MeshKit  1.0
IARoundingNlp.cpp
00001 // IARoundingNlp.cpp
00002 // Interval Assignment for Meshkit
00003 //
00004 // Adapted from
00005 // Copyright (C) 2005, 2006 International Business Machines and others.
00006 // All Rights Reserved.
00007 // This code is published under the Eclipse Public License.
00008 //
00009 // $Id: hs071_nlp.cpp 1864 2010-12-22 19:21:02Z andreasw $
00010 //
00011 // Authors:  Carl Laird, Andreas Waechter     IBM    2005-08-16
00012
00013 #include "meshkit/IARoundingNlp.hpp"
00014 #include "meshkit/IAData.hpp"
00015 #include "meshkit/IPData.hpp"
00016 #include "meshkit/IASolution.hpp"
00017 #include "meshkit/IANlp.hpp"
00018 #include "meshkit/IASolverToolInt.hpp"
00019
00020 #include <math.h>
00021 #include <limits>
00022 #include <algorithm>
00023
00024 // for printf
00025 #ifdef HAVE_CSTDIO
00026 # include <cstdio>
00027 #else
00028 # ifdef HAVE_STDIO_H
00029 #  include <stdio.h>
00030 # else
00031 #  error "don't have header file for stdio"
00032 # endif
00033 #endif
00034
00035
00036 namespace MeshKit
00037 {
00038
00039 bool IARoundingNlp::randomize_weights_of_non_int()
00040 {
00041   IASolverToolInt sti(data, solution);
00042   return sti.randomize_weights_of_non_int(&weights, 0.023394588);
00043 }
00044
00045
00046 // the objective function we should use for weights
00047 double IARoundingNlp::f_x_value( double I_i, double x_i )
00048 {
00049   return x_i > I_i ?
00050   (x_i - I_i) / I_i :
00051   1.103402234045 * (I_i - x_i) / x_i;
00052   // expected is 1/100 to 4 or so
00053
00054   // the range of magnitudes of these weights is too high, the weights are too non-linear if we take them to a power
00055   // was
00056   // const double fh = IANlp::eval_R_i(data->I[i], xl+1);
00057 }
00058
00059 // constructor
00060 IARoundingNlp::IARoundingNlp(const IAData *data_ptr, const IPData *ip_data_ptr, IASolution *solution_ptr,
00061   const bool set_silent):
00062 data(data_ptr), ipData(ip_data_ptr), solution(solution_ptr), baseNlp(data_ptr, solution_ptr, set_silent),
00063   weights(),
00064 silent(set_silent), debugging(false), verbose(true) // true
00065 {
00066   if (!silent)
00067   {
00068     printf("\nIARoundingNLP Problem size:\n");
00069     printf("  number of variables: %lu\n", data->I.size());
00070     printf("  number of constraints: %lu\n\n", data->constraints.size());
00071   }
00072
00073   weights.resize(data->I.size());
00074   if (0 && debugging)
00075     printf("raw linear +x weights: ");
00076   for (int i = 0; i < data->num_variables(); ++i)
00077   {
00078     const double x = ipData->relaxedSolution[i];
00079     const double xl = floor(x);
00080     // const double xl = floor( ipData.relaxedSolution[i] );
00081     assert(xl >= 1.);
00082     const double fl = f_x_value(data->I[i], xl);
00083     const double fh = f_x_value(data->I[i], xl+1);
00084     const double w = fh - fl;
00085     weights[i] = w;
00086
00087     if (0 && debugging)
00088       printf(" %f", w);
00089   }
00090
00091   // ensure weights are unique
00092   weights.uniquify(1., 1.e4);
00093
00094   if (debugging)
00095   {
00096     printf("\n");
00097     for (int i = 0; i < data->num_variables(); ++i)
00098     {
00099       const double x = ipData->relaxedSolution[i];
00100       const double xl = floor(x);
00101       printf("x %d (%f) in [%d,%d] weight %10.4f\n", i, x, (int) xl, (int) (xl + 1.), weights[i]);
00102     }
00103   }
00104 }
00105
00106
00107 // n = number of variables
00108 // m = number of constraints (not counting variable bounds)
00109
00110
00111 IARoundingNlp::~IARoundingNlp() {data = NULL;}
00112
00113 // returns the size of the problem
00114 bool IARoundingNlp::get_nlp_info(Index& n, Index& m, Index& nnz_jac_g,
00115                              Index& nnz_h_lag, IndexStyleEnum& index_style)
00116 {
00117   bool base_ok = baseNlp.get_nlp_info(n, m, nnz_jac_g, nnz_h_lag, index_style);
00118   nnz_h_lag = 0; // nele_h
00119   return true && base_ok;
00120   // need to change this if there are more variables, such as delta-minuses
00121 }
00122
00123 // returns the variable bounds
00124 bool IARoundingNlp::get_bounds_info(Index n, Number* x_l, Number* x_u,
00125                                 Index m, Number* g_l, Number* g_u)
00126 {
00127   const bool base_ok = baseNlp.get_bounds_info(n, x_l, x_u, m, g_l, g_u);
00128
00129   for (Index i=0; i<n; ++i)
00130   {
00131     const double x = ipData->relaxedSolution[i];
00132     const double xl = floor(x);
00133     assert(xl >= 1.);
00134     x_l[i] = xl;
00135     x_u[i] = xl + 1.;
00136 //    if (debugging)
00137 //      printf("x %d (%f) in [%d,%d]\n", i, x, (int) x_l[i], (int) x_u[i]);
00138   }
00139
00140   return true && base_ok; //means what?
00141 }
00142
00143 // returns the initial point for the problem
00144 bool IARoundingNlp::get_starting_point(Index n, bool init_x, Number* x_init,
00145                                    bool init_z, Number* z_L, Number* z_U,
00146                                    Index m, bool init_lambda,
00147                                    Number* lambda)
00148 {
00149   // Minimal info is starting values for x, x_init
00150   // Improvement: we can provide starting values for the dual variables if we wish
00151   assert(init_x == true);
00152   assert(init_z == false);
00153   assert(init_lambda == false);
00154
00155   // initialize x to the relaxed solution
00156   for (Index i=0; i<n; ++i)
00157   {
00158     x_init[i] = ipData->relaxedSolution[i];
00159   }
00160
00161   return true;
00162 }
00163
00164
00165 // returns the value of the objective function
00166 bool IARoundingNlp::eval_f(Index n, const Number* x, bool new_x, Number& obj_value)
00167 {
00168   assert(n == data->num_variables());
00169
00170   double obj = 0.;
00171   for (Index i = 0; i<n; ++i)
00172   {
00173     const double xl = floor( ipData->relaxedSolution[i] );
00174     obj += weights[i] * (x[i] - xl);
00175   }
00176
00177   obj_value = obj;
00178
00179   return true;
00180 }
00181
00182 // return the gradient of the objective function grad_{x} f(x)
00183 bool IARoundingNlp::eval_grad_f(Index n, const Number* x, bool new_x, Number* grad_f)
00184 {
00185   //printf("E ");
00186
00187   assert(n == data->num_variables());
00188
00189   for (Index i = 0; i<n; ++i)
00190   {
00191     grad_f[i] = weights[i];
00192   }
00193
00194   return true;
00195 }
00196
00197 // return the value of the constraints: g(x)
00198 bool IARoundingNlp::eval_g(Index n, const Number* x, bool new_x, Index m, Number* g)
00199 {
00200   return baseNlp.eval_g(n, x, new_x, m, g);
00201 }
00202
00203 // return the structure or values of the jacobian
00204 bool IARoundingNlp::eval_jac_g(Index n, const Number* x, bool new_x,
00205                            Index m, Index nele_jac, Index* iRow, Index *jCol,
00206                            Number* values)
00207 {
00208   return baseNlp.eval_jac_g(n, x, new_x, m, nele_jac, iRow, jCol, values);
00209 }
00210
00211 //return the structure or values of the hessian
00212 bool IARoundingNlp::eval_h(Index n, const Number* x, bool new_x,
00213                        Number obj_factor, Index m, const Number* lambda,
00214                        bool new_lambda, Index nele_hess, Index* iRow,
00215                        Index* jCol, Number* values)
00216 {
00217         // because the constraints are linear
00218   // and the objective function is linear
00219   // the hessian for this problem is actually empty
00220
00221   assert(nele_hess == 0);
00222
00223   // This is a symmetric matrix, fill the lower left triangle only.
00224   if (values == NULL) {
00225     // return the structure.
00226     ;
00227   }
00228   else {
00229     // return the values.
00230     ;
00231   }
00232
00233   return true;
00234 }
00235
00236 void IARoundingNlp::finalize_solution(SolverReturn status,
00237                                       Index n, const Number* x, const Number* z_L, const Number* z_U,
00238                                       Index m, const Number* g, const Number* lambda,
00239                                       Number obj_value,
00240                                       const IpoptData* ip_data,
00241                                       IpoptCalculatedQuantities* ip_cq)
00242 {
00243   baseNlp.finalize_solution(status, n, x, z_L, z_U, m, g, lambda, obj_value, ip_data, ip_cq);
00244 }
00245
00246 } // namespace MeshKit
