lasso
MeshAssocPairSide Class Reference
#include <MeshAssocPairSide.hpp>
Inheritance diagram for MeshAssocPairSide:
AssocPairSide
List of all members.
Public Member Functions
 MeshAssocPairSide (iRel_Instance relation, iBase_Instance instance, int id)
virtual ~MeshAssocPairSide ()
virtual iBase_Instance instance () const
virtual iRel_IfaceType type () const
virtual int create_relation_side ()
virtual int destroy_relation_side ()
virtual int get_all_entities (int dimension, iBase_EntityHandle **entities, int *entities_alloc, int *entities_size)
virtual int get_all_sets (iBase_EntitySetHandle **sets, int *sets_alloc, int *sets_size)
virtual int get_entities (int dimension, iBase_EntitySetHandle set_handle, iBase_EntityHandle **entities, int *entities_alloc, int *entities_size)
virtual int get_ents_dims (iBase_EntityHandle *entities, int entities_size, int **ent_types, int *ent_types_alloc, int *ent_types_size)
virtual int get_related_ents (iBase_EntityHandle **entities, int *entities_alloc, int *entities_size)
virtual int get_related_sets (iBase_EntitySetHandle **sets, int *sets_alloc, int *sets_size)
virtual int get_relation_side (iBase_EntityHandle *entities, int num_entities, void *values)
virtual int get_relation_side (iBase_EntitySetHandle *sets, int num_sets, void *values)
virtual int set_relation_side (iBase_EntityHandle *entities, int num_entities, const void *values)
virtual int set_relation_side (iBase_EntitySetHandle *sets, int num_sets, const void *values)
virtual int rmv_relation_side (iBase_EntityHandle *entities, int num_entities)
virtual int rmv_relation_side (iBase_EntitySetHandle *sets, int num_sets)
virtual int get_iterator (iBase_EntitySetHandle set, iBase_EntityIterator *iter)
virtual int get_gids (iBase_EntityHandle *entities, int num_entities, int *values)
virtual int get_gids (iBase_EntitySetHandle *sets, int num_sets, int *values)
virtual int get_dims (iBase_EntityHandle *entities, int num_entities, int *values)
virtual int get_dims (iBase_EntitySetHandle *sets, int num_sets, int *values)
Private Attributes
iMesh_Instance instance_
int id
iBase_TagHandle relation_tag
iBase_TagHandle gid_tag
iBase_TagHandle dim_tag
Detailed Description
Definition at line 7 of file MeshAssocPairSide.hpp.
MeshAssocPairSide::MeshAssocPairSide ( iRel_Instance  relation,
int  id
Definition at line 28 of file MeshAssocPairSide.cpp.
  relation(relation),
  instance_(reinterpret_cast<iMesh_Instance>(instance)),
  id(id)
  int result;
  create_relation_side();
  iMesh_getTagHandle(instance_, GLOBAL_ID_TAG_NAME, &gid_tag, &result,
                     strlen(GLOBAL_ID_TAG_NAME));
  if (result == iBase_TAG_NOT_FOUND) {
    iMesh_createTag(instance_, GLOBAL_ID_TAG_NAME, 1, iBase_INTEGER,
                    &gid_tag, &result, strlen(GLOBAL_ID_TAG_NAME));
  iMesh_getTagHandle(instance_, MESH_DIMENSION_TAG_NAME, &dim_tag, &result,
                     strlen(MESH_DIMENSION_TAG_NAME));
    dim_tag = NULL;
Definition at line 51 of file MeshAssocPairSide.cpp.
Member Function Documentation
Implements AssocPairSide.
Definition at line 66 of file MeshAssocPairSide.cpp.
  int result;
  std::stringstream ss;
  ss << RELATION_TAG_NAME << id;
  std::string rel_tag_name(ss.str());
  iMesh_getTagHandle(instance_, rel_tag_name.c_str(), &relation_tag, &result,
                     rel_tag_name.size());
    iMesh_createTag(instance_, rel_tag_name.c_str(), 1, iBase_ENTITY_HANDLE,
                    &relation_tag, &result, rel_tag_name.size());
  PROCESS_ERROR;
  RETURNR(iBase_SUCCESS);
Definition at line 84 of file MeshAssocPairSide.cpp.
  if (relation_tag) {
    int result;
    iMesh_destroyTag(instance_, relation_tag, true, &result);
    relation_tag = NULL;
    PROCESS_ERROR;
int MeshAssocPairSide::get_all_entities ( int  dimension,
iBase_EntityHandle **  entities,
int *  entities_alloc,
int *  entities_size
) [virtual]
Definition at line 97 of file MeshAssocPairSide.cpp.
  int this_type = (dimension == -1 ? iBase_ALL_TYPES : dimension);
  int result;
  iMesh_getEntities(instance_, 0, this_type, iMesh_ALL_TOPOLOGIES,
                    entities, entities_alloc, entities_size, &result);
  PROCESS_ERROR;
int MeshAssocPairSide::get_all_sets ( iBase_EntitySetHandle **  sets,
int *  sets_alloc,
int *  sets_size
) [virtual]
Definition at line 111 of file MeshAssocPairSide.cpp.
  int result;
  iMesh_getEntSets(instance_, 0, 0, sets, sets_alloc, sets_size, &result);
  PROCESS_ERROR;
int MeshAssocPairSide::get_dims ( iBase_EntityHandle *  entities,
int  num_entities,
int *  values
) [virtual]
Definition at line 293 of file MeshAssocPairSide.cpp.
  int values_alloc = num_entities * sizeof(int);
  int values_size;
  int result;
  iMesh_getArrData(instance_, entities, num_entities, dim_tag,
                   &values, &values_alloc, &values_size, &result);
  PROCESS_ERROR;
int MeshAssocPairSide::get_dims ( iBase_EntitySetHandle *  sets,
int  num_sets,
int *  values
) [virtual]
Definition at line 306 of file MeshAssocPairSide.cpp.
  char *data = reinterpret_cast<char*>(values);
  int values_alloc = sizeof(int);
  int values_size;
  int result;
  for (int i = 0; i < num_sets; i++) {
    iMesh_getEntSetData(instance_, sets[i], dim_tag,
                        reinterpret_cast<void**>(&data),
    data += values_size;
    PROCESS_ERROR;
int MeshAssocPairSide::get_entities ( int  dimension,
int *  entities_size
) [virtual]
Definition at line 121 of file MeshAssocPairSide.cpp.
  int result;
  iMesh_getEntities(instance_, set_handle, this_type, iMesh_ALL_TOPOLOGIES,
  PROCESS_ERROR;
int MeshAssocPairSide::get_ents_dims ( iBase_EntityHandle *  entities,
int  entities_size,
int **  ent_types,
int *  ent_types_alloc,
int *  ent_types_size
) [virtual]
Definition at line 136 of file MeshAssocPairSide.cpp.
  int result;
  iMesh_getEntArrType(instance_, entities, entities_size, ent_types,
                      ent_types_alloc, ent_types_size, &result);
  PROCESS_ERROR;
int MeshAssocPairSide::get_gids ( iBase_EntityHandle *  entities,
int  num_entities,
int *  values
) [virtual]
Definition at line 262 of file MeshAssocPairSide.cpp.
  int values_size;
  int result;
  iMesh_getArrData(instance_, entities, num_entities, gid_tag,
  PROCESS_ERROR;
int MeshAssocPairSide::get_gids ( iBase_EntitySetHandle *  sets,
int  num_sets,
int *  values
) [virtual]
Definition at line 275 of file MeshAssocPairSide.cpp.
  int values_size;
  int result;
    iMesh_getEntSetData(instance_, sets[i], gid_tag,
    PROCESS_ERROR;
int MeshAssocPairSide::get_iterator ( iBase_EntitySetHandle  set,
iBase_EntityIterator *  iter
) [virtual]
Definition at line 252 of file MeshAssocPairSide.cpp.
  int result;
  int resilient=0;
  iMesh_initEntIter(instance_, set, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES,
                    resilient, iter, &result);
int MeshAssocPairSide::get_related_ents ( iBase_EntityHandle **  entities,
int *  entities_size
) [virtual]
Definition at line 150 of file MeshAssocPairSide.cpp.
  int result;
  iMesh_getEntsByTagsRec(instance_, 0, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES,
                         &relation_tag, NULL, 1, false, entities,
  PROCESS_ERROR;
int MeshAssocPairSide::get_related_sets ( iBase_EntitySetHandle **  sets,
int *  sets_alloc,
int *  sets_size
) [virtual]
Definition at line 161 of file MeshAssocPairSide.cpp.
  int result;
  iMesh_getEntSetsByTagsRec(instance_, 0, &relation_tag, NULL, 1, false, sets,
  PROCESS_ERROR;
int MeshAssocPairSide::get_relation_side ( iBase_EntityHandle *  entities,
int  num_entities,
void *  values
) [virtual]
Definition at line 171 of file MeshAssocPairSide.cpp.
  int values_alloc = num_entities * sizeof(iBase_EntityHandle);
  int values_size;
  int result;
  iMesh_getArrData(instance_, entities, num_entities, relation_tag,
  PROCESS_ERROR;
int MeshAssocPairSide::get_relation_side ( iBase_EntitySetHandle *  sets,
int  num_sets,
void *  values
) [virtual]
Definition at line 184 of file MeshAssocPairSide.cpp.
  char *data = static_cast<char*>(values);
  int values_alloc = sizeof(iBase_EntityHandle);
  int values_size;
  int result;
    iMesh_getEntSetData(instance_, sets[i], relation_tag,
    PROCESS_ERROR;
iBase_Instance MeshAssocPairSide::instance ( ) const [virtual]
Definition at line 56 of file MeshAssocPairSide.cpp.
  return instance_;
int MeshAssocPairSide::rmv_relation_side ( iBase_EntityHandle *  entities,
int  num_entities
) [virtual]
Definition at line 229 of file MeshAssocPairSide.cpp.
  int result;
  iMesh_rmvArrTag(instance_, entities, num_entities, relation_tag, &result);
  PROCESS_ERROR;
int MeshAssocPairSide::rmv_relation_side ( iBase_EntitySetHandle *  sets,
int  num_sets
) [virtual]
Definition at line 239 of file MeshAssocPairSide.cpp.
  int result;
    iMesh_rmvEntSetTag(instance_, sets[i], relation_tag, &result);
    PROCESS_ERROR;
int MeshAssocPairSide::set_relation_side ( iBase_EntityHandle *  entities,
int  num_entities,
const void *  values
) [virtual]
Definition at line 202 of file MeshAssocPairSide.cpp.
  int result;
  iMesh_setArrData(instance_, entities, num_entities, relation_tag,
                   static_cast<const char*>(values),
                   num_entities*sizeof(iBase_EntityHandle), &result);
  PROCESS_ERROR;
int MeshAssocPairSide::set_relation_side ( iBase_EntitySetHandle *  sets,
int  num_sets,
const void *  values
) [virtual]
Definition at line 214 of file MeshAssocPairSide.cpp.
  const char *data = static_cast<const char*>(values);
  int size = sizeof(iBase_EntityHandle);
  int result;
    iMesh_setEntSetData(instance_, sets[i], relation_tag, data, size, &result);
    data += size;
    PROCESS_ERROR;
Definition at line 61 of file MeshAssocPairSide.cpp.
  return iRel_IMESH_IFACE;
Member Data Documentation
iBase_TagHandle MeshAssocPairSide::dim_tag [private]
Definition at line 68 of file MeshAssocPairSide.hpp.
iBase_TagHandle MeshAssocPairSide::gid_tag [private]
Definition at line 67 of file MeshAssocPairSide.hpp.
int MeshAssocPairSide::id [private]
Definition at line 64 of file MeshAssocPairSide.hpp.
iMesh_Instance MeshAssocPairSide::instance_ [private]
Definition at line 63 of file MeshAssocPairSide.hpp.
Definition at line 62 of file MeshAssocPairSide.hpp.
iBase_TagHandle MeshAssocPairSide::relation_tag [private]
Definition at line 66 of file MeshAssocPairSide.hpp.
 All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
