lasso
test_status.cpp File Reference
#include "iGeom.h"
#include "iMesh.h"
#include "iRel.h"
#include "TestUtil.hpp"
#include <cstdlib>
Functions
void test_initial_inactive ()
void test_initial_notexist ()
int main ()
Variables
iGeom_Instance geom
iMesh_Instance mesh
iRel_Instance rel
Function Documentation
int main ( )
Definition at line 89 of file test_status.cpp.
  int err;
  int num_fail = 0;
  iGeom_newGeom(0, &geom, &err, 0);
  iMesh_newMesh(0, &mesh, &err, 0);
  iRel_create(0, &rel, &err, 0);
  num_fail += RUN_TEST(test_initial_inactive);
  num_fail += RUN_TEST(test_initial_notexist);
  iRel_destroy(rel, &err);
  iMesh_dtor(mesh, &err);
  iGeom_dtor(geom, &err);
  return num_fail;
Definition at line 13 of file test_status.cpp.
  int err;
  iRel_PairHandle pair;
  iRel_createPair(rel, geom, iRel_SET, iRel_IGEOM_IFACE, iRel_INACTIVE,
                       mesh, iRel_SET, iRel_IMESH_IFACE, iRel_ACTIVE,
                  &pair, &err);
  CHECK_ERR(err);
  iBase_EntitySetHandle geom_set;
  iGeom_createEntSet(geom, false, &geom_set, &err);
  CHECK_ERR(err);
  iBase_EntitySetHandle mesh_set;
  iMesh_createEntSet(mesh, false, &mesh_set, &err);
  CHECK_ERR(err);
  iRel_setSetSetRelation(rel, pair, geom_set, mesh_set, &err);
  CHECK_ERR(err);
  iBase_EntitySetHandle related_set;
  iRel_getSetSetRelation(rel, pair, mesh_set, 1, &related_set, &err);
  CHECK_ERR(err);
  CHECK_EQUAL(related_set, geom_set);
  iRel_getSetSetRelation(rel, pair, geom_set, 0, &related_set, &err);
  CHECK(err != iBase_SUCCESS);
  iRel_changePairStatus(rel, pair, iRel_ACTIVE, iRel_ACTIVE, &err);
  CHECK_ERR(err);
  CHECK_ERR(err);
  CHECK_EQUAL(related_set, mesh_set);
Definition at line 51 of file test_status.cpp.
  int err;
  iRel_createPair(rel, geom, iRel_SET, iRel_IGEOM_IFACE, iRel_NOTEXIST,
                  &pair, &err);
  CHECK_ERR(err);
  CHECK_ERR(err);
  CHECK_ERR(err);
  CHECK_ERR(err);
  CHECK_ERR(err);
  CHECK_ERR(err);
  CHECK_ERR(err);
Variable Documentation
iGeom_Instance geom
Definition at line 9 of file test_status.cpp.
iMesh_Instance mesh
Definition at line 10 of file test_status.cpp.
Definition at line 11 of file test_status.cpp.
 All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Defines
