeomAssocPairSide::get_relation_side(iBase_EntityHandle *entities,
00155                                          int num_entities, void *values)
00156 {
00157   int values_alloc = num_entities * sizeof(iBase_EntityHandle);
00158   int values_size;
00159   int result;
00160
00161   iGeom_getArrData(instance_, entities, num_entities, relation_tag,
00162                    &values, &values_alloc, &values_size, &result);
00163   PROCESS_ERROR;
00164   RETURNR(iBase_SUCCESS);
00165 }
00166
00167 int GeomAssocPairSide::get_relation_side(iBase_EntitySetHandle *sets,
00168                                          int num_sets, void *values)
00169 {
00170   char *data = static_cast<char*>(values);
00171   int values_alloc = sizeof(iBase_EntityHandle);
00172   int values_size;
00173   int result;
00174
00175   for (int i = 0; i < num_sets; i++) {
00176     iGeom_getEntSetData(instance_, sets[i], relation_tag,
00177                         reinterpret_cast<void**>(&data),
00178                         &values_alloc, &values_size, &result);
00179     data += values_size;
00180     PROCESS_ERROR;
00181   }
00182   RETURNR(iBase_SUCCESS);
00183 }
00184
00185 int GeomAssocPairSide::set_relation_side(iBase_EntityHandle *entities,
00186                                          int num_entities, const void *values)
00187 {
00188   int result;
00189
00190   iGeom_setArrData(instance_, entities, num_entities, relation_tag,
00191                    static_cast<const char*>(values),
00192                    num_entities*sizeof(iBase_EntityHandle), &result);
00193   PROCESS_ERROR;
00194   RETURNR(iBase_SUCCESS);
00195 }
00196
00197 int GeomAssocPairSide::set_relation_side(iBase_EntitySetHandle *sets,
00198                                          int num_sets, const void *values)
00199 {
00200   const char *data = static_cast<const char*>(values);
00201   int size = sizeof(iBase_EntityHandle);
00202   int result;
00203
00204   for (int i = 0; i < num_sets; i++) {
00205     iGeom_setEntSetData(instance_, sets[i], relation_tag, data, size, &result);
00206     data += size;
00207     PROCESS_ERROR;
00208   }
00209   RETURNR(iBase_SUCCESS);
00210 }
00211
00212 int GeomAssocPairSide::rmv_relation_side(iBase_EntityHandle *entities,
00213                                          int num_entities)
00214 {
00215   int result;
00216
00217   iGeom_rmvArrTag(instance_, entities, num_entities, relation_tag, &result);
00218   PROCESS_ERROR;
00219   RETURNR(iBase_SUCCESS);
00220 }
00221
00222 int GeomAssocPairSide::rmv_relation_side(iBase_EntitySetHandle *sets,
00223                                          int num_sets)
00224 {
00225   int result;
00226
00227   for (int i = 0; i < num_sets; i++) {
00228     iGeom_rmvEntSetTag(instance_, sets[i], relation_tag, &result);
00229     PROCESS_ERROR;
00230   }
00231
00232   RETURNR(iBase_SUCCESS);
00233 }
00234
00235 int GeomAssocPairSide::get_iterator(iBase_EntitySetHandle set,
00236                                     iBase_EntityIterator *iter)
00237 {
00238   int result;
00239   iGeom_initEntIter(instance_, set, iBase_ALL_TYPES, iter, &result);
00240   RETURNR(iBase_SUCCESS);
00241 }
00242
00243 int GeomAssocPairSide::get_gids(iBase_EntityHandle *entities, int num_entities,
00244                                 int *values)
00245 {
00246   int values_alloc = num_entities * sizeof(int);
00247   int values_size;
00248   int result;
00249
00250   iGeom_getArrData(instance_, entities, num_entities, gid_tag,
00251                    reinterpret_cast<void**>(&values), &values_alloc,
00252                    &values_size, &result);
00253   PROCESS_ERROR;
00254   RETURNR(iBase_SUCCESS);
00255 }
00256
00257 int GeomAssocPairSide::get_gids(iBase_EntitySetHandle *sets, int num_sets,
00258                                 int *values)
00259 {
00260   char *data = reinterpret_cast<char*>(values);
00261   int values_alloc = sizeof(int);
00262   int values_size;
00263   int result;
00264
00265   for (int i = 0; i < num_sets; i++) {
00266     iGeom_getEntSetData(instance_, sets[i], gid_tag,
00267                         reinterpret_cast<void**>(&data),
00268                         &values_alloc, &values_size, &result);
00269     data += values_size;
00270     PROCESS_ERROR;
00271   }
00272   RETURNR(iBase_SUCCESS);
00273 }
00274
00275 int GeomAssocPairSide::get_dims(iBase_EntityHandle *entities, int num_entities,
00276                                 int *values)
00277 {
00278   RETURNR(iBase_FAILURE);
00279 }
00280
00281 int GeomAssocPairSide::get_dims(iBase_EntitySetHandle *sets, int num_sets,
00282                                 int *values)
00283 {
00284   RETURNR(iBase_FAILURE);
00285 }
 All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
