MeshKit  1.0
AF2RuleApplication.hpp
00001 /*
00002  * AF2RuleApplication.hpp
00003  *
00004  * An AF2RuleApplication is a representation of what is involved in applying
00005  * a particular AF2Rule is applied with a particular AF2Binding to points
00006  * and edges in some AF2Neighborhood.  The representation is independent
00007  * of the particular AF2Rule and AF2Binding so that it can be easily
00008  * compared with other AF2RuleApplications that involve other rules
00009  * or bind to other points and edges in the AF2Neighborhood.
00010  *
00011  * The AF2RuleApplication tells which new points and new faces are to
00012  * be added by applying the particular rule with the particular binding.
00013  * The AF2Point2D objects referenced by the AF2Polygon2D faces are
00014  * either from the AF2Neighborhood or from the list of new points.  Since
00015  * the points are copied when the AF2RuleApplication is copied, a reference
00016  * to a point from a polygon from a AF2RuleApplication will not match
00017  * any AF2Point2D reference returned by the getNewPoint method of
00018  * a copy of the AF2RuleApplication.
00019  */
00020 #ifndef AF2RULEAPPLICATION_HPP
00021 #define AF2RULEAPPLICATION_HPP
00022
00023 // C++
00024 #include <list>
00025 #include <map>
00026
00027 // MeshKit
00028 #include "meshkit/AF2Point2D.hpp"
00029 #include "meshkit/AF2Polygon2D.hpp"
00030
00031 class AF2RuleApplication
00032 {
00033   private:
00034
00035     unsigned int numNewPoints;
00036     const AF2Point2D** newPoints;
00037     unsigned int numNewFaces;
00038     const AF2Polygon2D** newFaces;
00039
00053     void mapCopyPolygon(const AF2Polygon2D & sourcePolygon,
00054         const AF2Polygon2D* & targetPolygon,
00055         const std::map<const AF2Point2D*, const AF2Point2D*> & vertexMap);
00056
00057   public:
00058
00084     AF2RuleApplication(std::list<const AF2Point2D*> const & newPointsList,
00085         std::list<const AF2Polygon2D*> const & newFacesList);
00086
00090     ~AF2RuleApplication();
00091
00100     AF2RuleApplication(const AF2RuleApplication & toCopy);
00101
00111     AF2RuleApplication& operator=(const AF2RuleApplication & rhs);
00112
00119     unsigned int getNumNewFaces() const;
00120
00133     const AF2Polygon2D* getNewFace(unsigned int newFaceIndex) const;
00134
00141     unsigned int getNumNewPoints() const;
00142
00155     const AF2Point2D* getNewPoint(unsigned int newPointIndex) const;
00156 };
00157
00158 #endif
