MeshKit  1.0
AssyGen.cpp
00001 /*********************************************
00002 AssyGen Tool: Reactor Geometry Generator
00003 Argonne National Laboratory
00004 *********************************************/
00005
00006 #ifdef _WIN32
00007 #define _USE_MATH_DEFINES
00008 #endif
00009
00010 #include "meshkit/AssyGen.hpp"
00011
00012 namespace MeshKit
00013 {
00014   // static registration of this  mesh scheme
00015   moab::EntityType AssyGen_tps[] = { moab::MBVERTEX,
00016                                      moab::MBEDGE,
00017                                      moab::MBTRI,
00018                                      moab::MBHEX,
00019                                      moab::MBMAXTYPE};
00020   const moab::EntityType* AssyGen::output_types()
00021   { return AssyGen_tps; }
00022
00023   AssyGen::AssyGen( MKCore *mk, const MEntVector &me_vec)
00024     : MeshScheme( mk, me_vec),
00025       igeomImpl(mk->igeom_instance())
00026   {
00027     err = 0;
00028     tmpSB = 1;
00029     m_nPlanar = 0; //default is 3D
00030     m_nLineNumber = 0;
00031     root_set= NULL;
00032     szComment = "!";
00033     MAXCHARS = 10000;
00034     MAXLINES = 1000;
00035     pi = M_PI;
00036     m_nTotalPincells = 0;
00037     m_dRadialSize = -1.0;
00038     m_dTetMeshSize = -1.0;
00039     m_nDimensions = 0;
00040     m_nMaterialSetId = 1;
00041     m_nNeumannSetId = 1;
00042     m_szEngine = "acis";
00043     m_szMeshType = "hex";
00044     m_nDuct = 0;
00045     m_nDuctNum = 0;
00046     m_nJouFlag = 0;
00047     m_szSideset = "yes";
00048     m_nAssyGenInputFiles = 0;
00049     m_dMergeTol = 1e-4;
00050     m_edgeInterval = 99;
00051     m_nStartpinid = 1;
00052     m_szInfo = "off";
00053     m_szMeshScheme = "pave";
00054     pin_name = "";
00055     m_nHblock = -1;
00056     m_nPincells = 0;
00057     m_bCreateMatFiles = false;
00058     m_nSuperBlocks = 0;
00059     m_bmerge = true;
00060     m_bimprint = true;
00061     save_exodus = false;
00062     have_common = true;
00063     com_run_count = 0;
00064     m_nBLAssemblyMat = 0;
00065     m_szInnerDuct = "";
00066     m_szSmooth  = "off";
00067   }
00068
00069   AssyGen::~AssyGen()
00070   {
00071 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
00072     iGeom_dtor(igeomImpl->instance(), &err);
00073 #endif
00074     //CHECK( "Interface destruction didn't work properly." );
00075     // close the input and output files
00076     m_FileInput.close ();
00077     m_FileOutput.close ();
00078     m_SchemesFile.close ();
00079     if(strcmp(m_szInfo.c_str(),"on") == 0)
00080       m_AssmInfo.close ();
00081   }
00082
00083
00084   bool AssyGen::add_modelent(ModelEnt *model_ent)
00085   {
00086     return MeshOp::add_modelent(model_ent);
00087   }
00088
00089   void AssyGen::setup_this()
00090   {
00091     // start the timer
00092     CClock Timer;
00093     clock_t sTime = clock();
00094     std::string szDateTime;
00095     Timer.GetDateTime (szDateTime);
00096     std::cout << "\nStarting out at : " << szDateTime << "\n";
00097
00098     if (have_common == true)
00099       ReadCommonInp();
00100
00101     //count pin cylinders and cell material, needed for setting array size before actual read
00102     ReadInputPhase1 ();
00103
00104     if (have_common == true)
00105       ReadCommonInp();
00106
00107     // read the problem size and create pincell
00108     ReadAndCreate ();
00109
00110     // create the .jou file
00111     CreateCubitJournal();
00112
00113     CreateAssyGenInputFiles();
00114
00115     // get the current date and time
00116     Timer.GetDateTime (szDateTime);
00117     std::cout << "Ending at : " << szDateTime;
00118
00119     // compute the elapsed time
00120     std::cout << "Elapsed wall clock time: " << Timer.DiffTime ()
00121               << " seconds or " << (Timer.DiffTime ())/60.0 << " mins\n";
00122
00123     std::cout << "## Total CPU time used := " << (double) (clock() - sTime)/CLOCKS_PER_SEC \
00124               << " seconds" << std::endl;
00125   }
00126
00127   void AssyGen::execute_this()
00128   {
00129   }
00130
00131
00132   void AssyGen::PrepareIO (int argc, char *argv[],  std::string TestDir)
00133   // ---------------------------------------------------------------------------
00134   // Function: Obtains file names and opens input/output files
00135   // Input:    command line arguments
00136   // Output:   none
00137   // ---------------------------------------------------------------------------
00138   {
00139     std::cout << '\n';
00140     std::cout << "\t\t---------------------------------------------------------" << '\n';
00141     std::cout << "\t\tProgram to Generate Nuclear Reactor Assembly Geometries      " << '\n';
00142     std::cout << "\t\t\t\tArgonne National Laboratory" << '\n';
00143     std::cout << "\t\t---------------------------------------------------------" << '\n';
00144     std::cout << "\nsee http://press3.mcs.anl.gov/sigma/meshkit-library/rgg/ for details.\n"<< std::endl;
00145     // set and open input output files
00146     bool bDone = false;
00147     do{
00148         if (2 == argc) {
00149             m_szFile = argv[1];
00150             m_szInFile=m_szFile+".inp";
00151             m_szJouFile = m_szFile+".jou";
00152             m_szSchFile = m_szFile+".template.jou";
00153             m_szAssmInfo = m_szFile + "_info.csv";
00154             m_szLogFile = m_szFile + ".screenlog";
00155             m_szPyCubGeom = m_szFile + ".py";
00156             m_szCommonFile = "common.inp";
00157           }
00158         else if (3 == argc) {
00159             int i=1;// will loop through arguments, and process them
00160             for (i=1; i<argc-1 ; i++) {
00161                 if (argv[i][0]=='-') {
00162                     switch (argv[i][1])
00163                       {
00164                       case 'j':
00165                         {
00166                           m_nJouFlag = 1;
00167                           std::cout << "Creating journal file only.\n Geometry file must exist in the same directory." << std::endl;
00168                           m_szFile = argv[2];
00169                           m_szInFile=m_szFile+".inp";
00170                           m_szJouFile = m_szFile+".jou";
00171                           m_szSchFile = m_szFile+".template.jou";
00172                           m_szAssmInfo = m_szFile + "_info.csv";
00173                           m_szLogFile = m_szFile + ".screenlog";
00174                           m_szPyCubGeom = m_szFile + ".py";
00175                           m_szCommonFile = "common.inp";
00176                           break;
00177                         }
00178                       case 'h':
00179                         {
00180                           std::cout << "\nInstruction on writing assygen input file can also be found at: " << std::endl;
00181                           std::cout << "        http://press3.mcs.anl.gov/sigma/meshkit/rgg/assygen-input-file-keyword-definitions/" << std::endl;
00182                           std::cout << "Usage: assygen [-j -h] <input file name without extension>"<< std::endl;
00183                           std::cout << "        -j create journal file only" << std::endl;
00184                           std::cout << "        -h print help" << std::endl;
00185
00186                           exit(0);
00187                           break;
00188                         }
00189                       }
00190                   }
00191               }
00192           }
00193         else if (1 == argc){
00194             std::cout << "\nInstruction on writing assygen input file can also be found at: " << std::endl;
00195             std::cout << "        http://press3.mcs.anl.gov/sigma/meshkit/rgg/assygen-input-file-keyword-definitions/" << std::endl;
00196             std::cout << "Usage: assygen [-t -j -h] <input file name without extension>"<< std::endl;
00197             std::cout << "        -t print timing and memory usage info in each step" << std::endl;
00198             std::cout << "        -j create journal file only" << std::endl;
00199             std::cout << "        -h print help" << std::endl;
00200
00201             m_szInFile = TestDir + "/" + (char *)DEFAULT_TEST_FILE;
00202             m_szGeomFile = (char *)TEST_FILE_NAME;
00203             m_szJouFile = (char *)TEST_FILE_NAME;
00204             m_szFile =  (char *)TEST_FILE_NAME;
00205             m_szInFile+=".inp";
00206             m_szJouFile+=".jou";
00207             m_szSchFile = m_szFile+".template.jou";
00208             m_szAssmInfo = m_szFile + "_info.csv";
00209             m_szLogFile = m_szFile + ".screenlog";
00210             m_szPyCubGeom = m_szFile + ".py";
00211             m_szCommonFile = TestDir + "/" + "common.inp";
00212
00213             std::cout <<"Default case input file is located here <MeshKit/data> "<< std::endl;
00214           }
00215         // open the file
00216         m_FileInput.open (m_szInFile.c_str(), std::ios::in);
00217         if (!m_FileInput){
00218             std::cout << "Usage: assygen <input filename WITHOUT EXTENSION>"<< std::endl;
00219             m_FileInput.clear ();
00220             exit(1);
00221           }
00222         else
00223           bDone = true; // file opened successfully
00224
00225         // open common.inp file, if not found do nothing.
00226         m_FileCommon.open (m_szCommonFile.c_str(), std::ios::in);
00227         if (!m_FileCommon){
00228             have_common = false;
00229             std::cout << "common.inp file not specified." << std::endl;
00230             m_FileCommon.clear ();
00231           }
00232         else {
00233             have_common = true;
00234           }
00235         std::cout << " opened file " << m_szCommonFile << " have common is "
00236                   << have_common << std::endl;
00237       } while (!bDone);
00238     std::cout << "\nEntered input file name: " <<  m_szInFile <<std::endl;
00239
00240     // open the file
00241     do{
00242         m_FileOutput.open (m_szJouFile.c_str(), std::ios::out);
00243         if (!m_FileOutput){
00244             std::cout << "Unable to open o/p file: " << m_szJouFile << std::endl;
00245             m_FileOutput.clear ();
00246             exit(1);
00247           }
00248         else
00249           bDone = true; // file opened successfully
00250       } while (!bDone);
00251
00252     // open the template journal file for writing
00253     do{
00254         m_SchemesFile.open (m_szSchFile.c_str(), std::ios::out);
00255         if (!m_SchemesFile){
00256             std::cout << "Unable to open o/p file: " << m_szSchFile << std::endl;
00257             m_SchemesFile.clear ();
00258             exit(1);
00259           }
00260         else
00261           bDone = true; // file opened successfully
00262       } while (!bDone);
00263
00264     do{
00265         m_PyCubGeomFile.open (m_szPyCubGeom.c_str(), std::ios::out);
00266         if (!m_PyCubGeomFile){
00267             std::cout << "Unable to open o/p file: " << m_szPyCubGeom << std::endl;
00268             m_PyCubGeomFile.clear ();
00269             exit(1);
00270           }
00271         else
00272           bDone = true; // file opened successfully
00273       } while (!bDone);
00274
00275     std::cout<<"\no/p Cubit journal file name: "<< m_szJouFile
00276             << std::endl;
00277
00278     // filename to be saved with cubit journal file
00279     m_szGeomFile1 = m_szFile+".sat";
00280
00281     //ACIS ENGINE
00282 #ifdef HAVE_ACIS
00283     //  if(m_szEngine == "acis"){
00284     m_szGeomFile = m_szFile+".sat";
00285     //  }
00286 #elif defined(HAVE_OCC)
00287     //  OCC ENGINE
00288     //  if (m_szEngine == "occ"){
00289     m_szGeomFile = m_szFile+".brep";
00290     //  }
00291 #endif
00292     std::cout << "\no/p geometry file name: " <<  m_szGeomFile <<std::endl;
00293
00294     // writing schemes .jou file ends, now write the main journal file.
00295     // stuff common to both surface and volume
00296     m_FileOutput << "## This file is created by rgg program in MeshKit ##\n";
00297     m_FileOutput << "#User needs to specify mesh interval and schemes in this file\n#" << std::endl;
00298
00299     m_PyCubGeomFile << "## This python script is created by the RGG AssyGen program in MeshKit ##\n";
00300     m_PyCubGeomFile << "# Here the RGG AssyGen program creates the assembly geometry and mesh\n#" << std::endl;
00301     m_PyCubGeomFile << "\nimport cubit" << std::endl;
00302
00303
00304     // write the name faces python function here
00305     m_PyCubGeomFile << "def name_faces(name, body):\n"
00306                        "    vector_locs = cubit.get_bounding_box(\"volume\", body.id())\n"
00307                        "    topno = vector_locs[7] - 1e-2\n"
00308                        "    botno = vector_locs[6] + 1e-2\n"
00309                        "    cubit.cmd('group \"g1\" equals surf in vol {0} '.format(body.id()))\n"
00310                        "    cubit.cmd('group \"g2\" equals surf  in g1 with z_coord  < {0} and z_coord > {1}'.format(topno,botno))\n"
00311                        "    cubit.cmd('group  \"g3\" subtract g2 from g1')\n"
00312                        "    cubit.cmd('group \"gtop\" equals surf in g3 with z_coord > {0}'.format(topno) )\n"
00313                        "    cubit.cmd('group \"gbot\" equals surf in g3 with z_coord < {0}'.format(botno) )\n"
00314                        "    g2id = cubit.get_id_from_name(\"g2\")\n"
00315                        "    ssurfs = cubit.get_group_surfaces(g2id)\n"
00316                        "    side_surfs = len(ssurfs)\n"
00317                        "    for i in range(0,side_surfs):\n"
00318                        "      sname = name + \"_side\" + str(i+1)\n"
00319                        "      cubit.cmd('surf {0} name \"{1}\"'.format( ssurfs[i] , sname )  )\n"
00320                        "    top_surf = name + \"_top\"\n"
00321                        "    bot_surf = name + \"_bot\"\n"
00322                        "    cubit.cmd('surf in gtop name \"{0}\"'.format(top_surf) )\n"
00323                        "    cubit.cmd('surf in gbot name \"{0}\"'.format(bot_surf) )\n"
00324                        "    cubit.cmd('delete group g1 g2 g3 gtop gbot')\n" << std::endl;
00325
00326
00327     // write the name faces python function here
00328     m_PyCubGeomFile << "\n\ndef section_assm(cDir, dOffset, szReverse):\n"
00329                        "    vol = cubit.get_entities(\"volume\")\n"
00330                        "    for i in range(len(vol)):\n"
00331                        "      vl = cubit.get_bounding_box(\"volume\", vol[i])\n"
00332                        "      xmin = vl[0]\n"
00333                        "      xmax = vl[1]\n"
00334                        "      ymin = vl[3]\n"
00335                        "      ymax = vl[4]\n"
00336                        "      print xmin, xmax, ymin, ymax\n"
00337                        "      if(xmin > dOffset and cDir == \"x\" and szReverse == \"reverse\"):\n"
00338                        "        cubit.cmd('delete vol {0}'.format(vol[i]) )\n"
00339                        "        continue\n"
00340                        "      if(ymin > dOffset and cDir == \"y\" and szReverse == \"reverse\"):\n"
00341                        "        cubit.cmd('delete vol {0}'.format(vol[i]) )\n"
00342                        "        continue\n"
00343                        "      if(xmax < dOffset and cDir == \"x\" and szReverse == \"\"):\n"
00344                        "        cubit.cmd('delete vol {0}'.format(vol[i]) )\n"
00345                        "        continue\n"
00346                        "      if(ymax < dOffset and cDir == \"y\" and szReverse == \"\"):\n"
00347                        "        cubit.cmd('delete vol {0}'.format(vol[i]) )\n"
00348                        "        continue\n"
00349                        "      else:\n"
00350                        "        if (ymax > dOffset and cDir == \"y\" and ymin < dOffset):\n"
00351                        "          cubit.cmd('section vol {0} with yplane offset {1} {2}'.format(vol[i], dOffset, szReverse))\n"
00352                        "        if (xmax > dOffset and cDir == \"x\" and xmin < dOffset):\n"
00353                        "          cubit.cmd('section vol {0} with xplane offset {1} {2}'.format(vol[i], dOffset, szReverse))\n" << std::endl;
00354
00355     m_PyCubGeomFile << "\ncubit.cmd('reset')" << std::endl;
00356
00357
00358     m_FileOutput << "#" << std::endl;
00359     m_FileOutput << "set logging on file '" << m_szLogFile << "'" <<std::endl;
00360     m_FileOutput << "Timer Start" << std::endl;
00361     // import the geometry file
00362     m_FileOutput << "# Import geometry file " << std::endl;
00363     // Use sat file always as step isn't supported
00364     m_FileOutput << "import '" << m_szGeomFile1 <<"'" << std::endl;
00365     m_FileOutput << "{include(\"" << m_szSchFile << "\")}" <<std::endl;
00366     m_FileOutput << "#" << std::endl;
00367
00368   }
00369
00370
00371   void AssyGen::ReadCommonInp ()
00372   // -------------------------------------------------------------------------------------------
00373   // Function: reads the input file to count the no. of cyl in a pincell, before the actual read
00374   // Input:    none
00375   // Output:   none
00376   // -------------------------------------------------------------------------------------------
00377   {
00378     ++com_run_count;
00379     if(com_run_count > 1){
00380         //Rewind the reader for common.inp file
00381         m_FileCommon.clear (std::ios_base::goodbit);
00382         m_FileCommon.seekg (0L, std::ios::beg);
00383       }
00384     CParser Parse1;
00385     bool found = false;
00386     std::string card;
00387     m_nLineNumber = 0;
00388     std::cout << "Reading from common.inp file." << std::endl;
00389     for(;;){
00390         if (!Parse1.ReadNextLine (m_FileCommon, m_nLineNumber, szInputString,
00391                                   MAXCHARS, szComment))
00392           IOErrorHandler (INVALIDINPUT);
00393
00394         if (szInputString.substr(0,10) == "geomengine"){
00395             found = true;
00396             std::istringstream szFormatString (szInputString);
00397             szFormatString >> card >> m_szEngine;
00398             if( ((strcmp (m_szEngine.c_str(), "acis") != 0) &&
00399                  (strcmp (m_szEngine.c_str(), "occ") != 0)) || szFormatString.fail())
00400               IOErrorHandler(EGEOMENGINE);
00401           }
00402         // start id for pin number
00403         if (szInputString.substr(0, 10) == "startpinid") {
00404             found = true;
00405             std::istringstream szFormatString(szInputString);
00406             szFormatString >> card >> m_nStartpinid;
00407           }
00408         if (szInputString.substr(0,8) == "meshtype"){
00409             found = true;
00410             std::istringstream szFormatString (szInputString);
00411             szFormatString >> card >> m_szMeshType;
00412             if( ((strcmp (m_szMeshType.c_str(), "hex") != 0) &&
00413                  (strcmp (m_szMeshType.c_str(), "tet") != 0)) || szFormatString.fail())
00414               IOErrorHandler(INVALIDINPUT);
00415           }
00416         // info flag
00417         if (szInputString.substr(0,4) == "info"){
00418             found = true;
00419             std::istringstream szFormatString (szInputString);
00420             szFormatString >> card >> m_szInfo;
00421             std::cout <<"--------------------------------------------------"<<std::endl;
00422           }
00423         // hex block along z
00424         if (szInputString.substr(0,6) == "hblock"){
00425             found = true;
00426             std::istringstream szFormatString (szInputString);
00427             szFormatString >> card >> m_nHblock >> m_dZstart >> m_dZend;
00428             std::cout <<"--------------------------------------------------"<<std::endl;
00429           }
00430         // Hex or Rect geometry type
00431         if (szInputString.substr(0,12) == "geometrytype"){
00432             found = true;
00433             std::istringstream szFormatString (szInputString);
00434             szFormatString >> card >> m_szGeomType;
00435             if( ((strcmp (m_szGeomType.c_str(), "hexagonal") != 0) &&
00436                  (strcmp (m_szGeomType.c_str(), "rectangular") != 0)) || szFormatString.fail())
00437               IOErrorHandler(EGEOMTYPE);
00438
00439             // set the number of sides in the geometry
00440             if(m_szGeomType == "hexagonal")
00441               m_nSides = 6;
00442             else  if(m_szGeomType == "rectangular")
00443               m_nSides = 4;
00444           }
00445         // Default if volume, set geometry type to surface for 2D assemblies
00446         if (szInputString.substr(0,8) == "geometry"){
00447             found = true;
00448             std::string outfile;
00449             std::istringstream szFormatString (szInputString);
00450             szFormatString >> card >> outfile;
00451             if(strcmp (outfile.c_str(), "surface") == 0 || szFormatString.fail())
00452               m_nPlanar=1;
00453           }
00454         // 'yes' or 'no' for creating sidesets
00455         if (szInputString.substr(0,13) == "createsideset"){
00456             found = true;
00457             std::istringstream szFormatString (szInputString);
00458             szFormatString >> card >> m_szSideset;
00459             std::cout <<"--------------------------------------------------"<<std::endl;
00460           }
00461         // Create specified number of files with varying material ids
00462         if (szInputString.substr(0,11) == "createfiles"){
00463             found = true;
00464             std::istringstream szFormatString (szInputString);
00465             szFormatString >> card >> m_nAssyGenInputFiles;
00466             std::cout <<"--------------------------------------------------"<<std::endl;
00467           }
00468         // Create specified number of files with varying material ids
00469         if (szInputString.substr(0,11) == "save_exodus"){
00470             found = true;
00471             save_exodus = true;
00472             std::cout <<"--------------------------------------------------"<<std::endl;
00473           }
00474         // specify a merge tolerance value for cubit journal file
00475         if (szInputString.substr(0,14) == "mergetolerance"){
00476             found = true;
00477             std::istringstream szFormatString (szInputString);
00478             szFormatString >> card >> m_dMergeTol;
00479             std::cout <<"--------------------------------------------------"<<std::endl;
00480           }
00481         // Handle mesh size inputs
00482         if (szInputString.substr(0,14) == "radialmeshsize"){
00483             found = true;
00484             std::istringstream szFormatString (szInputString);
00485             szFormatString >> card >> m_dRadialSize;
00486             if(m_dRadialSize < 0 || szFormatString.fail())
00487               IOErrorHandler(ENEGATIVE);
00488             std::cout <<"--------------------------------------------------"<<std::endl;
00489
00490           }
00491         // Handle mesh size inputs
00492         if (szInputString.substr(0,11) == "tetmeshsize"){
00493             found = true;
00494             std::istringstream szFormatString (szInputString);
00495             szFormatString >> card >> m_dTetMeshSize;
00496             if(m_dTetMeshSize < 0 || szFormatString.fail())
00497               IOErrorHandler(ENEGATIVE);
00498             std::cout <<"--------------------------------------------------"<<std::endl;
00499
00500           }
00501         // Handle mesh size inputs
00502         if (szInputString.substr(0,13) == "axialmeshsize"){
00503             found = true;
00504             if(com_run_count > 1){
00505                 std::istringstream szFormatString (szInputString);
00506                 szFormatString >> card;
00507                 m_dAxialSize.SetSize(m_nDuct);
00508                 int num_ams_specified = std::distance(std::istream_iterator<std::string>(szFormatString),
00509                                                       std::istream_iterator<std::string>());
00510                 std::istringstream szFormatStringAgain (szInputString);
00511                 szFormatStringAgain >> card;
00512                 for (int p = 1; p <= m_nDuct; p++){
00513                     if(p <= num_ams_specified)
00514                       szFormatStringAgain >> m_dAxialSize(p);
00515                     else
00516                       m_dAxialSize(p) = m_dAxialSize(num_ams_specified);
00517                     if(m_dAxialSize(p) < 0)
00518                       IOErrorHandler(ENEGATIVE);
00519                   }
00520                 std::cout <<"--------------------------------------------------"<<std::endl;
00521               }
00522           }
00523         // edge interval
00524         if (szInputString.substr(0, 12) == "edgeinterval") {
00525             found = true;
00526             std::istringstream szFormatString(szInputString);
00527             szFormatString >> card >> m_edgeInterval;
00528           }
00529         // mesh scheme - hole or pave
00530         if (szInputString.substr(0, 10) == "meshscheme") {
00531             std::istringstream szFormatString(szInputString);
00532             szFormatString >> card >> m_szMeshScheme;
00533           }
00534         // breaking condition
00535         if(szInputString.substr(0,3) == "end" || m_nLineNumber == MAXLINES){
00536             found = true;
00537             break;
00538           }
00539         if (found == false){
00540             std::cout << "Cannot specify: " << szInputString << " in common.inp files" << std::endl;
00541           }
00542       }
00543
00544   }
00545
00546   void AssyGen::ReadInputPhase1 ()
00547   // -------------------------------------------------------------------------------------------
00548   // Function: reads the input file to count the no. of cyl in a pincell, before the actual read
00549   // Input:    none
00550   // Output:   none
00551   // -------------------------------------------------------------------------------------------
00552   {
00553     std::cout << "Reading from AssyGen input file." << std::endl;
00554     CParser Parse;  bool bDone = false;
00555     int nCyl =0, nCellMat=0, nInputLines=0;
00556     std::string card, szVolId, szVolAlias;
00557     m_nLineNumber = 0;
00558     // count the total number of cylinder commands in each pincell
00559     for(;;){
00560         if (!Parse.ReadNextLine (m_FileInput, m_nLineNumber, szInputString,
00561                                  MAXCHARS, szComment))
00562           IOErrorHandler (INVALIDINPUT);
00563
00564         if (szInputString.substr(0,10) == "geomengine"){
00565             std::istringstream szFormatString (szInputString);
00566             szFormatString >> card >> m_szEngine;
00567             if( ((strcmp (m_szEngine.c_str(), "acis") != 0) &&
00568                  (strcmp (m_szEngine.c_str(), "occ") != 0)) || szFormatString.fail())
00569               IOErrorHandler(EGEOMENGINE);
00570           }
00571         // Read material data
00572         if ((szInputString.substr(0,9) == "materials") && (szInputString.substr(0,19) != "materialset_startid")){
00573
00574             std::istringstream szFormatString (szInputString);
00575             szFormatString >> card >> m_nAssemblyMat;
00576             if(szFormatString.fail())
00577               IOErrorHandler(INVALIDINPUT);
00578             m_szAssmMat.SetSize(m_nAssemblyMat); m_szAssmMatAlias.SetSize(m_nAssemblyMat);
00579             for (int j=1; j<=m_nAssemblyMat; j++){
00580                 szFormatString >> m_szAssmMat(j) >> m_szAssmMatAlias(j);
00581                 if( (strcmp (m_szAssmMat(j).c_str(), "") == 0) ||
00582                     (strcmp (m_szAssmMatAlias(j).c_str(), "") == 0)){
00583                     IOErrorHandler(EMAT);
00584                   }
00585                 // checking if & inserted at the end of the material by mistake
00586                 if (j == m_nAssemblyMat){
00587                     std::string dummy = "";
00588                     szFormatString >> dummy;
00589                     if (strcmp (dummy.c_str(), "") != 0)
00590                       IOErrorHandler(EMAT);
00591                   }
00592               }
00593           }
00594         // Read material data
00595         if (szInputString.substr(0,11) == "blmaterials"){
00596
00597             std::istringstream szFormatString (szInputString);
00598             szFormatString >> card >> m_nBLAssemblyMat;
00599             if(szFormatString.fail())
00600               IOErrorHandler(INVALIDINPUT);
00601             m_szBLAssmMat.SetSize(m_nBLAssemblyMat); m_dBLMatBias.SetSize(m_nBLAssemblyMat);
00602             m_nBLMatIntervals.SetSize(m_nBLAssemblyMat);
00603             for (int j=1; j<=m_nBLAssemblyMat; j++){
00604                 szFormatString >> m_szBLAssmMat(j) >> m_dBLMatBias(j) >> m_nBLMatIntervals(j);
00605                 if( (strcmp (m_szBLAssmMat(j).c_str(), "") == 0) ||
00606                     (m_nBLMatIntervals(j) < 0) ){
00607                     IOErrorHandler(EMAT);
00608                   }
00609                 // checking if & inserted at the end of the material by mistake
00610                 if (j == m_nBLAssemblyMat){
00611                     std::string dummy = "";
00612                     szFormatString >> dummy;
00613                     if (strcmp (dummy.c_str(), "") != 0)
00614                       IOErrorHandler(EMAT);
00615                   }
00616               }
00617           }
00618
00619         // start id for pin number
00620         if (szInputString.substr(0, 10) == "startpinid") {
00621             std::istringstream szFormatString(szInputString);
00622             szFormatString >> card >> m_nStartpinid;
00623           }
00624         if (szInputString.substr(0,8) == "meshtype"){
00625             std::istringstream szFormatString (szInputString);
00626             szFormatString >> card >> m_szMeshType;
00627             if( ((strcmp (m_szMeshType.c_str(), "hex") != 0) &&
00628                  (strcmp (m_szMeshType.c_str(), "tet") != 0)) || szFormatString.fail())
00629               IOErrorHandler(INVALIDINPUT);
00630           }
00631         if (szInputString.substr(0,4) == "duct" || szInputString.substr(0,10) == "dimensions"){
00632             ++m_nDuct;
00633           }
00634         if (szInputString.substr(0,8) == "pincells"){
00635             std::istringstream szFormatString (szInputString);
00636             szFormatString >> card >> m_nPincells;
00637             if(m_nPincells>0)
00638               m_Pincell.SetSize(m_nPincells);
00639             else if(m_nPincells ==0)
00640               m_Pincell.SetSize(1); // assume for using dummy pincell
00641
00642             // count the number of cylinder lines for each pincell
00643             for (int i=1; i<=m_nPincells; i++){
00644                 // read the no. of input lines first pincell
00645                 if (!Parse.ReadNextLine (m_FileInput, m_nLineNumber, szInputString,
00646                                          MAXCHARS, szComment))
00647                   IOErrorHandler (INVALIDINPUT);
00648                 std::istringstream szFormatString1 (szInputString);
00649                 szFormatString1 >> szVolId >> szVolAlias >> nInputLines;
00650                 if(szFormatString1.fail())
00651                   IOErrorHandler(INVALIDINPUT);
00652                 // loop thru the input lines of each pincell
00653                 for(int l=1; l<=nInputLines; l++){
00654                     if (!Parse.ReadNextLine (m_FileInput, m_nLineNumber, szInputString,
00655                                              MAXCHARS, szComment))
00656                       IOErrorHandler (INVALIDINPUT);
00657                     if (szInputString.substr(0,8) == "cylinder" || szInputString.substr(0,7) == "frustum"){
00658                         ++nCyl;
00659                       }
00660                     if (szInputString.substr(0,12) == "cellmaterial"){
00661                         ++nCellMat;
00662                       }
00663                   }
00664
00665                 // set the sizes
00666                 if(nCyl>0){
00667                     if  (nCellMat!=0){
00668                         m_Pincell(i).SetCellMatSize(nCyl);
00669                       }
00670                     m_Pincell(i).SetNumCyl(nCyl);
00671                   }
00672                 else if(nCyl ==0){
00673                     if(nInputLines >0)
00674                       m_Pincell(i).SetCellMatSize(nCellMat);
00675                   }
00676                 nCyl = 0;
00677                 nCellMat = 0;
00678               }
00679           }
00680         // info flag
00681         if (szInputString.substr(0,4) == "info"){
00682             std::istringstream szFormatString (szInputString);
00683             szFormatString >> card >> m_szInfo;
00684             std::cout <<"--------------------------------------------------"<<std::endl;
00685           }
00686         // merge
00687         if (szInputString.substr(0,7) == "imprint"){
00688             m_bimprint = true;
00689             std::cout <<"--------------------------------------------------"<<std::endl;
00690           }
00691         // imprint
00692         if (szInputString.substr(0,5) == "merge"){
00693             m_bmerge = true;
00694             std::cout <<"--------------------------------------------------"<<std::endl;
00695           }
00696         // info flag
00697         if (szInputString.substr(0,6) == "smooth"){
00698             std::istringstream szFormatString (szInputString);
00699             szFormatString >> card >> m_szSmooth;
00700             std::cout <<"--------------------------------------------------"<<std::endl;
00701           }
00702         // mesh scheme - hole or pave
00703         if (szInputString.substr(0, 10) == "meshscheme") {
00704             std::istringstream szFormatString(szInputString);
00705             szFormatString >> card >> m_szMeshScheme;
00706           }
00707         // hex block along z
00708         if (szInputString.substr(0,6) == "hblock"){
00709             std::istringstream szFormatString (szInputString);
00710             szFormatString >> card >> m_nHblock >> m_dZstart >> m_dZend;
00711             std::cout <<"--------------------------------------------------"<<std::endl;
00712           }
00713         // breaking condition
00714         if(szInputString.substr(0,3) == "end" || m_nLineNumber == MAXLINES){
00715             break;
00716           }
00717       }
00718
00719     if(strcmp(m_szInfo.c_str(),"on") == 0){
00720         std::cout  << m_szAssmInfo <<std::endl;
00721         do{
00722             m_AssmInfo.open (m_szAssmInfo.c_str(), std::ios::out);
00723             if (!m_AssmInfo){
00724                 std::cout << "Unable to open o/p file: " << m_szAssmInfo << std::endl;
00725                 m_AssmInfo.clear ();
00726                 exit(1);
00727               }
00728             else
00729               bDone = true; // file opened successfully
00730           } while (!bDone);
00731
00732         // write header for info file
00733         m_AssmInfo <<"pincell"<<  " \t" <<
00734                      "m" << " \t" << "n" << " \t" << "dX" << " \t" <<
00735                      "dY" << " \t" << "dZ"  << std::endl;
00736       }
00737     // set the size of cp_inpins matrix
00738     //  cp_inpins.resize(m_nDuct);
00739     for (int j=0; j<m_nDuct ; j++)
00740       cp_inpins.push_back(std::vector<iBase_EntityHandle>());
00741
00742   }
00743
00744   void AssyGen::ReadPinCellData (int i)
00745   //---------------------------------------------------------------------------
00746   //Function: reading pincell i from file and storing the data
00747   //Input:    none
00748   //Output:   none
00749   //---------------------------------------------------------------------------
00750   {
00751     CParser Parse;
00752     std::string card, szVolId, szVolAlias, szIFlag;
00753     int nInputLines, nMaterials, nCyl = 0, nRadii=0, nCellMat=0;
00754     double dLZ=0.0, dFlatF=0.0, dPX=0.0, dPY=0.0, dPZ=0.0;
00755     CVector <std::string> szVMatName, szVMatAlias, szVCylMat, szVCellMat;
00756     CVector<double> dVCoor(2), dVCylRadii, dVCylZPos, dZVStart, dZVEnd;
00757
00758     //loop over input lines
00759     if (m_szGeomType == "rectangular"){
00760
00761         std::cout << "\ngetting volume id";
00762         if (!Parse.ReadNextLine (m_FileInput, m_nLineNumber, szInputString,
00763                                  MAXCHARS, szComment))
00764           IOErrorHandler (INVALIDINPUT);
00765         std::istringstream szFormatString (szInputString);
00766         szFormatString >> szVolId >> szVolAlias >> nInputLines >> szIFlag;
00767
00768         // error checking
00769         if( (strcmp (szVolAlias.c_str(), "") == 0) ||
00770             (strcmp (szVolId.c_str(), "") == 0))
00771           IOErrorHandler(EPIN);
00772         if( nInputLines < 0 )
00773           IOErrorHandler(ENEGATIVE);
00774
00775         m_Pincell(i).SetLineOne (szVolId, szVolAlias, nInputLines);
00776         if(szIFlag == "intersect"){
00777             m_Pincell(i).SetIntersectFlag(1);
00778           }
00779         else{
00780             m_Pincell(i).SetIntersectFlag(0);
00781           }
00782         for(int l=1; l<=nInputLines; l++){
00783             if (!Parse.ReadNextLine (m_FileInput, m_nLineNumber, szInputString,
00784                                      MAXCHARS, szComment))
00785               IOErrorHandler (INVALIDINPUT);
00786             if (szInputString.substr(0,5) == "pitch"){
00787
00788                 std::istringstream szFormatString (szInputString);
00789                 std::cout << "\ngetting pitch data";
00790                 szFormatString >> card >> dPX >> dPY >> dPZ;
00791
00792                 if( dPX < 0 || dPY < 0 || dPZ < 0 || szFormatString.fail())
00793                   IOErrorHandler(ENEGATIVE);
00794                 m_Pincell(i).SetPitch (dPX, dPY, dPZ);
00795               }
00796             if (szInputString.substr(0,9) == "materials"){
00797
00798                 std::istringstream szFormatString (szInputString);
00799                 szFormatString >> card >> nMaterials;
00800                 if(szFormatString.fail())
00801                   IOErrorHandler(INVALIDINPUT);
00802
00803                 //setting local arrays
00804                 szVMatName.SetSize(nMaterials);
00805                 szVMatAlias.SetSize(nMaterials);
00806
00807                 //set class variable sizes
00808                 m_Pincell(i).SetMatArray(nMaterials);
00809                 std::cout << "\ngetting material data";
00810                 for(int j=1; j<= nMaterials; j++){
00811                     szFormatString >> szVMatName(j) >> szVMatAlias(j);
00812                     if(szFormatString.fail())
00813                       IOErrorHandler(INVALIDINPUT);
00814                   }
00815                 m_Pincell(i).SetMat(szVMatName, szVMatAlias);
00816               }
00817             if (szInputString.substr(0,8) == "cylinder"){
00818
00819                 ++nCyl;
00820                 std::cout << "\ngetting cylinder data";
00821                 std::istringstream szFormatString (szInputString);
00822                 szFormatString >> card >> nRadii >> dVCoor(1) >> dVCoor(2);
00823                 if(szFormatString.fail())
00824                   IOErrorHandler(INVALIDINPUT);
00825                 m_Pincell(i).SetCylSizes(nCyl, nRadii);
00826                 m_Pincell(i).SetCylPos(nCyl, dVCoor);
00827                 m_Pincell(i).SetCellType(nCyl, 0);
00828
00829                 //set local array
00830                 dVCylRadii.SetSize(2*nRadii);
00831                 szVCylMat.SetSize(nRadii);
00832                 dVCylZPos.SetSize(2);
00833                 m_Pincell(i).SetCylSizes(nCyl, nRadii);
00834
00835                 // reading ZCoords
00836                 for(int k=1; k<=2; k++){
00837                     szFormatString >> dVCylZPos(k);
00838                     if(szFormatString.fail())
00839                       IOErrorHandler(INVALIDINPUT);
00840                   }
00841                 m_Pincell(i).SetCylZPos(nCyl, dVCylZPos);
00842
00843                 // reading Radii
00844                 for(int l=1; l<= nRadii; l++){
00845                     szFormatString >> dVCylRadii(l);
00846                     if( dVCylRadii(l) < 0  || szFormatString.fail())
00847                       IOErrorHandler(ENEGATIVE);
00848                   }
00849                 m_Pincell(i).SetCylRadii(nCyl, dVCylRadii);
00850
00851                 // reading Material alias
00852                 for(int m=1; m<= nRadii; m++){
00853                     szFormatString >> szVCylMat(m);
00854                     if(strcmp (szVCylMat(m).c_str(), "") == 0 || szFormatString.fail())
00855                       IOErrorHandler(EALIAS);
00856                     // setting stuff for hole scheme determination for meshing
00857                     if (m > 1 && m_szMeshScheme == "hole" && m_nBLAssemblyMat == 0){
00858                         // find material name for this alias
00859                         for (int ll=1; ll<= m_nAssemblyMat; ll++){
00860                             if(szVCylMat(m) == m_szAssmMatAlias(ll)){
00861
00862 #ifdef HAVE_RGG16
00863                                 m_FileOutput << "group 'hole_surfaces' add surface with name '"<< m_szAssmMat(ll)  << "_top*'" << std::endl;
00864 #else
00865                                 m_FileOutput << "group 'hole_surfaces' add surface with name '"<< m_szAssmMat(ll)  << "_top'" << std::endl;
00866 #endif
00867                               }
00868                           }
00869                       }
00870                     m_Pincell(i).SetCylMat(nCyl, szVCylMat);
00871                   }
00872               }
00873             if (szInputString.substr(0,7) == "frustum"){
00874
00875                 ++nCyl;
00876                 std::cout << "\ngetting frustum data";
00877                 std::istringstream szFormatString (szInputString);
00878                 szFormatString >> card >> nRadii >> dVCoor(1) >> dVCoor(2);
00879                 if(szFormatString.fail())
00880                   IOErrorHandler(INVALIDINPUT);
00881                 m_Pincell(i).SetCylSizes(nCyl, nRadii);
00882                 m_Pincell(i).SetCylPos(nCyl, dVCoor);
00883                 m_Pincell(i).SetCellType(nCyl, 1);
00884
00885                 //set local array
00886                 dVCylRadii.SetSize(2*nRadii);
00887                 szVCylMat.SetSize(nRadii);
00888                 dVCylZPos.SetSize(2);
00889                 m_Pincell(i).SetCylSizes(nCyl, nRadii);
00890
00891                 // reading ZCoords
00892                 for(int k=1; k<=2; k++){
00893                     szFormatString >> dVCylZPos(k);
00894                     if(szFormatString.fail())
00895                       IOErrorHandler(INVALIDINPUT);
00896                   }
00897                 m_Pincell(i).SetCylZPos(nCyl, dVCylZPos);
00898
00899                 // reading Radii
00900                 for(int l=1; l<= 2*nRadii; l++){
00901                     szFormatString >> dVCylRadii(l);
00902                     if( dVCylRadii(l) < 0  || szFormatString.fail())
00903                       IOErrorHandler(ENEGATIVE);
00904                   }
00905                 m_Pincell(i).SetCylRadii(nCyl, dVCylRadii);
00906
00907                 // reading Material alias
00908                 for(int m=1; m<= nRadii; m++){
00909                     szFormatString >> szVCylMat(m);
00910                     if(strcmp (szVCylMat(m).c_str(), "") == 0 || szFormatString.fail())
00911                       IOErrorHandler(EALIAS);
00912                     // setting stuff for hole scheme determination for meshing
00913                     if (m > 2 && m_szMeshScheme == "hole"){
00914                         // find material name for this alias
00915                         for (int ll=1; ll<= m_nAssemblyMat; ll++){
00916                             if(szVCylMat(m) == m_szAssmMatAlias(ll)){
00917 #ifdef HAVE_RGG16
00918                                 m_FileOutput << "group 'hole_surfaces' add surface with name '"<< m_szAssmMat(ll)  << "_top*'" << std::endl;
00919 #else
00920                                 m_FileOutput << "group 'hole_surfaces' add surface with name '"<< m_szAssmMat(ll)  << "_top'" << std::endl;
00921 #endif
00922                               }
00923                           }
00924                       }
00925                   }
00926                 m_Pincell(i).SetCylMat(nCyl, szVCylMat);
00927               }
00928             if (szInputString.substr(0,12) == "cellmaterial"){
00929
00930                 std::cout << "\ngetting cell material data\n";
00931                 std::istringstream szFormatString (szInputString);
00932                 szFormatString >> card;
00933
00934                 //set local arrays
00935                 m_Pincell(i).GetCellMatSize(nCellMat); // since size of cell material already set equal to number of cylinders
00936                 dZVStart.SetSize(nCellMat);
00937                 dZVEnd.SetSize(nCellMat);
00938                 szVCellMat.SetSize(nCellMat);
00939
00940                 for(int k=1; k<=nCellMat; k++){
00941                     szFormatString >> dZVStart(k)>> dZVEnd(k) >> szVCellMat(k);
00942                     if(strcmp (szVCellMat(k).c_str(), "") == 0 || szFormatString.fail())
00943                       IOErrorHandler(EALIAS);
00944                   }
00945                 m_Pincell(i).SetCellMat(dZVStart, dZVEnd, szVCellMat);
00946               }
00947           }
00948       }//if rectangular ends
00949
00950     if (m_szGeomType == "hexagonal"){
00951
00952         std::cout << "\ngetting volume id";
00953         if (!Parse.ReadNextLine (m_FileInput, m_nLineNumber, szInputString,
00954                                  MAXCHARS, szComment))
00955           IOErrorHandler (INVALIDINPUT);
00956         std::istringstream szFormatString (szInputString);
00957         szFormatString >> szVolId >> szVolAlias >> nInputLines >> szIFlag;
00958
00959         // error checking
00960         if( (strcmp (szVolAlias.c_str(), "") == 0) ||
00961             (strcmp (szVolId.c_str(), "") == 0))
00962           IOErrorHandler(EPIN);
00963         if( nInputLines < 0 )
00964           IOErrorHandler(ENEGATIVE);
00965
00966         m_Pincell(i).SetLineOne (szVolId, szVolAlias, nInputLines);
00967         if(szIFlag == "intersect"){
00968             m_Pincell(i).SetIntersectFlag(1);
00969           }
00970         else{
00971             m_Pincell(i).SetIntersectFlag(0);
00972           }
00973         for(int l=1; l<=nInputLines; l++){
00974             if (!Parse.ReadNextLine (m_FileInput, m_nLineNumber, szInputString,
00975                                      MAXCHARS, szComment))
00976               IOErrorHandler (INVALIDINPUT);
00977             if (szInputString.substr(0,5) == "pitch"){
00978
00979                 std::istringstream szFormatString (szInputString);
00980                 std::cout << "\ngetting pitch data";
00981                 szFormatString >> card >> dFlatF >> dLZ;
00982                 if( dFlatF < 0 || dLZ < 0  || szFormatString.fail())
00983                   IOErrorHandler(ENEGATIVE);
00984                 m_Pincell(i).SetPitch (dFlatF, dLZ);
00985               }
00986             if (szInputString.substr(0,9) == "materials"){
00987
00988                 std::istringstream szFormatString (szInputString);
00989                 szFormatString >> card >> nMaterials;
00990                 if(szFormatString.fail())
00991                   IOErrorHandler(INVALIDINPUT);
00992                 //setting local arrays
00993                 szVMatName.SetSize(nMaterials);
00994                 szVMatAlias.SetSize(nMaterials);
00995
00996                 //set class variable sizes
00997                 m_Pincell(i).SetMatArray(nMaterials);
00998                 std::cout << "\ngetting material data";
00999                 for(int j=1; j<= nMaterials; j++){
01000                     szFormatString >> szVMatName(j) >> szVMatAlias(j);
01001                     if(szFormatString.fail())
01002                       IOErrorHandler(INVALIDINPUT);
01003                   }
01004                 m_Pincell(i).SetMat(szVMatName, szVMatAlias);
01005               }
01006             if (szInputString.substr(0,8) == "cylinder"){
01007
01008                 ++nCyl;
01009                 std::cout << "\ngetting cylinder data";
01010                 std::istringstream szFormatString (szInputString);
01011                 szFormatString >> card >> nRadii >> dVCoor(1) >> dVCoor(2);
01012                 if(szFormatString.fail())
01013                   IOErrorHandler(INVALIDINPUT);
01014                 m_Pincell(i).SetCylSizes(nCyl, nRadii);
01015                 m_Pincell(i).SetCylPos(nCyl, dVCoor);
01016                 m_Pincell(i).SetCellType(nCyl, 0);
01017
01018                 //set local array
01019                 dVCylRadii.SetSize(2*nRadii);
01020                 szVCylMat.SetSize(nRadii);
01021                 dVCylZPos.SetSize(2);
01022                 //
01023                 m_Pincell(i).SetCylSizes(nCyl, nRadii);
01024
01025                 // reading ZCoords - max and min 2 always
01026                 for(int k=1; k<=2; k++)
01027                   szFormatString >> dVCylZPos(k);
01028                 m_Pincell(i).SetCylZPos(nCyl, dVCylZPos);
01029
01030                 // reading Radii
01031                 for(int l=1; l<= nRadii; l++){
01032                     szFormatString >> dVCylRadii(l);
01033                     if( dVCylRadii(l) < 0 || szFormatString.fail())
01034                       IOErrorHandler(ENEGATIVE);
01035                   }
01036                 m_Pincell(i).SetCylRadii(nCyl, dVCylRadii);
01037
01038                 // reading Material alias
01039                 for(int m=1; m<= nRadii; m++){
01040                     szFormatString >> szVCylMat(m);
01041                     if(strcmp (szVCylMat(m).c_str(), "") == 0 || szFormatString.fail())
01042                       IOErrorHandler(EALIAS);
01043                     // setting stuff for hole scheme determination for meshing
01044                     if (m > 1 && m_szMeshScheme == "hole" && m_nBLAssemblyMat == 0){
01045                         // find material name for this alias
01046                         for (int ll=1; ll<= m_nAssemblyMat; ll++){
01047                             //   if(szVCylMat(m) == m_szAssmMatAlias(ll))
01048                             if(strcmp (m_szAssmMatAlias(ll).c_str(), szVCylMat(m).c_str()) == 0){
01049 #ifdef HAVE_RGG16
01050                                 m_FileOutput << "group 'hole_surfaces' add surface with name '"<< m_szAssmMat(ll)  << "_top*'" << std::endl;
01051 #else
01052                                 m_FileOutput << "group 'hole_surfaces' add surface with name '"<< m_szAssmMat(ll)  << "_top'" << std::endl;
01053 #endif
01054                               }
01055                           }
01056                       }
01057                   }
01058
01059                 m_Pincell(i).SetCylMat(nCyl, szVCylMat);
01060               }
01061             if (szInputString.substr(0,7) == "frustum"){
01062
01063                 ++nCyl;
01064                 std::cout << "\ngetting frustum data";
01065                 std::istringstream szFormatString (szInputString);
01066                 szFormatString >> card >> nRadii >> dVCoor(1) >> dVCoor(2);
01067                 if(szFormatString.fail())
01068                   IOErrorHandler(INVALIDINPUT);
01069                 m_Pincell(i).SetCylSizes(nCyl, nRadii);
01070                 m_Pincell(i).SetCylPos(nCyl, dVCoor);
01071                 m_Pincell(i).SetCellType(nCyl, 1);
01072
01073                 //set local array
01074                 dVCylRadii.SetSize(2*nRadii);
01075                 szVCylMat.SetSize(nRadii);
01076                 dVCylZPos.SetSize(2);
01077                 m_Pincell(i).SetCylSizes(nCyl, nRadii);
01078
01079                 // reading ZCoords
01080                 for(int k=1; k<=2; k++){
01081                     szFormatString >> dVCylZPos(k);
01082                     if(szFormatString.fail())
01083                       IOErrorHandler(INVALIDINPUT);
01084                   }
01085                 m_Pincell(i).SetCylZPos(nCyl, dVCylZPos);
01086
01087                 // reading Radii
01088                 for(int l=1; l<= 2*nRadii; l++){
01089                     szFormatString >> dVCylRadii(l);
01090                     if( dVCylRadii(l) < 0  || szFormatString.fail())
01091                       IOErrorHandler(ENEGATIVE);
01092                   }
01093                 m_Pincell(i).SetCylRadii(nCyl, dVCylRadii);
01094
01095                 // reading Material alias
01096                 for(int m=1; m<= nRadii; m++){
01097                     szFormatString >> szVCylMat(m);
01098                     if(strcmp (szVCylMat(m).c_str(), "") == 0 || szFormatString.fail())
01099                       IOErrorHandler(EALIAS);
01100                     // setting stuff for hole scheme determination for meshing
01101                     if (m > 2 && m_szMeshScheme == "hole"){
01102                         // find material name for this alias
01103                         for (int ll=1; ll<= m_nAssemblyMat; ll++){
01104                             if(szVCylMat(m) == m_szAssmMatAlias(ll)){
01105 #ifdef HAVE_RGG16
01106                                 m_FileOutput << "group 'hole_surfaces' add surface with name '"<< m_szAssmMat(ll)  << "_top*'" << std::endl;
01107 #else
01108                                 m_FileOutput << "group 'hole_surfaces' add surface with name '"<< m_szAssmMat(ll)  << "_top'" << std::endl;
01109 #endif
01110                               }
01111                           }
01112                       }
01113                   }
01114                 m_Pincell(i).SetCylMat(nCyl, szVCylMat);
01115               }
01116             if (szInputString.substr(0,12) == "cellmaterial"){
01117
01118                 std::cout << "\ngetting cell material data";
01119                 std::istringstream szFormatString (szInputString);
01120                 szFormatString >> card;
01121
01122                 //set local arrays
01123                 m_Pincell(i).GetCellMatSize(nCellMat); // since size of cell material already set equal to number of cylinders
01124                 dZVStart.SetSize(nCellMat);
01125                 dZVEnd.SetSize(nCellMat);
01126                 szVCellMat.SetSize(nCellMat);
01127
01128                 for(int k=1; k<=nCellMat; k++){
01129                     szFormatString >> dZVStart(k)>> dZVEnd(k) >> szVCellMat(k);
01130                     if(strcmp (szVCellMat(k).c_str(), "") == 0 || szFormatString.fail())
01131                       IOErrorHandler(EALIAS);
01132                   }
01133                 m_Pincell(i).SetCellMat(dZVStart, dZVEnd, szVCellMat);
01134               }
01135           }
01136       }// if hexagonal end
01137
01138   }
01139
01140
01141   void AssyGen::ReadAndCreate()
01142   //---------------------------------------------------------------------------
01143   //Function: reads the input file and creates assembly
01144   //Input:    none
01145   //Output:   none
01146   //---------------------------------------------------------------------------
01147   {
01148     //Rewind the input file
01149     m_FileInput.clear (std::ios_base::goodbit);
01150     m_FileInput.seekg (0L, std::ios::beg);
01151     m_nLineNumber = 0;
01152     CParser Parse;
01153     std::string card;
01154
01155     // start reading the input file break when encounter end
01156     for(;;){
01157         if (!Parse.ReadNextLine (m_FileInput, m_nLineNumber, szInputString,
01158                                  MAXCHARS, szComment))
01159           IOErrorHandler (INVALIDINPUT);
01160         if (szInputString.substr(0,12) == "geometrytype"){
01161             std::istringstream szFormatString (szInputString);
01162             szFormatString >> card >> m_szGeomType;
01163             if( ((strcmp (m_szGeomType.c_str(), "hexagonal") != 0) &&
01164                  (strcmp (m_szGeomType.c_str(), "rectangular") != 0)) || szFormatString.fail())
01165               IOErrorHandler(EGEOMTYPE);
01166
01167             // set the number of sides in the geometry
01168             if(m_szGeomType == "hexagonal")
01169               m_nSides = 6;
01170             else  if(m_szGeomType == "rectangular")
01171               m_nSides = 4;
01172           }
01173
01174         if (szInputString.substr(0,8) == "geometry"){
01175             std::string outfile;
01176             std::istringstream szFormatString (szInputString);
01177             szFormatString >> card >> outfile;
01178             if(strcmp (outfile.c_str(), "surface") == 0 || szFormatString.fail())
01179               m_nPlanar=1;
01180           }
01181         if( (szInputString.substr(0,10) == "dimensions") ||
01182             (szInputString.substr(0,4) == "duct") ){
01183
01184             ++m_nDuctNum;
01185             std::cout << "getting assembly dimensions " << m_nDuctNum << std::endl;
01186
01187             if(m_szGeomType =="hexagonal"){
01188                 std::istringstream szFormatString (szInputString);
01189
01190                 if(m_nDuctNum == 1){
01191                     m_dMXYAssm.SetSize(m_nDuct, 2); m_dMZAssm.SetSize(m_nDuct, 2);
01192                   }
01193                 szFormatString >> card >> m_nDimensions
01194                     >> m_dMXYAssm(m_nDuctNum, 1) >> m_dMXYAssm(m_nDuctNum, 2)
01195                                                  >> m_dMZAssm(m_nDuctNum, 1) >> m_dMZAssm(m_nDuctNum, 2);
01196                 if(m_nDuctNum == 1){
01197                     m_dMAssmPitch.SetSize(m_nDuct, m_nDimensions); m_szMMAlias.SetSize(m_nDuct, m_nDimensions);
01198
01199                     assms.resize(m_nDimensions*m_nDuct); // setup while reading the problem size
01200                     // Declaration for python script
01201                     m_PyCubGeomFile << "assms = range(" << m_nDimensions*m_nDuct << ")\ncp_inpins  = []\n" << std::endl;
01202                   }
01203
01204                 for (int i=1; i<=m_nDimensions; i++){
01205                     szFormatString >> m_dMAssmPitch(m_nDuctNum, i);
01206                     if( m_dMAssmPitch(m_nDuctNum, i) < 0 )
01207                       IOErrorHandler(ENEGATIVE);
01208                   }
01209
01210                 for (int i=1; i<=m_nDimensions; i++){
01211                     szFormatString >> m_szMMAlias(m_nDuctNum, i);
01212                     if(strcmp (m_szMMAlias(m_nDuctNum, i).c_str(), "") == 0)
01213                       IOErrorHandler(EALIAS);
01214                     m_szDuctMats.push_back(m_szMMAlias(m_nDuctNum, i));
01215                     // this is the innermost duct add to group for journaling later
01216                     if (i==1){
01217                         // find material name for this alias
01218                         for (int ll=1; ll<= m_nAssemblyMat; ll++){
01219                             //   if(szVCylMat(m) == m_szAssmMatAlias(ll))
01220                             if(strcmp (m_szAssmMatAlias(ll).c_str(),  m_szMMAlias(m_nDuctNum, i).c_str()) == 0){
01221 #ifdef HAVE_RGG16
01222                                 m_FileOutput << "group 'innerduct' add surface with name '"<< m_szAssmMat(ll)  << "_top*'" << std::endl;
01223 #else
01224                                 m_FileOutput << "group 'innerduct' add surface with name '"<< m_szAssmMat(ll)  << "_top'" << std::endl;
01225 #endif
01226                               }
01227                           }
01228                       }
01229                     // setting stuff for hole scheme determination for meshing
01230                     if (i > 1 && m_szMeshScheme == "hole"){
01231                         // find material name for this alias
01232                         for (int ll=1; ll<= m_nAssemblyMat; ll++){
01233                             //   if(szVCylMat(m) == m_szAssmMatAlias(ll))
01234                             if(strcmp (m_szAssmMatAlias(ll).c_str(),  m_szMMAlias(m_nDuctNum, i).c_str()) == 0)
01235 #ifdef HAVE_RGG16
01236                               m_FileOutput << "group 'hole_surfaces' add surface with name '"<< m_szAssmMat(ll)  << "_top*'" << std::endl;
01237 #else
01238                               m_FileOutput << "group 'hole_surfaces' add surface with name '"<< m_szAssmMat(ll)  << "_top'" << std::endl;
01239 #endif
01240                           }
01241                       }
01242                   }
01243               }
01244             if(m_szGeomType =="rectangular"){
01245                 std::istringstream szFormatString (szInputString);
01246                 if(m_nDuctNum == 1){
01247                     m_dMXYAssm.SetSize(m_nDuct, 2);
01248                     m_dMZAssm.SetSize(m_nDuct, 2);
01249                   }
01250                 szFormatString >> card >> m_nDimensions
01251                     >> m_dMXYAssm(m_nDuctNum, 1) >> m_dMXYAssm(m_nDuctNum, 2)
01252                                                  >> m_dMZAssm(m_nDuctNum, 1) >> m_dMZAssm(m_nDuctNum, 2);
01253                 if (szFormatString.fail())
01254                   IOErrorHandler(INVALIDINPUT);
01255                 if(m_nDuctNum == 1){
01256                     m_dMAssmPitchX.SetSize(m_nDuct, m_nDimensions);
01257                     m_dMAssmPitchY.SetSize(m_nDuct, m_nDimensions);
01258                     m_szMMAlias.SetSize(m_nDuct, m_nDimensions);
01259                     assms.resize(m_nDimensions*m_nDuct);
01260                     // Declaration for python script
01261                     m_PyCubGeomFile << "assms = range(" << m_nDimensions*m_nDuct << ")\ncp_inpins  = []\n" << std::endl;
01262                   }
01263                 for (int i=1; i<=m_nDimensions; i++){
01264                     szFormatString >> m_dMAssmPitchX(m_nDuctNum, i) >> m_dMAssmPitchY(m_nDuctNum, i);
01265                     if( m_dMAssmPitchX(m_nDuctNum, i) < 0 || m_dMAssmPitchY(m_nDuctNum, i) < 0 || szFormatString.fail())
01266                       IOErrorHandler(ENEGATIVE);
01267                   }
01268
01269                 for (int i=1; i<=m_nDimensions; i++){
01270                     szFormatString >> m_szMMAlias(m_nDuctNum, i);
01271                     if(strcmp (m_szMMAlias(m_nDuctNum, i).c_str(), "") == 0 || szFormatString.fail())
01272                       IOErrorHandler(EALIAS);
01273                     m_szDuctMats.push_back(m_szMMAlias(m_nDuctNum, i));
01274                     // this is the innermost duct
01275                     if (i==1){
01276                         // find material name for this alias
01277                         for (int ll=1; ll<= m_nAssemblyMat; ll++){
01278                             //   if(szVCylMat(m) == m_szAssmMatAlias(ll))
01279                             if(strcmp (m_szAssmMatAlias(ll).c_str(),  m_szMMAlias(m_nDuctNum, i).c_str()) == 0){
01280 #ifdef HAVE_RGG16
01281                                 m_FileOutput << "group 'innerduct' add surface with name '"<< m_szAssmMat(ll)  << "_top*'" << std::endl;
01282 #else
01283                                 m_FileOutput << "group 'innerduct' add surface with name '"<< m_szAssmMat(ll)  << "_top'" << std::endl;
01284 #endif
01285                               }
01286                           }
01287                       }
01288                     // setting stuff for hole scheme determination for meshing
01289                     if (i > 1 && m_szMeshScheme == "hole"){
01290                         // find material name for this alias
01291                         for (int ll=1; ll<= m_nAssemblyMat; ll++){
01292                             //   if(szVCylMat(m) == m_szAssmMatAlias(ll))
01293                             if(strcmp (m_szAssmMatAlias(ll).c_str(),  m_szMMAlias(m_nDuctNum, i).c_str()) == 0){
01294 #ifdef HAVE_RGG16
01295                                 m_FileOutput << "group 'hole_surfaces' add surface with name '"<< m_szAssmMat(ll)  << "_top*'" << std::endl;
01296 #else
01297                                 m_FileOutput << "group 'hole_surfaces' add surface with name '"<< m_szAssmMat(ll)  << "_top'" << std::endl;
01298 #endif
01299                               }
01300                           }
01301                       }
01302                   }
01303               }
01304           }
01305         if (szInputString.substr(0,8) == "pincells"){
01306             std::istringstream szFormatString (szInputString);
01307
01308             szFormatString >> card >> m_nPincells >> m_dPitch;
01309             if(m_nPincells < 0)
01310               IOErrorHandler(ENEGATIVE);
01311
01312             // this is an option if a user wants to specify pitch here
01313             double dTotalHeight = 0.0;
01314
01315             //get the number of cylinder in each pincell
01316             int nTemp = 1;
01317             if(m_nDimensions > 0){
01318                 dTotalHeight = m_dMZAssm(nTemp, 2)-m_dMZAssm(nTemp, 1);
01319               }
01320             else{
01321                 dTotalHeight = 0; // nothing specified only pincells in the model
01322               }
01323
01324             // loop thro' the pincells and read/store pincell data
01325             for (int i=1; i<=m_nPincells; i++){
01326
01327                 // set pitch if specified in pincell card
01328                 if(m_dPitch > 0.0)
01329                   m_Pincell(i).SetPitch(m_dPitch, dTotalHeight);
01330
01331                 ReadPinCellData(i);
01332                 //ERRORR("Error in ReadPinCellData", err);
01333                 std::cout << "\nread pincell " << i << std::endl;
01334               }
01335           }
01336         if (szInputString.substr(0,8) == "assembly"){
01337             if(m_szGeomType =="hexagonal"){
01338                 Create_HexAssm(szInputString);
01339                 //ERRORR("Error in Create_HexAssm", err);
01340               }
01341             if(m_szGeomType =="rectangular"){
01342                 Create_CartAssm(szInputString);
01343                 //ERRORR("Error in Create_CartAssm", err);
01344               }
01345             if (m_nJouFlag == 0){
01346                 CreateOuterCovering();
01347                 //ERRORR("Error in CreateOuterCovering", err);
01348
01349                 // subtract pins before save
01350                 if(m_nDuct > 0){
01351                     Subtract_Pins();
01352                     clock_t s_subtract = clock();
01353                     std::cout << "## Subract Pins CPU time used := " << (double) (clock() - s_subtract)/CLOCKS_PER_SEC
01354                               << " seconds" << std::endl;
01355                   }
01356               }
01357           }
01358
01359         // section the assembly as described in section card
01360         if (szInputString.substr(0,7) == "section" && m_nJouFlag == 0){
01361             std::cout << "Sectioning geometry .." << std::endl;
01362             char cDir;
01363             double dOffset;
01364             std::string szReverse = "";
01365             std::istringstream szFormatString (szInputString);
01366             szFormatString >> card >> cDir >> dOffset >> szReverse;
01367             Section_Assm(cDir, dOffset, szReverse);
01368             m_PyCubGeomFile << "section_assm(\"" << cDir << "\", " << dOffset << ", \"" << szReverse << "\")" << std::endl;
01369             //ERRORR("Error in Section_Assm", err);
01370             std::cout <<"--------------------------------------------------"<<std::endl;
01371
01372           }
01373         if (szInputString.substr(0,4) == "move" && m_nJouFlag == 0){
01374             std::cout << "Moving geometry .." << std::endl;
01375             double dX, dY, dZ;
01376             std::istringstream szFormatString (szInputString);
01377             szFormatString >> card >> dX >> dY >> dZ;
01378             if(szFormatString.fail())
01379               IOErrorHandler(INVALIDINPUT);
01380             Move_Assm(dX, dY, dZ);
01381             //ERRORR("Error in Move_Assm", err);
01382             std::cout <<"--------------------------------------------------"<<std::endl;
01383
01384           }
01385         // center the assembly
01386         if (szInputString.substr(0,6) == "center" && m_nJouFlag == 0){
01387
01388             char rDir = 'q';
01389             std::istringstream szFormatString (szInputString);
01390             szFormatString >> card >> rDir;
01391             if (rDir != 'q')
01392               std::cout << "Positioning assembly to "<< rDir << " center" << std::endl;
01393             else
01394               std::cout << "Positioning assembly to xy center" << std::endl;
01395             Center_Assm(rDir);
01396             //ERRORR("Error in Center_Assm", err);
01397             std::cout <<"--------------------------------------------------"<<std::endl;
01398           }
01399         // rotate the assembly if rotate card is specified
01400         if (szInputString.substr(0,6) == "rotate" && m_nJouFlag == 0){
01401             char cDir;
01402             double dAngle;
01403             std::cout << "Rotating geometry .." << std::endl;
01404             std::istringstream szFormatString (szInputString);
01405             szFormatString >> card >> cDir >> dAngle;
01406             if(szFormatString.fail())
01407               IOErrorHandler(INVALIDINPUT);
01408             Rotate_Assm(cDir, dAngle);
01409             //ERRORR("Error in Rotate_Assm", err);
01410             std::cout <<"--------------------------------------------------"<<std::endl;
01411
01412           }
01413         // 'yes' or 'no' for creating sidesets
01414         if (szInputString.substr(0,13) == "createsideset"){
01415             std::istringstream szFormatString (szInputString);
01416             szFormatString >> card >> m_szSideset;
01417             std::cout <<"--------------------------------------------------"<<std::endl;
01418           }
01419         // Create specified number of files with varying material ids
01420         if (szInputString.substr(0,11) == "createfiles"){
01421             std::istringstream szFormatString (szInputString);
01422             szFormatString >> card >> m_nAssyGenInputFiles;
01423             std::cout <<"--------------------------------------------------"<<std::endl;
01424           }
01425         // Create specified number of files with varying material ids
01426         if (szInputString.substr(0,14) == "creatematfiles"){
01427             m_bCreateMatFiles = true;
01428             std::istringstream szFormatString (szInputString);
01429             szFormatString >> card >> m_nAssyGenInputFiles;
01430             std::cout <<"--------------------------------------------------"<<std::endl;
01431           }
01432         // Create specified number of files with varying material ids
01433         if (szInputString.substr(0,11) == "save_exodus"){
01434             save_exodus = true;
01435             std::cout <<"--------------------------------------------------"<<std::endl;
01436           }
01437         // specify a merge tolerance value for cubit journal file
01438         if (szInputString.substr(0,14) == "mergetolerance"){
01439             std::istringstream szFormatString (szInputString);
01440             szFormatString >> card >> m_dMergeTol;
01441             std::cout <<"--------------------------------------------------"<<std::endl;
01442           }
01443         // Handle mesh size inputs
01444         if (szInputString.substr(0,14) == "radialmeshsize"){
01445             std::istringstream szFormatString (szInputString);
01446             szFormatString >> card >> m_dRadialSize;
01447             if(m_dRadialSize < 0 || szFormatString.fail())
01448               IOErrorHandler(ENEGATIVE);
01449             std::cout <<"--------------------------------------------------"<<std::endl;
01450
01451           }
01452         // Handle mesh size inputs
01453         if (szInputString.substr(0,11) == "tetmeshsize"){
01454             std::istringstream szFormatString (szInputString);
01455             szFormatString >> card >> m_dTetMeshSize;
01456             if(m_dTetMeshSize < 0 || szFormatString.fail())
01457               IOErrorHandler(ENEGATIVE);
01458             std::cout <<"--------------------------------------------------"<<std::endl;
01459
01460           }
01461         // Handle mesh size inputs
01462         if (szInputString.substr(0,13) == "axialmeshsize"){
01463             std::istringstream szFormatString (szInputString);
01464             szFormatString >> card;
01465             if(m_nDuct > 0){
01466                 m_dAxialSize.SetSize(m_nDuct);
01467                 int num_ams_specified = std::distance(std::istream_iterator<std::string>(szFormatString),
01468                                                       std::istream_iterator<std::string>());
01469                 std::istringstream szFormatStringAgain (szInputString);
01470                 szFormatStringAgain >> card;
01471                 for (int p = 1; p <= m_nDuct; p++){
01472                     if(p <= num_ams_specified)
01473                       szFormatStringAgain >> m_dAxialSize(p);
01474                     else
01475                       m_dAxialSize(p) = m_dAxialSize(num_ams_specified);
01476                     if(m_dAxialSize(p) < 0)
01477                       IOErrorHandler(ENEGATIVE);
01478                   }
01479               }
01480             else{
01481                 m_dAxialSize.SetSize(1);
01482                 szFormatString >> m_dAxialSize(1);
01483               }
01484             std::cout <<"--------------------------------------------------"<<std::endl;
01485
01486           }
01487         // edge interval
01488         if (szInputString.substr(0, 12) == "edgeinterval") {
01489             std::istringstream szFormatString(szInputString);
01490             szFormatString >> card >> m_edgeInterval;
01491           }
01492         // Handle mesh size inputs
01493         if (szInputString.substr(0,18) == "neumannset_startid"){
01494             std::istringstream szFormatString (szInputString);
01495             szFormatString >> card >> m_nNeumannSetId;
01496             if(m_nNeumannSetId < 0 || szFormatString.fail())
01497               IOErrorHandler(ENEGATIVE);
01498             std::cout <<"--------------------------------------------------"<<std::endl;
01499
01500           }
01501         // Handle mesh size inputs
01502         if (szInputString.substr(0,19) == "materialset_startid"){
01503             std::istringstream szFormatString (szInputString);
01504             szFormatString >> card >> m_nMaterialSetId;
01505             if(m_nMaterialSetId < 0 || szFormatString.fail())
01506               IOErrorHandler(ENEGATIVE);
01507             std::cout <<"--------------------------------------------------"<<std::endl;
01508
01509           }
01510         if ((szInputString.substr(0,23) == "list_neumannset_startid") ){
01511             std::istringstream szFormatString (szInputString);
01512             int num_nset_ids = 0;
01513             szFormatString >> card >> num_nset_ids;
01514             m_nListNeuSet.SetSize(num_nset_ids);
01515             for (int p = 1; p <= num_nset_ids; p++){
01516                 szFormatString >> m_nListNeuSet(p);
01517                 if(m_nListNeuSet(p) < 0 || szFormatString.fail())
01518                   IOErrorHandler(ENEGATIVE);
01519               }
01520           }
01521         if ((szInputString.substr(0,14) == "numsuperblocks") ){
01522             std::istringstream szFormatString (szInputString);
01523             szFormatString >> card >> m_nSuperBlocks;
01524             sb.SetSize(m_nSuperBlocks);
01525           }
01526         if ((szInputString.substr(0,10) == "superblock") ){
01527             std::istringstream szFormatString (szInputString);
01528             szFormatString >> card >> sb(tmpSB).m_nSuperBlockId  >> sb(tmpSB).m_szSuperBlockAlias >> sb(tmpSB).m_nNumSBContents;
01529             sb(tmpSB).m_nSBContents.SetSize(sb(tmpSB).m_nNumSBContents);
01530             for (int p = 1; p <= sb(tmpSB).m_nNumSBContents; p++){
01531                 szFormatString >> sb(tmpSB).m_nSBContents(p);
01532                 if(sb(tmpSB).m_nSBContents(p) < 0 || szFormatString.fail())
01533                   IOErrorHandler(ENEGATIVE);
01534               }
01535             ++tmpSB;
01536           }
01537         if ((szInputString.substr(0,24) == "list_materialset_startid") ){
01538             std::istringstream szFormatString (szInputString);
01539             int num_mset_ids = 0;
01540             szFormatString >> card >> num_mset_ids;
01541             m_nListMatSet.SetSize(num_mset_ids);
01542             for (int p = 1; p <= num_mset_ids; p++){
01543                 szFormatString >> m_nListMatSet(p);
01544                 if(m_nListMatSet(p) < 0 || szFormatString.fail())
01545                   IOErrorHandler(ENEGATIVE);
01546               }
01547           }
01548         if (szInputString.substr(0,3) == "end" || m_nLineNumber == MAXLINES){
01549             // if this is a surface only case, delete all the volume entities create so far
01550             if(m_nPlanar ==1){
01551                 Create2DSurf();
01552               }
01553             if ( m_nJouFlag == 0){
01554                 // impring merge before saving
01555                 Imprint_Merge(m_bimprint, m_bmerge);
01556
01557                 clock_t s_save= clock();
01558                 // save .sat file
01559 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
01560                 iGeom_save(igeomImpl->instance(), m_szGeomFile.c_str(), NULL, &err, m_szGeomFile.length() , 0);
01561 #endif
01562
01563                 std::cout << "## Saving CPU time used := " << (double) (clock() - s_save)/CLOCKS_PER_SEC
01564                           << " seconds" << std::endl;
01565
01566                 m_PyCubGeomFile << "cubit.cmd('export acis \"" <<m_szGeomFile1 << "\" over')\nexit()" << std::endl;
01567
01568                 std::cout << "Normal Termination.\n"<< "Geometry file: " << m_szGeomFile << " saved." << std::endl;
01569                 //                // Now run the journal file from the python script
01570                 //                m_PyCubGeomFile << "infile = open(\""<< m_szJouFile << "\", \"r\")" << std::endl;
01571                 //                m_PyCubGeomFile << "for line in infile:\n  cubit.cmd(line)" << std::endl;
01572
01573                 // Reloading file to check load times
01574                 bool if_loadagain = false;
01575                 if (if_loadagain == true){
01576                     clock_t s_load= clock();
01577 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
01578                     iGeom_load(igeomImpl->instance(), m_szGeomFile.c_str(), NULL, &err,
01579                                strlen(m_szGeomFile.c_str()), 0);
01580 #endif
01581                     std::cout << "## Load again CPU time used := " << (double) (clock() - s_load)/CLOCKS_PER_SEC
01582                               << " seconds" << std::endl;
01583                   }
01584               }
01585             break;
01586           }
01587       }
01588
01589   }
01590
01591   void AssyGen::CreateAssyGenInputFiles()
01592   //---------------------------------------------------------------------------
01593   //Function: Create Cubit Journal File for generating mesh
01594   //Input:    none
01595   //Output:   none
01596   //---------------------------------------------------------------------------
01597   {
01598     // create file names
01599     std::ostringstream os;
01600     std::string file, temp, temp1;
01601     int counter_ms = 0;
01602     int counter_ns = 0;
01603     for(int i=1; i<=m_nAssyGenInputFiles; i++){
01604         // form the name of the AssyGen input file
01605         if(m_bCreateMatFiles)
01606           os << m_nListMatSet(i) << ".inp";
01607         else
01608           os << m_szFile << i << ".inp";
01609         std::ofstream ofs;
01610         // open input file
01611
01612         std::cout << os.str() << std::endl;
01613         bool bDone = false;
01614         do{
01615             file = os.str();
01616             ofs.open (file.c_str(), std::ios::out);
01617             if(!ofs){
01618                 ofs.clear();
01619                 std::cout << "Unable to open AssyGen Input File(s) for writing" << std::endl;
01620                 exit(1);
01621               }
01622             else {
01623                 bDone = true;
01624                 std::cout << "File Opened" << std::endl;
01625               }
01626             os.str("");
01627
01628             // write the input deck
01629             ofs << "! ## This is an automatically created AssyGen Input File: "<< file << std::endl;
01630             ofs << "MeshType " << m_szMeshType << std::endl;
01631             ofs << "GeomEngine " << m_szEngine << std::endl;
01632             ofs << "GeometryType " << m_szGeomType << std::endl;
01633             ofs << "Materials " << m_nAssemblyMat;
01634
01635             // list all materials and alias with subscripts
01636             for (int j =1;j<=m_nAssemblyMat; j++){
01637                 if(!m_bCreateMatFiles){
01638                     os << m_szAssmMat(j) << "_" << (i-1)*m_nAssemblyMat + j;
01639                     temp = os.str();
01640
01641                     ofs << "  " << temp << " " << m_szAssmMatAlias(j);
01642                     os.str("");
01643                   }
01644                 else{
01645                     ofs << "  " << m_szAssmMat(j) << " " << m_szAssmMatAlias(j);
01646                   }
01647               }
01648             ofs << "\n";
01649
01650             //Rewind the input file
01651             int nDumpAllLinesAfter = 0, nMid = 0;
01652             m_FileInput.clear (std::ios_base::goodbit);
01653             m_FileInput.seekg (0L, std::ios::beg);
01654             m_nLineNumber = 0;
01655             CParser Parse;
01656             std::string card;
01657
01658             // start reading the input file break when encounter end
01659             for(;;){
01660                 if (!Parse.ReadNextLine (m_FileInput, m_nLineNumber, szInputString,
01661                                          MAXCHARS, szComment))
01662                   IOErrorHandler (INVALIDINPUT);
01663                 // dump all the lines after duct command, limiting the format for writing AssyGen Files
01664                 if( (szInputString.substr(0,10) == "dimensions") ||
01665                     (szInputString.substr(0,4) == "duct") ){
01666                     ofs << szInputString << std::endl;
01667                     nDumpAllLinesAfter = m_nLineNumber;
01668                   }
01669                 else if ((szInputString.substr(0,19) == "materialset_startid") ){
01670                     nMid = (i-1)*m_nAssemblyMat + 1;
01671                     ofs << "MaterialSet_StartId " << nMid << std::endl;
01672                   }
01673                 else if ((szInputString.substr(0,18) == "neumannset_startid") ){
01674                     nMid = (i-1)*m_nAssemblyMat + 1;
01675                     ofs << "NeumannSet_StartId " << nMid << std::endl;
01676                   }
01677                 else if ((szInputString.substr(0,24) == "list_materialset_startid") ){
01678                     ++counter_ms;
01679                     ofs << "MaterialSet_StartId " << m_nListMatSet(counter_ms) << std::endl;
01680                   }
01681                 else if ((szInputString.substr(0,23) == "list_neumannset_startid") ){
01682                     ++counter_ns;
01683                     ofs << "NeumannSet_StartId " << m_nListNeuSet(counter_ns) << std::endl;
01684                   }
01685                 else if((szInputString.substr(0,11) == "createfiles")){
01686                     //skip this line
01687                   }
01688                 else if((szInputString.substr(0,14) == "creatematfiles")){
01689                     //skip this line
01690                   }
01691                 else if (nDumpAllLinesAfter > 0 && m_nLineNumber > nDumpAllLinesAfter){
01692                     ofs << szInputString << std::endl;
01693                   }
01694
01695                 if (szInputString.substr(0,3) == "end" || m_nLineNumber == MAXLINES){
01696                     break;
01697                   }
01698               }
01699             ofs.close();
01700           } while(!bDone);
01701       }
01702
01703
01704
01705   }
01706
01707   void AssyGen:: ComputePinCentroid(int nTempPin, CMatrix<std::string> MAssembly,
01708                                     int m, int n, double &dX, double &dY, double &dZ)
01709   // ---------------------------------------------------------------------------
01710   // Function: computes the centroid in the whole assembly of rectangular or hexagonal pincell
01711   // Input:    number and location of the pincell
01712   // Output:   coordinates of pin in assembly
01713   // ---------------------------------------------------------------------------
01714   {
01715     int nTempPin1 = -1, nTempPin2 = 0, nInputLines;
01716     std::string szVolId, szVolAlias;
01717     if(m_szGeomType == "hexagonal"){
01718         double dP, dZ;
01719         m_Pincell(nTempPin).GetPitch(dP, dZ);
01720
01721         if (m < m_nPin){
01722             dX = (m_nPin - n + 1)*dP/2.0 + n*dP/2.0 + (n-1)*dP - (m-1)*dP/2.0;
01723             dY = (m-1)*(0.5*dP/sin(pi/3.0) + 0.5*dP*sin(pi/6.0)/sin(pi/3.0));
01724           }
01725         else{
01726             dX = (m_nPin - n + 1)*dP/2.0 + n*dP/2.0 + (n-1)*dP - (2*m_nPin - m -1)*dP/2.0;
01727             dY = (m-1)*(0.5*dP/sin(pi/3.0) + 0.5*dP*sin(pi/6.0)/sin(pi/3.0));
01728           }
01729       }
01730     if(m_szGeomType == "rectangular"){
01731         double dPX, dPY, dPZ, dPX1, dPY1, dPZ1, dPX2, dPY2, dPZ2;
01732         if((m_Assembly(m,n)=="x")||(m_Assembly(m,n)=="xx"))
01733           m_Pincell(1).GetPitch(dPX, dPY, dPZ);
01734         else
01735           m_Pincell(nTempPin).GetPitch(dPX, dPY, dPZ);
01736
01737         if (n==1){
01738             dX = 0;
01739             if(m==1)
01740               dY = 0;
01741           }
01742         else{
01743             dX+= dPX/2.0;
01744             // find the previous pincell type
01745             // check if it's dummy
01746             if((m_Assembly(m,n-1)=="x")||(m_Assembly(m,n-1)=="xx")){
01747                 dX+=dPX/2.0;
01748               }
01749             else{
01750                 for(int b=1; b<=m_nPincells; b++){
01751                     m_Pincell(b).GetLineOne(szVolId, szVolAlias, nInputLines);
01752                     if(m_Assembly(m,n-1) == szVolAlias)
01753                       nTempPin1 = b;
01754                   }
01755                 if(nTempPin1 == -1){
01756                     std::cout << "Unknown pincell, pincell " << m_Assembly(m,n-1) << " not declared" << std::endl;
01757                     exit(1);
01758                   }
01759                 m_Pincell(nTempPin1).GetPitch(dPX1, dPY1, dPZ1);
01760                 // now add half of X pitch to the previous cells pitch
01761                 dX+= dPX1/2.0;
01762               }
01763           }
01764         if (m > 1 && n==1){
01765             dY+= dPY/2.0;
01766             // check if it's dummy
01767             if((m_Assembly(m-1,n)=="x")||(m_Assembly(m-1,n)=="xx")){
01768                 dY+= dPY/2.0;
01769               }
01770             else{
01771                 for(int c=1; c<=m_nPincells; c++){
01772                     m_Pincell(c).GetLineOne(szVolId, szVolAlias, nInputLines);
01773                     if(m_Assembly(m-1,n) == szVolAlias)
01774                       nTempPin2 = c;
01775                   }
01776                 m_Pincell(nTempPin2).GetPitch(dPX2, dPY2, dPZ2);
01777                 dY+= dPY2/2.0;
01778               }
01779           }
01780         dZ = 0.0; // moving in XY plane only
01781       }//if rectangular ends
01782
01783   }
01784
01785   void AssyGen::IOErrorHandler (ErrorStates ECode) const
01786   // ---------------------------------------------------------------------------
01787   // Function: displays error messages related to input data
01788   // Input:    error code
01789   // Output:   none
01790   // ---------------------------------------------------------------------------
01791   {
01792     std::cerr << '\n';
01793
01794     if (ECode == PINCELLS) // invalid number of pincells
01795       std::cerr << "Number of pincells must be >= 0.";
01796     else if (ECode == INVALIDINPUT) // invalid input
01797       std::cerr << "Invalid input.";
01798     else if (ECode == EMAT) // invalid input
01799       std::cerr << "Invalid Material Data.";
01800     else if (ECode == EGEOMTYPE) // invalid input
01801       std::cerr << "Invalid GeomType Data.";
01802     else if (ECode == EGEOMENGINE) // invalid input
01803       std::cerr << "Invalid Geometry Engine.";
01804     else if (ECode == EALIAS) // invalid input
01805       std::cerr << "Error Reading Aliases.";
01806     else if (ECode == ENEGATIVE) // invalid input
01807       std::cerr << "Unexpected negative value.";
01808     else if (ECode == EPIN) // invalid input
01809       std::cerr << "Invalid pinCell specs.";
01810     else if (ECode == EUNEQUAL) // invalid input
01811       std::cerr << "Number of cyliders and ducts in Z don't match, check .inp file.";
01812     else
01813       std::cerr << "Unknown error ...?";
01814
01815     std::cerr << '\n' << "Error in input file line : " << m_nLineNumber;
01816     std::cerr << std::endl;
01817     exit (1);
01818   }
01819
01820   void AssyGen:: Name_Faces(const std::string sMatName, const iBase_EntityHandle body,  iBase_TagHandle this_tag )
01821   // ---------------------------------------------------------------------------
01822   // Function: names all the faces in the body
01823   // Input:    none
01824   // Output:   none
01825   // ---------------------------------------------------------------------------
01826   {
01827     double dTol = 1e-4, ttol = 1e-2;
01828     if(m_dMAssmPitch.GetRows()!=0 && m_dMAssmPitch.GetColumns()!=0){
01829         if(m_szGeomType == "hexagonal")
01830           ttol = m_dMAssmPitch(1, 1);
01831         else if (m_szGeomType == "rectangular")
01832           ttol = m_dMAssmPitchX(1,1);
01833       }
01834     // set tolerance for surface identification
01835     if (ttol != 0){
01836         dTol=ttol*1.0e-2;
01837       }
01838     double dZTemp = 0.0;
01839     int flag = 0, locTemp = 0;
01840     iBase_EntityHandle max_surf = NULL, min_surf = NULL, side_surf =NULL;
01841     SimpleArray<iBase_EntityHandle> surfs;
01842     int nSide = 0;
01843     std::ostringstream os;
01844     std::string sMatName0=sMatName+"_top";
01845     std::string sMatName1=sMatName+"_bot";
01846     std::string sSideName;
01847 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
01848     iGeom_getEntAdj( igeomImpl->instance(), body, iBase_FACE, ARRAY_INOUT(surfs), &err );
01849 #endif
01850
01851     SimpleArray<double> max_corn, min_corn;
01852 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
01853     iGeom_getArrBoundBox( igeomImpl->instance(), ARRAY_IN(surfs), iBase_INTERLEAVED,
01854                           ARRAY_INOUT( min_corn ),
01855                           ARRAY_INOUT( max_corn ),
01856                           &err );
01857 #endif
01858
01859     for (int i = 0; i < surfs.size(); ++i){
01860         // first find the max z-coordinate
01861         if( (fabs(min_corn[3*i+2]-max_corn[3*i+2])) < dTol ) {
01862             if(flag == 0){
01863                 dZTemp = min_corn[3*i+2];
01864                 locTemp = i;
01865                 flag = 1;
01866               }
01867             else if(dZTemp > min_corn[3*i+2]){
01868                 // we have a bot surface
01869                 min_surf = surfs[i];
01870                 // the top surface is dZTemp
01871                 max_surf = surfs[locTemp];
01872               }
01873             else{
01874                 //we have a top surface
01875                 min_surf = surfs[locTemp];
01876                 // the top surface is dZTemp
01877                 max_surf = surfs[i];
01878               }
01879           }
01880         // see if max or min set name
01881         if(max_surf !=0){
01882 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
01883             iGeom_setData(igeomImpl->instance(), max_surf, this_tag,
01884                           sMatName0.c_str(), sMatName0.size(), &err);
01885 #endif
01886
01887             std::cout << sMatName0 << ",  ";
01888             max_surf = NULL;
01889
01890           }
01891         if(min_surf !=0){
01892 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
01893             iGeom_setData(igeomImpl->instance(), min_surf, this_tag,
01894                           sMatName1.c_str(), sMatName1.size(), &err);
01895 #endif
01896             std::cout << sMatName1 << ",  ";
01897             min_surf = NULL;
01898
01899           }
01900       }
01901     for (int i = 0; i < surfs.size(); ++i){
01902         if( (fabs(min_corn[3*i+2]-max_corn[3*i+2])) < dTol ) {
01903             continue; // its a max of min surface
01904           }
01905         else{ // its a side surface
01906             side_surf = surfs[i];
01907           }
01908         //set name for the sidesurf now
01909         if(side_surf !=0){
01910             ++nSide;
01911             sSideName = sMatName + "_side";
01912             if(m_szGeomType == "hexagonal") {
01913                 if(nSide <= 6)
01914                   os << sSideName << nSide;
01915                 else
01916                   os << sSideName << "_" << nSide;
01917               }
01918
01919             if(m_szGeomType == "rectangular"){
01920                 if(nSide <= 4)
01921                   os << sSideName << nSide;
01922                 else
01923                   os << sSideName << "_" << nSide;
01924               }
01925             sSideName = os.str();
01926 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
01927             iGeom_setData(igeomImpl->instance(), side_surf, this_tag,
01928                           sSideName.c_str(), sMatName1.size(), &err);
01929 #endif
01930             std::cout << sSideName << ",  " ;
01931             sSideName = "";
01932             os.str("");
01933             side_surf = NULL;
01934           }
01935         else {
01936             std::cerr << "Couldn't find surface for naming" << std::endl;
01937           }
01938       }
01939     std::cout <<"\n";
01940
01941   }
01942
01943
01944   void AssyGen::Center_Assm (char &rDir)
01945   // ---------------------------------------------------------------------------
01946   // Function: centers all the entities along x and y axis
01947   // Input:    none
01948   // Output:   none
01949   // ---------------------------------------------------------------------------
01950   {
01951 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
01952     double xmin = 0.0, xmax = 0.0, ymin = 0.0, ymax = 0.0, zmin = 0.0, zmax = 0.0, xcenter = 0.0, ycenter = 0.0, zcenter = 0.0;
01953     // position the assembly such that origin is at the center before sa
01954     iGeom_getBoundBox(igeomImpl->instance(),&xmin,&ymin,&zmin,
01955                       &xmax,&ymax,&zmax, &err);
01956     // moving all geom entities to center
01957
01958
01959     if( rDir =='x'){
01960         xcenter = (xmin+xmax)/2.0;
01961       }
01962     else if( rDir =='y'){
01963         ycenter = (ymin+ymax)/2.0;
01964       }
01965     else if ( rDir =='z'){
01966         zcenter = (zmin+zmax)/2.0;
01967       }
01968     else{
01969         // assume that it is centered along x and y and not z direction
01970         xcenter = (xmin+xmax)/2.0;
01971         ycenter = (ymin+ymax)/2.0;
01972       }
01973
01974     SimpleArray<iBase_EntityHandle> all;
01975     iGeom_getEntities( igeomImpl->instance(), root_set, iBase_REGION,ARRAY_INOUT(all),&err );
01976     for(int i=0; i<all.size(); i++){
01977         iGeom_moveEnt(igeomImpl->instance(),all[i],-xcenter,-ycenter,-zcenter,&err);
01978       }
01979 #endif
01980
01981     // OCC bounding box computation is buggy, better to compute bounding box in python and supply to the script.
01982     m_PyCubGeomFile << "vol = cubit.get_entities(\"volume\")" << std::endl;
01983     m_PyCubGeomFile << "vl = cubit.get_total_bounding_box(\"volume\", vol)\nzcenter = 0.0" << std::endl;
01984
01985     if( rDir =='x'){
01986         m_PyCubGeomFile << "xcenter = (vl[0]+vl[1])/2.0" << std::endl;
01987         m_PyCubGeomFile << "ycenter = 0" << std::endl;
01988         m_PyCubGeomFile << "zcenter = 0" << std::endl;
01989       }
01990     else if( rDir =='y'){
01991         m_PyCubGeomFile << "ycenter = (vl[3]+vl[4])/2.0" << std::endl;
01992         m_PyCubGeomFile << "xcenter = 0" << std::endl;
01993         m_PyCubGeomFile << "zcenter = 0" << std::endl;
01994       }
01995     else if ( rDir =='z'){
01996         m_PyCubGeomFile << "zcenter = (vl[6]+vl[7])/2.0" << std::endl;
01997         m_PyCubGeomFile << "xcenter = 0" << std::endl;
01998         m_PyCubGeomFile << "ycenter = 0" << std::endl;
01999       }
02000     else{
02001         // assume that it is centered along x and y and not z direction
02002         m_PyCubGeomFile << "xcenter = (vl[0]+vl[1])/2.0" << std::endl;
02003         m_PyCubGeomFile << "ycenter = (vl[3]+vl[4])/2.0" << std::endl;
02004       }
02005
02006     m_PyCubGeomFile << "cubit.cmd('move vol all x {0} y {1} z {2}'.format(-xcenter, -ycenter, -zcenter) )" <<  std::endl;
02007   }
02008
02009   void AssyGen::Section_Assm (char &cDir, double &dOffset, const std::string szReverse)
02010   // ---------------------------------------------------------------------------
02011   // Function: sections the assembly about the cutting plane
02012   // Input:    none
02013   // Output:   none
02014   // ---------------------------------------------------------------------------
02015   {
02016 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02017     double xmin = 0.0, xmax = 0.0, ymin = 0.0, ymax = 0.0, zmin = 0.0, zmax = 0.0, yzplane = 0.0, xzplane = 0.0;
02018     iBase_EntityHandle sec = NULL;
02019     int nReverse = 0;
02020     // check if reverse side is needed
02021     if(szReverse == "reverse"){
02022         nReverse = 1;
02023       }
02024     if( cDir =='x'){
02025         yzplane = 1.0;
02026         xzplane = 0.0;
02027       }
02028     if( cDir =='y'){
02029         yzplane = 0.0;
02030         xzplane = 1.0;
02031       }
02032     SimpleArray<iBase_EntityHandle> all;
02033     iGeom_getEntities( igeomImpl->instance(), root_set, iBase_REGION,ARRAY_INOUT(all),&err );
02034     // loop and section/delete entities
02035     for(int i=0; i < all.size(); i++){
02036         //get the bounding box to decide
02037         iGeom_getEntBoundBox(igeomImpl->instance(),all[i],&xmin,&ymin,&zmin,
02038                              &xmax,&ymax,&zmax, &err);
02039
02040         if(xmin > dOffset && yzplane ==1 && nReverse ==1){
02041             iGeom_deleteEnt(igeomImpl->instance(),all[i],&err);
02042             continue;
02043           }
02044         if(ymin > dOffset && xzplane == 1 && nReverse ==1){
02045             iGeom_deleteEnt(igeomImpl->instance(),all[i],&err);
02046             continue;
02047           }
02048         if(xmax < dOffset && yzplane ==1 && nReverse ==0){
02049             iGeom_deleteEnt(igeomImpl->instance(),all[i],&err);
02050             continue;
02051           }
02052         if(ymax < dOffset && xzplane == 1 && nReverse ==0){
02053             iGeom_deleteEnt(igeomImpl->instance(),all[i],&err);
02054             continue;
02055           }
02056         else{
02057             if(xzplane ==1 && ymax >dOffset && ymin < dOffset){
02058                 iGeom_sectionEnt(igeomImpl->instance(), all[i],yzplane,xzplane,0, dOffset, nReverse,&sec,&err);
02059               }
02060             if(yzplane ==1 && xmax >dOffset && xmin < dOffset){
02061                 iGeom_sectionEnt(igeomImpl->instance(), all[i],yzplane,xzplane,0, dOffset,nReverse,&sec,&err);
02062               }
02063           }
02064       }
02065 #endif
02066   }
02067
02068   void AssyGen::Rotate_Assm (char &cDir, double &dAngle)
02069   // ---------------------------------------------------------------------------
02070   // Function: rotates the whole assembly
02071   // Input:    none
02072   // Output:   none
02073   // ---------------------------------------------------------------------------
02074   {
02075     m_PyCubGeomFile << "cDir = '" << cDir << "'" << "\ncubit.cmd('rotate vol all angle " << dAngle << " about {0}'.format(cDir))" << std::endl;
02076
02077 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02078     double dX = 0.0, dY=0.0, dZ=0.0;
02079     if( cDir =='x'){
02080         dX = 1.0;
02081       }
02082     if( cDir =='y'){
02083         dY = 1.0;
02084       }
02085     if( cDir =='z'){
02086         dZ = 1.0;
02087       }
02088     SimpleArray<iBase_EntityHandle> all;
02089     iGeom_getEntities( igeomImpl->instance(), root_set, iBase_REGION,ARRAY_INOUT(all),&err );
02090
02091     // loop and rotate all entities
02092     for(int i=0; i<all.size(); i++){
02093         //get the bounding box to decide
02094         iGeom_rotateEnt(igeomImpl->instance(),all[i],dAngle,
02095                         dX, dY, dZ, &err);
02096       }
02097 #endif
02098   }
02099
02100   void AssyGen::Move_Assm (double &dX,double &dY, double &dZ)
02101   // ---------------------------------------------------------------------------
02102   // Function: move's the model by dX, dY and dZ
02103   // Input:    none
02104   // Output:   none
02105   // ---------------------------------------------------------------------------
02106   {
02107     SimpleArray<iBase_EntityHandle> all;
02108 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02109     iGeom_getEntities( igeomImpl->instance(), root_set, iBase_REGION,ARRAY_INOUT(all),&err );
02110 #endif
02111     m_PyCubGeomFile << "cubit.cmd('move vol all x " << dX << " y " << dY << " dZ " << dZ << "')" << std::endl;
02112
02113     // loop and rotate all entities
02114     for(int i=0; i<all.size(); i++){
02115         //get the bounding box to decide
02116 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02117         iGeom_moveEnt(igeomImpl->instance(),all[i],
02118                       dX, dY, dZ, &err);
02119 #endif
02120       }
02121
02122   }
02123
02124   void AssyGen::Create_HexAssm(std::string &szInputString)
02125   // ---------------------------------------------------------------------------
02126   // Function: read and create the assembly for hexagonal lattice
02127   // Input:    error code
02128   // Output:   none
02129   // ---------------------------------------------------------------------------
02130   {
02131     CParser Parse;
02132     std::string card, szVolId, szVolAlias;
02133     int nInputLines, nTempPin = 1, t, nIFlag = 0, total_pincells = 0;
02134     double dX = 0.0, dY =0.0, dZ=0.0;
02135     double  dP, dH, dSide, dHeight;
02136     iBase_EntityHandle assm = NULL;
02137     std::cout << "\ngetting Assembly data and creating ..\n"<< std::endl;
02138     std::istringstream szFormatString (szInputString);
02139
02140     szFormatString >> card >> m_nPin;
02141     if(m_nPin <=0 )
02142       IOErrorHandler (INVALIDINPUT);
02143
02144     // width of the hexagon is n*n+1/2
02145     int nWidth =2*m_nPin -1;
02146
02147     // creating a square array of size width
02148     m_Assembly.SetSize(nWidth, nWidth);
02149     if (m_nJouFlag == 1)
02150       return;
02151
02152     for(int m=1; m<=nWidth; m++){
02153         if (!Parse.ReadNextLine (m_FileInput, m_nLineNumber, szInputString,
02154                                  MAXCHARS, szComment))
02155           IOErrorHandler (INVALIDINPUT);
02156         if(m>m_nPin)
02157           t = 2*m_nPin - m;
02158         else
02159           t = m;
02160         std::istringstream szFormatString1 (szInputString);
02161
02162         for(int n=1; n<=(m_nPin + t - 1); n++){
02163             ++total_pincells;
02164             nTempPin = -1;
02165             szFormatString1 >> m_Assembly(m,n);
02166             if(szFormatString1.fail())
02167               IOErrorHandler (INVALIDINPUT);
02168             // if dummy pincell skip and continue
02169             if((m_Assembly(m,n)=="x")||(m_Assembly(m,n)=="xx")){
02170                 continue;
02171               }
02172             // find that pincell
02173             ++m_nTotalPincells;
02174             for(int b=1; b<=m_nPincells; b++){
02175                 m_Pincell(b).GetLineOne(szVolId, szVolAlias, nInputLines);
02176                 if(m_Assembly(m,n) == szVolAlias)
02177                   nTempPin = b;
02178               }
02179             if(nTempPin == -1){
02180                 std::cout << "Unknown pincell, pincell " << m_Assembly(m,n) << " not declared" << std::endl;
02181                 exit(1);
02182               }
02183
02184             // now compute the location and create it
02185             ComputePinCentroid(nTempPin, m_Assembly, m, n, dX, dY, dZ);
02186             //ERRORR("Error in function ComputePinCentroid", err);
02187
02188             // now create the pincell in the location found
02189             std::cout << "\n--------------------------------------------------"<<std::endl;
02190             std::cout << " m = " << m <<" n = " << n << std::endl;
02191             std::cout << "creating pin: " << nTempPin;
02192             std::cout << " at X Y Z " << dX << " " << dY << " " << dZ << std::endl;
02193
02194             if(strcmp(m_szInfo.c_str(),"on") == 0)
02195               m_AssmInfo << nTempPin  << " \t" << m << " \t" << n << " \t" << dX << " \t" << dY << " \t" << dZ << std::endl;
02196
02197             m_Pincell(nTempPin).GetIntersectFlag(nIFlag);
02198             if(nIFlag){
02199                 CreatePinCell_Intersect(nTempPin, dX, -dY, dZ);
02200                 //ERRORR("Error in function CreatePinCell_Intersect", err);
02201               }
02202             else{
02203                 CreatePinCell(nTempPin, dX, -dY, dZ);
02204                 //ERRORR("Error in function CreatePinCell", err);
02205               }
02206           }
02207       }
02208
02209     // get all the entities (in pins)defined so far, in an entity set - for subtraction later
02210 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02211     iGeom_getEntities( igeomImpl->instance(), root_set, iBase_REGION, ARRAY_INOUT(in_pins),&err );
02212 #endif
02213     std::cout << "Expected pin definitions: " << total_pincells << "\n\nCreating surrounding outer hexes .." << std::endl;
02214
02215     for (int nTemp = 1; nTemp <= m_nDuct; nTemp ++){
02216         if(m_nDimensions >0){
02217
02218             // create outermost hexes
02219             for(int n=1;n<=m_nDimensions; n++){
02220                 dSide = m_dMAssmPitch(nTemp, n)/(sqrt(3));
02221                 dHeight = m_dMZAssm(nTemp, 2) - m_dMZAssm(nTemp, 1);
02222
02223                 // creating coverings
02224 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02225                 iGeom_createPrism(igeomImpl->instance(), dHeight, 6,
02226                                   dSide, dSide,
02227                                   &assm, &err);
02228 #endif
02229                 m_PyCubGeomFile << "##\nassm = cubit.prism(" << dHeight << ", 6, " << dSide << ", " << dSide << ")" << std::endl;
02230
02231                 // rotate the prism to match the pins
02232 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02233                 iGeom_rotateEnt (igeomImpl->instance(), assm, 30, 0, 0, 1, &err);
02234 #endif
02235                 m_PyCubGeomFile << "cubit.cmd('rotate body {0} angle 30 about z'.format(assm.id()) )" << std::endl;
02236
02237                 if(0 != m_Pincell.GetSize()){
02238                     m_Pincell(1).GetPitch(dP, dH);
02239                     dX = m_nPin*dP;
02240                     dY = -(m_nPin-1)*dP*sqrt(3.0)/2.0;
02241                   }
02242                 else{
02243                     dX = 0.0;
02244                     dY = 0.0;
02245                   }
02246                 dZ = (m_dMZAssm(nTemp, 2) + m_dMZAssm(nTemp, 1))/2.0;
02247
02248                 // position the prism
02249 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02250                 iGeom_moveEnt(igeomImpl->instance(), assm, dX,dY,dZ, &err);
02251 #endif
02252                 m_PyCubGeomFile << "vector = [" << dX << ", " << dY << ", " << dZ << "]" << std::endl;
02253                 m_PyCubGeomFile << "cubit.move(assm, vector)" << std::endl;
02254
02255                 // populate the coverings array
02256                 int loc = (nTemp-1)*m_nDimensions + n -1;
02257                 assms[(nTemp-1)*m_nDimensions + n -1]=assm;
02258                 m_PyCubGeomFile << "assms.insert(" << loc << ", assm)" << std::endl;
02259               }
02260           }
02261       }
02262
02263   }
02264
02265   void AssyGen::Create_CartAssm(std::string &szInputString)
02266   // ---------------------------------------------------------------------------
02267   // Function: read and create the assembly for rectangular lattice
02268   // Input:    error code
02269   // Output:   none
02270   // ---------------------------------------------------------------------------
02271   {
02272     CParser Parse;
02273     std::string card, szVolId, szVolAlias;
02274     int nInputLines, nTempPin = 1, nIFlag = 0.0;
02275     double dX = 0.0, dY =0.0, dZ=0.0, dMoveX = 0.0, dMoveY = 0.0, dHeight = 0, dPX=0.0, dPY=0.0, dPZ=0.0;
02276     iBase_EntityHandle assm = NULL;
02277
02278     std::istringstream szFormatString (szInputString);
02279     szFormatString >> card >> m_nPinX >> m_nPinY;
02280     if(m_nPinX <=0 || m_nPinY <=0)
02281       IOErrorHandler (INVALIDINPUT);
02282     m_Assembly.SetSize(m_nPinY,m_nPinX);
02283
02284     if (m_nJouFlag == 1)
02285       return;
02286
02287     //read the next line to get assembly info &store assembly info
02288     if(0 != m_Pincell.GetSize()){
02289         for(int m=1; m<=m_nPinY; m++){
02290             if (!Parse.ReadNextLine (m_FileInput, m_nLineNumber, szInputString,
02291                                      MAXCHARS, szComment))
02292               IOErrorHandler (INVALIDINPUT);
02293             std::istringstream szFormatString1 (szInputString);
02294
02295             //store the line read in Assembly array and create / position the pin in the core
02296             for(int n=1; n<=m_nPinX; n++){
02297                 szFormatString1 >> m_Assembly(m,n);
02298                 if(szFormatString1.fail())
02299                   IOErrorHandler (INVALIDINPUT);
02300
02301
02302                 // loop thro' all pins to get the type of pin
02303                 for(int b=1; b<=m_nPincells; b++){
02304                     m_Pincell(b).GetLineOne(szVolId, szVolAlias, nInputLines);
02305                     if(m_Assembly(m,n) == szVolAlias)
02306                       nTempPin = b;
02307                   }
02308
02309                 //now compute the location where the pin needs to be placed
02310                 ComputePinCentroid(nTempPin, m_Assembly, m, n, dX, dY, dZ);
02311                 //ERRORR("Error in function ComputePinCentroid", err);
02312
02313                 // if dummy pincell skip and continue
02314                 if((m_Assembly(m,n)=="x")||(m_Assembly(m,n)=="xx")){
02315                     m_Pincell(1).GetPitch(dPX, dPY, dPZ);
02316                     // dMoveX and dMoveY are stored for positioning the outer squares later
02317                     if(m == m_nPinY && n ==m_nPinX){
02318                         dMoveX = dX/2.0;
02319                         dMoveY = -dY/2.0;
02320                       }
02321                     continue;
02322                   }
02323                 ++m_nTotalPincells;
02324                 // now create the pincell in the location found
02325                 std::cout << "\n--------------------------------------------------"<<std::endl;
02326                 std::cout << " m = " << m <<" n = " << n << std::endl;
02327                 std::cout << "creating pin: " << nTempPin;
02328                 std::cout << " at X Y Z " << dX << " " << -dY << " " << dZ << std::endl;
02329
02330                 if(strcmp(m_szInfo.c_str(),"on") == 0)
02331                   m_AssmInfo << nTempPin  << " \t" << m << " \t" << n << " \t" << dX << " \t" << dY << " \t" << dZ << std::endl;
02332
02333                 m_Pincell(nTempPin).GetIntersectFlag(nIFlag);
02334                 if(nIFlag){
02335                     CreatePinCell_Intersect(nTempPin, dX, -dY, dZ);
02336                     //ERRORR("Error in function CreatePinCell_Intersect", err);
02337                   }
02338                 else{
02339                     CreatePinCell(nTempPin, dX, -dY, dZ);
02340                     //ERRORR("Error in function CreatePinCell", err);
02341                   }
02342                 // dMoveX and dMoveY are stored for positioning the outer squares later
02343                 if(m == m_nPinY && n ==m_nPinX){
02344                     dMoveX = dX/2.0;
02345                     dMoveY = -dY/2.0;
02346                   }
02347               }
02348           }
02349       }
02350     std::cout << "\n--------------------------------------------------"<<std::endl;
02351
02352     // get all the entities (in pins)defined so far, in an entity set - for subtraction later
02353     //  iGeom_getEntities( igeomImpl->instance(), root_set, iBase_REGION, ARRAY_INOUT(in_pins),&err );
02354     //  //CHECK( "ERROR : getRootSet failed!" );
02355
02356
02357     if(m_nDimensions > 0){
02358
02359         // create outermost rectangular blocks
02360         std::cout << "\nCreating surrounding outer blocks .." << std::endl;
02361         int nCount = -1;
02362         for(int nTemp = 1; nTemp <= m_nDuct; nTemp ++){
02363             for(int n=1;n<=m_nDimensions; n++){
02364                 ++nCount;
02365                 dHeight = m_dMZAssm(nTemp, 2) - m_dMZAssm(nTemp, 1);
02366 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02367                 iGeom_createBrick(igeomImpl->instance(), m_dMAssmPitchX(nTemp, n),  m_dMAssmPitchY(nTemp, n), dHeight,
02368                                   &assm, &err);
02369 #endif
02370                 m_PyCubGeomFile << "assm = cubit.brick( " << m_dMAssmPitchX(nTemp, n) << ", " << m_dMAssmPitchY(nTemp, n) << ", " << dHeight << ")" << std::endl;
02371
02372                 // position the outer block to match the pins
02373                 dZ = (m_dMZAssm(nTemp, 2) + m_dMZAssm(nTemp, 1))/2.0;
02374                 std::cout << "Move " <<   dMoveX << " " << dMoveY <<std::endl;
02375 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02376                 iGeom_moveEnt(igeomImpl->instance(), assm, dMoveX,dMoveY,dZ, &err);
02377 #endif
02378                 m_PyCubGeomFile << "vector = [" << dMoveX << ", " << dMoveY << ", " << dZ << "]" << std::endl;
02379                 m_PyCubGeomFile << "cubit.move(assm, vector)" << std::endl;
02380
02381                 // populate the outer covering array squares
02382                 assms[nCount]=assm;
02383                 m_PyCubGeomFile << "assms.insert(" << nCount << ", assm)" << std::endl;
02384
02385               }
02386           }
02387       }
02388
02389   }
02390
02391   void AssyGen::CreateOuterCovering ()
02392   // ---------------------------------------------------------------------------
02393   // Function: this function sets the names of the coverings
02394   // Input:    error code
02395   // Output:   none
02396   // ---------------------------------------------------------------------------
02397   {
02398     double zmin = 0.0, zmax = 0.0;
02399     iBase_TagHandle this_tag = NULL;
02400     std::string sMatName = "";
02401     std::string sMatName0 = "";
02402     std::string sMatName1 = "";
02403     m_PyCubGeomFile << "sub1 = []\nsub2=[]" << std::endl;
02404
02405     // get tag handle for 'NAME' tag, already created as iGeom instance is created
02406 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02407     char* tag_name =(char *)"NAME";
02408     iGeom_getTagHandle(igeomImpl->instance(), tag_name, &this_tag, &err, 4);
02409 #endif
02410     iBase_EntityHandle tmp_vol= NULL, tmp_new= NULL;
02411
02412     // name the innermost outer covering common for both rectangular and hexagonal assembliees
02413     if(m_nDimensions >0){
02414         //    int tag_no = 0;
02415         for (int nTemp1 = 1; nTemp1 <=m_nDuct; nTemp1++){
02416             for(int p=1;p<=m_szAssmMatAlias.GetSize();p++){
02417                 if(strcmp ( m_szMMAlias(nTemp1, 1).c_str(), m_szAssmMatAlias(p).c_str()) == 0){
02418                     sMatName =  m_szAssmMat(p);
02419                     //    tag_no=p;
02420                   }
02421               }
02422
02423             std::cout << "\ncreated innermost block: " << sMatName << std::endl;
02424
02425             tmp_vol = assms[(nTemp1 - 1)*m_nDimensions];
02426 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02427             iGeom_setData(igeomImpl->instance(), tmp_vol, this_tag,
02428                           sMatName.c_str(), sMatName.size(), &err);
02429 #endif
02430             Name_Faces(sMatName, tmp_vol, this_tag);
02431             m_PyCubGeomFile << "lid = assms[" << (nTemp1 - 1)*m_nDimensions << "].id()" << std::endl;
02432             if (sMatName == "")
02433               IOErrorHandler(EALIAS);
02434             m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \""  << sMatName <<  "\" )" << std::endl;
02435             m_PyCubGeomFile << "name_faces(\"" << sMatName << "\", assms[" << (nTemp1 - 1)*m_nDimensions << "])" << std::endl;
02436           }
02437
02438         int count =0;//index for edge names
02439         for (int nTemp = 1; nTemp <= m_nDuct; nTemp++){
02440             //  Naming outermost block edges - sidesets in cubit journal file
02441             std::cout << "Naming outermost block edges" << std::endl;
02442             SimpleArray<iBase_EntityHandle> edges;
02443
02444 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02445             iGeom_getEntAdj( igeomImpl->instance(), assms[nTemp*m_nDimensions-1] , iBase_EDGE,ARRAY_INOUT(edges),
02446                 &err );
02447 #endif
02448             // get the top corner edges of the outer most covering
02449             //m_PyCubGeomFile << "lid=assms<<["<< nTemp*m_nDimensions-1 << "].id()" << std::endl;
02450             m_PyCubGeomFile << "cubit.cmd('group \"g1\" equals curve in vol {0} '.format(assms[" << nTemp*m_nDimensions-1 << "].id()))" << std::endl;
02451             m_PyCubGeomFile << "cubit.cmd('group \"g2\" equals curve with z_max<> z_min in g1')\ncubit.cmd('group  \"g3\" subtract g2 from g1')" << std::endl;
02452             m_PyCubGeomFile <<                        "tmp_g3id = cubit.get_id_from_name(\"g3\")\n"
02453                                                       "gs_curves = cubit.get_group_curves(tmp_g3id)\n"
02454                                                       "side_curves = len(gs_curves)\n"
02455                                                       "for i in range(0,side_curves):\n"
02456                                                       "  sname = \"side_edge\" + str(i+1)\n"
02457                                                       "  cubit.cmd('curve {0} name \"{1}\"'.format( gs_curves[i] , sname )  )\n" << std::endl;
02458             std::ostringstream os;
02459             for (int i = 0; i < edges.size(); ++i){
02460 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02461                 double xmin = 0.0, xmax = 0.0, ymin = 0.0, ymax = 0.0;
02462                 iGeom_getEntBoundBox(igeomImpl->instance(), edges[i],&xmin,&ymin,&zmin,
02463                                      &xmax,&ymax,&zmax, &err);
02464 #endif
02465                 double dTol = 1e-5; // tolerance for comparing coordinates
02466
02467                 if(fabs(zmax - m_dMZAssm(nTemp, 2)) <  dTol){
02468                     if(fabs(zmax-zmin) < dTol){
02469
02470                         //we have a corner edge - name it
02471                         sMatName="side_edge";
02472                         ++count;
02473                         os << sMatName << count;
02474                         sMatName=os.str();
02475                         std::cout << sMatName << std::endl;
02476                         tmp_vol=edges[i];
02477 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02478                         iGeom_setData(igeomImpl->instance(), tmp_vol, this_tag,
02479                                       sMatName.c_str(), sMatName.size(), &err);
02480 #endif
02481                         std::cout << "created: " << sMatName << std::endl;
02482                         os.str("");
02483                         sMatName="";
02484                       }
02485                   }
02486               }
02487           }
02488         // now subtract the outermost hexes and name them
02489         std::cout << "Subtract outermost hexes and naming them" << std::endl;
02490         int nCount = 0;
02491         for(int nTemp=1; nTemp<=m_nDuct; nTemp++){
02492             for(int n=m_nDimensions; n>1 ; n--){
02493                 if(n>1){
02494                     ++nCount;
02495                     // copy cyl before subtract
02496 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02497                     iGeom_copyEnt(igeomImpl->instance(), assms[(nTemp-1)*m_nDimensions + n-2], &tmp_vol, &err);
02498 #endif
02499                     m_PyCubGeomFile << "tmp_vol = cubit.copy_body(assms[" << (nTemp-1)*m_nDimensions + n-2 << "])" << std::endl;
02500
02501                     // subtract outer most cyl from brick
02502                     m_PyCubGeomFile << "\nsub1.append(tmp_vol)" << std::endl;
02503                     m_PyCubGeomFile << "\nsub2.append(assms[" << (nTemp-1)*m_nDimensions + n-1 <<"])" << std::endl;
02504 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02505                     iGeom_subtractEnts(igeomImpl->instance(), assms[(nTemp-1)*m_nDimensions + n-1], tmp_vol, &tmp_new, &err);
02506 #endif
02507                     m_PyCubGeomFile << "tmp_new = cubit.subtract(sub1, sub2)" << std::endl;
02508                     m_PyCubGeomFile << "assms[" << (nTemp-1)*m_nDimensions + n-1 << "] = tmp_new[0]\n\nsub1[:]=[]\nsub2[:]=[]"   << std::endl;
02509
02510                     assms[(nTemp-1)*m_nDimensions + n-1]=tmp_new;
02511
02512                     // name the vols by searching for the full name of the abbreviated Cell Mat
02513                     for(int p=1;p<=m_szAssmMatAlias.GetSize();p++){
02514                         if(strcmp ( m_szMMAlias(nTemp, n).c_str(), m_szAssmMatAlias(p).c_str()) == 0){
02515                             sMatName =  m_szAssmMat(p);
02516                           }
02517                       }
02518                     std::cout << "created: " << sMatName << std::endl;
02519 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02520                     iGeom_setData(igeomImpl->instance(), tmp_new, this_tag,
02521                                   sMatName.c_str(), sMatName.size(), &err);
02522 #endif
02523                     m_PyCubGeomFile << "lid = tmp_new[0].id()" << std::endl;
02524                     if (sMatName == "")
02525                       IOErrorHandler(EALIAS);
02526                     m_PyCubGeomFile << "cubit.set_entity_name(\"body\", lid, \""  << sMatName <<  "\" )" << std::endl;
02527                     m_PyCubGeomFile << "name_faces(\"" << sMatName << "\", tmp_new[0]) " << std::endl;
02528                     Name_Faces(sMatName, tmp_new, this_tag);
02529                   }
02530               }
02531           }
02532         std::cout << "\n--------------------------------------------------"<<std::endl;
02533       }
02534
02535   }
02536
02537   void AssyGen::Subtract_Pins()
02538   // ---------------------------------------------------------------------------
02539   // Function: subtract the pins from the outer block
02540   // Input:    none
02541   // Output:   none
02542   // ---------------------------------------------------------------------------
02543   {
02544     if (m_nDimensions >0){
02545         std::cout <<"Total number of pins in the model = " << m_nTotalPincells << std::endl;
02546
02547         for (int k=1; k<=m_nDuct; k++){
02548             if(cp_inpins[k-1].size() ==0)
02549               continue;
02550             // put all the in pins in a matrix of size duct for subtraction with ducts
02551             std::vector <iBase_EntityHandle> pin_copy( cp_inpins[k-1].size(), NULL);
02552             m_PyCubGeomFile << "pin_copy=[]\n\nsub1=[]\nsub2=[]\n" << std::endl;
02553             for (int i=0; i< (int) cp_inpins[k-1].size();i++){
02554 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02555                 iGeom_copyEnt(igeomImpl->instance(), cp_inpins[k-1][i], &pin_copy[i], &err);
02556 #endif
02557                 m_PyCubGeomFile << "tmp_vol = cubit.copy_body(cp_inpins[" << k-1 << "][" << i << "])" << std::endl;
02558                 m_PyCubGeomFile << "pin_copy.append(tmp_vol)" << std::endl;
02559                 m_PyCubGeomFile << "\nsub2.append(cp_inpins[" << k-1 << "]["<< i << "])" << std::endl;
02560               }
02561
02562             iBase_EntityHandle tmp_vol = NULL;
02563             (void) tmp_vol;
02564             tmp_vol = assms[(k-1)*m_nDimensions];
02565             m_PyCubGeomFile << "tmp_vol = assms[" << k << "]" << std::endl;
02566
02567             // subtract the innermost hex from the pins
02568             std::cout << "Duct no.: " << k << " subtracting " <<  cp_inpins[k-1].size() << " pins from the duct .. " << std::endl;
02569
02570             //#if HAVE_ACIS
02571             iBase_EntityHandle unite= NULL, tmp_new1 = NULL;
02572             (void) unite;
02573
02574             // if there are more than one pins
02575             if( cp_inpins[k-1].size() > 1){
02576 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02577                 iGeom_uniteEnts(igeomImpl->instance(), &cp_inpins[k-1][0], cp_inpins[k-1].size(), &unite, &err);
02578 #endif
02579                 m_PyCubGeomFile << "\nsub1.append(assms[" << (k-1)*m_nDimensions <<"])" << std::endl;
02580 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02581                 iGeom_subtractEnts(igeomImpl->instance(), tmp_vol,unite, &tmp_new1, &err);
02582 #endif
02583                 m_PyCubGeomFile << "tmp_new1 = cubit.subtract(sub2, sub1)" << std::endl;
02584                 m_PyCubGeomFile << "tmp_vol = tmp_new1" << std::endl;
02585
02586                 tmp_vol = tmp_new1;
02587                 unite = NULL;
02588                 tmp_new1=NULL;
02589               }
02590             else{ // only one pin in in_pins
02591 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02592                 iGeom_subtractEnts(igeomImpl->instance(), tmp_vol, cp_inpins[k-1][0], &tmp_new1, &err);
02593 #endif
02594                 m_PyCubGeomFile << "\nsub1.append(assms[" << (k-1)*m_nDimensions <<"])" << std::endl;
02595                 m_PyCubGeomFile << "tmp_new1 = cubit.subtract(sub2, sub1)" << std::endl;
02596               }
02597             //#endif
02598             // This block was needed for OCE below 0.13 or OCC 6.6
02599             //#if HAVE_OCC
02600             //            iBase_EntityHandle tmp_new1 = NULL;
02601             //            // if there are more than one pins
02602             //            if( cp_inpins[k-1].size() > 1){
02603             //                std::cout << "Subtraction is slower in OCC, since each pin is subtracted one by one" << std::endl;
02604             //                for (int i=0; i< (int)cp_inpins[k-1].size(); i++){
02605             //                    // iGeom_copyEnt(igeomImpl->instance(), cp_inpins[k-1][i], &unite, &err);
02606             //                    iGeom_subtractEnts(igeomImpl->instance(), tmp_vol,cp_inpins[k-1][i], &tmp_new1, &err);
02607             //                    ////CHECK("Couldn't subtract pins from block.");
02608             //                    tmp_vol = tmp_new1;
02609             //                    tmp_new1=NULL;
02610             //                  }
02611
02612             //              }
02613             //            else{ // only one pin in in_pins
02614             //                iGeom_subtractEnts(igeomImpl->instance(), tmp_vol, cp_inpins[k-1][0], &tmp_new1, &err);
02615             //                ////CHECK("Couldn't subtract pins from block.");
02616             //              }
02617             //#endif
02618
02619           }
02620         std::cout << "\n--------------------------------------------------"<<std::endl;
02621       }
02622     else{
02623         std::cout <<"Nothing to subtract" << std::endl;
02624       }
02625
02626   }
02627
02628   void AssyGen::Imprint_Merge(bool if_merge, bool if_imprint)
02629   // ---------------------------------------------------------------------------
02630   // Function: Imprint and Merge
02631   // Input:    none
02632   // Output:   none
02633   // ---------------------------------------------------------------------------
02634   {
02635     // getting all entities for merge and imprint
02636     SimpleArray<iBase_EntityHandle> entities;
02637 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02638     iGeom_getEntities( igeomImpl->instance(), root_set, iBase_REGION, ARRAY_INOUT(entities),&err );
02639 #endif
02640
02641     if(if_imprint ==  true){
02642         //  now imprint
02643         std::cout << "\n\nImprinting...." << std::endl;
02644         clock_t s_imprint = clock();
02645 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02646         iGeom_imprintEnts(igeomImpl->instance(), ARRAY_IN(entities),&err);
02647 #endif
02648         std::cout << "## Imprint CPU time used := " << (double) (clock() - s_imprint)/CLOCKS_PER_SEC
02649                   << " seconds" << std::endl;
02650         std::cout << "\n--------------------------------------------------"<<std::endl;
02651       }
02652
02653     if(if_merge == true){
02654         // merge tolerance
02655         // now  merge
02656         std::cout << "\n\nMerging...." << std::endl;
02657         clock_t s_merge = clock();
02658 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02659         double dTol = 1e-4;
02660         iGeom_mergeEnts(igeomImpl->instance(), ARRAY_IN(entities), dTol, &err);
02661 #endif
02662         std::cout << "## Merge CPU time used := " << (double) (clock() - s_merge)/CLOCKS_PER_SEC
02663                   << " seconds" << std::endl;
02664         std::cout <<"merging finished."<< std::endl;
02665         std::cout << "\n--------------------------------------------------"<<std::endl;
02666       }
02667   }
02668
02669   void AssyGen::Create2DSurf ()
02670   // ---------------------------------------------------------------------------
02671   // Function: creating planar top surface with zmax
02672   // Input:    error code
02673   // Output:   none
02674   // ---------------------------------------------------------------------------
02675   {
02676     m_PyCubGeomFile << "#keep top surface delete the rest" << std::endl;
02677     m_PyCubGeomFile << "cubit.cmd('surf with z_coord == {0} copy'.format(vl[7]) )" << std::endl;
02678     m_PyCubGeomFile << "cubit.cmd('delete vol with z_coord < {0}'.format(vl[7]) )" << std::endl;
02679
02680 #if defined (HAVE_ACIS) || defined (HAVE_OCC)
02681     std::cout << "Creating surface; 2D assembly specified..." << std::endl;
02682     SimpleArray<iBase_EntityHandle>  all_geom;
02683     SimpleArray<iBase_EntityHandle> surfs;
02684     int t=0;
02685     SimpleArray<double> max_corn, min_corn;
02686
02687     // get all the entities in the model (delete after making a copy of top surface)
02688     int *offset = NULL, offset_alloc = 0, offset_size = -1;
02689     iGeom_getEntities( igeomImpl->instance(), root_set, iBase_REGION,ARRAY_INOUT(all_geom),&err );
02690
02691     // get all the surfaces in the model
02692     iGeom_getArrAdj( igeomImpl->instance(), ARRAY_IN(all_geom) , iBase_FACE, ARRAY_INOUT(surfs),
02693                      &offset, &offset_alloc, &offset_size, &err );
02694
02695     iGeom_getArrBoundBox( igeomImpl->instance(), ARRAY_IN(surfs), iBase_INTERLEAVED,
02696                           ARRAY_INOUT( min_corn ),
02697                           ARRAY_INOUT( max_corn ),
02698                           &err );
02699
02700     // find the number of surfaces 't' for array allocation
02701     int nTemp = 1;
02702     double dTol = 1e-5;
02703     double dtop = m_dMZAssm(nTemp, 2);
02704     for (int i = 0; i < surfs.size(); ++i){
02705         if((fabs(max_corn[3*i+2] -  dtop) < dTol) && (fabs(min_corn[3*i+2] - dtop)<dTol))
02706           t++;
02707       }
02708
02709     // allocate arrays
02710     SimpleArray<iBase_EntityHandle> max_surfs(t);
02711     SimpleArray<iBase_EntityHandle> new_surfs(t);
02712     t=0;
02713
02714     // store the max surfaces in max_surfs
02715     for (int i = 0; i < surfs.size(); ++i){
02716
02717         // locate surfaces for which max and min zcoord is same as maxz coord
02718         if((fabs(max_corn[3*i+2] -  dtop) < dTol) && (fabs(min_corn[3*i+2] - dtop) < dTol)){
02719             max_surfs[t] = surfs[i];
02720             t++;
02721           }
02722       }
02723
02724     // make a copy of max_surfs
02725     for(int i = 0; i < max_surfs.size(); ++i){
02726         iGeom_copyEnt(igeomImpl->instance(), max_surfs[i], &new_surfs[i], &err);
02727       }
02728
02729     // delete all the old ents
02730     for(int i=0; i<all_geom.size(); i++){
02731         iGeom_deleteEnt(igeomImpl->instance(), all_geom[i], &err);
02732       }
02733     // position the final assembly at the center
02734     // get the assembly on z=0 plane
02735
02736     double zcenter = m_dMZAssm(nTemp, 2)/2.0;//move up
02737     SimpleArray<iBase_EntityHandle> all;
02738     iGeom_getEntities( igeomImpl->instance(), root_set, iBase_REGION,ARRAY_INOUT(all),&err );
02739
02740     for(int i=0; i<all.size(); i++){
02741         iGeom_moveEnt(igeomImpl->instance(),all[i],0,0,-zcenter,&err);
02742       }
02743     free(offset);
02744 #endif
02745     std::cout << "-----Done creating 2D surface-----"<<std::endl;
02746
02747   }
02748 }
