lasso
test_entsetFB.cpp
00001 #include "FBiGeom.h"
00002 #include "iMesh.h"
00003 #include "iRel.h"
00004
00005 #include "stdio.h"
00006 #include "stdlib.h"
00007 #include "string.h"
00008
00009 #define DEFAULT_TEST_FILE shell.h5m
00010 #define DEFAULT_TEST_FILE1 shellQuad.h5m
00011
00012 #define STRINGIFY_(X) #X
00013 #define STRINGIFY(X) STRINGIFY_(X)
00014 #ifdef SRCDIR
00015 #  define DEFAULT_INPUT_FILE STRINGIFY(SRCDIR/DEFAULT_TEST_FILE)
00016 #  define DEFAULT_INPUT_FILE1 STRINGIFY(SRCDIR/DEFAULT_TEST_FILE1)
00017 #else
00018 #  define DEFAULT_INPUT_FILE STRINGIFY(DEFAULT_TEST_FILE)
00019 #  define DEFAULT_INPUT_FILE1 STRINGIFY(DEFAULT_TEST_FILE1)
00020 #endif
00021
00022 #define CHECK_SIZE_C(type, array, allocated_size, size)  \
00023           if (NULL == *array || *allocated_size == 0) {\
00024             *array = (type *) malloc(sizeof(type) * size); \
00025             *allocated_size = size;} \
00026           else if (*allocated_size < size) { \
00027              printf("   Array passed in is non-zero but too short.\n"); }
00028
00029 typedef void* iRel_EntityHandle;
00030
00034 void handle_error_code(const int result,
00035                        int *number_failed,
00036                        int *number_not_implemented,
00037                        int *number_successful)
00038 {
00039   if (result) {
00040     printf("Success");
00041     (*number_successful)++;
00042   }
00043   else {
00044     printf("Failure");
00045     (*number_failed)++;
00046   }
00047 }
00048
00049 int print_geom_info(FBiGeom_Instance geom, iBase_EntityHandle gent)
00050 {
00051     /* print information about this entity */
00052   int ent_type;
00053   int result;
00054   const char *type_names[] = {"Vertex", "Edge", "Face", "Region"};
00055
00056   FBiGeom_getEntType(geom, gent, &ent_type, &result);
00057
00058   if (iBase_SUCCESS != result) {
00059     printf("Trouble getting entity adjacencies or types.");
00060     return 0;
00061   }
00062
00063   printf("%s 0x%lx\n", type_names[ent_type], (unsigned long)gent);
00064
00065   return 1;
00066 }
00067
00068 int print_mesh_info(iMesh_Instance mesh, iBase_EntityHandle ment)
00069 {
00070     /* print information about this entity */
00071
00072     /* get adjacencies first; assume not more than 50 */
00073   iBase_EntityHandle adj_ents[50], *adj_ents_ptr = adj_ents;
00074    int ent_types[50], *ent_types_ptr = ent_types;
00075   int adj_ents_alloc = 50, adj_ents_size, ent_types_size,
00076     ent_types_allocated = 50;
00077   int result;
00078   iBase_TagHandle *ment_tags = NULL;
00079   int ment_tags_size, ment_tags_alloc;
00080   char **tag_names;
00081   int i;
00082   const char *type_names[] = {"Vertex", "Edge", "Face", "Region"};
00083   int tag_type;
00084
00085   char *dum_handle = NULL;
00086   int dum_handle_alloc = 0, dum_handle_size = 0;
00087   int int_data;
00088   double dbl_data;
00089   iBase_EntityHandle eh_data;
00090
00091   iMesh_getEntAdj(mesh, ment, iBase_ALL_TYPES,
00092                   &adj_ents_ptr, &adj_ents_alloc, &adj_ents_size,
00093                   &result);
00094
00095   if (iBase_SUCCESS != result) return 0;
00096
00097     /* put this ent on the end, then get types */
00098   adj_ents[adj_ents_size] = ment;
00099   iMesh_getEntArrType(mesh, adj_ents, adj_ents_size+1,
00100                       &ent_types_ptr, &ent_types_allocated,
00101                       &ent_types_size, &result);
00102   if (iBase_SUCCESS != result) {
00103     printf("Trouble getting entity adjacencies or types.");
00104     return 0;
00105   }
00106
00107     /* get tags on ment */
00108   iMesh_getAllTags(mesh, ment,
00109                    &ment_tags, &ment_tags_alloc, &ment_tags_size,
00110                    &result);
00111
00112   printf("Trouble getting tags on an entity or their names.");
00113
00114     /* while we're at it, get all the tag names */
00115
00116   tag_names = (char **) malloc(ment_tags_size * sizeof(char*));
00117
00118   for (i = 0; i < ment_tags_size; i++) {
00119     tag_names[i] = (char*)malloc(120*sizeof(char));
00120     iMesh_getTagName(mesh, ment_tags[i], tag_names[i], &result, 120);
00121   }
00122
00123     /* now print the information */
00124   printf("%s %ld:\n", type_names[ent_types[ent_types_size-1]], (long)ment);
00125   printf("Adjacencies:");
00126   for (i = 0; i < adj_ents_size; i++) {
00127     if (i > 0) printf(", ");
00128     printf("%s %ld", type_names[ent_types[i]],
00129            (long)adj_ents[i]);
00130   }
00131   printf("\nTags: \n");
00132   for (i = 0; i < ment_tags_size; i++) {
00133     printf("%s ", tag_names[i]);
00134     iMesh_getTagType(mesh, ment_tags[i], &tag_type, &result);
00135     if (iBase_SUCCESS != result)
00136       printf("(trouble getting type...)\n");
00137     else {
00138       dum_handle = NULL;
00139       dum_handle_alloc = 0, dum_handle_size = 0;
00140
00141       switch (tag_type) {
00142         case iBase_INTEGER:
00143           iMesh_getIntData(mesh, ment, ment_tags[i], &int_data, &result);
00144           printf("(Int value=%d)", int_data);
00145           break;
00146         case iBase_DOUBLE:
00147           iMesh_getDblData(mesh, ment, ment_tags[i], &dbl_data, &result);
00148           printf("(Dbl value=%f)", dbl_data);
00149           break;
00150         case iBase_ENTITY_HANDLE:
00151           iMesh_getEHData(mesh, ment, ment_tags[i], &eh_data, &result);
00152           printf("(EH value=%ld)", (long)eh_data);
00153           break;
00154         case iBase_BYTES:
00155           iMesh_getData(mesh, ment, ment_tags[i],
00156                         (void**)&dum_handle, &dum_handle_alloc,
00157                         &dum_handle_size, &result);
00158           if (NULL != dum_handle && dum_handle_size > 0)
00159             printf("(Opaque value=%c)", dum_handle[0]);
00160           break;
00161       }
00162     }
00163
00164     printf("\n");
00165   }
00166   printf("(end tags)\n\n");
00167
00168   return 1;
00169 }
00170
00176 int load_geom_mesh_test(const char *geom_filename,
00177                         const char *mesh_filename,
00178                         FBiGeom_Instance geom,
00179                         iMesh_Instance mesh)
00180 {
00181     /* load a geom */
00182   int result;
00183   FBiGeom_load(geom, geom_filename, 0, &result, strlen(geom_filename), 0);
00184   if (iBase_SUCCESS != result) {
00185     printf("ERROR : can not load a geometry\n");
00186     return 0;
00187   }
00188
00189     /* load a mesh */
00190   iMesh_load(mesh, 0, mesh_filename, 0, &result, strlen(mesh_filename), 0);
00191   if (iBase_SUCCESS != result) {
00192     printf("ERROR : can not load a mesh\n");
00193     return 0;
00194   }
00195
00196   return 1;
00197 }
00198
00204 int create_relation_test(iRel_Instance assoc,
00205                          FBiGeom_Instance geom,
00206                          iMesh_Instance mesh,
00207                          iRel_PairHandle *pair)
00208 {
00209   int result;
00210
00211   iBase_Instance iface1, iface2;
00212   int type1, type2;
00213   int ent_or_set1, ent_or_set2;
00214   int status1, status2;
00215
00216   iRel_PairHandle tmp_pair;
00217   iRel_PairHandle *pair_ptr = &tmp_pair;
00218   int pairs_alloc = 1, pairs_size;
00219
00220     /* create an relation, entity to set */
00221   iRel_createPair(assoc,
00222                   geom, iRel_ENTITY, iRel_FBIGEOM_IFACE, iRel_ACTIVE,
00223                   mesh, iRel_SET,    iRel_IMESH_IFACE, iRel_ACTIVE,
00224                   pair, &result);
00225   if (iBase_SUCCESS != result) {
00226     printf("Couldn't create a new relation.\n");
00227     return 0;
00228   }
00229
00230   iRel_getPairInfo(assoc, *pair,
00231                    &iface1, &ent_or_set1, &type1, &status1,
00232                    &iface2, &ent_or_set2, &type2, &status2, &result);
00233   if (iBase_SUCCESS != result) {
00234     printf("Couldn't retrieve relation info.\n");
00235     return 0;
00236   }
00237   if (iface1 != geom || ent_or_set1 != iRel_ENTITY ||
00238       type1 != iRel_FBIGEOM_IFACE || iface2 != mesh || ent_or_set2 != iRel_SET ||
00239       type2 != iRel_IMESH_IFACE) {
00240     printf("Unexpected relation info returned.\n");
00241     return 0;
00242   }
00243
00244   iRel_findPairs(assoc, geom, &pair_ptr, &pairs_alloc, &pairs_size, &result);
00245   if (iBase_SUCCESS != result) {
00246     printf("Couldn't find relation pair when querying geom.\n");
00247     return 0;
00248   }
00249   if (pairs_size != 1 || tmp_pair != *pair) {
00250     printf("Unexpected relation pairs returned when querying geom.\n");
00251     return 0;
00252   }
00253
00254   iRel_findPairs(assoc, mesh, &pair_ptr, &pairs_alloc, &pairs_size, &result);
00255   if (iBase_SUCCESS != result) {
00256     printf("Couldn't find relation pair when querying mesh.\n");
00257     return 0;
00258   }
00259   if (pairs_size != 1 || tmp_pair != *pair) {
00260     printf("Unexpected relation pairs returned when querying mesh.\n");
00261     return 0;
00262   }
00263
00264   return 1;
00265 }
00266
00272 int relate_geom_mesh_test(iRel_Instance assoc,
00273                           FBiGeom_Instance geom,
00274                           iMesh_Instance mesh,
00275                           iRel_PairHandle pair)
00276 {
00277     /* relate geometry entities with coresponding mesh entity sets */
00278   iBase_EntityHandle *gentities = NULL;
00279   int gentities_size = 0, gentities_alloc = 0;
00280   int result;
00281
00282   iBase_EntitySetHandle *mentity_handles = NULL;
00283   int mentity_handles_size = 0, mentity_handles_alloc = 0;
00284
00285   const char *dim_tag_name = "GEOM_DIMENSION";
00286   iBase_TagHandle dim_tag_mesh;
00287
00288   iBase_EntitySetHandle *mentities_vec;
00289   int mentities_vec_size;
00290   int i;
00291
00292   iBase_EntitySetHandle *out_mentities = NULL;
00293   int out_mentities_size = 0, out_mentities_alloc = 0;
00294
00295   iBase_EntitySetHandle *out_mentities2 = NULL;
00296   int out_mentities2_size = 0, out_mentities2_alloc = 0;
00297
00298   iBase_EntityHandle *out_gentities = NULL;
00299   int out_gentities_size = 0, out_gentities_alloc = 0;
00300
00301   FBiGeom_getEntities(geom, NULL,
00302                     iBase_VERTEX,
00303                     &gentities,
00304                     &gentities_alloc,
00305                     &gentities_size, &result);
00306   if (iBase_SUCCESS != result) {
00307     printf("Failed to get gentities by type in relate_geom_mesh_test.\n");
00308     return 0;
00309   }
00310
00311   iRel_inferEntArrRelations(assoc, pair,
00312                             gentities, gentities_size, 0,
00313                             &result);
00314   if (iBase_SUCCESS != result) {
00315     printf("Failed to relate geom entities in relate_geom_mesh_test.\n");
00316     return 0;
00317   }
00318
00319     /* relate coresponding mesh entity sets for geometry entities */
00320     /* get 1-dimensional mesh entitysets */
00321
00322   iMesh_getEntSets(mesh, NULL, 1,
00323                    &mentity_handles, &mentity_handles_alloc,
00324                    &mentity_handles_size, &result);
00325   if (iBase_SUCCESS != result) {
00326     printf("Problem to get all entity sets.\n");
00327     return 0;
00328   }
00329
00330     /* get geom dimension tags for mesh entitysets */
00331   iMesh_createTag(mesh, dim_tag_name, 1, iBase_INTEGER,
00332                   &dim_tag_mesh, &result, 15);
00333   if (iBase_SUCCESS != result && result != iBase_TAG_ALREADY_EXISTS) {
00334     printf("Couldn't create geom dim tag for mesh entities.\n");
00335     return 0;
00336   }
00337
00338     /* get 1-dimensional mesh entitysets */
00339   mentities_vec = (iBase_EntitySetHandle*)malloc(mentity_handles_size*sizeof(iBase_EntitySetHandle));
00340   mentities_vec_size = 0;
00341
00342   for (i = 0; i < mentity_handles_size; i++) {
00343     int dim;
00344     iMesh_getEntSetIntData(mesh, mentity_handles[i], dim_tag_mesh,
00345                            &dim, &result);
00346     if (iBase_SUCCESS != result)
00347       continue;
00348
00349     if (dim == 1)
00350       mentities_vec[mentities_vec_size++] = mentity_handles[i];
00351   }
00352
00353   iRel_inferSetArrRelations(assoc, pair,
00354                             mentities_vec, mentities_vec_size,
00355                             1, &result);
00356   if (iBase_SUCCESS != result) {
00357     printf("Failed to relate mesh entities in relate_geom_mesh_test.\n");
00358     return 0;
00359   }
00360
00361     /* relate all geometry and mesh entities */
00362   iRel_inferAllRelations(assoc, pair, &result);
00363   if (iBase_SUCCESS != result) {
00364     printf("Failed to relate all geom and mesh entities in relate_geom_mesh_test.\n");
00365     return 0;
00366   }
00367
00368     /* reset geom entities list and get all geom entities (prev
00369        only vertices) */
00370   free(gentities);
00371   gentities = NULL;
00372   gentities_alloc = 0;
00373   FBiGeom_getEntities(geom, NULL,
00374                     iBase_ALL_TYPES,
00375                     &gentities,
00376                     &gentities_alloc,
00377                     &gentities_size, &result);
00378   if (iBase_SUCCESS != result) {
00379     printf("Failed to get gentities by type in relate_geom_mesh_test.\n");
00380     return 0;
00381   }
00382
00383     /* get related mesh entity sets for geometry entities */
00384   iRel_getEntArrSetArrRelation(assoc, pair,
00385                                gentities, gentities_size, 0,
00386                                &out_mentities, &out_mentities_alloc,
00387                                &out_mentities_size,
00388                                &result);
00389   if (iBase_SUCCESS != result) {
00390     printf("Failed to get geom entities in relate_geom_mesh_test.\n");
00391     return 0;
00392   }
00393
00394   if (out_mentities_size != gentities_size) {
00395     printf("Number of input geom entities and output mesh entity sets should be same\n");
00396     return 0;
00397   }
00398
00399     /* now try deleting this relation */
00400   iRel_rmvEntArrRelation(assoc, pair, gentities, gentities_size, 0, &result);
00401   if (iBase_SUCCESS != result) {
00402     printf("Failed to remove relation in relate_geom_mesh_test.\n");
00403     return 0;
00404   }
00405   iRel_getEntArrSetArrRelation(assoc, pair,
00406                                gentities, gentities_size, 0,
00407                                &out_mentities2, &out_mentities2_alloc,
00408                                &out_mentities2_size,
00409                                &result);
00410   if (iBase_SUCCESS == result) {
00411     printf("Shouldn't have gotten mesh sets in relate_geom_mesh_test.\n");
00412     return 0;
00413   }
00414
00415     /* restore the relation, since we need it later */
00416   iRel_setEntArrSetArrRelation(assoc, pair, gentities, gentities_size,
00417                                out_mentities, out_mentities_size, &result);
00418   if (iBase_SUCCESS != result) {
00419     printf("Failed to restore relation in relate_geom_mesh_test.\n");
00420     return 0;
00421   }
00422
00423     /* get related geometry entities for mesh entity sets */
00424   iRel_getSetArrEntArrRelation(assoc, pair,
00425                                out_mentities, out_mentities_size, 1,
00426                                &out_gentities, &out_gentities_alloc,
00427                                &out_gentities_size,
00428                                &result);
00429   if (iBase_SUCCESS != result) {
00430     printf("Failed to get mesh entities in relate_geom_mesh_test.\n");
00431     return 0;
00432   }
00433
00434   if (out_mentities_size != out_gentities_size) {
00435     printf("Number of input mesh entity sets and output geom entities should be same\n");
00436     return 0;
00437   }
00438
00439   return 1;
00440 }
00441
00447 int query_relations_test(iRel_Instance assoc,
00448                          FBiGeom_Instance geom,
00449                          iMesh_Instance mesh,
00450                          iRel_PairHandle pair)
00451 {
00452     /* get all the geom entities, and find relation to some mesh entity */
00453   iBase_EntityHandle *gentities = NULL;
00454   int gentities_size = 0, gentities_alloc = 0;
00455   int result;
00456
00457   iBase_EntitySetHandle *out_mentities = NULL;
00458   int out_mentities_size, out_mentities_alloc = 0;
00459
00460   char descr[120];
00461   int i;
00462   int is_list;
00463
00464   iBase_EntityHandle *out_gentities = NULL;
00465   int out_gentities_size, out_gentities_alloc = 0;
00466
00467   FBiGeom_getEntities(geom, NULL, iBase_ALL_TYPES,
00468                     &gentities, &gentities_alloc,
00469                     &gentities_size, &result);
00470   if (iBase_SUCCESS != result) {
00471     printf("Problem getting all geom entities.\n" );
00472     return 0;
00473   }
00474
00475   iRel_getEntArrSetArrRelation(assoc, pair,
00476                                gentities, gentities_size, 0,
00477                                &out_mentities, &out_mentities_alloc,
00478                                &out_mentities_size,
00479                                &result);
00480     /* might not all be */
00481   if (iBase_SUCCESS != result) {
00482     printf("Failed to get mesh entities related to geom entities in query_relations_test.\n");
00483
00484     iRel_getDescription(assoc, descr, sizeof(descr)-1);
00485     printf("Entities missing relations: %s\n", descr);
00486
00487     for (i = 0; i < gentities_size; i++) {
00488         print_geom_info(geom, gentities[i]);
00489     }
00490
00491     return 0;
00492   }
00493
00494     /* check that they're all non-null */
00495   if (out_mentities_size != gentities_size) {
00496     printf("Number of mesh & related geom entities don't match.\n");
00497     return 0;
00498   }
00499
00500     /* check to make sure they're mesh sets; how to do that? */
00501   for (i = 0; i < out_mentities_size; i++) {
00502     iMesh_isList(mesh, (iBase_EntitySetHandle)out_mentities[i], &is_list, &result);
00503     if (iBase_SUCCESS != result) {
00504       printf("Entity set returned from classification wasn't valid.\n");
00505       return 0;
00506     }
00507   }
00508
00509     /* now turn around and check classification of those mesh entities */
00510   iRel_getSetArrEntArrRelation(assoc, pair,
00511                                out_mentities, out_mentities_size, 1,
00512                                &out_gentities, &out_gentities_alloc,
00513                                &out_gentities_size,
00514                                &result);
00515   if (iBase_SUCCESS != result) {
00516     printf("Failed to get geom entities related to mesh entities in query_relations_test.\n");
00517     return 0;
00518   }
00519
00520     /* check that they're all non-null */
00521   if (out_mentities_size != out_gentities_size) {
00522     printf("Number of geom & related mesh entities don't match.\n" );
00523     return 0;
00524   }
00525
00526     /* ok, we're done */
00527   return 1;
00528 }
00529
00530
00531 int main( int argc, char *argv[] )
00532 {
00533     /* Check command line arg */
00534   const char *geom_filename = DEFAULT_INPUT_FILE;
00535   const char *mesh_filename = DEFAULT_INPUT_FILE1;
00536
00537   int result;
00538   int number_tests = 0;
00539   int number_tests_successful = 0;
00540   int number_tests_not_implemented = 0;
00541   int number_tests_failed = 0;
00542
00543   FBiGeom_Instance geom;
00544   iMesh_Instance mesh;
00545   iRel_Instance assoc;
00546   iRel_PairHandle pair;
00547
00548   if (argc == 2 && !strcmp(argv[1], "-h")) {
00549     printf("Usage: %s <geom_filename> <mesh_filename>\n",
00550            argv[0]);
00551     return 1;
00552   }
00553   else if (argc == 2) {
00554     geom_filename = argv[1];
00555     mesh_filename = argv[1];
00556   }
00557   else if (argc == 3) {
00558     geom_filename = argv[1];
00559     mesh_filename = argv[2];
00560   }
00561
00562     /* initialize the Geometry */
00563   FBiGeom_newGeom(0, &geom, &result, 0);
00564
00565     /* initialize the Mesh */
00566   iMesh_newMesh(0, &mesh, &result, 0);
00567
00568     /* initialize the Associate */
00569   iRel_create(0, &assoc, &result, 0);
00570
00571     /* Print out Header information */
00572   printf("\n\niRel TEST PROGRAM:\n\n");
00573
00574
00575     /* load_geom_mesh test */
00576   printf("   load_geom_mesh: ");
00577   result = load_geom_mesh_test(geom_filename, mesh_filename,
00578                                geom, mesh);
00579   handle_error_code(result, &number_tests_failed,
00580                     &number_tests_not_implemented,
00581                     &number_tests_successful);
00582   number_tests++;
00583   printf("\n");
00584
00585     /* create_relation test */
00586   printf("   create_relation: ");
00587   result = create_relation_test(assoc, geom, mesh, &pair);
00588   handle_error_code(result, &number_tests_failed,
00589                     &number_tests_not_implemented,
00590                     &number_tests_successful);
00591   number_tests++;
00592   printf("\n");
00593
00594     /* relate_geom_mesh test */
00595   printf("   relate_geom_mesh: ");
00596   result = relate_geom_mesh_test(assoc, geom, mesh, pair);
00597   handle_error_code(result, &number_tests_failed,
00598                     &number_tests_not_implemented,
00599                     &number_tests_successful);
00600   number_tests++;
00601   printf("\n");
00602
00603     /* query_relations test */
00604   printf("   query_relations: ");
00605   result = query_relations_test(assoc, geom, mesh, pair);
00606   handle_error_code(result, &number_tests_failed,
00607                     &number_tests_not_implemented,
00608                     &number_tests_successful);
00609   number_tests++;
00610   printf("\n");
00611
00612     /* summary */
00613
00614   printf("\niRel TEST SUMMARY: \n");
00615   printf("   Number Tests:           %d\n", number_tests);
00616   printf("   Number Successful:      %d\n", number_tests_successful);
00617   printf("   Number Not Implemented: %d\n", number_tests_not_implemented);
00618   printf("   Number Failed:          %d\n", number_tests_failed);
00619   printf("\n\n");
00620
00621   iRel_destroy(assoc, &result);
00622
00623   return number_tests_failed != 0;
00624 }
00625
 All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
