lasso
GeomAssocPairSide Class Reference
#include <GeomAssocPairSide.hpp>
Inheritance diagram for GeomAssocPairSide:
AssocPairSide
List of all members.
Public Member Functions
 GeomAssocPairSide (iRel_Instance relation, iBase_Instance instance, int id)
virtual ~GeomAssocPairSide ()
virtual iBase_Instance instance () const
virtual iRel_IfaceType type () const
virtual int create_relation_side ()
virtual int destroy_relation_side ()
virtual int get_all_entities (int dimension, iBase_EntityHandle **entities, int *entities_alloc, int *entities_size)
virtual int get_all_sets (iBase_EntitySetHandle **sets, int *sets_alloc, int *sets_size)
virtual int get_entities (int dimension, iBase_EntitySetHandle set_handle, iBase_EntityHandle **entities, int *entities_alloc, int *entities_size)
virtual int get_ents_dims (iBase_EntityHandle *entities, int entities_size, int **ent_types, int *ent_types_alloc, int *ent_types_size)
virtual int get_related_ents (iBase_EntityHandle **entities, int *entities_alloc, int *entities_size)
virtual int get_related_sets (iBase_EntitySetHandle **sets, int *sets_alloc, int *sets_size)
virtual int get_relation_side (iBase_EntityHandle *entities, int num_entities, void *values)
virtual int get_relation_side (iBase_EntitySetHandle *sets, int num_sets, void *values)
virtual int set_relation_side (iBase_EntityHandle *entities, int num_entities, const void *values)
virtual int set_relation_side (iBase_EntitySetHandle *sets, int num_sets, const void *values)
virtual int rmv_relation_side (iBase_EntityHandle *entities, int num_entities)
virtual int rmv_relation_side (iBase_EntitySetHandle *sets, int num_sets)
virtual int get_iterator (iBase_EntitySetHandle set, iBase_EntityIterator *iter)
virtual int get_gids (iBase_EntityHandle *entities, int num_entities, int *values)
virtual int get_gids (iBase_EntitySetHandle *sets, int num_sets, int *values)
virtual int get_dims (iBase_EntityHandle *entities, int num_entities, int *values)
virtual int get_dims (iBase_EntitySetHandle *sets, int num_sets, int *values)
Private Attributes
iGeom_Instance instance_
int id
iBase_TagHandle relation_tag
iBase_TagHandle gid_tag
Detailed Description
Definition at line 7 of file GeomAssocPairSide.hpp.
GeomAssocPairSide::GeomAssocPairSide ( iRel_Instance  relation,
int  id
Definition at line 25 of file GeomAssocPairSide.cpp.
  relation(relation),
  instance_(reinterpret_cast<iGeom_Instance>(instance)),
  id(id)
  int result;
  create_relation_side();
  iGeom_getTagHandle(instance_, GLOBAL_ID_TAG_NAME, &gid_tag, &result,
                     strlen(GLOBAL_ID_TAG_NAME));
  if (result == iBase_TAG_NOT_FOUND) {
    iGeom_createTag(instance_, GLOBAL_ID_TAG_NAME, 1, iBase_INTEGER,
                    &gid_tag, &result, strlen(GLOBAL_ID_TAG_NAME));
Definition at line 43 of file GeomAssocPairSide.cpp.
Member Function Documentation
Implements AssocPairSide.
Definition at line 58 of file GeomAssocPairSide.cpp.
  int result;
  std::stringstream ss;
  ss << RELATION_TAG_NAME << id;
  std::string rel_tag_name(ss.str());
  iGeom_getTagHandle(instance_, rel_tag_name.c_str(), &relation_tag, &result,
                     rel_tag_name.size());
    iGeom_createTag(instance_, rel_tag_name.c_str(), 1, iBase_ENTITY_HANDLE,
                    &relation_tag, &result, rel_tag_name.size());
  PROCESS_ERROR;
  RETURNR(iBase_SUCCESS);
Definition at line 76 of file GeomAssocPairSide.cpp.
  if (relation_tag) {
    int result;
    iGeom_destroyTag(instance_, relation_tag, true, &result);
    relation_tag = NULL;
    PROCESS_ERROR;
int GeomAssocPairSide::get_all_entities ( int  dimension,
iBase_EntityHandle **  entities,
int *  entities_alloc,
int *  entities_size
) [virtual]
Definition at line 89 of file GeomAssocPairSide.cpp.
  int this_type = (dimension == -1 ? iBase_ALL_TYPES : dimension);
  int result;
  iGeom_getEntities(instance_, 0, this_type, entities, entities_alloc,
                    entities_size, &result);
  PROCESS_ERROR;
int GeomAssocPairSide::get_all_sets ( iBase_EntitySetHandle **  sets,
int *  sets_alloc,
int *  sets_size
) [virtual]
Definition at line 103 of file GeomAssocPairSide.cpp.
  int result;
  iGeom_getEntSets(instance_, 0, 0, sets, sets_alloc, sets_size, &result);
  PROCESS_ERROR;
int GeomAssocPairSide::get_dims ( iBase_EntityHandle *  entities,
int  num_entities,
int *  values
) [virtual]
Definition at line 275 of file GeomAssocPairSide.cpp.
  RETURNR(iBase_FAILURE);
int GeomAssocPairSide::get_dims ( iBase_EntitySetHandle *  sets,
int  num_sets,
int *  values
) [virtual]
Definition at line 281 of file GeomAssocPairSide.cpp.
int GeomAssocPairSide::get_entities ( int  dimension,
int *  entities_size
) [virtual]
Definition at line 113 of file GeomAssocPairSide.cpp.
  int result;
  iGeom_getEntities(instance_, set_handle, this_type, entities, entities_alloc,
  PROCESS_ERROR;
int GeomAssocPairSide::get_ents_dims ( iBase_EntityHandle *  entities,
int  entities_size,
int **  ent_types,
int *  ent_types_alloc,
int *  ent_types_size
) [virtual]
Definition at line 128 of file GeomAssocPairSide.cpp.
  int result;
  iGeom_getArrType(instance_, entities, entities_size, ent_types,
                   ent_types_alloc, ent_types_size, &result);
  PROCESS_ERROR;
int GeomAssocPairSide::get_gids ( iBase_EntityHandle *  entities,
int  num_entities,
int *  values
) [virtual]
Definition at line 243 of file GeomAssocPairSide.cpp.
  int values_alloc = num_entities * sizeof(int);
  int values_size;
  int result;
  iGeom_getArrData(instance_, entities, num_entities, gid_tag,
                   reinterpret_cast<void**>(&values), &values_alloc,
                   &values_size, &result);
  PROCESS_ERROR;
int GeomAssocPairSide::get_gids ( iBase_EntitySetHandle *  sets,
int  num_sets,
int *  values
) [virtual]
Definition at line 257 of file GeomAssocPairSide.cpp.
  char *data = reinterpret_cast<char*>(values);
  int values_alloc = sizeof(int);
  int values_size;
  int result;
  for (int i = 0; i < num_sets; i++) {
    iGeom_getEntSetData(instance_, sets[i], gid_tag,
                        reinterpret_cast<void**>(&data),
                        &values_alloc, &values_size, &result);
    data += values_size;
    PROCESS_ERROR;
int GeomAssocPairSide::get_iterator ( iBase_EntitySetHandle  set,
iBase_EntityIterator *  iter
) [virtual]
Definition at line 235 of file GeomAssocPairSide.cpp.
  int result;
  iGeom_initEntIter(instance_, set, iBase_ALL_TYPES, iter, &result);
int GeomAssocPairSide::get_related_ents ( iBase_EntityHandle **  entities,
int *  entities_size
) [virtual]
Definition at line 142 of file GeomAssocPairSide.cpp.
int GeomAssocPairSide::get_related_sets ( iBase_EntitySetHandle **  sets,
int *  sets_alloc,
int *  sets_size
) [virtual]
Definition at line 148 of file GeomAssocPairSide.cpp.
int GeomAssocPairSide::get_relation_side ( iBase_EntityHandle *  entities,
int  num_entities,
void *  values
) [virtual]
Definition at line 154 of file GeomAssocPairSide.cpp.
  int values_alloc = num_entities * sizeof(iBase_EntityHandle);
  int values_size;
  int result;
  iGeom_getArrData(instance_, entities, num_entities, relation_tag,
                   &values, &values_alloc, &values_size, &result);
  PROCESS_ERROR;
int GeomAssocPairSide::get_relation_side ( iBase_EntitySetHandle *  sets,
int  num_sets,
void *  values
) [virtual]
Definition at line 167 of file GeomAssocPairSide.cpp.
  char *data = static_cast<char*>(values);
  int values_alloc = sizeof(iBase_EntityHandle);
  int values_size;
  int result;
    iGeom_getEntSetData(instance_, sets[i], relation_tag,
    PROCESS_ERROR;
iBase_Instance GeomAssocPairSide::instance ( ) const [virtual]
Definition at line 48 of file GeomAssocPairSide.cpp.
  return instance_;
int GeomAssocPairSide::rmv_relation_side ( iBase_EntityHandle *  entities,
int  num_entities
) [virtual]
Definition at line 212 of file GeomAssocPairSide.cpp.
  int result;
  iGeom_rmvArrTag(instance_, entities, num_entities, relation_tag, &result);
  PROCESS_ERROR;
int GeomAssocPairSide::rmv_relation_side ( iBase_EntitySetHandle *  sets,
int  num_sets
) [virtual]
Definition at line 222 of file GeomAssocPairSide.cpp.
  int result;
    iGeom_rmvEntSetTag(instance_, sets[i], relation_tag, &result);
    PROCESS_ERROR;
int GeomAssocPairSide::set_relation_side ( iBase_EntityHandle *  entities,
int  num_entities,
const void *  values
) [virtual]
Definition at line 185 of file GeomAssocPairSide.cpp.
  int result;
  iGeom_setArrData(instance_, entities, num_entities, relation_tag,
                   static_cast<const char*>(values),
                   num_entities*sizeof(iBase_EntityHandle), &result);
  PROCESS_ERROR;
int GeomAssocPairSide::set_relation_side ( iBase_EntitySetHandle *  sets,
int  num_sets,
const void *  values
) [virtual]
Definition at line 197 of file GeomAssocPairSide.cpp.
  const char *data = static_cast<const char*>(values);
  int size = sizeof(iBase_EntityHandle);
  int result;
    iGeom_setEntSetData(instance_, sets[i], relation_tag, data, size, &result);
    data += size;
    PROCESS_ERROR;
Definition at line 53 of file GeomAssocPairSide.cpp.
  return iRel_IGEOM_IFACE;
Member Data Documentation
iBase_TagHandle GeomAssocPairSide::gid_tag [private]
Definition at line 67 of file GeomAssocPairSide.hpp.
int GeomAssocPairSide::id [private]
Definition at line 64 of file GeomAssocPairSide.hpp.
iGeom_Instance GeomAssocPairSide::instance_ [private]
Definition at line 63 of file GeomAssocPairSide.hpp.
Definition at line 62 of file GeomAssocPairSide.hpp.
iBase_TagHandle GeomAssocPairSide::relation_tag [private]
Definition at line 66 of file GeomAssocPairSide.hpp.
 All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
